1000 Eaton Boulevard
Cleveland, OH 44122
United States
500VA 300W 120V Line-Interactive UPS - 6 NEMA
5-15R Outlets, USB, DB9, Network Card Option,
1U Rack/Tower
Highlights
Protects equipment against
blackouts, brownouts, transient
surges and line noise
Keeps AC power running during
blackouts to allow time for file
saves and safe shutdown
Maintains continuous 120V
nominal output during
brownouts as low as 90V
6 NEMA 5-15R outlets power
and protect networking, telecom
and other sensitive equipment
Optional WEBCARDLX network
interface allows you 24/7 remote
access from anywhere
MODEL NUMBER: SMART500RT1U
Applications
1U rack-mount UPS offers complete power protection for small network applications, including telecom,
security and digital signage.
Deliver battery-derived AC
output to connected equipment
in a network closet or small
business network
Protect point-of-sale and VoIP
networks against power surges
and spikes
Operate essential equipment
during short-term power outages
using battery backup power
Shut down desktop PCs and
other equipment without data
loss during long-term power
outages
Features
500VA/300W/120V Battery Backup for PC Networks, Security Systems or Digital Signage
The SmartPro® line-interactive SMART500RT1U UPS system with AVR protection provides reliable
battery backup and AC power protection against blackouts, brownouts, surges and line noise that can
damage valuable electronics or destroy data. The 120V battery backup is ideal protection for point-of-sale
and kiosk applications, a small business VoIP network, or rack-mount equipment in your server room or
network closet.
Allows Time to Back Up Critical Files During a Blackout
Backup support allows you to work through short power failures and gives you enough time to safely save
files and shut down your system in case of a prolonged blackout. Backup time varies according to load,
but the line-interactive UPS system should keep a half load (150W) powered as long as 14 minutes and a
full load (300W) up to three minutes.
6 NEMA Outlets Protect Your Connected Components
Six 5-15R outlets provide battery backup, 567 joules of network-grade surge protection and voltage
regulation for your crucial components. Five outlets are UPS-supported, and one is surge-only to connect
peripherals not requiring battery backup. One UPS-supported outlet is switchable, allowing you to power
its connected device on and off remotely to reset or reboot it or to shed a less significant load to extend
battery runtime for more critical equipment.
Automatic Voltage Regulation (AVR) Corrects Low-Voltage Conditions
AVR protects your equipment from incremental hardware damage, data loss and performance problems
caused by brownouts. The SMART500RT1U maintains regulated 120V nominal output during brownouts
as low as 90V, while keeping the battery fully charged and ready to take over in case of power failure. The
fast-to-recharge internal batteries are field-replaceable and hot-swappable.
Optional WEBCARDLX Network Interface Offers 24/7 Access
An accessory slot accommodates the optional Java-free HTML5-based WEBCARDLX interface (sold
separately), which enables full remote access for site power and UPS status monitoring, configuration,
control and email notifications via secure web browser, SNMP, telnet or SSH. It supports 10/100 Mbps
auto-sensing for optimal communication with an Ethernet network. Automated alerts help prevent
1/6
Package Includes
SMART500RT1U 500VA 300W
USB cable
DB9 cable
EPO cable
Rack-mounting hardware
Owner’s manual
Cleveland, OH 44122
United States
accidental overloads, power loss and downtime.
Premium Protection from EMI/RFI Line Noise Helps Your Equipment Perform Better
This UPS system filters out disruptive electromagnetic and radio frequency interference that can inflict
hardware damage or data loss. This EMI/RFI filtering also helps your connected components perform
better and last longer.
Designed for High Efficiency to Help You Save Money and Protect the Environment
A 97% efficiency rating reduces BTU emissions, energy consumption and, ultimately, your energy costs.
LED Indicators and Audible Alarms Keep You Informed
Five front-panel LEDs keep you apprised of line power, battery power, overload, voltage regulation and
battery low/replace status at a glance. A multi-function alarm sounds to warn you of power failure,
overload and low-battery conditions.
Advanced Communications Ports Allow for Automatic Saves and Shutdowns
RS-232 and HID-compliant USB ports connect to a computer running Tripp Lite’s free downloadable
PowerAlert® software to enable safe unattended shutdown in case of a prolonged power failure. The EPO
port supports emergency shutdown in large facilities. Cables are included.
Versatile Installation Options
Hardware is included for mounting the UPS in 1U of space in an EIA-standard 19-inch 2-port or 4-post
rack or in an upright tower position. The 10-foot power cord with NEMA 5-15P plug connects to any
compatible AC outlet.
Specifications
OVERVIEW
UPC Code
037332119247
UPS Type
Line-Interactive
INPUT
Input Phase
Single-Phase
Rated input current (Maximum Load)
10A
Nominal Input Voltage(s) Supported
120V AC
UPS Input Connection Type
5-15P
Input Circuit Breakers
10A
UPS Input Cord Length (ft.)
10
UPS Input Cord Length (m)
3.1
Recommended Electrical Service
15A 120V
OUTPUT
Output Capacity (VA)
500
Output Capacity (kVA)
0.5
Output Capacity (Watts)
300
2/6
Cleveland, OH 44122
United States
Output Capacity (kW)
0.3
Output Capacity Details
4.2A @ 120V. (LINE MODE) 120% @ 5 minutes; (BATTERY MODE) 120% @ 5 seconds
Power Factor
0.6
Nominal Voltage Details
120V sinusoidal in line mode and 120V PWM in battery mode
Frequency Compatibility
60 Hz
Frequency Compatibility Details
Output is regulated to +/-0.05Hz when input frequency exceeds +/-5Hz of nominal.
