GC123506BH-8DA.05.N.B515 数据手册
SUNON
SPECIFICATION FOR APPROVAL
CUSTOMER
:INTEL/USA
MODEL
NO
:GC123506BH-8
P/N
: DA.05.N.B515
DESCRIPTION :3D VGA CARD COOLER
:38X38X8mm
DIMENSIONS
APPROVED NO :
(AUTHORIZED)
APPROVED BY :
Drafted by
Fanny 2/27
Checked by
Jessica
Kiddy
Appd. by
Winner
SPEC. NO
Y202017
ISSUED DATE
02. 27. 2003
EDITION
建準電機工業股份有限公司
SUNONWEALTH ELECTRIC MACHINE INDUSTRY CO., LTD.
12FL., 120 CHUNG CHENG 1ST RD.,
TEL:886-7-7163069(41 LINES)
FAX:886-7-7163086~89
KAOHSIUNG, TAIWAN, R. O. C.
SUNON
MODEL NUMERING SYSTEM
GC
12
35
06
B
H
8
CAP FAN SERIRS
GC:Green Motor CAP Fan
MOTOR POLES
:8 POLES
8
BLANK:4 POLES
VOLTAGE
05 : 5VDC
12 : 12VDC
24 : 24VDC
SPEED
H : HIGH
M: MIDDLE
L : LOW
FAN SIZE
35 : 35 mm
04 : 40 mm
FAN
06 :
07 :
10 :
THICKNESS
6 mm
7 mm
10mm
P/N :
DA
BEARING SYSTYEM
B : BALL
S : SLEEVE
V : VAPO
05
CAP FAN SIZE
N
SMALLER HUB
DA :38X38x8mm With Groove
COOLER SIZE
05 : 38X38X6 mm Heat Sink
建準電機工業股份有限公司
PAGE
1
SPEC. NO.
Y202017
ISSUED DATE
02. 27. 2003
EDITION
SUNON
3D CARD COOLER SERIES
:GC123506BH-8
MODEL:
P/N
: DA.05.N.B515
SPECIFICATIONS
1.Plastic Material of Cap Fan
Polybutylene Terephthalate (PBT)/Black Color
2.Bearing System
Ball Bearing System
3.Rated Voltage (VDC)
12 VDC
4.Operating Voltage Range(VDC)
6~13.8 VDC
5.Starting Voltage (VDC)
5 VDC
6.Rated Current (AMP)
0.10 AMP
7.Rated Power (WATTS)
1.2 WATTS
8.Rated Speed (RPM)
8800 RPM ± 10%
9.Noise Level (dBA)
32 dB(A)
10.Air Delivery (CFM)
6.0 CFM
11.Static Pressure (Inch-H2O)
0.16 Inch-H2O
12.Operating Temperature
-10℃~+70℃
13.Storage Temperature
-40℃~+70℃
14.Insulation Resistance
More than 500M ohm
15.Heat Sink Size
38X38X6mm
16.Heat Sink Material
Aluminum alloy 6063 T5
17.Input Power
10 W
18.Thermal Resistance
2.29 ℃/W
19.Weight
11g
建準電機工業股份有限公司
PAGE
2
SPEC. NO.
Y202017
ISSUED DATE
02. 27. 2003
EDITION
SUNON
3D VGA CARD Cooler Thermal Resistance testing
A. Purpose : The measurement of total thermal resistance for the Cooler
B. Test Conditions : Input power 10W, temperature of environment 45℃
C. Results of the test :
environment Temperature (Ta)
Total Thermal Resistance (℃/W)
45℃
2.29
△T Chart
△T (℃)
60
50
40
30
10
15
30
35
40
45
50
55
60
Time(Minutes)
建準電機工業股份有限公司
PAGE
3
SPEC. NO.
Y202017
ISSUED DATE
02. 27. 2003
EDITION
SUNON
DIMENSION
建準電機工業股份有限公司
PAGE
4
SPEC. NO.
Y202017
ISSUED DATE
02. 27. 2003
EDITION
SUNON
Manufacturing Assembly Flow
建準電機工業股份有限公司
PAGE
5
SPEC. NO.
