AS1313-BTDM-18
AS1313-BTDM-18
    AMSOSRAM(艾迈斯半导体)
    UFQFN8_EP
    ICREGBCK1.8V0.15ASYNC8MLPD
AS1313-BTDM-18 数据手册
AS1313 Ultra Low Quiescent Current, DC-DC Step Down Converter General Description The AS1313 is an ultra-low quiescent current hysteretic step-down DC-DC converter optimized for light loads and with efficiencies of up to 95%. AS1313 operates from a 2.4V to 5.5V supply and supports output voltages between 1.2V and 3.6V. Besides the available AS1313 standard variants, any variant with output voltages in 50mV steps are available. In order to save power the AS1313 features a shutdown mode, where it draws less than 100nA. During shutdown mode the battery is disconnected from the output. In light load operation, the device enters an idle mode when most of the internal operating blocks are turned off in order to save power. This mode is active approximately 100μs after a current pulse provided that the output is in regulation. The capacitor connected to the REF pin is an essential part of this feature. The AS1313 is available in an 8-pin MLPD (2mm x 2mm) and a 6-pin WL-CSP (0.4mm pitch). Ordering Information and Content Guide appear at end of datasheet. Key Benefits & Features The benefits and features of AS1313, Ultra Low Quiescent Current, DC-DC Step Down Converter are listed below: Figure 1: Added Value of using AS1313 Benefits Features Ideal for single Li-Ion battery powered applications Wide Input Voltage Range (2.4V to 5.5V) Extended battery life High Efficiency up to 95% Less Power Consumption Low Quiescent Current of typ. 1μA Low Shutdown Current of less than 100nA Supports a variety of end applications Fixed output voltage range (1.2V to 3.6V) Output Current of 150mA Over – temperature protection and shutdown Integrated temperature monitoring Cost effective, small package 6-pin WL-CSP with 0.4mm pitch 8-pin MLPD (2mm x 2mm) ams Datasheet, Confidential: 2014-Jun-12 [v1-42] AS1313 – 1 General Description Applications The AS1313 is an ideal solution for Li-Ion and coin cell powered devices as: • Blood glucose meters • Remote controls • Hearing aids • Wireless mouse or any light-load application Block Diagram The functional blocks of this device for reference are shown below: Figure 2: AS1313 Block Diagram VIN 2.4V to 5.5V VIN CIN 22µF AS1313 ON EN UVLO PDRV OFF L1 6.8µH Int LDO LX Logic VOUT NDRV Ipk Det REF REF CREF 100nF Zero Cross Det OUT COUT 22µF Overtemp Shdn GND AS1313 – 2 ams Datasheet, Confidential: 2014-Jun-12 [v1-42] Pi n A s s i g n m e n t The AS1313 pin assignment is described below. Pin Assignment Figure 3: Pin Assignment for MLPD and WL-CSP Pin A1 indicator PWR_GND 1 LX 2 8 GND 7 REF 6 OUT AS1313 MLPD 8-pin 2x2mm 3 PWR_VIN Exposed pad: GND 4 VIN 5 9 A1 OUT A2 REF A3 LX B1 EN B2 VIN B3 GND EN Pin Assignment: Shows the TOP view pin assignment of the AS1313. Figure 4: Pin Description Pin Number Pin Name Pin Type Description MLPD WLP 1 - PWR_GND GND 2 A3 LX DO 3 - PWR_VIN S Power Input Supply. Connect to VIN; only available in MLPD package 4 B2 VIN S Battery Voltage Input. Decouple VIN with a 22μF ceramic capacitor as close as possible to VIN and GND. Ground. Connect to GND; only available in MLPD package Switch Node Connection to Coil. This pin connects to the drains of the internal main and synchronous power MOSFET switches. 5 B1 EN DI Enable Input. Logic controlled shutdown input. 