1000 Eaton Boulevard
Cleveland, OH 44122
United States
OmniSmart 120V 1400VA 940W Line-Interactive
UPS, Tower, USB port
MODEL NUMBER: OMNISMART1400
Highlights
1400VA / 1.4kVA tower 120V
line interactive UPS
Corrects brownouts and
overvoltages from 75V to 147V
USB port, Front panel status
LEDs
NEMA 5-15P input plug and 6
NEMA 5-15R outlets
Package Includes
Description
Tripp Lite's OMNISMART1400 line interactive UPS system offers voltage regulation, surge suppression
and long lasting battery support for personal computers, internetworking equipment and other sensitive
electronics. Supports a single entry level PC system for up to 75 minutes during power failures to facilitate
a safe shutdown without data loss. Automatic Voltage Regulation (AVR) circuits regulate brownouts as
low as 75 volts and overvoltages to 147 volts back to normal 120V levels, all without using battery power.
Includes 6 battery supported outlets and 6-ft. (1.83 m) AC line cord. USB port enables optional safe
unattended system shutdown in the case of extended power failure as well as continuous UPS and site
power condition monitoring, USB cable included. PowerAlert software available via free download. Built-in
audible alarm and 5 front panel LEDs indicate status of line power, battery power, battery low/replace,
voltage regulation and overload. 1400VA/940 watt power handling ability supports multiple entry-level
PCs, network workstations, point-of-sale terminals, small to medium business phone systems, audio/video
workstations and heavily configured home theater systems. Offers 8 minutes battery runtime with a full
load of 1400VA and 24 minutes with a half load of 700VA. Supports hot swap battery replacement via
built-in access panel. $200,000 Ultimate Lifetime Insurance (USA and Canada Only).
Features
OMNISMART1400 line interactive UPS system offers voltage regulation and battery support, plus
complete AC and dialup/DSL modem line surge suppression
Prevents equipment damage, data loss and downtime due to power problems
Supports a single entry level PC system for up to 75 minutes during power failures to enable a safe
system shutdown
Supports a max load of 1400VA for 8 minutes
Supports a half load of 700VA for 24 minutes
Automatic Voltage Regulation (AVR) circuits correct brownouts as low as 75 and overvoltages as high
as 147 volts back to normal 120 volt levels without using battery power
Upright tower configuration uses only 66 square inches of floor or desktop space
1/5
OMNI SMART 1400 UPS
System
USB cable
Warranty information
Instruction manual
Cleveland, OH 44122
United States
Includes 6 battery supported outlets, 6-ft. (1.83 m) AC line cord (all NEMA 5-15)
USB port enables data-saving unattended shutdown when used with Tripp Lite's PowerAlert software,
available via FREE download from tripplite.eaton.com/products/power-alert
Supports Tripp Lite's WatchDog software application to restore unresponsive programs by automatically
restarting them and rebooting completely locked computers by automatically switching UPS power off
and back on again
Built-in audible alarm and 5 front panel LEDs indicate status of line power, battery power, battery
low/replace, voltage regulation and overload status
1400VA/940 watt power handling ability supports multiple entry-level PCs, network workstations, pointof-sale terminals, small to medium business phone systems, audio/video equipment stations and
Supports hot-swap battery replacement via built-in battery access panel
Compatible with 120V/60Hz applications for USA, Canada, Mexico and more
Optional PDUB15 bypass PDU enables hot-swappable UPS replacement with no disruption to
connected equipment
Specifications
OVERVIEW
UPC Code
037332033390
UPS Type
Line-Interactive
INPUT
Input Phase
Single-Phase
Rated input current (Maximum Load)
9.2A
Nominal Input Voltage(s) Supported
120V AC
UPS Input Connection Type
5-15P
UPS Input Cord Length (ft.)
