1000 Eaton Boulevard
Cleveland, OH 44122
United States
20-60kVA 3-Phase Power Distribution Center
Highlights
Full size Rack Power
Distribution Cabinet supports
20-60kVA 3 phase UPS power
distribution in datacenter
equipment racks
42 pole breaker panel supports
3 phase 208V and single phase
208V and 120V output to
connected equipment
Pre-installed 225A 3 pole main
breaker, ground and neutral
bars
Secure front and rear doors,
removable side panels
Full line of accessories includes
circuit breakers, corded
receptacle whips and PDUs
MODEL NUMBER: SUDC208V42P
Description
Tripp Lite’s SUDC208V42P Power Distribution Cabinet supports 20-60kVA 3 phase UPS power
distribution in critical datacenter equipment racks. Full size rack enclosure with pre-installed 42 pole circuit
breaker panel supports 3 phase 208V and single phase 208V and 120V output via optional corded
receptacle whips. Breaker panel includes 225A 3 pole main breaker, ground and neutral bars, plus 1/2
and 3/4 inch knockouts. Rack enclosure offers secure front and rear doors, removable side panels and
shares common dimensions and overhead wiring tray accessories as Tripp Lite SR42UB rack enclosures.
Compatible with Tripp Lite SUBB-series breakers, SUWL-series corded receptacle whips and a full line of
compatible basic, metered, monitored and switched PDUs to support a variety of advanced network
configurations.
Features
SUDC208V42P Power Distribution Cabinet supports 20-60kVA 3 Phase UPS power distribution in
Full size rack enclosure with pre-installed 42 pole circuit panel supports 3PH 208V and 1PH 208V and
120V via optional corded receptacle whips
Line up and match power distribution cabinet blends with existing standard datacenter racks for an
aesthetically pleasing appearance while providing convenient connectivity between the centralized 3
phase UPS and protected electronic devices in equipment racks
Breaker panel includes 225A 3 pole main breaker, ground and neutral bars, 1/2 and 3/4 inch knockouts
(see Help & Downloads for manual with detailed wiring information)
Rack enclosure offers secure front and rear doors, removable side panels and shares common
dimensions and overhead wiring tray and ladder accessories as Tripp Lite SR42UB equipment racks
Requires appropriate SUBB-series output circuit breakers (see Related Items for list of compatible
SUBB breakers)
Optional SUWL-series cable whips and SUWEL-series extensions support a variety of connector types,
voltages and cable lengths (see Related Items for list of compatible SUWL-series and SUWEL-series
cabling accessories)
Specifications
OVERVIEW
1/2
Cleveland, OH 44122
United States
UPC Code
037332153593
PDU Type
Basic; Metered; Monitored; Switched
Accessory Type
Accessory Class
UPS Accessories
INPUT
PDU Plug Type
Hardwire
Input Phase
3-Phase
OUTPUT
Output Receptacles
Hardwire
PHYSICAL
PDU Form Factor
Vertical (0U)
Shipping Dimensions (hwd / in.)
84.00 x 45.50 x 26.00
Shipping Dimensions (hwd / cm)
213.36 x 115.57 x 66.04
Shipping Weight (lbs.)
344.00
Shipping Weight (kg)
156.04
Unit Dimensions (hwd / in.)
78.500 x 23.630 x 43.000
Unit Dimensions (hwd / cm)
199.39 x 60.02 x 109.22
Unit Weight (lbs.)
321
Unit Weight (kg)
145.60
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
1-year limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
2/2
很抱歉,暂时无法提供与“SUDC208V42P”相匹配的价格&库存,您可以联系我们找货
