74LVC1G66
Bilateral switch
Rev. 10 — 7 December 2016
Product data sheet
1. General description
The 74LVC1G66 provides one single pole, single-throw analog switch function. It has two
input/output terminals (Y and Z) and an active HIGH enable input pin (E). When E is LOW,
the analog switch is turned off.
Schmitt-trigger action at the enable input makes the circuit tolerant of slower input rise and
fall times across the entire VCC range from 1.65 V to 5.5 V.
2. Features and benefits
Wide supply voltage range from 1.65 V to 5.5 V
Very low ON resistance:
7.5 (typical) at VCC = 2.7 V
6.5 (typical) at VCC = 3.3 V
6 (typical) at VCC = 5 V
Switch current capability of 32 mA
High noise immunity
CMOS low power consumption
TTL interface compatibility at 3.3 V
Latch-up performance meets requirements of JESD78 Class I
ESD protection:
HBM JESD22-A114F exceeds 2000 V
MM JESD22-A115-A exceeds 200 V
Enable input accepts voltages up to 5.5 V
Multiple package options
Specified from 40 C to +85 C and 40 C to +125 C
3. Ordering information
Table 1.
Type number
Package
Temperature range Name
Description
Version
74LVC1G66GW
40 C to +125 C
TSSOP5
plastic thin shrink small outline package; 5 leads;
body width 1.25 mm
SOT353-1
74LVC1G66GV
40 C to +125 C
SC-74A
plastic surface-mounted package; 5 leads
SOT753
74LVC1G66GM
40 C to +125 C
XSON6
plastic extremely thin small outline package; no leads;
6 terminals; body 1 1.45 0.5 mm
SOT886
74LVC1G66
Nexperia
Bilateral switch
Table 1.
Ordering information …continued
Type number
Package
Description
Version
74LVC1G66GF
40 C to +125 C
XSON6
6 terminals; body 1 1 0.5 mm
SOT891
74LVC1G66GN
40 C to +125 C
XSON6
6 terminals; body 0.9 1.0 0.35 mm
SOT1115
74LVC1G66GS
40 C to +125 C
XSON6
6 terminals; body 1.0 1.0 0.35 mm
SOT1202
4. Marking
Table 2.
Marking
Type number
Marking code[1]
74LVC1G66GW
VL
74LVC1G66GV
V66
74LVC1G66GM
VL
74LVC1G66GF
VL
74LVC1G66GN
VL
74LVC1G66GS
VL
[1]
The pin 1 indicator is located on the lower left corner of the device, below the marking code.
5. Functional diagram
PQD
DDJ
Fig 1.
Logic symbol
Fig 2.
IEC logic symbol
9&&
Fig 3.
DDP
Logic diagram
74LVC1G66
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2017. All rights reserved
2 of 25
74LVC1G66
Nexperia
Bilateral switch
6. Pinning information
6.1 Pinning
/9&*
/9&*
*1'
9&&
9&&
QF
*1'
9&&
QF
*1'
DDJ
DDJ
7UDQVSDUHQWWRSYLHZ
7UDQVSDUHQWWRSYLHZ
DDG
Fig 4.
/9&*
Pin configuration
SOT353-1 and SOT753
Fig 5.
Pin configuration SOT886
Fig 6.
Pin configuration SOT891
and SOT1115 and SOT1202
6.2 Pin description
Table 3.
Symbol
Pin description
Pin
Description
SOT353-1, SOT753 SOT886, SOT891, SOT1115 and SOT1202
Y
1
1
independent input or output
Z
2
2
independent output or input
GND
3
3
ground (0 V)
E
4
4
enable input (active HIGH)
n.c.
5
not connected
VCC
5
6
supply voltage
7. Functional description
Table 4.
Function table[1]
Input E
Switch
L
OFF-state
H
ON-state
[1]
H = HIGH voltage level; L = LOW voltage level
74LVC1G66
Product data sheet
3 of 25
74LVC1G66
Nexperia
Bilateral switch
8. Limiting values
Table 5.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
Conditions
[1]
VI
input voltage
IIK
input clamping current
VI < 0.5 V or VI > VCC + 0.5 V
ISK
switch clamping current
[2]
Min
Max
Unit
0.5
+6.5
V
0.5
+6.5
V
50
mA
50
mA
0.5
VCC + 0.5
V
VSW
switch voltage
enable and disable mode
ISW
switch current
VSW > 0.5 V or VSW < VCC + 0.5 V
50
mA
ICC
supply current
100
mA
IGND
ground current
100
mA
Tstg
storage temperature
65
+150
C
250
mW
total power dissipation
Ptot
Tamb = 40 C to +125 C
[3]
[1]
The minimum input voltage rating may be exceeded if the input current rating is observed.
[2]
The minimum and maximum switch voltage ratings may be exceeded if the switch clamping current rating is observed.
[3]
For TSSOP5 and SC-74A packages: above 87.5 C the value of Ptot derates linearly with 4.0 mW/K.
