8-Outlet Power Strip with Surge Protection, 6 ft.
(1.83 m) Cord, 1050 Joules, 2 ft. (0.61 m) length
MODEL NUMBER: SS240806
Highlights
8-outlet NEMA 5-15R power
strip with a 6-ft. (1.83 m) Cord
Rated at 1800W, 120V, 15A and
featuring a resettable circuit
breaker to prevent dangerous
circuit overloads
Integral, premium-grade, 1050Joule, surge suppressor to
protect sensitive electronics
from destructive AC transient
surges and line noise
Easy-to-install, vertical or
horizontal mounting with
adjustable mounting clips
Rocker-style, illuminated power
switch with locking safety cover
to prevent accidental turn offs
Certified to meet UL 1449 3rd
Edition and UL 1363 standards
Package Includes
Conveniently add extra power outlets in computer rooms, workbenches, table tops, raceways, repair
shops, labs, offices or anywhere that needs to connect many electrical devices simultaneously to a single
AC wall outlet.
Description
Never search for an open outlet again! Tripp Lite's SS240806 power strip with integral AC surge
suppression will give you surge-protected outlets where you need them, when you need them. The
SS240806 contains a 6-ft. (1.83 m) cord and 8 NEMA 5-15R outlets with 2.25-in. center-to-center spacing
- wide enough for most transformers or adapters. And to eliminate need for a separate surge protector
that can clutter up your work area, the SS240806 contains a premium-grade surge suppressor rated at
1050 Joules for protecting computers, testing equipment and other sensitive electronics from destructive,
high-energy, AC transient surges and EMI/RFI line noise. Encased in a rugged, all-metal housing, it
comes with adjustable mounting clips for either vertical and horizontal mounting, making the SS240806
ideal for a variety of uses including computer rooms, workbenches, table tops, repair shops, labs, test
areas, work stations, offices, hobby shops and more. An illuminated, rocker-style power switch with a
locking, transparent guard helps prevent accidental turn-offs, while a 15-amp circuit breaker guards
against dangerous circuit overloads. To match the decor of most professional settings, it has an attractive
gray housing with black receptacles.
Features
Multi-Outlet 120V Power Distribution and Surge Protection for Locations with Limited Free Space
● A 1800W, 120V, 15A, corded, multi-outlet power strip connects multiple electrical devices to a single AC
wall socket
Saves the time and cost of installing new power outlets in un-powered areas
Contains an integral surge protector to eliminate the need for a separate surge protector
Numerous Uses for Home, Office, Industrial and IT Environments
● Ideal for distributing electric power to telecommunications, computers or networking equipment in rack
enclosures
Home uses include workbenches, table tops and work stations
Commercial uses include offices, factories, machine shops, repair shops, test stands and engineering
labs
1/4
SS240806 Power Strip/Surge
Suppressor
Set of adjustable mounting clips
Warranty information
Instruction manual
8 Convenient Outlets Power All Standard Electrical Equipment
● Features 8 NEMA 5-15R outlets that are compatible with all standard electrical equipment
Each power outlet is 2.25 inches apart (center to center), allowing enough room for most adapters and
transformers
A 6-ft. (1.83 m) long power cord easily reaches most wall outlets
Integral, Premium-Grade, Surge Suppression to Protect Against Destructive Surges and Line
Noise
● Contains a premium-grade surge suppressor rated at 1050 Joules for protecting computers, testing
equipment and other sensitive electronics from destructive, AC transient surges
Prevents data loss in sensitive electronics due to EMI/RFI line noise
Adjustable Vertical and Horizontal Mounting Options
● Convenient method of optional horizontal or vertical power distribution
Its 24-in. length and low-profile form factor fits in the most confined spaces unobtrusively
Easy-to-install with adjustable mounting clips
Premium Safety Features
● Features an illuminated, rocker-style power switch with a locking, transparent guard to prevent
An integral, 15-amp resettable circuit breaker prevents dangerous circuit overloads that can irreversibly
damage connected equipment
Rugged, Durable Housing
● A rugged, all-metal housing is durably constructed making it a great solution for industrial applications
An attractive, gray housing with stylish black receptacles match the decor of most professional settings
Specifications
OVERVIEW
UPC Code
037332186416
INPUT
Nominal Input Voltage(s) Supported
120V AC
Recommended Electrical Service
120V
Input Cord Gauge (AWG)
14
Voltage Compatibility (VAC)
120
Maximum Surge Amps
22000
Input Plug Type
NEMA 5-15P
Input Cord Details
SJT
Input Cord Length (ft.)
6
Right-Angle Plug
No
2/4
Input Cord Length (m)
1.83
Integrated Cord Clip
No
OUTPUT
Frequency Compatibility
50 / 60 Hz
Output (Watts)
1800
Output Receptacles
(8) 5-15R
Circuit Breaker (amps)
15
Outlet Spacing
USER INTERFACE, ALERTS & CONTROLS
Diagnostic LED(s)
No
Switches
Combination AC circuit breaker and lighted 2-position power switch controls power to all outlets
Locking Switch Cover
Transparent locking switch cover
SURGE / NOISE SUPPRESSION
AC Suppression Joule Rating
1050
UL1449 Let Through Rating
500V UL verified
EMI / RFI Filtering
Yes
Automatic Shut-Off
No
DATALINE SURGE SUPPRESSION
Cable (Coax) Protection
No
Network (Ethernet) Protection
No
Telephone/DSL Protection
No
PHYSICAL
Power Cord Color
Black
Housing Color
Silver
Included Mounting Accessories
Set of adjustable mounting clamps
Mounting Holes or Slots
No
Outlets Measurement (Center to
Center)
2.25
Receptacle Color
Black
Shipping Dimensions (hwd / in.)
2.40 x 3.50 x 28.10
Shipping Dimensions (hwd / cm)
6.10 x 8.89 x 71.37
Shipping Weight (lbs.)
2.40
Shipping Weight (kg)
1.09
3/4
Unit Dimensions (hwd / in.)
1.250 x 1.620 x 24.000
Unit Dimensions (hwd / cm)
3.18. x 34.11 x 60.1
Unit Weight (lbs.)
1.87
Unit Weight (kg)
0.85
Outlet Spacing
FEATURES & SPECIFICATIONS
Antimicrobial
No
Rotatable Outlets
No
STANDARDS & COMPLIANCE
Product Certifications
cUL Listed; UL 1449; UL 1363; UL Listed
Product Compliance
RoHS
WARRANTY
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does
not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice.
Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies:
https://www.tripplite.com/products/product-certification-agencies
4/4