Output Voltage Regulation (Line
Mode)
-14%, +16%
Output Voltage Regulation (Battery
Mode)
+/- 5%
UPS Output Receptacles (Surge
Suppression Only)
5 UPS outlets, 1 surge-only outlet
Load Management Receptacles
One switchable single-outlet 5-15R load bank
Output AC Waveform (AC Mode)
Sine wave
Output AC Waveform (Battery
Mode)
PWM sine wave
Nominal Output Voltage(s)
Supported
120V
Output Receptacles
(6) 5-15R
Individually Controllable Load Banks
Yes
BATTERY
Battery Type
Valve Regulated Lead Acid (VRLA)
Runtime Full Load (min.)
3 min. (300W)
Runtime Half Load (min.)
14 min. (150W)
Expandable Runtime
No
DC System Voltage (VDC)
12
Battery Recharge Rate (Included
Batteries)
Less than 12 hours to 90%
Battery Access
Battery access door
Internal UPS Replacement Battery
Cartridge
IMPORTANT BATTERY REPLACEMENT INFORMATION > Use Tripp Lite RBC12V-1U replacement battery for
SMART500RT1U models with Series Number AG-03AA listed on the UPS nameplate (sold starting in 2021); For all
prior versions of SMART500RT1U, use Tripp Lite RBC62-1U
replacement battery; Contact Tripp Lite customer service for additional information
Battery Replacement Description
Hot-swappable, user replaceable batteries
VOLTAGE REGULATION
Voltage Regulation Description
Automatic voltage regulation (AVR) maintains line power operation with input voltage as low as 90 (±5%). Input
voltage range of 90 to 139
Undervoltage Correction
Input voltages between 90 and 105 (±5%) are boosted by 14%
3/6
Cleveland, OH 44122
United States
USER INTERFACE, ALERTS & CONTROLS
Switches
2 Switches control off/on power status and alarm-cancel/self-test operation
Alarm Cancel Operation
Power-fail alarm can be silenced using alarm-cancel switch
Audible Alarm
Audible alarm indicates power-failure, overload and low-battery conditions
LED Indicators
5 LEDs indicate line power, battery power, overload, voltage regulation and battery low/replace status
SURGE / NOISE SUPPRESSION
EMI / RFI AC Noise Suppression
Yes
AC Suppression Joule Rating
567
AC Suppression Response Time
Instantaneous
PHYSICAL
Primary Form Factor
Rackmount; Tower
Rack Height
1U
Included Mounting Accessory
Description
Included mounting brackets provide front-rail installation in 2 or 4 post racks, plus upright tower configurations
Installation Form Factors Supported
with Included Accessories
2 post 19 inch rackmount; 2 post front mount; 4 post 19 inch rackmount; Tower
Minimum Required Rack Depth (cm)
38.10
(inches)
15
Primary UPS Depth (mm)
286
Primary UPS Height (mm)
44
Primary UPS Width (mm)
440
Shipping Dimensions (hwd / in.)
4.20 x 15.70 x 21.30
Shipping Dimensions (hwd / cm)
10.67 x 39.88 x 54.10
Shipping Weight (lbs.)
19.12
Shipping Weight (kg)
8.67
UPS Housing Material
Steel
UPS Power Module Dimensions
(hwd, cm)
4.39 x 43.99 x 28.60
(hwd, in.)
1.73 x 17.32 x 11.26
UPS Power Module Weight (kg)
7.18
UPS Power Module Weight (lbs.)
15.84
Unit Weight (lbs.)
15.800
Unit Weight (kg)
7.17
4/6
Cleveland, OH 44122
United States
ENVIRONMENTAL
Operating Temperature Range
32° to 104°F (0° to 40°C)
Storage Temperature Range
5° to 122°F (-15° to 50°C)
Relative Humidity
0 to 95%, non-condensing
AC Mode BTU / Hr. (Full Load)
48
AC Mode Efficiency Rating (100%
Load)
97%
AC Economy Mode Efficiency Rating
(100% Load)
0.97
Operating Elevation (ft.)
6561 ft. (2000 m) above sea level
Audible Noise
45 dBA maximum, front side 1m
COMMUNICATIONS
Network Management Cards
WEBCARDLX
Network Monitoring Port Description
Supports detailed monitoring of UPS and site power conditions
PowerAlert Software
For local monitoring via the UPS’s built-in communication ports, download PowerAlert software at
https://tripplite.eaton.com/products/power-alert
Communications Cable
USB and DB9 cabling included
WatchDog Compatibility
Supports Watchdog application, OS and hard-reboot restart options for remote applications
Description
Network management card optional
Communications Interface
DB9 Serial; EPO (emergency power off); Slot for SNMP/Web interface; USB (HID enabled)
LINE / BATTERY TRANSFER
Transfer Time
4-6 ms typical ( < 10 ms max)
Low Voltage Transfer to Battery
Power (Setpoint)
90
High Voltage Transfer to Battery
Power (Setpoint)
139
FEATURES & SPECIFICATIONS
Cold Start (Startup in Battery Mode
During a Power Failure)
Cold-start operation supported
High Availability UPS Features
Auto Probe Monitoring and Reboot (requires WEBCARDLX); Automatic Voltage Regulation (AVR); Hot swappable
batteries; Remote management; Surge/noise protection
Grounding Lug
Back panel grounding lug
STANDARDS & COMPLIANCE
Product Certifications
CSA (Canada); NOM (Mexico); UL 1778
Product Compliance
RoHS; ENERGY STAR Qualified
5/6
Cleveland, OH 44122
United States
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
2-year warranty, 3 year with registration. Note: Registration is required for 3-year
warranty.
Connected Equipment Insurance
(U.S., Canada & Puerto Rico)
$250,000 Ultimate Lifetime
Insurance
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
6/6
