high
performance
needs great
design.
Datasheet: AS8222 Enhanced FlexRay Standard Transceiver
Please be patient while we update our brand image as
austriamicrosystems and TAOS are now ams.
www.ams.com
AS8222
E n h a n c e d F l e x R a y S t a n d a r d Tr a n s c e i v e r
1 General Description
The AS8222 is a high-speed fault tolerant device operating as
interface between a generic FlexRay Communication Controller and
the copper wiring.
This device is the first FlexRay certified Transceiver for temperature
ranges up to 150°C ambient temperature. For bare-die deliveries
please contact ams for more information.
The AS8222 is designed to extend the application range for high
speed and safety critical time triggered bus systems in an
automotive environment. The bus driver is protected against short
circuits to the supply and GND. The AS8222 operates at baudrates
up to 10 Mbps and is fully conforming to the FlexRay Electrical
Physical Layer Specification V2.1 Rev B.
The AS8222 provides a host controller interface consisting of Enable
(EN) and Standby (STBN) input pins for mode handling by the
microcontroller and the Error (ERRN) output pin, signalling failures
and status information.
Interface with optional bus guardian for bus supervision
Automatic thermal shutdown protection
Supports 12, 24V systems with low sleep current consumption
Integrated power management system
Two INH pins for the external voltage regulators control
Local wake-up input
Remote wake-up capability via FlexRay bus in sleep mode
Supports 2.5, 3, 3.3, 5 V microcontrollers and automatically
adapts to interface levels
Does not disturb the bus line if not powered
Protected against damage due to short circuit conditions on the
bus (positive and negative battery voltage)
Small Pb-free package: SSOP-20
Automotive qualified to AEC-Q100, grade 0
For bare-die deliveries please contact us.
The device supports the NORMAL mode with activated FlexRay bus
transmitter and receiver, the RECEIVE_ONLY mode with activated
receiver only to avoid unwanted disturbances while listening to the
communication and the low-power modes STANDBY and SLEEP
with very low power consumption.
3 Applications
In case of undervoltage at one of the supply voltages (VBAT, VCC,
and VIO) the device will change its mode to a low-power mode
(either STANDBY or SLEEP mode) and the device will signal an
error accordingly. In case of low voltage is detected on both VBAT
and VCC the device will enter the POWER-OFF mode.
The device addresses all ECUs connected to the permanent battery
supply (terminal 30).
Ensuring application in safety critical environments a two wire busguardian interface is implemented where additional redundant
circuitries on the electronic-control-unit can monitor the
communication on the receive enable output (RxEN) and can
activate and deactivate through the bus guardian enable input (BGE)
the transmitter. Additionally in low-power modes the wake conditions
at the RxEN pin can be monitored.
The AS8222 FlexRay Standard Transceiver is best fitting for
automotive FlexRay nodes where bus wake-up and voltage regulator
control for voltage supplies is needed.
The device is best suited for high temperature applications with up to
150°C.
A thermal sensor circuit with an integral shutdown mechanism
prevents damage to the device in extreme temperature conditions.
2 Key Features
Data transfer up to 10 Mbps
Compliant with FlexRay Electrical Physical Layer Specification
V2.1 Rev. B
Wide operating ambient temperature range -40°C to +150°C
Excellent EMC performance
High common mode range insures excellent EMI immunity
www.ams.com/eng/FlexRay/AS8222
Revision 1.0
1 - 42
AS8222
Datasheet - A p p l i c a t i o n s
Figure 1. AS8222 Enhanced FlexRay Standard Transceiver Block Diagram
VIO
AS8222
Bus Failure Detector
STBN
EN
Host Controller Interface
ERRN
VIO
RxD
TxD
TxEN
Communication
Controller
Interface
BGE
Bus Guardian
Interface
RxEN
BP
Digital Logic
Transmitter
BM
Receiver
VBAT
VBAT
Revision 1.0
WAKE
GND
VIO
VBAT
INH2
Wake-Up
Detector
Power Supply Interface
VCC
INH1
2 - 42
AS8222
Datasheet - C o n t e n t s
Contents
1 General Description ..................................................................................................................................................................