Y202017
ISSUED DATE
02. 27. 2003
EDITION
SUNON
Notes
Ⅰ. Safety
1. We will not guarantee the products if your application exceeds the limitation
mentioned in this specification.
2. There is no thermo-protector installed in this product, such as thermo-fuse, or
current-fuse or thermo-protector. There may be smoking, ignition or electric
shock by insulation degradation in cases of motor lock, motor lead short
circuit,
over load, over voltage or other failure. Please add the protection
circuit on your machine.
3. Due to the diode of reverse-connected prevention of VDC(+) and GND(-)
is not installed in this product. Therefore, if VDC(+)and GND(-) are
connected reversely, it may get smoking and destruction, moreover there is
danger of the ignition. Even though it does not find the breakdown while
reverse connecting, please still do not connected it reversely, because parts
may be deteriorate. We recommend to install the protection device for the
motor on your product side when there is a possibility to reverse-connect.
4. Please check the safety of your product carefully when installing our products
into your machine
i) To make sure the safety of the motor in compliance with your application
standard.
ii) If problem happens, please inform us before your machines are shipped
into the market.
5. Please carefully handle and install this product. Hit or drop may cause
damage.
6. Please do not damage this product including coil and lead wires while
installing or wiring. There may be smoking or fire.
建準電機工業股份有限公司
PAGE
6
SPEC. NO.
Y202017
ISSUED DATE
02. 27. 2003
EDITION
SUNON
Notes
Ⅱ.Specification modification
1.We are able to counsel about the cooling system design and fan installation.
2.Any change to the parameters specified in this document will be determined
by mutual agreement on both parities.
3.Any parameters in this specification will not be modified without your
approval. Other parameters which are not mentioned in this specification will
be the same as the final sample which has been approved by your company.
4.If you think there is a essential to discuss a certain parameter in this
specification which was not be considered, please inform us in advance.
Otherwise we shall deem that there is no problems associate with this
specification, and start shipment in accordance with this specification.
5.Any characteristics which have been modified during or after mutual
discussion by both parties,or in any other occasions should be incorporated in
this specification, and we shall take them to be our final guaranteed
parameters.
6.Please inform us in advance if you are going to modify your machine or
operate our products onto other application, because we will need to do a reinvestigation .
建準電機工業股份有限公司
PAGE
7
SPEC. NO.
Y202017
ISSUED DATE
02. 27. 2003
EDITION
SUNON
Notes
Ⅲ.Others
1.When build in your model, please check throughly on the variation of this
product in association to the matching of performance, EMC, temperature rise,
setting, life, and the quality level by dropping and shock testing, etc. If there are
any problems or accidents in connection with this product, it should be
discussed and examined mutually.
2.Fan holders or bearings might get damaged if you touch the fan with fingers or
other objects. Please handle this product cautiously.
3.Please pay attentions during handling this product, since static electricity might
damage the internal circuit parts.
4.Please avoid operating our product in poisonous material (such as organic
silicon, cyanogens, formalin, phenol, etc.) or corrosion gas environments.(as
H2S, SO2, NO2, Cl2, etc.) Please check carefully if there is any above
substances.
5.We can not take any warranty for performance safety regarding accident
caused by dust, water, droplets, dew, bugs, etc. Please ensure well in advance.
6.Please advice us in advance if you require documents for export.
7.Please install this product precisely, as unfit mounting may cause harsh
resonance, vibration and noise.
8.When it comes to test, safety is always the top priority. Please furnish some
guard accessories to prevent personnel from getting injury.
9.Unless otherwise notice, all tests are conducted at 25℃ambient temperature and
65% relative humidity.
10.Always ensure that fans are stored according to the storage temperatures
specified. Do not store in an environment with a high humidity. If the fans were
stored for longer than 6 months,it is highly recommended to apply functional
testing before shipping.
11.In order to satisfy the mass production requirements, it is necessary to have
more than two suppliers. Therefore, parts with the equivalent specification but
different source can be accepted and used after being approved by SUNON.
建準電機工業股份有限公司
PAGE
8
SPEC. NO.
Y202017
ISSUED DATE
02. 27. 2003
EDITION
