SMART1500LCDT
SMART1500LCDT
    TRIPPLITE
    UPS SMART LCD TOWER BATT BACK UP
SMART1500LCDT 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States SmartPro LCD 120V 50/60Hz 1500VA 900W LineInteractive UPS, AVR, Tower, LCD, USB, 10 Outlets Highlights ● Supports a basic desktop PC up to 90 min. during power outage ● Features 10 protected outlets—5 battery-protected, 5 surge-only ● Offers automatic voltage regulation (AVR) ● LCD screen reports real-time UPS and power status ● Plugs into any NEMA 5-15R socket MODEL NUMBER: SMART1500LCDT Package Includes Provides reliable 1500VA/900W power protection for your desktop computer, network workstation, audio/video components or media center. Protects against surges, line noise, blackouts and brownouts. Description The SMART1500LCDT SmartPro LCD 120V, 1500VA/900W Line-Interactive Uninterruptible Power Supply provides battery backup and AC power protection against blackouts, brownouts, power surges and line noise that can damage electronics or destroy data. Ideal for backing up your desktop computer or audio/visual components, this line-interactive UPS switches to battery backup mode in milliseconds to keep your connected equipment running long enough to save files and shut down safely with no data loss. While all ten NEMA 5-15R outlets protect against surges, five outlets also provide up to 90 minutes of UPS battery support for a basic desktop PC and LCD monitor and up to 10 minutes of support at half load (450W). Automatic voltage regulation (AVR) corrects undervoltages as low as 92V and overvoltages as high as 150V without using any battery power. EMI/RFI noise filtering improves your equipment's performance and prevents damage. A 650-joule surge suppression rating protects your equipment from harmful power surges. NEMA 5-15P plug with 6-ft. (1.83 m) cord connects to any NEMA 5-15R socket. Large LCD screen shows real-time input voltage, overload, AVR, remaining battery runtime and battery statuses at a glance. Alarm sounds to indicate power loss or low battery. With Tripp Lite's PowerAlert software (available via free download), SMART1500LCDT enables safe unattended system shutdown and file saves in case of a prolonged power failure. Features Reliable Battery BackupProvides 1500VA/900W high-performance power protection for desktop computers, audio/video components, media centers and other electronicsSupports basic desktop computer and LCD monitor up to 90 minutes during power outageSupports 50% load (450W) up to 10 minutesAudible alarm indicates loss of utility power or low battery Optimized Outlets5 NEMA 5-15R outlets deliver battery backup for devices that require constant powerAll 10 outlets protect against surges or spikes that can harm equipment or dataNEMA 5-15P plug with 6-ft. (1.83 m) cord connects to any NEMA 5-15R socket Automatic Voltage Regulation (AVR)Corrects undervoltages as low as 92V and overvoltages as high as 150V without drawing battery backup power 1/5 ● SMART1500LCDT SmartPro LCD 120V 1500VA/900W LineInteractive UPS ● USB cable ● Owner’s Manual 1000 Eaton Boulevard Cleveland, OH 44122 United States LCD Status ScreenLarge LCD screen shows real-time input voltage, overload, AVR and battery statusesAutomatically displays remaining battery runtime in minutes during power outage AC Line, Tel/DSL and Ethernet Surge SuppressionSurge suppression rating of 650 joules protects connected equipment and data from harmful power surgesTel/DSL RJ11 jacks protect standard dialup/DSL/Ethernet phone connectionCoaxial jacks protect CATV, broadband cable internet, satellite or broadcast antenna connection EMI/RFI Line Noise FilteringRemoves electromagnetic and radio frequency interference that can disrupt or damage your equipment's performance USB Communication Port and Free PowerAlert SoftwareHID-compliant USB port integrates with builtin power management and auto-shutdown of Windows and Mac OS XUSB port enables data-saving unattended shutdown when used with Tripp Lite's PowerAlert software, available via FREE download from tripplite.eaton.com/products/power-alert Specifications OVERVIEW UPC Code 037332174109 UPS Type Line-Interactive INPUT Input Phase Single-Phase Rated input current (Maximum Load) 12A Nominal Input Voltage(s) Supported 120V AC UPS Input Connection Type 5-15P Input Circuit Breakers 20A UPS Input Cord Length (ft.) 6 UPS Input Cord Length (m) 1.8 Recommended Electrical Service 15A 120V OUTPUT Output Capacity (VA) 1500 Output Capacity (kVA) 1.5 Output Capacity (Watts) 900 Output Capacity (kW) 0.9 Nominal Voltage Details 120v nominal output in battery mode Frequency Compatibility 50 / 60 Hz Frequency Compatibility Details Automatic frequency