1000 Eaton Boulevard
Cleveland, OH 44122
United States
USB-C to HDMI Adapter with PD Charging,
HDCP, White
MODEL NUMBER: U444-06N-H4-C
Highlights
Transmits video signals from
sources supporting USB
DisplayPort Alt Mode
Supports UHD video resolutions
up to 3840 x 2160 (4K x 2K) @
30 Hz
Supports USB 3.2 Gen 1
speeds up to 5 Gbps to ensure
fast data transfers
USB-C PD charging port
supports power input up to 20V
3A (60W)
Plug-and-play operation with no
software or drivers required
Applications
Watch 4K video content from a
Blu-ray player, game console,
laptop or tablet on an Ultra HD
television or projector
Connect a Chromebook or
MacBook to a conference
table’s A/V box to give a video
presentation on a large screen
Charge and power a USB-C or
Thunderbolt 3 device with its AC
wall charger
Connect a USB peripheral, such
as an external hard drive, printer
or hub
USB 3.2 Gen 1 to HDMI adapter adds HDMI and USB-C PD ports to your laptop, MacBook or other
compatible device.
Features
USB-C to HDMI Adapter Connects to Your Device’s USB-C or Thunderbolt 3 PortThis USB 3.2 Gen
1 to HDMI adapter helps you transmit video from your tablet, laptop, Chromebook, MacBook, smartphone
or PC to an HDMI-enabled television, monitor or projector. It’s ideal for transmitting digital audio and 4K
video to a large display, as well as powering and charging a PD Charging-compliant mobile
device.Supports USB DisplayPort 1.2 Alternate Mode for Transmitting Video Signals
With a source device that also supports USB DisplayPort Alt Mode, you can extend video from your
primary display to another, duplicate the same video on both displays, or change the second display to
your primary.
Transmits Crystal-Clear 4K HDMI Video and Digital AudioTo send digital audio and Ultra High
Definition video to a 4K-ready HDMI television, projector or monitor, connect the HDMI port to the display
using an HDMI cable (sold separately). The HDMI port supports UHD video resolutions up to 3840 x 2160
(4K) at 30 Hz. The adapter is backward compatible with non-4K displays.
System Requirements
Source device with USB-C or
Thunderbolt 3 port that supports
USB DisplayPort Alternate
Mode
Display device with HDMI input
(HDMI port)
Package Includes
Charges the Connected Laptop, Smartphone or Other DeviceThe USB-C Power Delivery (PD) port
provides power and charging to the PD Charging-compliant device (such as a MacBook, Chromebook or
Android smartphone) the adapter is connected to. Connect the device’s AC wall charger to the adapter's
USB-C PD port, which supports power input up to 20V/3A (60W).Note: USB-C PD port does not support
Quick Charge (QC).
Built-In USB-C Cable Connects in Either DirectionConnect the reversible USB-C plug to your source
device’s USB-C or Thunderbolt 3 port. The fumble-free USB-C plug connects in either direction to ensure
fast, easy connection every time.
Ready to Use Right Out of the PackageThe plug-and-play USB 3.2 to HDMI adapter requires no
software, drivers or external power. It’s smaller than a credit card, making it easy to carry in a pocket,
briefcase or laptop bag for connecting on the go.
3-Year Warranty and Environmentally Responsible DesignThe U444-06N-H4-C comes with a 3-year
warranty. It’s manufactured in compliance with strict RoHS specifications, reflecting Tripp Lite’s
commitment to environmental responsibility.
1/4
U444-06N-H4-C USB 3.2 Gen 1
USB-C to HDMI 4K Adapter
Owner’s manual
Cleveland, OH 44122
United States
Specifications
OVERVIEW
UPC Code
037332193926
Product Type
USB-C Multiport Adapter
Technology
HDMI
Host Connector
USB C (MALE)
VIDEO
Video Input
USB C (MALE)
Video Output
HDMI (FEMALE)
Number of Monitors Supported
1
Video Ports
HDMI (FEMALE)
Video Ports Details
HDMI 1.4; HDCP 1.4; DisplayPort 1.2
Supported Resolutions
1280x720 (720p); 1920x1080 (1080p); 3840x2160 (4K)
Max Supported Video Resolution
3840 x 2160 (4K x 2K) @ 30Hz
3D Video Supported
Yes
INPUT
Bus Powered
Yes
BATTERY
Battery Charging (5V/1.5A Port)
No
POWER
USB Power Delivery (PD) Charging
Support
Yes
Specification
20V/3A; 60W
CHARGING
Number of Charging Ports
1
Total Charging Amps
3
Total Charging Watts
60
Charging Port Type
USB C (FEMALE)
Charging Ports Details
Provides up to 60W (20V/3A) of power to the host device via the PD Charging port
Charging Ports
USB-C: 60W (20V 3A) Power Delivery (PD 2.0)
2/4
Cleveland, OH 44122
United States
Charging Ports / Amps
3A
PHYSICAL
Color
White
Material of Construction
PVC, ABS
Cable Jacket Color
White
Cable Jacket Material
PVC
Cable Outer Diameter (OD)
3.9mm
Wire Gauge (AWG)
34 / 28
Number of Displays
1
Unit Dimensions (hwd / in.)
0.450 x 1.700 x 1.570
Unit Packaging Type
Box
Unit Weight (lbs.)
0.06
Unit Weight (kg)
0.03
ENVIRONMENTAL
Operating Temperature Range
32 to 113 F (0 to 45 C)
Storage Temperature Range
14 to 158 F (-10 to 70 C)
Operating Humidity Range
10% to 85% RH, Non-Condensing
Storage Humidity Range
5% to 90% RH, Non- Condensing
CONNECTIONS
Side A - Connector 1
USB C (MALE)
Side B - Connector 1
HDMI (FEMALE)
Connector Plating
Nickel
FEATURES & SPECIFICATIONS
HDCP Specification
1.4
USB Specification
USB 3.1 Gen 1 (up to 5 Gbps)
Driver Required
No
STANDARDS & COMPLIANCE
Product Compliance
RoHS; CE (Europe); REACH; FCC (USA)
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
3-year limited warranty
3/4
Cleveland, OH 44122
United States
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
4/4
很抱歉,暂时无法提供与“U444-06N-H4-C”相匹配的价格&库存,您可以联系我们找货
