1000 Eaton Boulevard
Cleveland, OH 44122
United States
SmartPro 230V 1kVA 750W Medical-Grade LineInteractive Tower UPS with 6 Outlets, Full
Isolation, Expandable Runtime
Highlights
Supports a half load up to 27.5
minutes; full load up to 11
minutes
Six IEC320 C13 hospital-grade
outlets and IEC320 C14
hospital-grade plug
Leakage current less than 100
microamps
340 joule surge suppression
rating protects connected
equipment
Alarm mute/alarm quiet control
is ideal for use around patients
Approved to EN60601-1-2:2015,
4th Edition
MODEL NUMBER: SMX1200XLHG
Package Includes
Provides UL 60601-1 compliant, medical-grade 1kVA/750W power backup, ideal for use in patient-care
vicinities. The built-in isolation transformer offers full isolation while maintaining AC surge protection in all
modes.
Description
Tripp Lite’s SMX1200XLHG medical-grade UPS system provides dependable battery backup and is fully
compliant with UL 60601-1 regulations when plugged into a hospital-grade outlet, making it ideal for use in
patient-care vicinities. The 1kVA/750W capacity provides up to 27.5 minutes of runtime for a half load, or
11 minutes for a full load so you can work through short power failures and perform an orderly system
shutdown in a prolonged blackout.
Built-in line-interactive voltage regulation corrects brownouts as low as 155V and overvoltages as high as
274V to normal 230V nominal output, without drawing battery power. The SMX1200XLHG’s built-in
isolation transformer with Faraday shield offers full isolation and removes common mode noise while
maintaining full AC surge suppression in all modes. Cumulative leakage current of all connected
equipment is less than 100 microamps.
This UPS system features six IEC320 C13 hospital-grade outlets and has a hospital-grade IEC320 C14
plug on a 15 cm (6 in.) dongle. All six outlets provide both backup protection and surge protection, rated to
340 joules.
The SMX1200XLHG also features diagnostic LEDs, as well as a USB port and a DB9 serial port that work
with Tripp Lite’s included PowerAlert software for safe, unattended system shutdown and file saves in the
event of a prolonged power failure.
Application Usage
This UPS contains a lead acid battery designed to be connected continuously to an AC power source,
except during brief power outages. It is not intended for frequent charge/discharge cycles, such as mobile
cart applications where the UPS is often disconnected from the power source. Using the SMX1200XLHG
in this type of application will void the battery warranty.
Features
Provides Ideal UPS Backup in Healthcare Facilities
● Compliant with UL 60601-1 standards for use in patient-care vicinities, when plugged into a hospitalgrade outlet
Built-in isolation transformer with Faraday shield offers full isolation and removes common mode noise
Battery Backup and Full Surge Protection
1/5
SMX1200XLHG 1kVA/750W
Medical-Grade Tower UPS
System
USB monitoring cable, 1.8 m (6
ft.)
DB9 serial monitoring cable, 1.8
m (6 ft.)
PowerAlert software
Owner’s Manual
Cleveland, OH 44122
United States
27.5 minutes runtime for half load (375W); 11 minutes for full load (750W)
All six hospital-grade outlets provide surge protection rated to 340 joules
EMI/RFI noise filtering ensures equipment runs smoothly without line noise interference
Resistant to electrostatic discharge
LEDs and Audible Alarms Keep You Aware of Power Status
● Indicator lights on the front of the unit show you when the UPS is on and supplying utility power, when
operating in voltage correction mode or in battery mode, relative load level and low-battery warning
Audible alarms alert you to power failure, overload and low battery conditions; the alarm’s mute/quiet
mode ensures patients are not disturbed
Saves Your Files, Even When You’re Away
● Works with Tripp Lite PowerAlert software (included) to enable safe, unattended system shutdown and
files saves during prolonged power failures
Connects to your computer via either the DB9 port or USB port
Specifications
OVERVIEW
UPC Code
037332140425
UPS Type
Line-Interactive
INPUT
Rated input current (Maximum Load)
5A
Nominal Input Voltage(s) Supported
230V AC
UPS Input Connection Type
C14 inlet
UPS Input Cord Length (ft.)
0.50
UPS Input Cord Length (m)
0.2
Recommended Electrical Service
10A 230V
Voltage Compatibility (VAC)
230
Input Phase
Single-Phase
OUTPUT
Output Capacity (VA)
1000
Output Capacity (kVA)
1
Output Capacity (Watts)
750
Output Capacity (kW)
0.75
Nominal Voltage Details
230v nominal inverter output voltage
Frequency Compatibility
50 / 60 Hz
Frequency Compatibility Details
Automatic frequency selection
2/5
Cleveland, OH 44122
United States
Output Voltage Regulation (Line
Mode)
-18%, +8%
Output AC Waveform (Battery
Mode)
PWM sine wave
Nominal Output Voltage(s)
Supported
220V; 230V; 240V
Output Receptacles
(6) C13
Individually Controllable Load Banks
No
BATTERY
Battery Type
Valve Regulated Lead Acid (VRLA)
Runtime Full Load (min.)
