SMART1050SLTAA
SMART1050SLTAA
    TRIPPLITE
    UPS SMART PRO TOWER 6 OUTLETS
SMART1050SLTAA 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States SmartPro 120V 1050VA 650W Line-Interactive Sine Wave UPS, Tower, Network Card Options, USB, DB9, 8 Outlets MODEL NUMBER: SMART1050SLTAA Highlights ● Corrects under- and overvoltages from 83V to 145V ● 8 NEMA 5-15R outlets ● Front-panel LEDs indicate load, power, voltage and battery statuses ● Network power management and control capability ● 19 min. runtime at half load; 7 min. at full load Package Includes Protects connected mission-critical equipment against damage, downtime and data loss due to blackouts, brownouts, power surges and line noise. Ideal solution for point-of-sale applications, VoIP systems and network closets. Description The SMART1050SLTAA SmartPro 120V 1.05kVA 650W Line-Interactive Sine Wave UPS provides battery backup and AC power protection against blackouts, brownouts, power surges and line noise that can damage electronics or destroy data. Ideal for backing up point-of-sale applications, VoIP systems and small business networks, the SMART1050SLTAA switches to battery mode in milliseconds to keep your connected equipment running long enough to save files and shut down safely with no data loss. Featuring eight NEMA 5-15R outlets and a six-foot power cord with 120V NEMA 5-15P input, the SMART1050SLTAA has an internal battery that provides 19 minutes of support at half load and seven minutes at full load. Front-panel LEDs indicate line power, battery power, overload, voltage regulation and battery status. An alarm sounds to indicate power failure, low battery or overload. Automatic voltage regulation (AVR) maintains selectable 100V, 110V or 120V nominal output over an input range of 83V to 145V without using battery power. EMI/RFI noise filtering improves your equipment’s performance and prevents damage. A 690-joule surge suppression rating protects your equipment from harmful power surges. With Tripp Lite’s PowerAlert software, available via free download, the SMART1050SLTAA enables safe unattended system shutdown and file saves in case of a prolonged power failure. Features Protects Mission-Critical Equipment ● Provides fully regulated sine wave AC output for point-of-sale applications, VoIP systems and small 1/6 ● SMART1050SLTAA SmartPro 120V 1.05kVA 650W LineInteractive Sine Wave UPS ● USB cable ● DB9 cable ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States business networks ● Audible alarm signals loss of utility power, low battery or overload ● 8 NEMA 5-15R outlets ● 6 ft. power cord with 120V NEMA 5-15P input ● 690-joule surge suppression rating Reliable Battery Backup ● Supports half load up to 19 min. and full load up to 7 min. ● Internal batteries designed for hot-swap field replacement ● 95% line-power efficiency rating saves money in energy costs ● Cold-start capability enables turn-on in battery mode during blackouts Automatic Voltage Regulation (AVR) ● Maintains selectable 100V, 110V or 120V nominal output over input range of 83V–145V without using battery power EMI/RFI Line Noise Filtering ● Removes electromagnetic and radio frequency interference that can disrupt or damage equipment’s performance LED Indicators ● Front-panel LEDs signal indicate line power, battery power, overload, voltage regulation and battery status Network Management Cards ● Compatible with Tripp Lite UPS management card options WEBCARDLX and SNMPWEBCARD Communication Ports ● USB & Serial ports enable data-saving unattended shutdown when used with Tripp Lite's PowerAlert software, available via FREE download from tripplite.eaton.com/products/power-alert Telephone/Network Jacks ● Protect against power surges over telephone/DSL or network Ethernet lines Specifications OVERVIEW UPC Code 037332152787 UPS Type Line-Interactive INPUT Input Phase Single-Phase Rated input current (Maximum Load) 6.1A (120V), 6.6A (110V), 7.2A (100V) 2/6 1000 Eaton Boulevard Cleveland, OH 44122 United States Nominal Input Voltage(s) Supported 100V AC; 110V AC; 120V AC UPS Input Connection Type 5-15P UPS Input Cord Length (ft.) 6 UPS Input Cord Length (m) 1.8 Recommended Electrical Service 15A 120V OUTPUT Output Capacity (VA) 1050 Output Capacity (kVA) 1.05 Output Capacity (Watts) 650 Nominal Voltage Details 120V default (voltage selection via back panel switches) Frequency Compatibility 50 / 60 Hz Frequency Compatibility Details Automatic frequency selection Output Voltage Regulation (Line Mode) -13%, + 15% Output Voltage Regulation (Battery Mode) +/- 5% Output AC Waveform (AC Mode) Sine wave Output AC