PRODUCT FAMILY DATA SHEET
CLM3C-WKW/MKW: PLCC2 1 IN 1 SMD LED
PRODUCT DESCRIPTION
FEATURES
APPLICATIONS
SMD LEDs is packaged in the industry
• Size (mm): 2.7 X 2.0
• Channel Letter
standard package. These LEDs have high
reliability performance and are
• Backlight
• Color Temperatures:
designed to work under a wide range of
environmental conditions.
This high reliability feature makes
Cool White :
Min . (4600K) / Typical (5500K)
Warm White :
Min . (2500K) / Typical (3200K)
them ideally suited to be used under
illumination application conditions.
• Luminous Intensity (mcd)
Its wide viewing angle makes these
CLM3C-WKW:(1400-3550)
LEDs ideally suited for channel letter, or
CLM3C-MKW:(1120-2800)
general
backlighting
and
illumina-tion
applications. The flat top emitting surface • CRI:
makes it easy for these LEDs
to mate with light pipes.
Typical CRI for Cool White is 72
Typical CRI for Warm White is 80
• Lead - Free
• RoHS Compliant
Cree LED / 4400 Silicon Drive / Durham, NC 27703 USA / +1.919.313.5330 / www.cree-led.com
© 2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the
Cree LED logo is a trademark, of Cree, Inc.
CLD-CT1076
REV 8
1
ABSOLUTE MAXIMUM RATINGS (TA = 25°C)
Items
Symbol
Absolute Maximum Rating
Unit
IF
25
mA
IFP
100
mA
Reverse Voltage
VR
5
V
Power Dissipation
PD
100
mW
Operation Temperature
Topr
-40 ~ +100
°C
Storage Temperature
Tstg
-40 ~ +100
°C
Junction Temperature
TJ
110
°C
Junction/Ambient
RTHJA
350
°C/W
Junction/Solder Point
RTHJS
300
°C/W
Forward Current
Peak Forward Current
Note 1
Note:
1.
Pulse width ≤0.1 msec, duty ≤1/10.
TYPICAL ELECTRICAL & OPTICAL CHARACTERISTICS (TA = 25°C)
Characteristics
Color
Symbol
Condition
Unit
Forward Voltage
Cool/Warm
VF
IF = 20 mA
V
Reverse Current
Cool/Warm
IR
VR = 5 V
μA
Cool
ΦV
IF = 20 mA
lm
Warm
ΦV
IF = 20 mA
lm
Cool
IV
IF = 20 mA
mcd
1400
Warm
IV
IF = 20 mA
mcd
1120
x
IF = 20 mA
0.3325
Luminous Flux
Luminous Intensity
Cool
Chromaticity
Coordinates
Warm
Minimum
Typical
Maximum
3.2
4.0
10
4200
4000
1850
1560
y
IF = 20 mA
0.3411
x
IF = 20 mA
0.4234
y
IF = 20 mA
0.3990
Continuous reverse voltage can cause LED damage.
CLD-CT1076
REV 8
2
INTENSITY BIN LIMIT
Cool White (20 mA) - CLM3C-WKW
Bin Code
Min.(mcd)
Max.(mcd)
Wb
1400
Xa
1800
Xb
2240
Ya
2800
Warm White (20 mA) - CLM3C-MKW
Bin Code
Min.(mcd)
Max.(mcd)
1800
Wa
1120
1400
2240
Wb
1400
1800
2800
Xa
1800
2240
3550
Xb
2240
2800
Tolerance of measurement of luminous intensity is ±10%
VOLTAGE BIN LIMIT
Warm White (20 mA) -CLM3C-MKW
Bin Code
Min. (V)
Max. (V)
Bin Code
Min. (V)
Max. (V)
27
2.8
3.0
27
2.8
3.0
28
3.0
3.2
28
3.0
3.2