For XSON6 packages: above 118 C the value of Ptot derates linearly with 7.8 mW/K.
9. Recommended operating conditions
Table 6.
Symbol
Parameter
VCC
supply voltage
VI
input voltage
VSW
Conditions
[1]
switch voltage
Tamb
ambient temperature
t/V
input transition rise and
fall rate
Min
Typ
Max
Unit
1.65
5.5
V
V
VCC
V
40
+125
C
VCC = 1.65 V to 2.7 V
[2]
ns/V
VCC = 2.7 V to 5.5 V
[2]
10
ns/V
[1]
To avoid sinking GND current from terminal Z when switch current flows in terminal Y, the voltage drop across the bidirectional switch
must not exceed 0.4 V. If the switch current flows into terminal Z, no GND current will flow from terminal Y. In this case, there is no limit
for the voltage drop across the switch.
[2]
Applies to control signal levels.
74LVC1G66
Product data sheet
4 of 25
74LVC1G66
Nexperia
Bilateral switch
10. Static characteristics
Table 7.
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol Parameter
40 C to +85 C
Conditions
Min
HIGH-level
input voltage
VIH
LOW-level
input voltage
VIL
VCC = 1.65 V to 1.95 V
Typ[1]
40 C to +125 C Unit
Max
Min
Max
0.65VCC
0.65VCC
V
VCC = 2.3 V to 2.7 V
1.7
1.7
V
VCC = 2.7 V to 3.6 V
2.0
2.0
V
VCC = 4.5 V to 5.5 V
0.7VCC
0.7VCC
V
0.35VCC
0.7
0.7
V
0.8
0.8
V
0.35VCC V
0.3VCC
0.3VCC V
0.1
1
1
A
II
input leakage pin E; VI = 5.5 V or GND;
current
VCC = 0 V to 5.5 V
[2]
IS(OFF)
OFF-state
leakage
current
VCC = 5.5 V; see Figure 7
[2]
0.1
0.2
0.5
A
IS(ON)
ON-state
leakage
current
VCC = 5.5 V; see Figure 8
[2]
0.1
1
2
A
ICC
supply
current
VI = 5.5 V or GND;
VSW = GND or VCC;
VCC = 1.65 V to 5.5 V
[2]
0.1
4
4
A
ICC
additional
supply
current
pin E; VI = VCC 0.6 V;
VSW = GND or VCC; VCC = 5.5 V
[2]
5
500
500
A
CI
input
capacitance
2.0
pF
CS(OFF)
OFF-state
capacitance
6.5
pF
CS(ON)
ON-state
capacitance
11
pF
[1]
All typical values are measured at Tamb = 25 C.
[2]
These typical values are measured at VCC = 3.3 V.
74LVC1G66
Product data sheet
5 of 25
74LVC1G66
Nexperia
Bilateral switch
10.1 Test circuits
9&&
9&&
9,/
9,
9,+
,6
*1'
,6
92
*1'
9,
92
DDP
DDP
VI = VCC or GND and VO = GND or VCC.
Fig 7.
VI = VCC or GND and VO = open circuit.
Test circuit for measuring OFF-state leakage
current
Fig 8.
Test circuit for measuring ON-state leakage
current
10.2 ON resistance
Table 8.
ON resistance
At recommended operating conditions; voltages are referenced to GND (ground 0 V); for graphs see Figure 10 to Figure 15.
Symbol
Parameter
RON(peak) ON resistance (peak)
RON(rail)
ON resistance (rail)
40 C to +85 C
Conditions
40 C to +125 C Unit
Min
Typ[1]
Max
Min
Max
ISW = 4 mA;
34.0
130
195
ISW = 8 mA; VCC = 2.3 V to 2.7 V
12.0
30
45
ISW = 12 mA; VCC = 2.7 V
10.4
25
38
ISW = 24 mA; VCC = 3.0 V to 3.6 V
7.8
ISW = 32 mA; VCC = 4.5 V to 5.5 V
6.2
15
23
ISW = 4 mA;
8.2
18
27
7.1
16
24
6.9
14
21
6.5
12
18
5.8
10
15
ISW = 4 mA;
10.4
30
45
7.6
7.0
18
27
6.1
15
23
4.9
10
15
VI = GND to VCC; see Figure 9
VI = GND; see Figure 9
VI = VCC; see Figure 9
74LVC1G66
Product data sheet
6 of 25
74LVC1G66
Nexperia
Bilateral switch
Table 8.
ON resistance …continued
Symbol
RON(flat)
Parameter
40 C to +85 C
Conditions
ON resistance
(flatness)
40 C to +125 C Unit
Min
Typ[1]
Max
Min
Max
ISW = 4 mA;
26.0
5.0
3.5
2.0
1.5
[2]
VI = GND to VCC
[1]
Typical values are measured at Tamb = 25 C and nominal VCC.
[2]
Flatness is defined as the difference between the maximum and minimum value of ON resistance measured at identical VCC and
temperature.
