1000 Eaton Boulevard
Cleveland, OH 44122
United States
5.5kW Single-Phase Switched PDU - LX Interface,
208/230V Outlets (8 C13 & 6 C19), L6-30P Input,
15 ft. (4.57 m) Cord, 2U Rack-Mount, TAA
Highlights
5.5kW 208/230V Switched 24A
PDU, 2U rackmount, Reversible
housing
Pre-installed WEBCARDLX with
latest version of PADM20 for IPbased Auto Probe feature
Reports voltage, frequency and
load level; Front-panel digital
current meter
14 Switched outlets (8 C13, 6
C19) and 15ft./4.5m NEMA L630P input cord
Federal Trade Agreements Act /
TAA Compliant for GSA
Schedule purchases
MODEL NUMBER: PDUMH30HV19NET
Package Includes
Features
30A 208/230V Switched Power Distribution Unit / PDU with built-in web/network interface (Agency
derated to 24A continuous)
Attached L6-30P 208/230V single phase input, 15 ft. / 4.6m input cord
2U horizontal rackmount form factor
14 switched outlets (8 C13, 6 C19)
Supports power-on, power-off or reboot of each outlet on a real-time or programmable basis
Enables reboot of locked equipment, custom power-on/power-off sequences, load-shedding of optional
loads and disabling unused outlets
Network interface provides PDU control and data regarding input voltage and total output load level in
amps
Digital display continuously reports total output load level in amps
Supports user-specified alarm notification thresholds
Pre-installed WEBCARDLX with the latest version of PowerAlert Device Manager firmware (PADM20)
provides enhanced remote management capabilities
PADM20 and PowerAlert Element Manager (PAEM) form a powerful tool for expanding maintenance
functions in large installations, including firmware update checks and backup and restoration of device
configurations
IP-based Auto Probe detects lost connectivity and restores service autonomously
DHCP/Manual configuration support
10/100 Mbps auto-sensing
Real-time clock backup maintains the time of day and date even if the PDU is unpowered
Tiered access privileges allow an administrator and a guest to login via web browser
Alert notifications via email or SNMP traps offer immediate event notification
Firmware upgrade ability supports future product enhancements
Optional EnviroSense2 modules (sold separately) provide a variety of environmental monitoring
1/4
PDUMH30HV19NET with
attached L6-30P input power
cord
Installed WEBCARDLX network
interface
Installable 2U mounting
brackets
Configuration cable
User manual
Cleveland, OH 44122
United States
capabilities
Mounting flanges support installation in 2 and 4 post racks, with additional support for wall-mount and
under-counter installation formats
Mounting ears are reversible for front or rear facing rackmount installation
Included cord retention brackets
Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases
Specifications
OVERVIEW
UPC Code
037332153753
PDU Type
Switched
INPUT
PDU Input Voltage
208; 230
Recommended Electrical Service
Single-phase 30A 208/230V service
Maximum Input Amps
24
Maximum Input Amps Details
Agency de-rated to 24A continuous
PDU Plug Type
NEMA L6-30P
Input Phase
Single-Phase
Input Cord Length (ft.)
15
Input Cord Length (m)
4.57
OUTPUT
Output Capacity Details
5.5kW (230V), 5kW (208V) total capacity / 30A max (Agency de-rated to 24A), 20A max per breakered outlet bank;
16A max per C19 outlet; 12A max per C13 outlet
Frequency Compatibility
50 / 60 Hz
Output Receptacles
(8) C13; (6) C19
Output Nominal Voltage
208/230V
Overload Protection
3 20A circuit breakers; Breaker 1 (Bank 1 C13 outlets #1-8), Breaker 2 (Bank 2 C19 outlets #9-11), Breaker 3 (Bank
2 C19 outlets #12-14)
Customized Load Management
Receptacles
Each outlet is individually controllable via remote interface
USER INTERFACE, ALERTS & CONTROLS
Front Panel LCD Display
2 digit meter and pushbutton display toggle switch reports output current in amps in 3 loading segments, Bank 1
(C13 outlets #1-8), Bank 2 (C19 outlets #9-14) and Banks 1&2 combined (Outlets #1-14)
Front Panel LEDs
14 power availability LEDs confirm power off/on status for each built-in outlet; Two additional LEDs identify which
bank the visual current meter is reporting (Bank 1, Bank 2 or Banks 1&2 combined)
Switches
Pushbutton near the two digit current meter toggles reporting of output amps on Bank 1, Bank 2 and Total PDU
output (Banks 1 & 2 combined)
2/4
Cleveland, OH 44122
United States
SURGE / NOISE SUPPRESSION
Automatic Shut-Off
No
PHYSICAL
Material of Construction
Metal
Form Factors Supported
2U rackmount
Minimum Required Rack Depth (cm)
40.64
(inches)
16
PDU Form Factor
Horizontal (2U)
Shipping Dimensions (hwd / in.)
7.80 x 16.90 x 20.00
Shipping Dimensions (hwd / cm)
19.81 x 42.93 x 50.80
Shipping Weight (lbs.)
17.80
Shipping Weight (kg)
8.07
Unit Dimensions (hwd / in.)
3.500 x 17.500 x 12.500
Unit Dimensions (hwd / cm)
8.9 x 44.5 x 31.75
Unit Weight (lbs.)
13.80
Unit Weight (kg)
6.26
ENVIRONMENTAL
Operating Temperature Range
0C ~ 40C (32F ~ 104F)
Storage Temperature Range
-30°C to +50°C (-22°F to +122°F)
Relative Humidity
5-95% non-condensing
Operating Elevation (ft.)
0-10,000
Operating Elevation (m)
0-3000
COMMUNICATIONS
PowerAlert Software
LX Platform Interface: PowerAlert Device Manager
Communications Cable
Micro-USB- to-USB A configuration/console Access cable
Network Monitoring Port
RJ45 Network port, Micro-USB Configuration port, USB A port supports a variety of Envirosense2 environmental and
control modules. See Accessories>Management Hardware section for more information about these modules.
SNMP Compatibility
Pre-installed LX platform interface provides remote monitoring via Java-free HTML5 web interface, telnet, SSH and
SNMP management systems
Network Compatibility
10 Mbps; 100 Mbps (Fast Ethernet)
FEATURES & SPECIFICATIONS
TVSS Grounding
Grounding lug
High Availability PDU Features
Auto Probe Monitoring and Reboot (included); Auto Load Shedding
3/4
Cleveland, OH 44122
United States
STANDARDS & COMPLIANCE
Product Certifications
CSA (Canada); NOM (Mexico); UL 60950-1
Product Compliance
RoHS; FCC Part 15 Class A (USA); Trade Agreements Act (TAA)
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
2-year limited warranty
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
4/4
很抱歉,暂时无法提供与“PDUMH30HV19NET”相匹配的价格&库存,您可以联系我们找货