1 = Normal Operation 0 = Shutdown Note: This pin should not be left floating. 6 A1 OUT AI Output Voltage. An internal resistor divider steps the output voltage down for comparison to the internal reference voltage. 7 A2 REF AIO Reference. Connect a 100nF capacitor to this pin 8 B3 GND GND Ground 9 - GND Exposed Pad. This pad is not connected internally. This pin also functions as a heat sink. Solder it to a large pad or to the circuit-board ground plane to maximize power dissipation. ams Datasheet, Confidential: 2014-Jun-12 [v1-42] AS1313 – 3 Absolute Maximum Ratings Absolute Maximum Ratings Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only. Functional operation of the device at these or any other conditions beyond those indicated under “Operating Conditions” is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. Figure 5: Absolute Maximum Ratings Symbol Parameter Min Max Units Comments Electrical Parameters Supply Voltage to Ground 5V pins -0.3 7.0 V Applicable for pins: VIN, PWR_VIN, VOUT, EN Supply Voltage to Ground 5V pins -0.3 VOUT + 0.3 V Applicable for pins: LX, REF Voltage Difference between Ground Terminals -0.3 0.3 V Applicable for pins: GND, PWR_GND, Exposed Pad Input Current (latch-up immunity) -100 100 mA Norm: JEDEC JESD78 kV Norm: JEDEC JESD22-A114F Electrostatic Discharge VESD-HBM AS1313 – 4 HBM ±2 ams Datasheet, Confidential: 2014-Jun-12 [v1-42] Absolute Maximum Ratings Symbol Parameter Min Max Units Comments Temperature Ranges and Storage Conditions θJA (1) Thermal Resistance TAMB Operating Temperature TJ Junction Temperature WL-CSP 95 °C/W MLPD 36 °C/W +85 °C WL-CSP +125 °C MLPD +150 °C +125 °C -40 Storage Temperature Range -55 Norm IPC/JEDEC J-STD-020 (2) WL-CSP TBODY Package Body Temperature +260 °C 85 % MLPD Humidity non-condensing 5 Norm IPC/JEDEC J-STD-020 (2) The lead for Pb-free leaded packages is matte tin (100% Sn) WL-CSP 1 Represents an unlimited floor life time MLPD 1 Represents an unlimited floor life time Moisture Sensitive Level Note(s) and/or Footnote(s): 1. Junction-to-ambient thermal resistance is very dependent on application and board-layout. In situations where high maximum power dissipation exists, special attention must be paid to thermal dissipation during board design. 2. The reflow peak soldering temperature (body temperature) is specified according IPC/JEDEC J-STD-020 “Moisture/Reflow Sensitivity Classification for Nonhermetic Solid State Surface Mount Devices”. ams Datasheet, Confidential: 2014-Jun-12 [v1-42] AS1313 – 5 Electrical Characteristics Electrical Characteristics All limits are guaranteed. The parameters with min and max values are guaranteed with production tests or SQC (Statistical Quality Control) method. Figure 6: Electrical Characteristics Symbol VIN VOUT VOUT_TOL Parameter Conditions Typ Max Unit Input Voltage VIN, PWR_VIN 2.4 5.5 V 1.2 3.6 V Regulated Output Voltage 3.6V ≤ VIN ≤ 5.5V (VIN ≥ VOUT + 0.5V) 2.4V < VIN < 3.6V 1.2 VIN – 0.5V V IOUT = 10mA, TAMB = +25°C -3 +3 % IOUT = 10mA -4 +4 % 2 μA 100 nA Output Voltage Tolerance IQ Quiescent Current VOUT = 1.03 x VOUTNOM no load, TAMB = +25°C ISHDN Shutdown Current VEN = 0V TAMB = +25°C LNR Min Output Voltage Line Regulation 0.35 1 Vin = 2.4V to 5.5V IOUT = 100mA 0.2 %/V Vin = 3.5V to 5.5V IOUT = 100mA 0.05 %/V LDR Output Voltage Load Regulation IOUT = 0 to 100mA 0.02 %/mA IPK Peak Coil Current VIN = 3V, TAMB = +25°C VOUT = 0.9 x VOUTNOM 400 mA ILOAD Load Current VIN ≥ VOUT + 0.5V RPMOS P-Channel FET RDS(ON) ILX = 100mA 0.4 Ω RNMOS N-Channel FET RDS(ON) ILX = -100mA 0.4 Ω AS1313 – 6 150 mA ams Datasheet, Confidential: 2014-Jun-12 [v1-42] Electrical Characteristics Symbol ILX Parameter Conditions LX Leakage VEN = 0V, VLX = 0V or 5V logic threshold pin EN VENH Min Typ Max ±0.01 Unit μA 1.2 V VENL 0.2 V IEN EN Input Bias Current EN = 3.6V TAMB = +25°C 100 nA IREF REF Input Bias Current REF = 0.99 x VOUTNOM TAMB = +25°C 100 nA TSHDN Thermal Shutdown 150 °C ΔTSHDN Thermal Shutdown Hysteresis 25 °C Electrical Characteristics: Shows the Electrical Characteristics of the DCDC Converter. VIN = EN = 3.6V, TAMB = –40 to +85°C (unless otherwise specified). ams Datasheet, Confidential: 2014-Jun-12 [v1-42] AS1313 – 7 Ty p i c a l O p e r a t i n g C h a r a c t e r i s t i c s Typical Operating Characteristics Figure 7: Efficiency vs. Output Current, VOUT = 1.8V Vin = 2.4V Vin = 2.6V Vin = 2.8V Vin = 3.0V Vin = 3.3V 0,1 1 10 100 100 95 90 85 80 75 70 65 60 55 50 45 40 35 30 25 20 0,01 Efficiency (%) Efficiency (%) 100 95 90 85 80 75 70 65 60 55 50 45 40 35 30 25 20 0,01 1000 Vin = 4.0V Vin = 4.5V Vin = 5.0V Vin = 5.5V 0,1 Output Current (mA) 1 10 100 1000 Output Current (mA) Efficiency vs. Output Current: These figures show the Efficiency vs. the Output Current for various Input Voltages. All measurements were done with VOUT = 1.8V at TAMB = 25°C with the coil LPS4018-682. Figure 8: Efficiency vs. Output Current, VOUT = 3.0V 100 95 90 85 80 75 70 65 60 55 50 45 40 35 30 25 20 0,01 Efficiency (%) Efficiency vs. Output Current: This figure shows the Efficiency vs. the Output Current for various Input Voltages. All measurements were done with VOUT = 3.0V at TAMB = 25°C with the coil LPS4018-682. Vin = 3.5V Vin = 4.0V Vin = 4.5V Vin = 5.0V 0,1 1 10 100 1000 Output Current (mA) AS1313 – 8 ams Datasheet, Confidential: 2014-Jun-12 [v1-42] Ty p i c a l O p e r a t i n g C h a r a c t e r i s t i c s Figure 9: Maximum Output Current vs. Input Voltage Maximum Output Current vs. Input Voltage: This figure shows the IOUT_MAX vs. the Input Voltage for VOUT = 1.8V and VOUT = 3.0V at TAMB = 25°C with the coil LPS4018-682. 0,3 Iout_max (A) 0,25 0,2 0,15 0,1 Ioutmax @ 1.8V 0,05 Ioutmax @ 3.0V 0 2 3 4 5 6 5 6 Input Voltage (V) Figure 10: Efficiency vs. Input Voltage, VOUT = 1.8V 100 90 80 Efficiency (%) Efficiency vs. Input Voltage: This figure shows the Efficiency vs. the Input Voltage for various Output Currents. All measurements were done with a VOUT = 1.8V at TAMB = 25°C with the coil LPS4018-682. 70 60 50 40 30 20 10 Iout = 10uA Iout = 100uA Iout = 1mA Iout = 10mA Iout = 100mA 0 2 3 4 Input Voltage (V) ams Datasheet, Confidential: 2014-Jun-12 [v1-42] AS1313 – 9 Ty p i c a l O p e r a t i n g C h a r a c t e r i s t i c s Figure 11: Efficiency vs. Input Voltage, VOUT = 3.0V 100 90 80 Efficiency (%) Efficiency vs. Input Voltage: This figure shows the Efficiency vs. the Input Voltage for various Output Currents. All measurements were done with a VOUT = 3.0V at TAMB = 25°C with the coil LPS4018-682. 70 60 50 40 Iout = 10uA 30 Iout = 100uA 20 Iout = 1mA Iout = 10mA 10 Iout = 100mA 0 2 3 4 5 6 Input Voltage (V) Figure 12: Quiescent Current vs. Input Voltage, VOUT = 1.8V Quiescent Current vs. Input Voltage: This figure shows the Quiescent Current vs. the Input Voltage for VOUT = 1.8V. The measurement was done at TAMB = 25°C with the coil LPS4018-682. 