LED LAMP
VAOL-5LDE1
Feature
Package Dimension
Low Power Consumption
I.C. compatible
Applications
Commercial Outdoor Sign Board
Front Panel Indicator
Dot-Matrix Module
LED Bulb
Description
These LEDs are Based on GaP/GaP
Material Technology
Emitted color:Green
Milky Diffusion Lens
*Tolerance:± 0.01
0.25
Unit:±
inch
mm
Absolute Maximum Ratings at Ta=25℃
Symbol
Parameter
Max.
Unit
100
mW
PD
Power Dissipation
VR
Reverse Voltage
5
V
IAF
Average Forward Current
30
mA
IPF
Peak Forward Current(Duty=0.1,1kHz)
100
mA
Derating Linear Form 25℃
0.4
mA∕℃
Topr
Operating Temperature Range
–20 to + 80
Tstg
Storage Temperature Range
–20 to + 100
Lead Soldering Temperature [1.6mm(0.063inch)From Body] 260℃ For 5 Seconds.
Electrical / Optical Characteristics and Curves at Ta=25℃
Symbol
Parameter
Test Condition
VF
Forward Voltage
IF= 20 mA
IR
Reverse Current
VR= 5
△θ
Half Intensity Angle
IF= 20 mA
60
Deg.
IV
Luminous Intensity
IF= 20 mA
50
mcd.
λd
Dominant Wavelength
IF= 20 mA
570
nm
Min.
Typ.
2.2
V
Max. Unit
2.8
V
100
μA
Electrical Characteristics at Ta=25℃
Symbol
Iv
VF
λD
Parameter
Luminous Intensity
Forward Voltage
Dominant Wavelength
Condition
IF=20mA
IF=20mA
IF=20mA
Unit
mcd
V
nm
Binning
Grade
Range
Grade
Range
Grade
Range
50
C
1.9~2.0
G9
569~571
D
2.0~2.1
G10
571~573
E
2.1~2.2
G11
573~575
F
2.2~2.3
G
2.3~2.4
Intensity: Tolerance of minimum and maximum = ± 15%
Vf: Tolerance of minimum and maximum = ± 0.05v
NOTE:
1. Static electricity and surge damages the LED. It is recommend to use a anti-static wrist
band or anti-electrostatic glove when handing the LEDs. All devices, equipment and machinery
must be properly grounded.
2. Specific binning requirements –please contact our home office
Radiation Diagram
IF=20 mA 50% Power Angle
Angle =60∘
GREEN
Typical Electro-optical Characteristic Curves
(25°C Free Air Temperature Unless Otherwise Specified)
λ
很抱歉,暂时无法提供与“VAOL-5LDE1”相匹配的价格&库存,您可以联系我们找货
