INTEGRATED CIRCUITS
DATA SHEET
For a complete data sheet, please also download:
• The IC06 74HC/HCT/HCU/HCMOS Logic Family Specifications
• The IC06 74HC/HCT/HCU/HCMOS Logic Package Information
• The IC06 74HC/HCT/HCU/HCMOS Logic Package Outlines
74HC/HCT139
Dual 2-to-4 line
decoder/demultiplexer
Product specification
File under Integrated Circuits, IC06
September 1993
Philips Semiconductors
Dual 2-to-4 line decoder/demultiplexer
74HC/HCT139
FEATURES
GENERAL DESCRIPTION
• Demultiplexing capability
The 74HC/HCT139 are high-speed Si-gate CMOS devices
and are pin compatible with low power Schottky TTL
(LSTTL). It is specified in compliance with JEDEC
standard no. 7A.
• Two independent 2-to-4 decoders
• Multifunction capability
• Active LOW mutually exclusive outputs
The 74HC/HCT139 are high-speed, dual 2-to-4 line
decoder/multiplexers. This device has two independent
decoders, each accepting two binary weighted inputs
(nA0 and nA1) and providing four mutually exclusive active
LOW outputs (nY0 to nY3). Each decoder has an active
LOW enable input (nE).
When nE is HIGH, every output is forced HIGH. The
enable can be used as the data input for a 1-to-4
demultiplexer application.
The “139” is identical to the HEF4556 of the HE4000B
family.
• Output capability: standard
• ICC category: MSI
QUICK REFERENCE DATA
GND = 0 V; Tamb = 25 °C; tr = tf = 6 ns
TYPICAL
SYMBOL
PARAMETER
CONDITIONS
UNIT
HC
tPHL/ tPLH
propagation delay
HCT
CL = 15 pF; VCC = 5 V
nAn to nYn
11
13
ns
nE3 to nYn
10
13
ns
3.5
3.5
pF
42
44
pF
CI
input capacitance
CPD
power dissipation capacitance per multiplexer
notes 1 and 2
Notes
1. CPD is used to determine the dynamic power dissipation (PD in µW):
PD = CPD × VCC2 × fi + ∑ (CL × VCC2 × fo) where:
fi = input frequency in MHz
fo = output frequency in MHz
∑ (CL × VCC2 × fo) = sum of outputs
CL = output load capacitance in pF
VCC = supply voltage in V
2. For HC the condition is VI = GND to VCC
For HCT the condition is VI = GND to VCC − 1.5 V
APPLICATIONS
• Memory decoding or data-routing
• Code conversion
ORDERING INFORMATION
See “74HC/HCT/HCU/HCMOS Logic Package Information”.
September 1993
2
74HC/HCT139
PIN DESCRIPTION
PIN NO.
SYMBOL
NAME AND FUNCTION
1, 15
1E, 2E
enable inputs (active LOW)
2, 3
1A0, 1A1
address inputs
4, 5, 6, 7
1Y0 to 1Y3
outputs (active LOW)
8
GND
ground (0 V)
12, 11, 10, 9
2Y0 to 2Y3
14, 13
2A0, 2A1
address inputs
16
VCC
positive supply voltage
Fig.1 Pin configuration.
Fig.2 Logic symbol.
(a)
(b)
Fig.3 IEC logic symbol.
September 1993
3
Fig.4 Functional diagram.
FUNCTION TABLE
INPUTS
nE
nA0
OUTPUTS
nA1
nY0
nY1
nY2
nY3
H
X
X
H
H
H
H
L
L
L
L
L
H
L
H
L
L
H
H
L
H
H
H
H
L
H
H
H
H
L
H
H
H
H
L
Notes
1. H = HIGH voltage level
L = LOW voltage level
X = don’t care
Fig.5 Logic diagram (one decoder/demultiplexer).
September 1993
4
74HC/HCT139
74HC/HCT139
DC CHARACTERISTICS FOR 74HC
For the DC characteristics see “74HC/HCT/HCU/HCMOS Logic Family Specifications”.
ICC category: MSI
AC CHARACTERISTICS FOR 74HC
GND = 0 V; tr = tf = 6 ns; CL = 50 pF
Tamb (°C)
TEST CONDITIONS
74HC
SYMBOL PARAMETER
+25
min.
typ.
−40 to +85
max.
min.
max.
−40 to +125
min.
UNIT
VCC WAVEFORMS
(V)
max.
tPHL/ tPLH
propagation delay
nAn to Yn
39
14
11
145
29
25
180
36
31
220
44
38
ns
2.0
4.5
6.0
Fig.6
tPHL/ tPLH
propagation delay
nE to nYn
33
12
10
135
27
23
170
34
29
205
41
35
ns
2.0
4.5
6.0
Fig.7
tTHL/ tTLH
output transition
time
19
7
6
75
15
13
95
19
16
110
22
19
ns
2.0
4.5
6.0
Figs 6 and 7
September 1993
5
74HC/HCT139
DC CHARACTERISTICS FOR HCT
ICC category: MSI
Note to HCT types
The value of additional quiescent supply current (∆ICC) for a unit load of 1 is given in the family specifications.
To determine ∆ICC per input, multiply this value by the unit load coefficient shown in the table below.
INPUT
UNIT LOAD
1An
2An
nE
0.70
0.70
1.35
COEFFICIENT
AC CHARACTERISTICS FOR 74HCT
GND = 0 V; tf = tf = 6 ns; CL = 50 pF
Tamb (°C)
TEST CONDITIONS
74HCT
SYMBOL PARAMETER
+25
min.
typ.
−40 to +85
max.
min.
max.
−40 to +125
min.
UNIT
VCC WAVEFORMS
(V)
max.
tPHL/ tPLH
propagation delay
nAn to Yn
16
34
43
51
ns
4.5
Fig.6
tPHL/ tPLH
propagation delay
nE to nYn
16
34
43
51
ns
4.5
Fig.7
tTHL/ tTLH
output transition
time
7
15
19
22
ns
4.5
Figs 6 and 7
September 1993
6
74HC/HCT139
AC WAVEFORMS
(1) HC : VM = 50%; VI = GND to VCC.
HCT: VM = 1.3 V; VI = GND to 3 V.
Fig.6
Waveforms showing the address input (nAn) to output (nYn) propagation delays and the output transition
times.
Fig.7
Waveforms showing the enable input (nE) to output (nYn) propagation delays and the output transition
times.
PACKAGE OUTLINES
See “74HC/HCT/HCU/HCMOS Logic Package Outlines”.
September 1993
7
很抱歉,暂时无法提供与“74HC139D,653”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.96600
- 100+0.90160
- 300+0.83720
- 500+0.77280
- 2000+0.74060
- 5000+0.72128