1,1 1 Quiescent Current (uA) 0,9 0,8 0,7 0,6 0,5 0,4 0,3 0,2 2 2,5 3 3,5 4 4,5 5 5,5 6 Input Voltage(V) AS1313 – 10 ams Datasheet, Confidential: 2014-Jun-12 [v1-42] Detailed Description The AS1313 is a hysteretic converter and has no continuously operating fixed oscillator, providing an independent timing reference. This means the triggering of the on-off switching of the internal switches depends only on comparators measuring the output voltage and the coil current measurement. This lead to a very low quiescent current. In addition, because there is no fixed timing reference, the operating frequency is determined by external components (inductor and capacitors) and the loading on the output. Detailed Description Ripple at the output is an essential operating behavior. A power cycle is initiated when the output regulated voltage drops below the nominal value of V OUT. Figure 13: Simplified Synchronous Step-down DCDC Architecture L1 ICOIL_on SW1 IPK VIN ICOIL_on VCOIL_on ICOIL_off VIN CIN VCOIL_off COUT SW2 GND VOUT ICOIL_off RLOAD VOUT FB IZERO 0V 0V When SW1 is closed and SW2 is open, the current is flowing from VIN through the coil to R LOAD. With neglecting the resistive voltage drop over SW1 the voltage across the coil is: V COIL – on = V IN – V OUT Based on the expression, which shows the correlation between voltage across the coil and the coil current, it's easy to rearrange this equation to get the coil current I COIL generated while SW1 is closed (tON). (EQ1) di u = L -----  I COIL dt ams Datasheet, Confidential: 2014-Jun-12 [v1-42] V IN – V OUT =  ------------------------------ ⋅ t ON L AS1313 – 11 Detailed Description When SW1 is open and SW2 is closed, the coil gets discharged, works like a voltage supply and forces the current through RLOAD and SW2. With neglecting the resistive voltage drop over SW2 the voltage across the coil is: V COIL – off = V OUT Similar to the expression above, the I COIL generated while SW2 is closed (tOFF) can be expressed as: (EQ2) V OUT I COIL = -------------- ⋅ t OFF L The increasing coil current during the charging (SW1 closed) and the decreasing coil current during the discharging of the coil (SW2 closed) must be the same. Hence, it’s easy to calculate the duty cycle of SW1. (EQ3) t ON V IN – V OUT V OUT V OUT I COIL = ------------------------------ ⋅ t ON =  -------------- ⋅ t OFF   -------------- = -------------------------- L L V IN t ON + t OFF Based on the EQ1, the on time of SW1 can be given by: (EQ4) L t ON = ------------------------------ ⋅ I COIL V IN – V OUT Figure 14: Simplified Voltage and Current Diagram V VIN VIN VCOIL A A VOUT_ripple VOUT_nom VIDLE 0 VCOIL B C D B -VOUT t I IPK 400mA ICOIL ILOAD 0 tON tOFF SW1 on SW2 off SW1 off SW2 on tWAIT tIDLE SW1 off SW2 off tON tOFF SW1 on SW2 off SW1 off SW2 on t Timing Diagram: This figure shows the relationship between the current and the voltages inside the loop within the switching cycle. AS1313 – 12 ams Datasheet, Confidential: 2014-Jun-12 [v1-42] Detailed Description If the V OUT falls below the V OUT_nom, SW1 closes and the coil current increases until the max. coil current of 400mA is reached. During this time tON, the V OUT increases. With reaching the 400mA, the switch SW1 opens immediately, the