1000 Eaton Boulevard
Cleveland, OH 44122
United States
700VA 350W Line-Interactive UPS - 8 NEMA 515R Outlets, AVR, 120V, 50/60 Hz, USB,
Desktop/Wall Mount
MODEL NUMBER: AVR700U
Highlights
Protects equipment against
blackouts, brownouts,
overvoltages, surges and line
noise
Keeps AC power running during
blackouts to allow time for file
saves and safe shutdown
8 NEMA 5-15R outlets power
and protect PC, home theater or
digital signage equipment
Home-friendly alarm remains
silent in backup mode, sounding
only when imperative
High >95% efficiency with low
BTU ratings saves electricity
and lowers your energy costs
Applications
Protect your PC and other
sensitive electronics against
power surges, line noise,
brownouts, overvoltages and
blackouts
Desktop UPS provides battery backup support with automatic voltage regulation (AVR) for your
home/office network system or home theater.
Operate essential equipment
during short-term power outages
using battery backup power
Features
Shut down desktop PCs and
other equipment without data
loss during long-term power
outages
Extend runtime for DVRs,
wireless routers and other lowpower home network equipment
700VA/350W/120V Battery Backup for PCs, Home Theater or Digital Signage
The line-interactive AVR700U UPS system with AVR protection provides reliable battery backup and AC
power protection against blackouts, brownouts, overvoltages, surges and line noise that can damage
valuable electronics or destroy data. The eight-outlet 120V battery backup is ideal protection for your
home office, media center or commerce components, including computers, routers, printers, HDTVs, Bluray players, game consoles, ATMs, security systems and digital signage equipment.
Allows Time to Back Up Critical Files During a Blackout
Backup support allows you to work through short power failures and gives you enough time to safely save
files and shut down your system in case of a prolonged blackout. Backup time varies according to load,
but the line-interactive UPS system should keep an energy-efficient desktop computer with small LCD
monitor powered as long as 43 minutes. During normal operation, incoming utility power keeps the
replaceable internal battery fully charged, so backup power will always be available.
8 NEMA 5-15R Outlets Protect Your Connected Components
Four 5-15R outlets provide battery backup, surge protection and voltage regulation for your computer,
monitor and other crucial components. The other four 5-15R outlets provide surge suppression only for
printers, speakers and other desktop equipment regarded as non-essential during a blackout. A high
>95% line mode efficiency rating reduces BTU emissions, energy consumption and, ultimately, your
energy costs.
Automatic Voltage Regulation (AVR) Corrects Low- and High-Voltage Conditions
AVR protects your equipment from incremental hardware damage, data loss and performance problems
caused by brownouts and overvoltages. The AVR700U can correct brownouts as low as 89V and
overvoltages as high as 145V back to nominal 120V power continuously, all while keeping the battery fully
charged and ready to take over in case of power failure.
316 Joules Fight Back Against Unexpected Power Surges
A 316-joule surge suppression rating protects connected components from the harmful effects of power
surges.
1/6
Package Includes
AVR700U 700VA 350W 120V
Line-Interactive UPS with 8
Outlets
USB cable
Owner’s manual
Cleveland, OH 44122
United States
Combats Electromagnetic Interference That Can Harm Equipment
Various electromagnetic and radio sources found in virtually every home and business can cause
disruptive interference on the AC line. Known as EMI (electromagnetic interference) and RFI (radio
frequency interference), this line noise is a common cause of performance problems and can lead to
incremental hardware damage, data corruption and audio/video transmission problems. The AVR700U
incorporates technology that filters out disruptive line noise so that it won’t affect your equipment.
Home-Friendly Alarm and Diagnostic LEDs Keep You Informed 24/7
The UPS remains silent in both line and battery backup modes. The alarm sounds only to report low
battery, battery replace, overload and fault condition. Dual front-panel LEDs report line and battery mode
operation.
HID-Compliant USB Port Allows for Automatic Saves and Shutdowns
This USB port connects the AVR700U to a computer running Tripp Lite’s free downloadable PowerAlert®
software to enable safe unattended file saves and system shutdown in case of a prolonged power failure.
USB cable is included.
Compact Housing Compatible with Easy Desktop or Wall-Mount Installation
The space-saving ABS housing fits on a desktop, shelf or anywhere else convenient to your workstation
or home theater. Keyhole mounting tabs on the rear allow easy wall-mount installation. The five-foot
power cord with NEMA 5-15P plug connects to any compatible AC outlet.
Specifications
OVERVIEW
UPC Code
037332211477
UPS Type
Line-Interactive
INPUT
Input Phase
Single-Phase
Rated input current (Maximum Load)
10A
Nominal Input Voltage(s) Supported
120V AC
UPS Input Connection Type
5-15P
Input Circuit Breakers
10A
UPS Input Cord Length (ft.)
5
UPS Input Cord Length (m)
1.5
Recommended Electrical Service
15A 120V
OUTPUT
Output Capacity (VA)
700
Output Capacity (kVA)
0.7
Output Capacity (Watts)
350
Output Capacity (kW)
0.35
Nominal Voltage Details
120v nominal output in battery mode
2/6
Cleveland, OH 44122
United States
Frequency Compatibility
50 / 60 Hz
Output Voltage Regulation (Line
Mode)
120V (+6%/-12%)
Output Voltage Regulation (Battery
Mode)
120V (±10%)
UPS Output Receptacles (Surge
Suppression Only)
4 UPS outlets, 4 surge-only outlets
Output AC Waveform (AC Mode)
Pure sine wave
Output AC Waveform (Battery
Mode)
PWM sine wave
Nominal Output Voltage(s)
Supported
110V; 115V; 120V
Output Receptacles
(8) 5-15R
Individually Controllable Load Banks
No
BATTERY
Battery Type
Valve Regulated Lead Acid (VRLA)
Runtime Full Load (min.)