1
2 Key Features............................................................................................................................................................................
1
3 Applications...............................................................................................................................................................................
1
4 Pin Assignments .......................................................................................................................................................................
5
4.1 Pin Descriptions....................................................................................................................................................................................
5
5 Absolute Maximum Ratings ......................................................................................................................................................
6
6 Electrical Characteristics...........................................................................................................................................................
8
6.1 Supply Voltage......................................................................................................................................................................................
8
6.2 State Transitions..................................................................................................................................................................................
9
6.3 Transmitter............................................................................................................................................................................................
9
6.4 Receiver .............................................................................................................................................................................................
11
6.5 Wake-up Detector...............................................................................................................................................................................
13
6.6 Supply Voltage Monitor.......................................................................................................................................................................
14
6.7 Bus Error Detection ............................................................................................................................................................................
15
6.8 Over Temperature...............................................................................................................................................................................
15
6.9 Power Supply Interface ......................................................................................................................................................................
15
6.10 Communication Controller Interface .................................................................................................................................................
15
6.11 Host Interface ...................................................................................................................................................................................
17
6.12 Bus Guardian Interface.....................................................................................................................................................................
18
6.13 Read Out Interface ...........................................................................................................................................................................
7 Detailed Description................................................................................................................................................................
18
19
7.1 Block Description................................................................................................................................................................................
19
7.2 Events.................................................................................................................................................................................................
19
7.3 Operating Modes ................................................................................................................................................................................
19
7.3.1
7.3.2
7.3.3
7.3.4
7.3.5
NORMAL Mode .........................................................................................................................................................................
RECIEVE-ONLY Mode ..............................................................................................................................................................
STANDBY Mode........................................................................................................................................................................
GO-TO-SLEEP Mode ................................................................................................................................................................
SLEEP Mode .............................................................................................................................................................................
7.4 Non-Operating Modes ........................................................................................................................................................................
7.4.1 POWER-OFF Mode................................................................................................................................................................... 20
7.5 Undervoltage Events ..........................................................................................................................................................................
7.5.1 Undervoltage / Voltage Recovery VBAT .................................................................................................................................... 21
7.5.2 Undervoltage / Voltage Recovery VIO ....................................................................................................................................... 21
7.5.3 Undervoltage / Voltage Recovery VCC ...................................................................................................................................... 21
7.6 Power On/Off Events..........................................................................................................................................................................
21
7.7 Wake-Up Events.................................................................................................................................................................................
21
7.7.1 Remote Wake-Up Event ............................................................................................................................................................ 21
7.7.2 Remote Wake-up with Frames .................................................................................................................................................. 21
7.7.3 Local Wake-Up Event ................................................................................................................................................................ 22
7.8 Over-temperature Events ...................................................................................................................................................................
22
7.9 System Description.............................................................................................................................................................................
23
7.10 Fail Silent Behaviour.........................................................................................................................................................................
24
7.10.1 RxEN / BGE Timeout............................................................................................................................................................... 24
7.10.2 State Transitions due to Undervoltage Detection .................................................................................................................... 24
Revision 1.0
3 - 42
AS8222
7.10.3 State Transitions due to Voltage Recovery Detection ............................................................................................................. 24
7.11 Mode Transitions ..............................................................................................................................................................................
24
7.11.1 Error Pin Signalling .................................................................................................................................................................. 27
7.12 Loss of Ground .................................................................................................................................................................................
7.13 ERROR Flags Description................................................................................................................................................................
7.13.1 Undervoltage Detected VBAT Flag ..........................................................................................................................................
7.13.2 Undervoltage Detected VIO Flag .............................................................................................................................................
7.13.3 Undervoltage Detected VCC Flag............................................................................................................................................
7.13.4 Bus Error..................................................................................................................................................................................
7.13.5 Bus Open Line .........................................................................................................................................................................
7.13.6 BP Short Circuit to VCC ...........................................................................................................................................................
7.13.7 BP Short Circuit to GND ..........................................................................................................................................................
7.13.8 BM Short Circuit to VCC ..........................................................................................................................................................