SW2 closes and the coil current decreases down till it reaches the zero line. After this, SW2 opens and if the V OUT is then above the V OUT_nom, no further pulse is needed, both switches remain in their open position, hence no coil current is flowing. In this phase the needed output power only comes out of the COUT. This time is called t WAIT, which takes ~100us. If the V OUT falls below V OUT_nom within the time t WAIT, the SW1 closes and the charging cycle starts again. If the V OUT is still higher than V OUT_nom after t WAIT is elapsed, then the AS1313 falls into an idle mode, which results in a reduction of the quiescent current. Once, the AS1313 is in this idle mode, the idle-comparator is comparing VOUT with VIDLE (98% of V OUT_nom) and SW1 closes as soon as the V OUT reaches this threshold. ams Datasheet, Confidential: 2014-Jun-12 [v1-42] AS1313 – 13 Detailed Description External Component Selection Inductors For best efficiency, choose an inductor with high frequency core material, such as ferrite, to reduce core losses. The inductor should have low DCR (DC resistance) to reduce the I²R losses, and must be able to handle the peak inductor current without saturating. A 6.8μH inductor with at least 500mA current rating and DCR of 500mΩ (max) is recommended. Figure 15: Recommended Inductors L DCR Current Rating Size in mm (L/W/H) ELLVEG6R8N 6.8μH 0.35Ω 0.58A 3x3x1 ELLVFG6R8MC 6.8μH 0.23Ω 0.6A 3x3x1.2 ELLVGG6R8N 6.8μH 0.23Ω 1A 3x3x1.5 LQH3NPN6R8MM0 6.8μH 0.24Ω 1A 3x3x1.4 LQH3NPN6R8NM0 6.8μH 0.24Ω 1A 3x3x1.4 LQH3NPN6R8MJ0 6.8μH 0.252Ω 0.85A 3x3x1.1 LQH3NPN6R8NJ0 6.8μH 0.252Ω 0.85A 3x3x1.1 LQH3NPN6R8MMR 6.8μH 0.186Ω 1.25A 3x3x1.1 VLS2012ET-6R8M 6.8μH 0.498 0.57A 2x2x1.2 VLS252015ET-6R8M 6.8μH 0.48 0.85A 2.5x2x1.5 VLS3010ET-6R8M 6.8μH 0.312 0.69A 3x3x1 VLS3012ET-6R8M 6.8μH 0.228 0.81A 3x3x1.2 VLS3015ET-6R8M 6.8μH 0.216 0.92A 3x3x1.5 LPS4018-682ML 6.8μH 0.15 1.2A 4x4x1.7 Part Number AS1313 – 14 Manufacturer Panasonic www.industrial.panasonic.com Murata www.murata.com TDK www.tdk.com Coilcraft www.coilcraft.com ams Datasheet, Confidential: 2014-Jun-12 [v1-42] Detailed Description Capacitors The AS1313 requires 3 capacitors. Recommended ceramic X5R or X7R types will minimize ESL and ESR while maintaining capacitance at rated voltage over temperature. The input capacitor supports the triangular current during the on-time of SW1 and maintains a broadly constant input voltage during this time. The capacitance value is obtained from choosing a ripple voltage during the on-time of SW1. (EQ5) I COIL C IN = --------------------- ⋅ t ON V RIPPLE Using tON = 1μs, I COIL = 400mA and VRIPPLE = 50mV, EQ5 yields: CIN = 8μF. Because ceramic capacitors lose a lot of their initial capacitance at their maximum rated voltage, it is recommended that either a higher input capacity or a capacitance with a higher rated voltage is used. A 22μF cap for C IN is recommended. Additionally, ripple voltage is generated by the equivalent series resistance (ESR) of the capacitor. (EQ6) V RIPPLE – ESR = I COIL ⋅ R ESR The output capacitor supports the triangular current during the off-time SW1 (coil discharge period), and also the load current during the wait time (Region C) and the idle time (Region D). (EQ7) I OUT C OUT = ------------------------------------------- ⋅ ( t WAIT + t IDLE ) 0.02 ⋅ V OUT – nom Using tWAIT = 100μs, tIDLE = 500μs, I