A Global Leader in the Design, Development, and
Manufacture of Sensor and Magnetic Components
www.standexmeder.com
Series Datasheet – SHV Reed Relays
SHV Series
Reed Relays
Features: Small High Voltage Relay, Dielectric Strength up to 4 kVDC, Internal Magnetic Shield, UL-listed
Applications: High Density Assembly, Portable Test and Medical Equipment, Cable and In-Circuit Tester
Markets: Test & Measurement, ATE, Medical & Others
SHV00-1A85-78X0K
Part Description:
Nominal
Voltage
Contact
Quantity
Contact
Form
Switch
Model
Pin Out
Option
Breakdown
Voltage
05, 12, 24
1
A
85
78
L, D
2K, 3K, 4K
See page 3 for explanation
Switch Model
85
Contact Data (at 20°C)
Unit
(A-Dry)
Contact Material
Rhodium
Rated Power (max.)
Any DC combination of V&A not to exceed max rated power
Switching Voltage (max.)
DC or peak AC
Switching Current (max.)
DC or peak AC
Carry Current (max.)
DC or peak AC
Contact Resistance (max.)
@ 0.5V & 10mA, Measured with 40% Pull-In Overdrive
Breakdown Voltage (min.) (depending on configuration)
According to IEC 60255-27
Operating Time (max.)
Including Bounce, Measured with 40% Pull-In Overdrive
Release Time (max.)
Measured without Coil Suppression
Insulation Resistance (min. / typ.)
Rh
很抱歉,暂时无法提供与“SHV05-1A85-78D3K”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+77.829501+9.40270
- 24+65.3283024+7.89240
- 120+58.69280120+7.09080
- 264+53.48010264+6.46100
- 504+50.87960504+6.14690
- 1008+47.182801008+5.70030
