USB-TO-SERIAL
CONVERTERS
EDGEPORT®
Easy out-of-the-box solution for I/O expansion is
available in a wide variety of configurations for
maximum flexibility and scalability
Edgeport USB-to-serial converters offer instant I/O expansion
for peripheral device connectivity. An out-of-the-box (external)
alternative to PCI cards, Edgeport makes it easy to add serial
and USB ports to a PC, server or thin client in minutes –
without opening the chassis, reconfiguring or rebooting the
system.
to one box; models with galvanic isolated ports for extended
electrical safety; and DB-9 or DB-25 connectors to meet
cabling requirements.
Feature-rich design, reliability and unmatched operating
system support make Edgeport USB-to-serial converters
ideal for mission-critical enterprise applications.
Edgeport is available in multiple configurations for maximum
flexibility and scalability. Choose from compact form factors
for space-prohibitive applications; single port “bump-in-thecable” solutions for notebook expansion; software-selectable
RS-232/422/485 models to connect any type of serial device
BENEFITS
APPLICATION EXAMPLE
– Add 1, 2, 4, 8 or 16 serial ports to a PC, thin client or
server in minutes
POS CONNECTIVITY
– Designed for peripheral device connectivity in retail
stations, self check-out systems, emergency vehicles,
kiosks, ATMs and more
EDGEPORT®/8
– Software selectable MEI, galvanic isolated, industrial,
and compact models
– Low total cost of ownership with external, user-
installable solution
Hubport®
RS-232
Serial
RS-232
Serial
Bar-Code
Scanner
RELATED PRODUCTS
AnywhereUSB®
PC
USB
Credit Card
Reader
Modem
Rapidport/4®
PortServer® TS
Cables and
Accessories
Check
Voucher
Receipt Printer
Pole Display
Touch Screen
Monitor
SPECIFICATIONS
Edgeport® Serial
| Edgeport® Extended Safety | Edgeport® Industrial
| Edgeport® Compact
INTERFACES (VARIES BY MODEL)
SERIAL PORTS
1, 2, 4, 8 or 16
4 (separately isolated)
1, 2, 4 or 8
2
SERIAL TYPE
RS-232
RS-232/422/485
RS-422/485, software selectable
RS-232/422/485
RS-232
SERIAL CONNECTOR
DB-9, DB-25
DB-9
DB-9
DB-9
SERIAL DATA RATE
230 Kbps per port
simultaneously
230 Kbps per port
simultaneously
230 Kbps per port
simultaneously
230 Kbps per port
simultaneously
DOWNSTREAM USB PORTS
4 (16-port models only)
1 (separately isolated)
FEATURES
USB
USB 1.0 and USB 1.1 compatible; backwards compatibility for USB 2.0 and USB 3.0; USB-IF certified; Plug and Play
LEDS
Tri-state LED displays device status and COM port activity
OPERATING SYSTEMS
Windows Server® 2016, Windows 10®, Windows 8®, Windows 7®, Windows Vista®, Windows Server 2012, Windows Server 2008 R2, Windows XP®,
Windows XP Embedded, Windows CE® 5, Windows CE 6 (x86 only), Windows Server 2003 R2, Windows 2000®; Linux*, Sun Solaris® (SPARC)**
CABLES
1-meter USB cable
OTHER (GENERAL)
Automatic port reacquisition; COM port assignments maintained across reboots; Full hardware and software flow control;
No additional IRQ or memory address requirements; Low power consumption; Rack mountable; Hot-swappable
OTHER (MODEL-SPECIFIC)
N/A
1-meter USB cable
2.0 kV DC galvanic isolation
on all ports
1-meter USB cable
N/A
Captive 2-meter cable for secure
connection in rugged environments (mobile computing)
N/A
POWER REQUIREMENTS
External power supply not required for models without USB ports (USB powered);
Models with USB ports (Edgeport 416) ship with power supply: 100/240VAC 60/50 Hz at 5VDC @ 3 Amps max
USB powered
OPERATING TEMPERATURE
0° C to 55° C (32° F to 131° F)
RELATIVE HUMIDITY
0% to 95% (non-condensing)
SAFETY
EN60950, UL 1950, CSA 2.2 No.