10.3 ON resistance test circuit and graphs
PQD
521
ȍ
96:
9&&
9,+
9,
*1'
,6:
RON = VSW/ISW.
9,9
DDP
(1) VCC = 1.8 V.
(2) VCC = 2.5 V.
(3) VCC = 2.7 V.
(4) VCC = 3.3 V.
(5) VCC = 5.0 V.
Fig 9.
Test circuit for measuring ON resistance
74LVC1G66
Product data sheet
Fig 10. Typical ON resistance as a function of input
voltage; Tamb = 25 C
7 of 25
74LVC1G66
Nexperia
Bilateral switch
DDD
521
ȍ
DDD
521
ȍ
9,9
(1) Tamb = 125 C.
(1) Tamb = 125 C.
(2) Tamb = 85 C.
(2) Tamb = 85 C.
(3) Tamb = 25 C.
(3) Tamb = 25 C.
(4) Tamb = 40 C.
(4) Tamb = 40 C.
Fig 11. ON resistance as a function of input voltage;
VCC = 1.8 V
DDD
521
ȍ
9,9
Fig 12. ON resistance as a function of input voltage;
VCC = 2.5 V
DDD
521
ȍ
9,9
(1) Tamb = 125 C.
(2) Tamb = 85 C.
(2) Tamb = 85 C.
(3) Tamb = 25 C.
(3) Tamb = 25 C.
(4) Tamb = 40 C.
(4) Tamb = 40 C.
74LVC1G66
Product data sheet
9,9
(1) Tamb = 125 C.
Fig 13. ON resistance as a function of input voltage;
VCC = 2.7 V
Fig 14. ON resistance as a function of input voltage;
VCC = 3.3 V
8 of 25
74LVC1G66
Nexperia
Bilateral switch
DDD
521
ȍ
9,9
(1) Tamb = 125 C.
(2) Tamb = 85 C.
(3) Tamb = 25 C.
(4) Tamb = 40 C.
Fig 15. ON resistance as a function of input voltage; VCC = 5.0 V
11. Dynamic characteristics
Table 9.
At recommended operating conditions; voltages are referenced to GND (ground = 0 V); for test circuit see Figure 18.
Symbol Parameter
tpd
40 C to +85 C
Conditions
Min
Max
Min
Max
0.8
2.0
3.0
ns
0.4
1.2
2.0
ns
VCC = 2.7 V
0.4
1.0
1.5
ns
0.3
0.8
1.5
ns
0.2
0.6
1.0
ns
[2][3]
propagation delay Y to Z or Z to Y;
see Figure 16
ten
enable time
74LVC1G66
Product data sheet
40 C to +125 C Unit
Typ[1]
E to Y or Z; see Figure 17
[4]
1.0
5.3
12
1.0
15.5
ns
1.0
3.0
6.5
1.0
8.5
ns
VCC = 2.7 V
1.0
2.6
6.0
1.0
8.0
ns
1.0
2.5
5.0
1.0
6.5
ns
1.0
1.9
4.2
1.0
5.5
ns
9 of 25
74LVC1G66
Nexperia
Bilateral switch
Table 9.
Dynamic characteristics …continued
Symbol Parameter
40 C to +85 C
Conditions
Min
tdis
disable time
40 C to +125 C Unit
Max
Min
Max
[5]
1.0
4.2
10
1.0
13
ns
1.0
2.4
6.9
1.0
9.0
ns
VCC = 2.7 V
1.0
3.6
7.5
1.0
9.5
ns
1.0
3.4
6.5
1.0
8.5
ns
1.0
2.5
5.0
1.0
6.5
ns
VCC = 2.5 V
9.8
pF
VCC = 3.3 V
12.0
pF
VCC = 5.0 V
17.3
pF
power dissipation
capacitance
CPD
Typ[1]
[6]
CL = 50 pF; fi = 10 MHz;
VI = GND to VCC
[1]
[2]
tpd is the same as tPLH and tPHL
[3]
propagation delay is the calculated RC time constant of the typical ON resistance of the switch and the specified capacitance when
driven by an ideal voltage source (zero output impedance).
[4]
ten is the same as tPZH and tPZL
[5]
tdis is the same as tPLZ and tPHZ
[6]
CPD is used to determine the dynamic power dissipation (PD in W).
PD = CPD VCC2 fi N + {(CL + CS(ON)) VCC2 fo} where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
CS(ON) = maximum ON-state switch capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
{(CL + CS(ON)) VCC2 fo} = sum of the outputs.
11.1 Waveforms and test circuit
9,
90
很抱歉,暂时无法提供与“74LVC1G66GV,125”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 3000+0.34208
- 6000+0.34171
- 国内价格
- 5+0.67430
- 50+0.53890
- 150+0.47110
- 500+0.42030
- 3000+0.37960
- 6000+0.35930
- 国内价格
- 1+0.85150
- 30+0.81900
- 100+0.78650
- 500+0.72150
- 1000+0.68900
- 2000+0.66950