OUT = 1mA and V OUT_nom = 3.3V, EQ7 yields: COUT = 9μF. Due to the DC bias of the cap and to sustain also load steps, the COUT should be between 22μF and 47μF. A larger output capacitor should be used if lower peak to peak output voltage ripple is desired. A larger output capacitor will also improve load regulation on V OUT. ams Datasheet, Confidential: 2014-Jun-12 [v1-42] AS1313 – 15 Detailed Description Figure 16: Recommended Input & Output Capacitors C TC Code Voltage Rating Size in mm (L/W/H) GRM21BR60J226ME39L 22μF X5R 6.3V 2x1.25x1.25 GRM31CR61A226ME19L 22μF X5R 10V 3.2x1.6x1.6 12066D226KAT_A 22μF X5R 6.3V 3.2x1.6x1.78 1210ZD226KAT_A 22μF X5R 10V 3.2x1.6x1.78 1210YD226KAT_A 22μF X5R 16V 3.2x1.6x1.78 C2012X5R0J226K/1.25 22μF X5R 6.3V 2x1.2x1.25 C2012X5R1A226K/1.25 22μF X5R 10V 2x1.2x1.25 C2012X5R1C226K 22μF X5R 16V 2x1.2x1.25 Part Number Manufacturer Murata www.murata.com AVX www.avx.com TDK www.tdk.com For C REF a 100nF cap (X5R or better) is recommended. AS1313 – 16 ams Datasheet, Confidential: 2014-Jun-12 [v1-42] Application Information The AS1313 is an ideal solution for Li-Ion and coin cell powered devices as blood glucose meters, remote controls, hearing aids, wireless mouse or any light-load application. Application Information Figure 17: Typical Application Circuit VIN VIN 2.4V to 5.5V LX L1 6.8µH VOUT 1.2V to 3.6V AS1313 ON PWR_VIN OUT EN REF OFF CREF 100nF GND CIN 22µF COUT 22µF PWR_GND 0V 0V 8-pin MLPD VIN VIN 2.4V to 5.5V ON LX L1 6.8µH VOUT 1.2V to 3.6V AS1313 EN OUT GND REF OFF CIN 22µF CREF 100nF COUT 22µF 0V 0V 6-pin WL-CSP Typical Application: This figure shows the typical application of the DCDC Step Down Converter for 8-pin MLPD package and 6-pin WL-CSP. ams Datasheet, Confidential: 2014-Jun-12 [v1-42] AS1313 – 17 Pack age Drawings & Mark ings Package Drawings & Markings Figure 18: MLPD-8 2x2 0.5mm Pitch Package Drawing Symbol Min Nom Max A 0.51 0.55 0.60 A1 0.00 0.02 0.05 A3 0.15 REF L 0.225 0.325 0.425 b 0.18 0.25 0.30 D 2.00 BSC E 2.00BSC e 0.50 BSC D2 1.45 1.60 1.70 E2 0.75 0.90 1.00 aaa - 0.15 - bbb - 0.10 - ccc - 0.10 - ddd - 0.05 - eee - 0.08 - fff - 0.10 - N 8 Note(s) and/or Footnote(s): 1. Dimensioning and tolerancing conform to ASME Y14.5M-1994. 2. All dimensions are in millimeters. Angles are in degrees. 3. Coplanarity applies to the exposed heat slug as well as the terminal. 4. Radius on terminal is optional. 5. N is the total number of terminals. AS1313 – 18 ams Datasheet, Confidential: 2014-Jun-12 [v1-42] Pa c k a g e D r a w i n g s & M a r k i n g s Figure 19: WLCSP6 0.4mm Pitch Package Drawing Top through view Bottom view (ball side) Note(s) and/or Footnote(s): 1. ccc Coplanarity. 2. All dimensions are in μm. ams Datasheet, Confidential: 2014-Jun-12 [v1-42] AS1313 – 19 Pack age Drawings & Mark ings Figure 20: MLPD and WL-CSP Marking MLPD package WL-CSP XXX zz XXXX ZZZZ AS1313 Marking: Shows the package marking of the MLPD and the WL-CSP product version Figure 21: Package Codes XXXX Encoded Datecode for WL-CSP XXX Encoded Datecode for MLPD ZZ Marking Code for MLPD ZZZZ Marking Code for WL-CSP Package Codes: Shows the package codes of the MLPD and WL-SCP product version AS1313 – 20 ams Datasheet, Confidential: 2014-Jun-12 [v1-42] Ordering & Contac t Information Ordering & Contact Information Figure 22: Ordering Information Delivery Form Package Ultra Low IQ DCDC Buck Converter