Waveform (Battery Mode) Pure Sine wave Nominal Output Voltage(s) Supported 100V; 110V; 120V Output Receptacles (8) 5-15R Individually Controllable Load Banks No BATTERY Battery Type Valve Regulated Lead Acid (VRLA) Runtime Full Load (min.) 7 min. (650w) Runtime Half Load (min.) 19 min. (325w) Expandable Runtime No DC System Voltage (VDC) 24 Battery Recharge Rate (Included Batteries) 3 hours Battery Access Battery access door Internal UPS Replacement Battery Cartridge  RBC24-SLT  Battery Replacement Description Hot-swappable, user replaceable batteries VOLTAGE REGULATION 3/6 1000 Eaton Boulevard Cleveland, OH 44122 United States Voltage Regulation Description Automatic voltage regulation (AVR) maintains line power operation with an input voltage range of 95 to 145 (120v), 87 to 133 (110v), 83 to 121 (100v) Overvoltage Correction Voltage reduction of 12% applies when input is 127 to 145 (120v), 116 to 133 (110v), 111 to 121 (100v); All voltage setpoints ±5% tolerance Undervoltage Correction Voltage boost of 14% applies when input is 95 to 108 (120v), 87 to 99 (110v), 83 to 90 (100v); All voltage setpoints ±5% tolerance USER INTERFACE, ALERTS & CONTROLS Switches 2 Switches control off/on power status and alarm-cancel/self-test operation; rear panel protected switches support nominal voltage selection Alarm Cancel Operation Power-fail alarm can be silenced using alarm-cancel switch Audible Alarm Audible alarm indicates power failure and overload conditions LED Indicators 9 LEDs indicate line power, battery power, AVR, overload and replace battery status - with a 3-LED level meter for load and battery charge level Site Wiring Fault Indication Rear panel site wiring fault LED SURGE / NOISE SUPPRESSION UPS AC Suppression Joule Rating 690 UPS AC Suppression Response Time Instantaneous UPS Dataline Suppression 1 line TEL/DSL (1 in / 1 out); 10/100Base T Ethernet EMI / RFI AC Noise Suppression Yes PHYSICAL Primary Form Factor Tower Cooling Method Fan Installation Form Factors Supported with Included Accessories Tower Primary UPS Depth (mm) 335 Primary UPS Height (mm) 259 Primary UPS Width (mm) 173 Shipping Dimensions (hwd / in.) 13.30 x 17.90 x 9.30 Shipping Dimensions (hwd / cm) 33.78 x 45.47 x 23.62 Shipping Weight (lbs.) 38.40 Shipping Weight (kg) 17.42 UPS Housing Material Steel UPS Power Module Dimensions (hwd, cm) 25.91 x 17.27 x 33.53 UPS Power Module Dimensions (hwd, in.) 10.2 x 6.8 x 13.2 UPS Power Module Weight (kg) 16.33 4/6 1000 Eaton Boulevard Cleveland, OH 44122 United States UPS Power Module Weight (lbs.) 36 ENVIRONMENTAL Operating Temperature Range +32 to +104 degrees Fahrenheit / 0 to +40 degrees Celsius. Storage Temperature Range +5 to +122 degrees Fahrenheit / -15 to +50 degrees Celsius. Relative Humidity 0 to 95%, non-condensing AC Mode BTU / Hr. (Full Load) 107 Battery Mode BTU / Hr. (Full Load) 455 AC Mode Efficiency Rating (100% Load) 95% Audible Noise Audible Noise < 50 dBA at Front Side 1 Meter COMMUNICATIONS Network Management Cards SNMPWEBCARD;  WEBCARDLX  Network Monitoring Port Description Supports detailed monitoring of UPS and site power conditions PowerAlert Software For local monitoring via the UPS’s built-in communication ports, download PowerAlert software at https://tripplite.eaton.com/products/power-alert Communications Cable USB and DB9 cabling included WatchDog Compatibility Supports Watchdog application, OS and hard-reboot restart options for remote applications. Network UPS Tools (NUT) Compatibility NUT compatible. See the full list of Tripp Lite NUT compatible UPS systems at https://www.networkupstools.org/stable-hcl.html?manufacturer=Tripp Lite Communications Interface DB9 Serial; Slot for SNMP/Web interface; USB (HID enabled) LINE / BATTERY TRANSFER Transfer Time 4-6 milliseconds Low Voltage Transfer to Battery Power (Setpoint) 95V (120V), 87V (110V), 83V (100V); All voltage setpoints ±5% tolerance High Voltage Transfer to Battery Power (Setpoint) 145V (120V), 133V (110V), 121V (100V); All voltage setpoints ±5% tolerance FEATURES & SPECIFICATIONS Cold Start (Startup in Battery Mode During a Power Failure) Cold-start operation supported High Availability UPS Features Auto Probe Monitoring (requires WEBCARDLX); Automatic Voltage Regulation (AVR); Hot swappable batteries; Remote management; Sine wave output; Surge/noise protection WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty Connected Equipment Insurance (U.S., Canada & Puerto Rico) $250,000 Ultimate Lifetime Insurance  5/6 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 6/6
SMART1050SLTAA 价格&库存
很抱歉,暂时无法提供与“SMART1050SLTAA”相匹配的价格&库存,您可以联系我们找货
