1000 Eaton Boulevard
Cleveland, OH 44122
United States
BC Pro 120V 1050VA 705W Standby UPS, Tower,
USB port, 6 Outlets
MODEL NUMBER: BCPRO1050
Highlights
1050VA / 1.05kVA tower 120V
standby UPS
Maintains AC output during
power failures
USB port, Front panel status
LEDs, 97% efficient
NEMA 5-15P input plug and 6
NEMA 5-15R outlets
Package Includes
Description
Tripp Lite's BCPRO1050 standby UPS offers AC surge suppression and long lasting battery support for
desktop PCs, network workstations and a wide variety of consumer and professional electronics.
Uninterruptible Power Supply / UPS circuits switch to battery backup mode within milliseconds to keep
connected equipment running without interruption or data loss during power failures, brownouts and
overvoltages. AC surge suppression prevents connected equipment damage. USB communications port
supports full featured monitoring and data-saving auto-shutdown options using Tripp Lite's free PowerAlert
monitoring software.
Features
BCPRO1050 tower 120V standby UPS offers AC power protection from blackouts, brownouts,
overvoltages and transient surges
1050VA / 705 watt UPS output capacity
Uninterruptible Power Supply / UPS operation maintains battery-derived AC output during blackouts,
brownouts and overvoltages to prevent data loss and system downtime for connected equipment
Built-in USB port enables data-saving unattended shutdown when used with Tripp Lite's PowerAlert
software, available via FREE download from tripplite.eaton.com/products/power-alert
7 minutes runtime at 100% load (705 watts), 23 minutes runtime at 50% load (355 watts)
107 minutes runtime for a desktop computer system consuming 80 watts continuous
6 built-in NEMA 5-15R UPS supported outlets
NEMA 5-15P input connection with 6ft / 1.8m line cord
Network grade AC surge protection is available from all outlets
97% line mode efficiency rating uses less energy and BTU emissions
Front panel LEDs indicate line / battery mode, low battery, replace battery status; Audible alarm with
alarm cancel / self-test button
Hot swappable user battery replacement
Optional PDUB15 bypass PDU enables hot-swappable UPS replacement with no disruption to
connected equipment
1/5
BCPRO1050 UPS System
USB cable
Instruction manual
Cleveland, OH 44122
United States
Tower housing supports desk or floor placement
Specifications
OVERVIEW
UPC Code
037332033376
UPS Type
Standby
INPUT
Input Phase
Single-Phase
Rated input current (Maximum Load)
6.4A
Nominal Input Voltage(s) Supported
120V AC
UPS Input Connection Type
5-15P; Right-Angled
Input Circuit Breakers
15A
UPS Input Cord Length (ft.)
6
UPS Input Cord Length (m)
1.8
Recommended Electrical Service
15A 120V
OUTPUT
Output Capacity (VA)
1050
Output Capacity (kVA)
1.05
Output Capacity (Watts)
705
Nominal Voltage Details
115v nominal output in battery mode
Frequency Compatibility
60 Hz
Output Voltage Regulation (Battery
Mode)
+/- 5%
Hot-Swap PDU options
PDUB15 (2U / 8 5-15R outlets)
Output AC Waveform (AC Mode)
Sine wave
Output AC Waveform (Battery
Mode)
PWM sine wave
Nominal Output Voltage(s)
Supported
110V; 115V; 120V
Output Receptacles
(6) 5-15R
Individually Controllable Load Banks
No
BATTERY
Runtime Full Load (min.)
7 min. (705w)
Runtime Half Load (min.)
23 min. (355w)
2/5
Cleveland, OH 44122
United States
Expandable Runtime
No
DC System Voltage (VDC)
18
Battery Recharge Rate (Included
Batteries)
Less than 4 hours from 10% to 90%
Battery Access
Battery access door
Internal UPS Replacement Battery
Cartridge
RBC52 (quantity 3)
Battery Replacement Description
Hot-swappable, user replaceable batteries
USER INTERFACE, ALERTS & CONTROLS
Switches
2 Switches control off/on power status and alarm-cancel/self-test operation
Alarm Cancel Operation
Power-fail alarm can be silenced using alarm-cancel switch; once silenced, alarm will re-sound to indicate lowbattery status
Audible Alarm
Audible alarm indicates power-failure and low-battery conditions
LED Indicators
5 LEDs indicate line power, battery power, battery low/replace and overload status
SURGE / NOISE SUPPRESSION
UPS AC Suppression Joule Rating
510
UPS AC Suppression Response
Time
Instantaneous
EMI / RFI AC Noise Suppression
Yes
510
AC Suppression Response Time
Instantaneous
PHYSICAL
Primary Form Factor
Tower
Installation Form Factors Supported
with Included Accessories
Tower
with Optional Accessories
Wallmount ( UPSWM - tower mounting kit)
Primary UPS Depth (mm)
178
Primary UPS Height (mm)
286
Primary UPS Width (mm)
171
Shipping Dimensions (hwd / in.)
15.00 x 10.80 x 10.60
Shipping Dimensions (hwd / cm)
38.10 x 27.43 x 26.92
Shipping Weight (lbs.)
31.20
Shipping Weight (kg)
14.15
UPS Housing Material
Polycarbonate
UPS Power Module Dimensions
(hwd, cm)
28.58 x 17.14 x 17.78
3/5
Cleveland, OH 44122
United States
(hwd, in.)
11.25 x 6.75 x 7
UPS Power Module Weight (kg)
13.15
UPS Power Module Weight (lbs.)
29
ENVIRONMENTAL
Operating Temperature Range
+32 to +104 degrees Fahrenheit / 0 to +40 degrees Celsius
Storage Temperature Range
+5 to +122 degrees Fahrenheit / -15 to +50 degrees Celsius
Relative Humidity
0 to 95%, non-condensing
AC Mode BTU / Hr. (Full Load)
74
Battery Mode BTU / Hr. (Full Load)
564
AC Mode Efficiency Rating (100%
Load)
97%
COMMUNICATIONS
PowerAlert Software
For local monitoring via the UPS’s built-in communication ports, download PowerAlert software at
https://tripplite.eaton.com/products/power-alert
Communications Cable
USB interface cable included
WatchDog Compatibility
Supports Watchdog application, OS and hard-reboot restart options for remote applications
Communications Interface
USB
LINE / BATTERY TRANSFER
Transfer Time
2-4 milliseconds
Low Voltage Transfer to Battery
Power (Setpoint)
99
High Voltage Transfer to Battery
Power (Setpoint)
143
FEATURES & SPECIFICATIONS
Cold Start (Startup in Battery Mode
During a Power Failure)
Cold-start operation supported
High Availability UPS Features
Hot swappable batteries
Green Energy-Saving Features
Greater than 95% efficiency - GREEN UPS
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
2-year limited warranty
Connected Equipment Insurance
(U.S., Canada & Puerto Rico)
$200,000 Ultimate Lifetime
Insurance
4/5
Cleveland, OH 44122
United States
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
5/5
很抱歉,暂时无法提供与“BCPRO1050”相匹配的价格&库存,您可以联系我们找货