Tape & Reel MLPD-8lead (2mm x 2mm) 3.0V Ultra Low IQ DCDC Buck Converter Tape & Reel MLPD-8lead (2mm x 2mm) BU 3.3V Ultra Low IQ DCDC Buck Converter Tape & Reel MLPD-8lead (2mm x 2mm) AS1313-BTDT-ES ES Engineering sample Ultra Low IQ DCDC Buck Converter Tray MLPD-8lead (2mm x 2mm) AS1313-BWLT-ES ASU8 Engineering sample Ultra Low IQ DCDC Buck Converter Tray 6-pin WL-CSP 0.4mm pitch AS1313-BWLT-12 ASU9 1.2V Ultra Low IQ DCDC Buck Converter Tape & Reel 6-pin WL-CSP 0.4mm pitch Ordering Code Marking Output AS1313-BTDM-18 BT 1.8V AS1313-BTDM-30 BV AS1313-BTDM-33 Description Ordering Information: Specifies the different available variants of the AS1313. Buy our products or get free samples online at: www.ams.com/ICdirect Technical Support is available at: www.ams.com/Technical-Support For further information and requests, e-mail us at: ams_sales@ams.com For sales offices, distributors and representatives, please visit: www.ams.com/contact Headquarters ams AG Tobelbaderstrasse 30 8141 Unterpremstaetten Austria, Europe Tel: +43 (0) 3136 500 0 Website: www.ams.com ams Datasheet, Confidential: 2014-Jun-12 [v1-42] AS1313 – 21 RoHS Compliant & ams Green Statement RoHS Compliant & ams Green Statement RoHS: The term RoHS compliant means that ams AG products fully comply with current RoHS directives. Our semiconductor products do not contain any chemicals for all 6 substance categories, including the requirement that lead not exceed 0.1% by weight in homogeneous materials. Where designed to be soldered at high temperatures, RoHS compliant products are suitable for use in specified lead-free processes. ams Green (RoHS compliant and no Sb/Br): ams Green defines that in addition to RoHS compliance, our products are free of Bromine (Br) and Antimony (Sb) based flame retardants (Br or Sb do not exceed 0.1% by weight in homogeneous material). Important Information: The information provided in this statement represents ams AG knowledge and belief as of the date that it is provided. ams AG bases its knowledge and belief on information provided by third parties, and makes no representation or warranty as to the accuracy of such information. Efforts are underway to better integrate information from third parties. ams AG has taken and continues to take reasonable steps to provide representative and accurate information but may not have conducted destructive testing or chemical analysis on incoming materials and chemicals. ams AG and ams AG suppliers consider certain information to be proprietary, and thus CAS numbers and other limited information may not be available for release. AS1313 – 22 ams Datasheet, Confidential: 2014-Jun-12 [v1-42] Copyrights & Disclaimer Copyrights & Disclaimer Copyright ams AG, Tobelbader Strasse 30, 8141 Unterpremstaetten, Austria-Europe. Trademarks Registered. All rights reserved. The material herein may not be reproduced, adapted, merged, translated, stored, or used without the prior written consent of the copyright owner. Devices sold by ams AG are covered by the warranty and patent indemnification provisions appearing in its General Terms of Trade. ams AG makes no warranty, express, statutory, implied, or by description regarding the information set forth herein. ams AG reserves the right to change specifications and prices at any time and without notice. Therefore, prior to designing this product into a