FBK04F24H
FBK04F24H
    NMBTECHNOLOGIESCORPORATION
    FAN AXIAL 40X20MM 24VDC WIRE
FBK04F24H 数据手册
10 FBK04F (40mm) (black) + 300 (red) - 4-ø3.5 FLOW 40 32 Panaflo 20 40 FLOW ROTATION 38.4 4-ø3.5 32 9 32 ø3 38.4 Panaflo ROTATION CUT OUT 32 Inlet/Outlet Features • Operating Temperature: -10°C — +70°C (65% RH) • Locked rotor protection and auto-start function • Storage Temperature: -40°C — +75°C (65% RH) • Lower circuit noise • Bearing Type: Ball • Optional third lead wire signal ( Locked rotor alarm sensor) Basic Data (nominal at room temperature) 6 Rated Voltage (V) Operating Voltage (V) Rated Current (mA) Rated Input (W) Nominal Speed (r/min) Maximum Air Flow FBK04F05L 5 4.5 — 6.0 120 .060 4700 0.11 3.9 2.50 24.5 24.0 FBK04F05H 5 4.5 — 6.0 280 1.40 7500 0.19 6.7 6.60 64.7 33.0 FBK04F12L 12 7.0 — 13.8 75 0.90 4700 0.11 3.9 2.50 24.5 23.0 FBK04F12H 12 7.0 — 13.8 150 1.80 7500 0.19 6.7 6.60 64.7 32.0 FBK04F12U 12 7.0 — 13.8 170 2.04 9500 0.26 9.2 12.00 117.7 42.0 FBK04F24H 24 14.0 — 27.6 92 2.21 7500 0.19 6.7 6.60 64.7 33.0 FBK04F24U 24 14.0 — 27.6 100 2.40 9500 0.26 9.2 12.00 117.7 42.0 (m3/min) (CFM) Maximum Air Pressure (mmH2O) (Pa) Noise (dB-A) FBK04F (40mm) 0.3 10 5 0.2 0.3 10 5 (m3/min) Air Pressure 12V (24V) 10.0 7V (14V) (r/min) Nominal Speed N 10.2V (20.4V) 7V (14V) 2.5 0 0.1 0.2 0.3 10 5 (m3/min) (CFM) Air Flow P— Q P N 5.0 0 Conversion Factors 12V (24V) 5.0 15.0 10.2V (20.4V) 50 50 Q 13.8V (27.6V) 100 13.8V (27.6V) (CFM) FBK04F12U/FBK04F24U (CFM) Air Flow FBK04F12H/FBK04F24H Air Flow (r/min) (mmH20) (Pa) N P 0.1 Q 150 7.5 25 7V 0 7.5 10.2V) 2.5 10 (m3/min) N 5.0 0.3 5 (mmH20) FBK04F12L 12V 25 0.2 Q 13.8V 50 (mmH20) (CFM) (Pa) 7.5 0.1 Air Flow (r/min) (mmH20) 7.5 Air Pressure Case Quantity: 150 per box (Pa) Weight 40 grams (1.41 ounces) 0 Air Pressure Q (m3/min) (r/min) 0.2 4.5V 2.5 P N 0.1 5V 25 Nominal Speed 0 5.0 Nominal Speed Size 40.0 x 40.0 x 20.0 (1.57 x 1.57 x 0.79) (Pa) 4.5V 2.5 6V 50 Nominal Speed 5V 25 7.5 Air Pressure 5.0 P Housing and Fan Blade: Plastic (PET, PBT) 6V 50 7.5 FBK04F05H P 7.5 (r/min) 7.5 FBK04F05L Nominal Speed (mmH20) Lead Wire All lead wires are 300mm in length ± 15 mm. (bare wire 10mm ± 5mm.) Air Pressure All dimensions in mm. (Pa) Characteristics 0.1 0.2 10 5 Q 0.3 (m3/min) (CFM) Air Flow 1 mm H2O = 9.8 PA 1 m3/min = 35.313 CFM 7
FBK04F24H 价格&库存
很抱歉,暂时无法提供与“FBK04F24H”相匹配的价格&库存,您可以联系我们找货