11 min. (750W)
Runtime Half Load (min.)
27.5 min. (375W)
Expandable Runtime
Yes
Expandable Runtime Description
Supports extended runtime with optional BP36V15-2U (limit 1) and
BP36V42-3U external battery pack (multi-pack compatible)
External Battery Pack Compatibility
BP36V15-2U (limit 1); BP36V42-3U (multi-pack compatible); BP36V27-2US (multi-pack compatible)
DC System Voltage (VDC)
36
Battery Recharge Rate (Included
Batteries)
Less than 4.5 hours from 10% to 90%
Battery Access
Battery access door allows hot swap battery replacement without powering connected equipment off
Internal UPS Replacement Battery
Cartridge
RBC36SLT
Typical Battery Lifespan
3-6 years, depending on usage
VOLTAGE REGULATION
Voltage Regulation Description
Line interactive UPS offers 2 boost levels of brownout correction and a single level of overvoltage adjustment to
maintain usable, computer grade output without consuming battery power over an input voltage range of 155 to
274V AC.
Overvoltage Correction
Input voltages between 245 and 274V AC are reduced by 9%
Undervoltage Correction
Input voltages between 183 and 199 are boosted by 10%
Severe Undervoltage Correction
Input voltages between 156 and 182 are boosted by 21%
USER INTERFACE, ALERTS & CONTROLS
Switches
Yes, includes 2 front panel mounted push-button switches for system enable, self-test and alarm cancel functions
Audible Alarm
Audible Alarm is factory muted for silent operation; Audible alarm can be restored to indicate power failure, overload
conditions and Low Battery events using our Free Power Alert UPS management software.
LED Indicators
5 LEDs indicate line power, battery power, overload, voltage regulation and battery low/replace status
3/5
Cleveland, OH 44122
United States
SURGE / NOISE SUPPRESSION
UPS AC Suppression Joule Rating
340
EMI / RFI AC Noise Suppression
Yes
AC Suppression Response Time
Instantaneous
PHYSICAL
Primary Form Factor
Tower
Cooling Method
UPS cooling via rear-exit fan
Installation Form Factors Supported
with Included Accessories
Tower
with Optional Accessories
Wallmount ( UPSWM - tower mounting kit)
Primary UPS Depth (mm)
231
Primary UPS Height (mm)
323
Primary UPS Width (mm)
191
Shipping Dimensions (hwd / in.)
18.50 x 12.20 x 13.38
Shipping Dimensions (hwd / cm)
46.99 x 30.99 x 33.99
Shipping Weight (lbs.)
48.80
Shipping Weight (kg)
22.14
UPS Housing Material
PVC
UPS Power Module Dimensions
(hwd, cm)
32.26 x 19.05 x 23.11
(hwd, in.)
12.7 x 7.5 x 9.1
UPS Power Module Weight (kg)
20.64
UPS Power Module Weight (lbs.)
45.5
Unit Weight (lbs.)
45.5000
Unit Weight (kg)
20.64
ENVIRONMENTAL
Operating Temperature Range
32° to 104°F (0° to 40°C)
Storage Temperature Range
5° to 122°F (-15° to 50°C)
Relative Humidity
0 to 95%, non-condensing
AC Mode BTU / Hr. (Full Load)
252.2
Battery Mode BTU / Hr. (Full Load)
252.2
COMMUNICATIONS
4/5
Cleveland, OH 44122
United States
Network Management Card
Description
Network management not supported
Communications Interface
USB; DB9 Serial
LINE / BATTERY TRANSFER
Transfer Time
2-4 milliseconds
Low Voltage Transfer to Battery
Power (Setpoint)
155
High Voltage Transfer to Battery
Power (Setpoint)
274
FEATURES & SPECIFICATIONS
Cold Start (Startup in Battery Mode
During a Power Failure)
Cold-start operation supported
High Availability UPS Features
Surge/noise protection
Grounding Lug
Ground Potential Equalization Connector: POAG-S6/20
STANDARDS & COMPLIANCE
Product Certifications
UL 60601-1
Product Compliance
RoHS; CE (Europe)
WARRANTY & SUPPORT
Product Warranty Period
(International)
2-year limited warranty
Product Warranty Period (Mexico)
Product Warranty Period (Puerto
Rico)
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
5/5
很抱歉,暂时无法提供与“SMX1200XLHG”相匹配的价格&库存,您可以联系我们找货