7.13.9 BM Short Circuit to GND..........................................................................................................................................................
7.13.10 Short Circuit between BP and BM .........................................................................................................................................
7.13.11 Over-temperature ..................................................................................................................................................................
7.13.12 TxEN_BGE Timeout ..............................................................................................................................................................
7.13.13 Error Flag...............................................................................................................................................................................
7.14 STATUS Flags Description ...............................................................................................................................................................
27
27
27
27
27
27
27
27
28
28
28
28
28
28
28
28
7.14.1 Local and Remote Wake Flag ................................................................................................................................................. 28
7.14.2 Power on Flag.......................................................................................................................................................................... 28
7.14.3 BGE Status .............................................................................................................................................................................. 28
7.15 Error and Status Flags Read Out .....................................................................................................................................................
8 Bus Driver ...............................................................................................................................................................................
29
30
8.1 AS8222 Bus States ............................................................................................................................................................................
30
8.2 Transceiver Timing .............................................................................................................................................................................
30
8.3 Transmitter..........................................................................................................................................................................................
31
8.4 Receiver .............................................................................................................................................................................................
33
8.4.1 Bus activity and idle detection (only in NORMAL and RECEIVE ONLY mode)......................................................................... 33
8.4.2 Bus Data Detection (Only in NORMAL and RECEIVE ONLY Mode) ........................................................................................ 34
8.4.3 Receiver Test Signal.................................................................................................................................................................. 35
9 Test circuits .............................................................................................................................................................................
36
9.1 ISO7637-2 Test Pulses - Class D .......................................................................................................................................................
36
9.2 Application Circuit...............................................................................................................................................................................
37
10 Appendix...............................................................................................................................................................................
38
10.1 FlexRay Functional Classes .............................................................................................................................................................
38
10.2 FlexRay Parameter Comparison ......................................................................................................................................................
38
11 Package Drawings and Markings..........................................................................................................................................
39
12 Ordering Information.............................................................................................................................................................
40
Revision 1.0
4 - 42
AS8222
Datasheet - P i n A s s i g n m e n t s
4 Pin Assignments
The AS8222 is available in SSOP-20 5.3mm.
Figure 2. Pin Assignments (Top View)
INH2
1
INH1
2
19
VCC
EN
3
18
BP
17
BM
GND
VIO
4
TxD
5
AS8222
16
TxEN
6
(SSOP20)
15
WAKE
RxD
7
14
VBAT
BGE
8
13
ERRN
STBN
9
12
RxEN
10
11
Table 1. SSOP-20 Pin Descriptions
Pin Name
Pin Number
INH2
1
INH1
2
EN
3
Digital Input with Pull-down
VIO
4
Supply
TxD
5
TxEN
6
Digital Input with Pull-up
RxD
7
Digital Output
BGE
8
STBN
9
Reserved
10
Analog/digital Input/output
with Pull-down
Not used
11
RxEN
12
ERRN
13
VBAT
14
Supply
WAKE
15
Analog I/O
GND
16
Supply
BM
17
BP
18
VCC
19
Supply
Not used
Pin Type
Analog I/O
Digital Output
Analog I/O
Description
Analog Output. Inhibit 2 output for switching external voltage regulator
Analog Output. Inhibit 1 output for switching external voltage regulator
Digital Input. Enable input
Supply Voltage. I/O supply voltage
Digital Input. Transmit data input
Digital Input. Transmitter enable input
Digital Output. Receive data output
Digital Input. Bus guardian enable input
Digital Input. Standby input
To be connected to GND or to be unconnected
Digital Output. Receive data enable output
Digital Output. Error diagnosis output and wake status output
Supply Voltage. Battery supply voltage
Analog Input. Local wake-up input
Ground
Analog Input/Output. Bus line Minus
Analog Input/Output. Bus line Plus
Supply voltage.
Revision 1.0
5 - 42
AS8222
Datasheet - A b s o l u t e M a x i m u m R a t i n g s
Stresses beyond those listed in Table 2 may cause permanent damage to the device. These are stress ratings only. Functional operation of the
device at these or any other conditions beyond those indicated in Absolute Maximum Ratings is not implied. Exposure to absolute maximum
rating conditions for extended periods may affect device reliability.