selection Output Voltage Regulation (Line Mode) 120V (+9% / -12%) 2/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Output Voltage Regulation (Battery Mode) 120V (±10%) UPS Output Receptacles (Surge Suppression Only) 5 UPS outlets, 5 surge-only outlets Output AC Waveform (AC Mode) Sine wave Output AC Waveform (Battery Mode) PWM sine wave Nominal Output Voltage(s) Supported 110V; 115V; 120V Output Receptacles (10) 5-15R Individually Controllable Load Banks No BATTERY Battery Type Valve Regulated Lead Acid (VRLA) Runtime Full Load (min.) 2.3 min. (900W) Runtime Half Load (min.) 10 min. (450W) Expandable Runtime No DC System Voltage (VDC) 24 Battery Recharge Rate (Included Batteries) Less than 8 hours from 10% to 90% Internal UPS Replacement Battery Cartridge  RBC51  (requires 2) VOLTAGE REGULATION Voltage Regulation Description Automatic voltage regulation (AVR) maintains line power operation with an input voltage range of 92 to 150 Overvoltage Correction Input voltages between 129 and 147 are reduced by 15% Undervoltage Correction Input voltages between 92 and 108 are boosted by 18% USER INTERFACE, ALERTS & CONTROLS Front Panel LCD Display LCD screen with scroll buttons indicates Input voltage, Output voltage, Frequency (Hz), AVR boost / cut status, Output load in watts, Output load percentage, Battery voltage and Estimated runtime in minutes Switches Power switch offers whole UPS power control; Scroll/mute button enables LCD selection options and silences audible alarm; Test button initiates self test Alarm Cancel Operation Power-fail alarm can be silenced using alarm-cancel switch Audible Alarm Audible alarm indicates power-failure and low-battery conditions SURGE / NOISE SUPPRESSION UPS AC Suppression Joule Rating 650 UPS AC Suppression Response Time Instantaneous UPS Dataline Suppression 1 line TEL/DSL (1 in / 1 out); 10/100Base T Ethernet; Coax jacks (1 set) EMI / RFI AC Noise Suppression Yes 3/5 1000 Eaton Boulevard Cleveland, OH 44122 United States PHYSICAL Primary Form Factor Tower Cooling Method Fan Installation Form Factors Supported with Included Accessories Tower Primary UPS Depth (mm) 391 Primary UPS Height (mm) 203 Primary UPS Width (mm) 146 Shipping Dimensions (hwd / in.) 11.10 x 9.00 x 19.30 Shipping Weight (lbs.) 28.00 Shipping Weight (kg) 12.70 UPS Power Module Dimensions (hwd, cm) 20.32 x 14.60 x 39.12 UPS Power Module Dimensions (hwd, in.) 8 x 5.75 x 15.4 UPS Power Module Weight (kg) 12.25 UPS Power Module Weight (lbs.) 27 Unit Weight (lbs.) 25.3300 Unit Weight (kg) 11.49 ENVIRONMENTAL Operating Temperature Range 32° to 104°F (0° to 40°C) Storage Temperature Range 5° to 122°F (-15° to 50°C) Relative Humidity 0 to 95%, non-condensing AC Mode BTU / Hr. (Full Load) 119 Battery Mode BTU / Hr. (Full Load) 867 AC Mode Efficiency Rating (100% Load) 95% Audible Noise Less than 36 dB, front side 1m COMMUNICATIONS Network Monitoring Port Description Supports detailed monitoring of UPS and site power conditions PowerAlert Software For local monitoring via the UPS’s built-in USB port, download PowerAlert software at https://tripplite.eaton.com/products/power-alert Communications Cable USB and cabling included WatchDog Compatibility Supports Watchdog application, OS and hard-reboot restart options for remote applications Network Management Card Description Network management not supported 4/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Communications Interface USB (HID enabled) LINE / BATTERY TRANSFER Transfer Time 2 milliseconds (AC to battery mode), 6 milliseconds (battery to AC mode) Low Voltage Transfer to Battery Power (Setpoint) 92 High Voltage Transfer to Battery Power (Setpoint) 150 FEATURES & SPECIFICATIONS Cold Start (Startup in Battery Mode During a Power Failure) Cold-start operation supported High Availability UPS Features Automatic Voltage Regulation (AVR); Hot swappable batteries; Surge/noise protection Green Energy-Saving Features Greater than 95% efficiency - GREEN UPS STANDARDS & COMPLIANCE Product Certifications CSA (Canada); NOM (Mexico); UL 1778 Product Compliance RoHS; FCC Part 15 Class A (USA) WARRANTY & SUPPORT Product Warranty Period (U.S. & Canada) 3-year limited warranty Product Warranty Period (International) 2-year limited warranty Product Warranty Period (Mexico) 3-year limited warranty Product Warranty Period (Puerto Rico) 3-year limited warranty Connected Equipment Insurance (U.S., Canada & Puerto Rico) $250,000 Ultimate Lifetime Insurance  © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 5/5
SMART1500LCDT 价格&库存
很抱歉,暂时无法提供与“SMART1500LCDT”相匹配的价格&库存,您可以联系我们找货
SMART1500LCDT
    • 1+2598.80832
    库存:21
    SMART1500LCDT
    • 1+2527.241141+305.80224
    库存:21