950, IEC 950
950, IEC 950
950, IEC 950
950, IEC 950
EMISSIONS/IMMUNITY
CE, FCC Part 15 Class B, EN55022,
EN55024
EN55024
EN55024
EN55024
POWER SUPPLY
ENVIRONMENTAL
REGULATORY APPROVALS
*Driver support provided by Linux USB maintainers.
**Driver support provided by Sun.
WWW.DIGI.COM
SPECIFICATIONS
Measurements
EDGEPORT/1, 1I
Length: 3.15 in (8.00 cm)
Width: 1.75 in (4.40 cm)
Height: 0.80 in (2.03 cm)
Weight: 1.60 oz (45.36 g)
EDGEPORT/2C
Length: 2.38 in (6.04 cm)
Width: 3.94 in (10.00 cm)
Height: 1.00 in (2.54 cm)
Weight: 5.00 oz (141.75 g)
EDGEPORT/416, 416/DB-25, 8/DB-25
Length: 5.00 in (12.70 cm)
Width: 17.00* in (43.118 cm)
Height: 1.80 in (4.53 cm)
Weight: 41.30 oz (1170.84 g)
EDGEPORT/4/DB-25, 8, 8S MEI
Length: 4.35 in (11.05 cm)
Width: 7.20 in (18.29 cm)
Height: 1.75 in (4.45 cm)
Weight: 16.00 oz (453.59 g)
EDGEPORT/2, 2S, 4, 4S MEI, 4S MEI ISOLATED
Height: 1.03 in (2.61 cm)
Weight: 10.00 oz (311.00 g)
* 19.0 in (48.26 cm) with optional rack mount ears
VIDEO CAMERA
USB
TOUCH SCREEN
RS-232 Serial
MONEY DISPENSER
RS-232 Serial
TOUCH PAD
RS-232 Serial
CREDIT CARD READER
RS-232 Serial
RECEIPT PRINTER
USB
SERVER
Ethernet
USB
WWW.DIGI.COM
PART NUMBERS
DESCRIPTION
301-1003-10
Edgeport/2c - 2 RS-232 serial DB-9, captive 2-meter cable
301-1000-04
Edgeport/4 - 4 RS-232 serial DB-9
301-1002-08
Edgeport/8 DB-9 - 8 RS-232 serial DB-9
301-1016-01
Edgeport/4 - 4 RS-232 serial DB-25
301-1001-11
Edgeport/1 - 1 RS-232 serial DB-9
301-1001-15
Edgeport/1 with 2-Meter Captive Cable - 1 RS-232 serial DB-9, captive 2 meter cable
301-1002-08
301-2000-10
Edgeport/416 DB-9 - 4 USB, 16 RS-232 serial DB-9, rack mountable
301-1000-95
Edgeport/4s MEI Isolated - 4 RS-232/422/485 serial DB-9 software selectable with galvanic isolation
301-1000-94
Edgeport/4s MEI - 4 RS-232/422/485 serial DB-9; software selectable
301-1001-31
Edgeport/1i - 1 RS-422/485 serial DB-9
301-1002-98
Edgeport/8s MEI - 8 RS-232/422/485 serial DB-9; software selectable
FOR MORE INFORMATION
PLEASE VISIT WWW.DIGI.COM
DIGI SERVICE AND SUPPORT / You can purchase with confidence knowing that Digi
is always available to serve you with expert technical support and our industry
leading warranty. For detailed information visit www.digi.com/support.
© 1996-2018 Digi International Inc. All rights reserved.
All trademarks are the property of their respective owners.
91001226
F4/718
DIGI INTERNATIONAL WORLDWIDE HQ
877-912-3444 / 952-912-3444 / www.digi.com
DIGI INTERNATIONAL SINGAPORE
+65-6213-5380
DIGI INTERNATIONAL GERMANY
+49-89-540-428-0
DIGI INTERNATIONAL CHINA
+86-21-50492199 / www.digi.com.cn
DIGI INTERNATIONAL JAPAN
+81-3-5428-0261 / www.digi-intl.co.jp
