1000 Eaton Boulevard
Cleveland, OH 44122
United States
SmartPro 120V 1.5kVA 1kW Line-Interactive Sine
Wave UPS, 2U Rack/Tower, LCD, USB, DB9, 8
Outlets
MODEL NUMBER: SMC15002URM
Highlights
Corrects under- and
overvoltages from 83V to 147V
8 NEMA 5-15R outlets
Monitoring of power conditions
via POWERALERT12
Interactive LCD monitoring
screen
17.7 min. runtime at half load;
6.5 min. at full load
Package Includes
Protects connected mission-critical equipment against damage, downtime and data loss due to blackouts,
brownouts, power surges and line noise. Pure sine wave output is compatible with active PFC power
supplies.
Description
The SMC15002URM SmartPro 120V 1.5kVA 1kW Line-Interactive Sine Wave UPS provides battery
backup and AC power protection against blackouts, brownouts, power surges and line noise that can
damage electronics or destroy data. Ideal for backing up high-performance workstations, servers and
network equipment, the SMC15002URM switches to battery mode in milliseconds to keep your connected
equipment running long enough to save files and shut down safely with no data loss. Pure sine wave
output is compatible with active power factor correction (PFC) power supplies.
Featuring eight NEMA 5-15R outlets and a 10-ft. (3.05 m) power cord with 120V NEMA 5-15P input, the
SMC15002URM has an internal battery that provides 17.7 minutes of support at half load and 6.5 minutes
at full load. A front-panel LCD screen lets you configure settings and monitor operating data, such as load
level, voltage, battery charge and estimated runtimes.
Automatic voltage regulation (AVR) maintains 120V nominal output over an input range of 83V to 147V
without using battery power. EMI/RFI noise filtering improves your equipment's performance and prevents
damage. A 570-joule surge suppression rating protects your equipment from harmful power surges. With
Tripp Lite's free downloadable PowerAlert software, SMC15002URM enables safe unattended system
shutdown and file saves in case of a prolonged power failure.
Features
Protects Mission-Critical Electronic Equipment
● Provides fully regulated pure sine wave AC output compatible with active PFC power supplies
Audible alarm signals loss of utility power, overload and low battery
Reliable Battery Backup
● Supports half load up to 17.7 min. and full load up to 6.5 min.
Internal batteries designed for hot-swap field replacement
1/6
Sine Wave UPS
USB cable
UPSHDEARKIT mounting
hardware
Owner’s manual
Cleveland, OH 44122
United States
94% line-power efficiency rating saves money in energy costs
Automatic Voltage Regulation (AVR)
● Maintains 120V nominal output over input range of 83V-147V without using battery power
EMI/RFI Line Noise Filtering
● Removes electromagnetic and radio frequency interference that can disrupt or damage equipment's
performance
Interactive LCD Screen
● Front-panel LCD signals operating mode, load level, voltage, battery charge and estimated runtimes
Supports multiple advanced user setup and operating preferences
Rotates for easy viewing in rack-mount or tower configurations
Communications Ports
● USB & Serial ports enable data-saving unattended shutdown when used with Tripp Lite's PowerAlert
software, available via FREE download from tripplite.eaton.com/products/power-alert
EPO port supports emergency shutdown in large facilities
Versatile Installation Options
● UPSHDEARKIT 2- and 4-post hardware included for front-vertical-rail mounting in 2U of EIA-standard
19 in. rack
Mounts on wall with optional 2POSTRMKITWM
Mounts in upright tower position with optional 2-9USTAND
Mounts with extra front-to-rear support in 4-post racks with optional 4POSTRAILKIT
Specifications
OVERVIEW
UPC Code
037332186249
UPS Type
Line-Interactive
INPUT
Input Phase
Single-Phase
Rated input current (Maximum Load)
12A
Nominal Input Voltage(s) Supported
120V AC
UPS Input Connection Type
5-15P
Input Circuit Breakers
15A
UPS Input Cord Length (ft.)
10
UPS Input Cord Length (m)
3.1
Recommended Electrical Service
15A 120V
2/6
Cleveland, OH 44122
United States
OUTPUT
Output Capacity (VA)
1500
Output Capacity (kVA)
1.5
Output Capacity (Watts)
1000
Output Capacity (kW)
1
Nominal Voltage Details
120v nominal output in battery mode
Frequency Compatibility
60 Hz
Output Voltage Regulation (Line
Mode)
-21%, +8%
Output Voltage Regulation (Battery
Mode)
+/- 5%
Output AC Waveform (AC Mode)
Sine wave
Output AC Waveform (Battery
Mode)
Pure Sine wave
Nominal Output Voltage(s)
Supported
110V; 115V; 120V
Output Receptacles
(8) 5-15R
Individually Controllable Load Banks
No
BATTERY
Battery Type
Valve Regulated Lead Acid (VRLA)
Runtime Full Load (min.)
6.5 min. (1000W)
Runtime Half Load (min.)
