109E2024S001
109E2024S001
    SANYODENKI
    FAN200X70MM24VDCRBLSTACH
109E2024S001 数据手册
DC Fan 200 San Ace 200 φ 70mm thick (Round type) 70mm thick mm ■ General Specifications With a pulse sensor Specifications for pulse sensors Refer to Page 309 ・Material …………………… Frame: Aluminum, Impeller:Plastics (Flammability: UL94V-1) ・Expected Life …………… Varies for each model(L10:Survival rate:90% at 60℃ , rated voltage, and continuously run in a free air state) ・Lead Wire ………………… 䊝red 䊞black or blue Sensor yellow ・Storage Temperature …−30℃ to +70℃(Non-condensing) Power on when current is shut off. Do not power on 10sec or more after power off. 200mm×70mm φ ■ Specifications Round type Rated Voltage Operating Voltage Range Rated Current Rated Input Model No. 109E2024AS001 24 Max. Air Flow [A] [W] [min-1] [m³/min] [CFM] 21.6 to 26.4 20.4 to 27.6 1.9 1.0 1.9 1.45 1.0 0.63 45.6 24 45.6 34.8 24 15.12 3,200 2,600 3,200 2,800 2,600 2,100 10.45 8.2 10.45 9 8.2 6.7 369 289.5 369 317.8 289.5 236.6 21.6 to 26.4 109E2024MH001 Rated Speed [V] [V] 109E2024S001 109E2024H001 Without Sensor 〔Mass:1800g〕 The MH speed and AS speed are two speeds. 20.4 to 27.6 Pulse Sensor Available upon request for all the models above. Max. Static Pressure 287.1 192 287.1 215.6 192 115.4 330±20 0 70 ー1 (10) 0 φ200 ー1 188.4±0.3 Lead Wire リード線 AWG22 UL1007 7.5±0.4 7.5±0.4 188.4±0.3 Rotating Direction 回転方向 Air風吹出方向 Flow Direction ■ Reference dimension of mounting holes and vent opening(Unit : mm) Inlet side, Outlet side 4- 8- R5 188.4 φ 19 4 188.4 R2 4-φ4.5 167 1.153 0.771 1.153 0.865 0.771 0.463 57 51 57 54 51 45 Operating Temperature Expected Life [℃] [h] −10 to +70 40,000 Lock Sensor Please inquire as the availability of these functions depend on the model. ■ Dimensions(Unit : mm) 8-φ4.5±0.3 Mounting 取付用穴 Hole SPL [Pa] [inchH²O] [dB(A)] ■ Options(Unit : mm) Finger guards Color Surface treatment :Nickel-chrome plating(silver) :Cation electropainting(black) Color Surface treatment :Nickel-chrome plating(silver) :Cation electropainting(black) Model:109-721 :109-721H Inlet side, Outlet side Outlet side 4 88. φ1 78 φ1 4 88. φ1 71 φ1 +0.4 4.3 ー0.2 φ1.6 8  0 ー1 +0.4 4.3 ー0.2 φ1.6 DC Fan 200mm Model:109-720 :109-720H ー1 3.2  0 φ1.6 +1 194.5 ー0.5 φ178 194.5 +1 ー0.5 φ1.6 ■ Signal connection type VS VS + + Brushless ブラシレス VC Control fan VCコン トロール DC DCファン Brushless ブラシレス VC Control fan VCコン トロール DC DCファン IC=2mA MAX. IC=2mA MAX. − − ■ Air Flow - Static Pressure Characteristics S speed 200 27.6V 0.6 0.4 150 24V 20.4V 100 0.2 50 0 0 1 2 3 4 5 6 7 8 9 10 (m3/min) 0 50 100 150 200 250 300 350 (CFM) (inch H2O) (Pa) 1.4 350 1.2 300 26.4V 1.0 250 24V 0.8 200 0.6 150 0.4 100 0.2 50 0 0 21.6V 1 2 3 4 5 6 7 8 9 10 11 12 109E2024H001 (m3/min) 0 50 100 150 200 250 300 350 400 450 (CFM) → Air Flow → 風量 → Air Flow → 風量 → Static Pressure → 静圧 0.8 250 → Static Pressure → 静圧 → Static Pressure → 静圧 1.0 MH Two-speed (inch H2O)(Pa) 109E2024S001 1.0 250 0.8 200 0.6 150 0.4 100 0.2 50 0 0 24V 高速回転 High rotation 24V 低速回転 Low rotation 1 2 3 4 5 6 7 8 9 10 (m3/min) 0 50 100 150 200 250 300 350 (CFM) →→ Air風量 Flow 109E2024MH001 AS Two-speed → Static Pressure → 静圧 (inch H2O) (Pa) 1.4 350 1.2 300 1.0 250 24V rotation 24V High 高速回転 0.8 200 24V rotation 24V Low 低速回転 0.6 150 0.4 100 0.2 50 0 0 1 2 3 4 5 6 7 8 9 10 11 12 (m3/min) 0 50 100 150 200 250 300 350 400 450 (CFM) →→ Air風量 Flow 109E2024AS001 168 200mm H speed (inch H2O)(Pa)
109E2024S001 价格&库存
很抱歉,暂时无法提供与“109E2024S001”相匹配的价格&库存,您可以联系我们找货
