PJ-047BH
PJ-047BH
    CUIDEVICES
    CONN PWR JACK 2.5X5.5MM SOLDER
PJ-047BH 数据手册
Additional Resources: Product Page date 02/22/2023 page 1 of 3 MODEL: PJ-047BH | DESCRIPTION: DC POWER JACK FEATURES • 2.5 mm center pin • 5.0 A rating • right angle orientation • through hole • shielded SPECIFICATIONS parameter conditions/description min rated input voltage typ max 24 units Vdc rated input current 5.0 A contact resistance 30 mΩ insulation resistance at 250 Vdc voltage withstand for 1 minute 100 insertion/withdrawal force 0.3 operating temperature -25 life MΩ 500 Vac 3 kg 85 5,000 flammability rating UL94V-0 RoHS yes °C cycles SOLDERABILITY parameter conditions/description min wave soldering dipped in solder pot for 4~6 seconds cuidevices.com typ 250 max units °C Additional Resources: Product Page CUI DEVICES | MODEL: PJ-047BH | DESCRIPTION: DC POWER JACK date 02/22/2023 | page 2 of 3 MECHANICAL DRAWING units: mm tolerance: ±0.30 mm PCB: ±0.05 mm unless otherwise specified DESCRIPTION MATERIAL PLATING/COLOR center pin brass nickel terminal 1 brass t=0.30 silver terminal 2 SUS301 t=0.30 silver terminal 3 brass t=0.30 silver shield brass t=0.25 nickel housing PBT (UL94V-0) black Recommended PCB Layout Top View 1 3 2 SCHEMATIC MATING PLUG Jack Insertion Depth: 8.2 mm Model PJ-047BH Center Pin Ø2.5 mm cuidevices.com Additional Resources: Product Page CUI DEVICES | MODEL: PJ-047BH | DESCRIPTION: DC POWER JACK date 02/22/2023 | page 3 of 3 REVISION HISTORY rev. description date 1.0 initial release 07/30/2007 1.01 shield plating material changed from Tin to Nickel 09/30/2009 1.02 applied new spec template 09/30/2013 1.03 increased voltage rating 04/14/2016 1.04 brand update 11/05/2019 1.05 logo, datasheet style update 08/05/2022 1.06 product reengineered for improved manufacturability and production yield, see PCN for details 02/22/2023 The revision history provided is for informational purposes only and is believed to be accurate. CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website. CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate and reliable. However, no responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may result from its use. CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness. cuidevices.com
PJ-047BH 价格&库存
很抱歉,暂时无法提供与“PJ-047BH”相匹配的价格&库存,您可以联系我们找货
PJ-047BH
    • 1+9.92520
    • 10+9.70920
    • 30+9.55800
    库存:9