6
UPS Input Cord Length (m)
1.8
Recommended Electrical Service
15A 120V
OUTPUT
Output Capacity (VA)
1400
Output Capacity (kVA)
1.4
Output Capacity (Watts)
940
Nominal Voltage Details
115v nominal output in battery mode
Frequency Compatibility
60 Hz
Output Voltage Regulation (Line
Mode)
-18%, +8%
Output Voltage Regulation (Battery
Mode)
+/- 5%
2/5
Cleveland, OH 44122
United States
Hot-Swap PDU options
PDUB15 (2U / 8 5-15R outlets)
Output AC Waveform (AC Mode)
Sine wave
Output AC Waveform (Battery
Mode)
PWM sine wave
Nominal Output Voltage(s)
Supported
110V; 115V; 120V
Output Receptacles
(6) 5-15R
Individually Controllable Load Banks
No
BATTERY
Runtime Full Load (min.)
8 min. (940w)
Runtime Half Load (min.)
24 min. (470w)
Expandable Runtime
No
DC System Voltage (VDC)
36
Battery Recharge Rate (Included
Batteries)
Less than 8 hours from 10% to 90%
Battery Access
Battery access door
Internal UPS Replacement Battery
Cartridge
RBC53
VOLTAGE REGULATION
Voltage Regulation Description
Automatic voltage regulation (AVR) maintains line power operation with an input voltage range of 75 to 147
Overvoltage Correction
Input voltages between 128 and 147 are reduced by 12%
Undervoltage Correction
Input voltages between 93 and 107 are boosted by 14%
Severe Undervoltage Correction
Input voltages between 75 and 92 are boosted by 30%
USER INTERFACE, ALERTS & CONTROLS
Switches
2 Switches control off/on power status and alarm-cancel/self-test operation
Alarm Cancel Operation
Power-fail alarm can be silenced using alarm-cancel switch; once silenced, alarm will re-sound to indicate lowbattery status
Audible Alarm
Audible alarm indicates power-failure and low-battery conditions
LED Indicators
5 LEDs indicate line power, battery power, overload, voltage regulation and battery low/replace status
SURGE / NOISE SUPPRESSION
UPS AC Suppression Joule Rating
480
UPS AC Suppression Response
Time
Instantaneous
EMI / RFI AC Noise Suppression
Yes
480
AC Suppression Response Time
Instantaneous
3/5
Cleveland, OH 44122
United States
PHYSICAL
Primary Form Factor
Tower
Installation Form Factors Supported
with Included Accessories
Tower
with Optional Accessories
Wallmount ( UPSWM - tower mounting kit)
Primary UPS Depth (mm)
234
Primary UPS Height (mm)
325
Primary UPS Width (mm)
191
Shipping Dimensions (hwd / in.)
17.10 x 11.20 x 12.90
Shipping Dimensions (hwd / cm)
43.43 x 28.45 x 32.77
Shipping Weight (lbs.)
38.00
Shipping Weight (kg)
17.24
UPS Housing Material
PVC
UPS Power Module Dimensions
(hwd, cm)
32.51 x 19.05 x 23.37
(hwd, in.)
12.8 x 7.5 x 9.2
UPS Power Module Weight (kg)
16.51
UPS Power Module Weight (lbs.)
36.4
ENVIRONMENTAL
Operating Temperature Range
+32 to +104 degrees Fahrenheit / 0 to +40 degrees Celsius
Storage Temperature Range
+5 to +122 degrees Fahrenheit / -15 to +50 degrees Celsius
Relative Humidity
0 to 95%, non-condensing
AC Mode BTU / Hr. (Full Load)
134
Battery Mode BTU / Hr. (Full Load)
437
AC Mode Efficiency Rating (100%
Load)
94%
COMMUNICATIONS
PowerAlert Software
For local monitoring via the UPS’s built-in USB port, download PowerAlert software at
https://tripplite.eaton.com/products/power-alert
Communications Cable
USB cable included
WatchDog Compatibility
Supports Watchdog application, OS and hard-reboot restart options for remote applications
Communications Interface
USB
LINE / BATTERY TRANSFER
Transfer Time
2-4 milliseconds
4/5
Cleveland, OH 44122
United States
Low Voltage Transfer to Battery
Power (Setpoint)
75
High Voltage Transfer to Battery
Power (Setpoint)
147
FEATURES & SPECIFICATIONS
Cold Start (Startup in Battery Mode
During a Power Failure)
Cold-start operation supported
Green Energy-Saving Features
Greater than 95% efficiency - GREEN UPS
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
2-year limited warranty
Connected Equipment Insurance
(U.S., Canada & Puerto Rico)
Insurance
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
5/5