2 min. (350W)
Runtime Half Load (min.)
10 min. (175W)
Expandable Runtime
No
DC System Voltage (VDC)
12
Battery Recharge Rate (Included
Batteries)
8 hours (10% to 90%)
Battery Access
Battery access door
Internal UPS Replacement Battery
Cartridge
IMPORTANT BATTERY REPLACEMENT INFORMATION > If the original battery inside your AVR700U UPS has a
rating of 12V 7AH, please order Tripp Lite RBC51 (quantity 1) replacement battery; If the original battery inside your AVR700U UPS
has a rating of 12V 5AH, please contact Tripp Lite for assistance
Battery Replacement Description
Replaceable internal batteries (see manual)
VOLTAGE REGULATION
Voltage Regulation Description
Automatic voltage regulation (AVR) maintains line power operation with an input voltage range of 89 to 145
Overvoltage Correction
Input voltages between 128 and 145 are reduced by 15%
Undervoltage Correction
Input voltages between 89 and 108 are boosted by 18%
USER INTERFACE, ALERTS & CONTROLS
Switches
Power off/on switch
Audible Alarm
UPS remains silent in battery backup mode; Alarm sounds only to report low-battery, fault, overload and replacebattery conditions
LED Indicators
2 Status LEDs; GREEN indicates power status and operating mode / RED indicates battery-low, overload, replacebattery and fault conditions
3/6
Cleveland, OH 44122
United States
SURGE / NOISE SUPPRESSION
UPS AC Suppression Joule Rating
316
UPS AC Suppression Response
Time
Instantaneous
UPS Dataline Suppression
1 line TEL/DSL or Ethernet
EMI / RFI AC Noise Suppression
Yes
PHYSICAL
Primary Form Factor
Desktop
Installation Form Factors Supported
with Included Accessories
Tower; Ultra-compact desktop; Wallmount
Primary UPS Depth (mm)
305
Primary UPS Height (mm)
110
Primary UPS Width (mm)
163
Shipping Dimensions (hwd / in.)
9.40 x 6.20 x 15.00
Shipping Dimensions (hwd / cm)
23.88 x 15.75 x 38.10
Shipping Weight (lbs.)
14.80
Shipping Weight (kg)
6.71
UPS Housing Material
ABS
UPS Power Module Dimensions
(hwd, cm)
11.00 x 16.26 x 30.48
(hwd, in.)
4.33 x 6.4 x 12
UPS Power Module Weight (kg)
6.21
UPS Power Module Weight (lbs.)
13.7
Unit Weight (lbs.)
13.700
Unit Weight (kg)
6.21
ENVIRONMENTAL
Operating Temperature Range
32° to 104°F (0° to 40°C)
Storage Temperature Range
5° to 113°F (-15° to 45°C )
Relative Humidity
0 to 90%, non-condensing
AC Mode BTU / Hr. (Full Load)
61
AC Mode Efficiency Rating (100%
Load)
>95%
Operating Elevation (ft.)
Up to 10,000 ft.
Operating Elevation (m)
Up to 3000m
4/6
Cleveland, OH 44122
United States
COMMUNICATIONS
PowerAlert Software
For local monitoring via the UPS’s built-in communication ports, download PowerAlert software at
https://tripplite.eaton.com/products/power-alert
Communications Cable
USB interface cable included
WatchDog Compatibility
Supports Watchdog application, OS and hard-reboot restart options for remote applications
Network UPS Tools (NUT)
Compatibility
NUT compatible. See a full list of NUT compatible Tripp Lite UPS systems at https://networkupstools.org/stablehcl.html?manufacturer=Tripp%20Lite
Network Management Card
Description
Network management not supported
Communications Interface
USB (HID enabled)
LINE / BATTERY TRANSFER
Transfer Time
6 milliseconds typical (10 milliseconds max)
Low Voltage Transfer to Battery
Power (Setpoint)
89
High Voltage Transfer to Battery
Power (Setpoint)
145
FEATURES & SPECIFICATIONS
Cold Start (Startup in Battery Mode
During a Power Failure)
Cold-start operation supported
High Availability UPS Features
Automatic Voltage Regulation (AVR); Surge/noise protection
Green Energy-Saving Features
Greater than 95% efficiency - GREEN UPS
Grounding Details
Includes side-panel grounding lug
STANDARDS & COMPLIANCE
Product Certifications
RETIE (Colombia); CSA (Canada); NOM (Mexico); UL 1778
Product Compliance
RoHS; FCC Part 15 Class A (USA)
WARRANTY & SUPPORT
Product Warranty Period (U.S. &
Canada)
3-year limited warranty
Product Warranty Period (Latin
America)
(International)
2-year limited warranty
Product Warranty Period (Mexico)
Connected Equipment Insurance
(U.S., Canada & Puerto Rico)
$100,000 Ultimate Lifetime
Insurance
5/6
Cleveland, OH 44122
United States
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
6/6
