1000 Eaton Boulevard
Cleveland, OH 44122
United States
PowerVerter APS Inverter/Charger - Reliable
Power Source for Uninterruptible Emergency
Backup Applications
Highlights
24V DC input; 120V AC output
Hardwired
1500 watts continuous output
MODEL NUMBER: APS1524
3000 watts peak output for an
extended period
Description
Advanced battery charger
Fast load switching with less
transfer time
Tripp Lite's APS1524 3-function DC-to-AC inverter with auto line-to-battery transfer and integrated
charging system serves as an extended run UPS, a standalone power source or an automotive inverter.
PowerVerter APS Inverters accommodate "peak surge" demands by delivering more output power than
their continuous rating. PowerVerter APS Inverters supply up to double their output to easily handle
equipment start up and motor cycling requirements. A DoubleBoost feature provides up to 200% of the
continuous output for up to 10 seconds, providing the extra power needed to cold start heavy-duty tools
and equipment. An OverPower feature delivers up to 150% of the continuous output for up to 1 hour.
When hardwire input AC cable is energized, commercial power passes through to connected equipment
and the battery set is recharged via 3 stage, 10/30 amp selectable charging system. In UPS mode, the
APS system responds to blackouts and brownouts with an uninterrupted transfer to battery-derived AC
output. Includes a set of high current DC input terminals for simple installation (user supplies batteries and
cabling). Reliable large transformer design with efficient PWM sine wave output and frequency control
powers resistive electronic loads or large inductive motors, compressors and other items with high current
needs on startup. Supports an unlimited amount of runtime with any number of user-supplied batteries
connected. Highly adaptable to a variety of applications and site conditions with adjustable charger
settings for wet/gel battery types and selectable line to battery power transfer voltages.
Features
Functions as an extended run UPS system, standalone power source and automotive inverter
Includes hardwire AC input and auto-transfer to enable battery charging and automatic UPS support for
1500 watts continuous output power; 2250 watts power for up to an hour; 3000 watts peak power for up
to 10 seconds
Battery runtime is dependent upon the size and number of user-supplied batteries in 24V configuration
Hardwire input and output connections supported, DC input terminals for 24V battery connection
Converts 24V DC to 120V AC
Frequency control for operating stability
Advanced 10/30 amp selectable, 3-stage battery charger and selector switch for gel or wet cell batteries
Resettable circuit breaker protects APS against system overload
Switch allows user to select between off, auto-invert and charge-only settings
6 diagnostic LEDs indicate AC present, on battery, overload, & battery voltage level (high, medium, &
low)
Configuration switches to allow the user to select the high and low voltage for the unit to automatically
transfer from AC power to battery backup
Coated internal circuit boards offer continuous operation in humid environments (0-95%, non
condensing)
RJ45 port allows connection of APS remote switch (part# APSRM4)
Allows unlimited runtime capability by allowing the use any number of user-supplied batteries
Specifications
OVERVIEW
UPC Code
037332100375
1/3
Package Includes
APS1524 Inverter/Charger
Instruction manual with warranty
information
Cleveland, OH 44122
United States
INPUT
Maximum Input Amps / Watts
DC INPUT: Full continuous load - 70A at 24VDC. AC INPUT: 26 amps at 120VAC with full inverter and charger
load
Recommended Electrical Service
DC INPUT: Requires 24VDC input source capable of delivering 70A for the required duration (when used at full
continuous capacity). For automotive applications, professional hardwire installation with 125A minimum battery
system fusing is recommended.
Input Connection Type
DC INPUT: Set of 2 DC bolt-down terminals. AC INPUT: Hardwire via built in junction box with cover plate
Voltage Compatibility (VAC)
120
Voltage Compatibility (VDC)
24
OUTPUT
Frequency Compatibility
60 Hz
Pure Sine Wave Output
No
Nominal Output Voltage(s)
Supported
120V
Output Receptacles
(2) 5-15R
Continuous Output Capacity (Watts)
1500
Output Nominal Voltage
AC OUTPUT: 120VAC nominal, DC CHARGER OUTPUT (DC): 24VDC nominal
Output Voltage Regulation
LINE POWER (AC): Maintains 120V nominal sine wave output. INVERTER POWER (AC): Maintains PWM sine
wave output voltage of 120 VAC (+/-5%). DC CHARGER OUTPUT (See battery recharge rate section)
Output Frequency Regulation
60 Hz (+/- 0.3 Hz)
Overload Protection
Includes 15A input breaker dedicated to the charging system and 15A output breaker for AC output loads
BATTERY
Expandable Runtime
Yes
Expandable Runtime Description
Runtime is expandable with any number of user supplied wet or gel type batteries
DC System Voltage (VDC)
30
Battery Pack Accessory (Optional)
98-121 sealed lead acid battery (optional)
Battery Charge
Includes selectable 9 / 36 amp DC charging system with selectable profiles for vented wet cell and sealed gel cell
batteries. Optional use battery equalize charge function equalizes the charge level when used with multiple batteries
(see manual for detailed charger information).
USER INTERFACE, ALERTS & CONTROLS
Front Panel LEDs
Set of 6 LEDs offer continuous status information on load percentage (6 levels reported) and battery charge level (7
levels reported). See manual for sequences.
Switches
3 position on/off/remote switch enables simple on/off power control plus "auto/remote" setting that enables distant
on/off control of the inverter system when used in conjunction with optional
很抱歉,暂时无法提供与“APS1524”相匹配的价格&库存,您可以联系我们找货