17.7 min. (500W)
Expandable Runtime
No
DC System Voltage (VDC)
36
Battery Recharge Rate (Included
Batteries)
Less than 4.5 hours from 10% to 90% (typical, full load discharge)
Battery Access
Front panel battery access door
Internal UPS Replacement Battery
Cartridge
RBC93-2U
Battery Replacement Description
Hot-swappable, user replaceable batteries
VOLTAGE REGULATION
Voltage Regulation Description
Automatic voltage regulation (AVR) maintains line power operation with an input voltage range of 83 to 147
Overvoltage Correction
Input voltages between 128 and 147 are reduced by 12%
Undervoltage Correction
Input voltages between 83 and 107 are boosted by 14%
USER INTERFACE, ALERTS & CONTROLS
3/6
Cleveland, OH 44122
United States
Front Panel LCD Display
Front panel LCD information and configuration screen offers detailed UPS and site power status and operating data,
plus configuration of voltage, operating mode, alarm function and a variety of additional options (see manual for
detailed LCD configuration and monitoring options)
Switches
3 pushbutton switches control OFF / ON power status, MODE selection and MUTE / ENTER control functions
Alarm Cancel Operation
Power-fail alarm can be temporarily silenced using alarm-cancel switch; silent mode alarm configuration option
available
Audible Alarm
Audible alarm indicates UPS startup, power-failure, low-battery, overload, UPS fault and remote shutdown
conditions
SURGE / NOISE SUPPRESSION
UPS AC Suppression Joule Rating
570
UPS AC Suppression Response
Time
Instantaneous
EMI / RFI AC Noise Suppression
Yes
PHYSICAL
Primary Form Factor
Rackmount
Rack Height
2U
Cooling Method
Fan
Included Mounting Accessory
Description
Includes UPSHDEARKIT for 2 point front-mount and 2 point center-mount rackmount installation in 2 and 4 post
racks, plus wallmount installation; For additional stability in 4 post racks, consider optional 4 post mounting
accessories 4POSTRAILKIT and 4POSTRAILKITWM
Installation Form Factors Supported
with Included Accessories
2 post 19 inch rackmount; 2 post front mount; 4 post 19 inch rackmount
with Optional Accessories
4 post rackmount full-depth ( 4POSTRAILKIT ); Tower ( 2-9USTAND ); Wallmount ( 2POSTRMKITWM )
Minimum Required Rack Depth (cm)
43.18
(inches)
17
Optional Mounting Accessory Notes
Optional 2-9USTAND enables upright tower UPS placement; 4POSTRAILKIT enables installation in 4-post standard depth racks from 20.5
to 36 inches (521 to 914mm); 4POSTRAILKITWM
enables installation in 4-post short-depth racks from 14.5 to 23.5 inches (368 to 597mm)
Primary UPS Depth (mm)
342
Primary UPS Height (mm)
88
Primary UPS Width (mm)
439
Shipping Dimensions (hwd / in.)
8.70 x 20.00 x 23.40
Shipping Dimensions (hwd / cm)
22.10 x 50.80 x 59.44
Shipping Weight (lbs.)
52.80
Shipping Weight (kg)
23.95
4/6
Cleveland, OH 44122
United States
UPS Housing Material
Steel
UPS Power Module Dimensions
(hwd, cm)
8.76 x 43.94 x 34.16
(hwd, in.)
3.45 x 17.3 x 13.45
UPS Power Module Weight (kg)
21.09
UPS Power Module Weight (lbs.)
46.5
Unit Weight (lbs.)
46.5000
Unit Weight (kg)
21.09
ENVIRONMENTAL
Operating Temperature Range
32° to 104°F (0° to 40°C)
Storage Temperature Range
5° to 122°F (-15° to 50°C)
Relative Humidity
0 to 95%, non-condensing
AC Mode BTU / Hr. (Full Load)
223
Battery Mode BTU / Hr. (Full Load)
650
AC Mode Efficiency Rating (100%
Load)
94%
Operating Elevation (ft.)
0-3000M (0-10,000 Ft)
Audible Noise
45 dBA maximum, front side 1m
Operating Elevation (m)
0 - 3000 m
COMMUNICATIONS
Network Monitoring Port Description
Supports detailed monitoring of UPS and site power conditions
PowerAlert Software
For local monitoring via the UPS’s built-in communication ports, download PowerAlert software at
https://tripplite.eaton.com/products/power-alert
Communications Cable
USB cabling included
WatchDog Compatibility
Supports Watchdog application, OS and hard-reboot restart options for remote applications
Network UPS Tools (NUT)
Compatibility
NUT compatible. See a full list of NUT compatible Tripp Lite UPS systems at https://networkupstools.org/stablehcl.html?manufacturer=Tripp%20Lite
Network Management Card
Description
Network management not supported
Communications Interface
DB9 Serial; EPO (emergency power off); USB (HID enabled)
LINE / BATTERY TRANSFER
Transfer Time
5 milliseconds (AC to battery), 1 milliseconds (Battery to AC)
Low Voltage Transfer to Battery
Power (Setpoint)
83
High Voltage Transfer to Battery
Power (Setpoint)
147
5/6
Cleveland, OH 44122
United States
FEATURES & SPECIFICATIONS
Cold Start (Startup in Battery Mode
During a Power Failure)
Cold-start operation supported
High Availability UPS Features
Automatic Voltage Regulation (AVR); Hot swappable batteries; Surge/noise protection
Grounding Lug
Back panel grounding lug
STANDARDS & COMPLIANCE
Product Certifications
CSA (Canada); NOM (Mexico); UL 1778
Product Compliance
RoHS; FCC Part 15 Class A (USA)
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
2-year warranty, 3 year with registration. Note: Registration is required for 3-year
warranty.
Connected Equipment Insurance
(U.S., Canada & Puerto Rico)
$250,000 Ultimate Lifetime
Insurance
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
6/6