Note: All voltages are referred to pin GND.
Table 2. Absolute Maximum Ratings
Symbol
Parameter
Min
Max
Units
Note
Battery Supply Voltage
-0.3
+50
V
-0.3
+7.0
V
-0.3
+7.0
V
DC Voltage at EN, STBN, ERRN,
TxD, RxD, TxEN, BGE, RxEN
-0.3
VIO +0.3
V
DC Voltage on pin WAKE, INH1, INH2
-0.3
VBAT +0.3
DC Voltage at BP and BM
-40
+40
V
Input current (latchup immunity)
-100
100
mA
According to JEDEC 78
Electrical Parameters
VBAT
VCC
Supply Voltage
VIO
VIO < VCC
Electrostatic Discharge
ESD
±2
kV
All pins
AEC-Q100-002 (HBM)
uESDInt
2
kV
ESD on all other pins
±4
kV
For VBAT, GND, WAKE
AEC-Q100-002 (HBM)
uESDExt
4
kV
ESD protection on pins that lead to ECU
external terminals
±6
kV
BP, BM
AEC-Q100-002 (HBM)
uESDExt
4
kV
external terminals
±6
kV
BP, BM
FlexRay Physical Layer EMC Measurement
Specification Version 3.0
±500
V
±750
V
±100
V
Revision 1.0
On all pins
AEC-Q100-011 (Charge Device Model)
At the corner pins
On all pins
AEC-Q100-003 (Machine Model)
6 - 42
AS8222
Symbol
Parameter
Min
Max
Units
Note
V
ISO7637-2 test pulse 1; class D
(see Figure 14)
V
ISO7637-2 test pulses 2a; class D
(see Figure 14)
V
ISO7637-2 test pulses 3a; class D
(see Figure 14)
+100
V
ISO7637-2 test pulses 3b; class D
(see Figure 14)
150
mW
+150
ºC
260
ºC
85
Damage Tests
-100
Us
Transient voltage on VBAT, Bus and
Wake pins (damage tests)
+75
-150
Power Dissipation
Pt
Total power dissipation (all supplies
and outputs)
Temperature Ranges and Storage Conditions
Tstrg
Storage temperature
-55
TBODY
Package body temperature
H
Humidity non-condensing
MSL
Moisture Sensitivity Level
1
2
5
3
1. The reflow peak soldering temperature (body temperature) specified is in accordance with IPC/JEDEC J-STD-020 “Moisture/Reflow
Sensitivity Classification for Non-Hermetic Solid State Surface Mount Devices”. The lead finish for Pb-free leaded packages is matte tin
(100% Sn).
2. Represents a maximum floor life time of 168h.
Revision 1.0
7 - 42
AS8222
Datasheet - E l e c t r i c a l C h a r a c t e r i s t i c s
In this specification, all the defined tolerances for external components are assured over the whole operation conditions range as well as over
lifetime.
Operation Range:
TAMB=-40ºC to +150ºC, VCC=+4.75V to +5.25V, VBAT=5.5V to +40V, VIO=+2.2 to VCC, RL=40Ω, CL= 100pF unless otherwise specified.
6.1 Supply Voltage
Table 3. Supply Voltage
Symbol
Parameter
TAMB
Conditions
Min
Typ
Max
Units
Ambient temperature
-40
+25
+150
ºC
T
Ambient temperature
-40
+125
ºC
VCC-VIO
Difference of supplies
-0.1
3.05
V
VBAT=12V; SLEEP mode;
IBAT
VBAT current consumption
(standard transceiver only)
50
µA
170
µA
1
mA
-5
10
µA
Non-low-power mode: NORMAL, driver
enabled
15
25
45
mA
enabled; RBUS= ∞Ω
3
7
15
mA
Non-low-power mode: RECEIVE-ONLY
1
2
10
mA
-5
2
µA
1
mA
TAMB
很抱歉,暂时无法提供与“AS8222-HSSM”相匹配的价格&库存,您可以联系我们找货