system, it is necessary to check with ams AG for current information. This product is intended for use in commercial applications. Applications requiring extended temperature range, unusual environmental requirements, or high reliability applications, such as military, medical life-support or life-sustaining equipment are specifically not recommended without additional processing by ams AG for each application. This product is provided by ams AG “AS IS” and any express or implied warranties, including, but not limited to the implied warranties of merchantability and fitness for a particular purpose are disclaimed. ams AG shall not be liable to recipient or any third party for any damages, including but not limited to personal injury, property damage, loss of profits, loss of use, interruption of business or indirect, special, incidental or consequential damages, of any kind, in connection with or arising out of the furnishing, performance or use of the technical data herein. No obligation or liability to recipient or any third party shall arise or flow out of ams AG rendering of technical or other services. ams Datasheet, Confidential: 2014-Jun-12 [v1-42] AS1313 – 23 Document Status Document Status Document Status Product Preview Preliminary Datasheet Datasheet Datasheet (discontinued) AS1313 – 24 Product Status Definition Pre-Development Information in this datasheet is based on product ideas in the planning phase of development. All specifications are design goals without any warranty and are subject to change without notice Pre-Production Information in this datasheet is based on products in the design, validation or qualification phase of development. The performance and parameters shown in this document are preliminary without any warranty and are subject to change without notice Production Information in this datasheet is based on products in ramp-up to full production or full production which conform to specifications in accordance with the terms of ams AG standard warranty as given in the General Terms of Trade Discontinued Information in this datasheet is based on products which conform to specifications in accordance with the terms of ams AG standard warranty as given in the General Terms of Trade, but these products have been superseded and should not be used for new designs ams Datasheet, Confidential: 2014-Jun-12 [v1-42] Revision Information Revision Information Changes from 1-41 (2013-Oct) to current revision 1-42 (2014-Jun-12) Page(1) Content was updated to the latest ams design Updated Figure 22 21 Note(s) and/or Footnote(s): 1. Page numbers for the previous version may differ from page numbers in the current revision. ams Datasheet, Confidential: 2014-Jun-12 [v1-42] AS1313 – 25 Content Guide Content Guide AS1313 – 26 1 1 2 2 General Description Key Benefits & Features Applications Block Diagram 3 4 6 8 Pin Assignment Absolute Maximum Ratings Electrical Characteristics Typical Operating Characteristics 11 14 14 15 Detailed Description External Component Selection Inductors Capacitors 17 18 21 22 23 24 25 Application Information Package Drawings & Markings Ordering & Contact Information RoHS Compliant & ams Green Statement Copyrights & Disclaimer Document Status Revision Information ams Datasheet, Confidential: 2014-Jun-12 [v1-42]
AS1313-BTDM-18 价格&库存
很抱歉,暂时无法提供与“AS1313-BTDM-18”相匹配的价格&库存,您可以联系我们找货