29
3.2
3.4
29
3.2
3.4
2a
3.4
3.6
2a
3.4
3.6
2b
3.6
3.8
2b
3.6
3.8
2c
3.8
4.0
2c
3.8
4.0
Tolerance of measurement of voltage is ±0.05V
CLD-CT1076
REV 8
3
COLOR BIN LIMIT
Bin
Code
Sub-bin
Wa
Wb
W1
Wc
Wd
We
Wf
W2
Wg
Wh
x
y
Bin
Code
Sub-bin
x
y
Bin
Code
Sub-bin
x
y
0.2545
0.2480
0.2830
0.3050
0.3300
0.3600
0.2633
0.2410
0.2950
0.3210
0.3455
0.3725
0.2545
0.2245
0.2998
0.3028
0.3443
0.3535
0.2450
0.2290
0.2895
0.2905
0.3300
0.3390
Wj
Wt
0.2633
0.2410
0.2895
0.2905
0.3300
0.3390
0.2720
0.2340
0.2998
0.3028
0.3443
0.3535
0.2640
0.2200
0.3045
0.2865
0.3430
0.3345
0.2545
0.2245
0.2960
0.2760
0.3300
0.3180
0.2950
0.3210
0.3455
0.3725
0.3070
0.3370
0.3610
0.3850
Wk
W3
Wu
W5
0.2545
0.2480
0.2640
0.2670
0.2720
0.2575
0.3100
0.3150
0.3585
0.3680
0.2633
0.2410
0.2998
0.3028
0.3443
0.3535
Wm
Wv
0.2633
0.2410
0.2998
0.3028
0.3443
0.3535
0.2720
0.2575
0.3100
0.3150
0.3585
0.3680
0.2800
0.2480
0.3130
0.2970
0.3560
0.3510
0.2720
0.2340
0.3045
0.2865
0.3430
0.3345
Wn
0.2640
0.2670
0.3070
0.3370
0.2735
0.2860
0.3185
0.3485
0.2808
0.2740
0.3200
0.3270
0.2720
0.2575
0.3100
0.3150
0.2720
0.2575
0.3100
0.3150
0.2808
0.2740
0.3200
0.3270
0.2880
0.2620
0.3215
0.3075
0.2800
0.2480
0.3130
0.2970
0.2735
0.2860
0.3185
0.3485
0.2830
0.3050
0.3300
0.3600
0.2895
0.2905
0.3300
0.3390
0.2808
0.2740
0.3200
0.3270
0.2808
0.2740
0.3200
0.3270
0.2895
0.2905
0.3300
0.3390
0.2960
0.2760
0.3300
0.3180
0.2880
0.2620
0.3215
0.3075
Wp
Wq
W4
Wr
Ws
Ww
Tolerance of measurement of the color coordinates is ±0.01
CLD-CT1076
REV 8
4
COLOR BIN LIMIT
Bin
Code
Sub-bin
Ma
Mb
M1
Mc
Md
x
y
Bin
Code
Sub-bin
x
y
Bin
Code
Sub-bin
x
y
0.3610
0.3900
0.4030
0.4250
0.4490
0.4530
0.3576
0.3651
0.3926
0.3915
0.4310
0.4128
0.3751
0.3783
0.4118
0.4021
0.4572
0.4203
0.3820
0.4075
0.4260
0.4390
0.4785
0.4625
Me
Mj
0.3576
0.3651
0.3926
0.3915
0.4310
0.4128
0.3541
0.3401
0.3822
0.3580
0.4129
0.3726
0.3682
0.3491
0.3976
0.3653
0.4359
0.3782
0.3749
0.3781
0.4118
0.4021
0.4572
0.4203
0.4260
0.4390
0.4785
0.4625
0.4118
0.4021
0.4572
0.4203
Mf
M2
Mk
M3
0.3820
0.4075
0.3751
0.3783
0.3926
0.3915
0.4310
0.4128
0.4834
0.4279
0.4030
0.4250
0.4490
0.4530
0.5080
0.4720
Mg
Mm
0.3751
0.3783
0.4118
0.4021
0.4572
0.4203
0.3682
0.3491
0.3976
0.3653
0.4359
0.3782
0.3822
0.3580
0.4129
0.3725
0.4588
0.3838
0.3926
0.3915
0.4310
0.4128
0.4834
0.4279
Mh
Mn
CLD-CT1076
REV 8
5
CIE CHROMATICITY DIAGRAM
0.5300
0.4700
M3
M
2
Mm
Mj
Mg
M
0K
500
W
W
3
W
W
W
1
W
W
0.2300
0.2300
a
c
W
W
g
e
W
W
p
W
Ma
r
W
W
t
W
W
v
Mb
Mf
Mn
Mh
Md
w
u
Mk
Mc
5
W
60
00
K
4
W
70
00
K
80
00
K
W
2
0.2900
W
m
W
j
W
W
W
W
10
00
0K 9 00
0K
y
0.3500
0.1700
0.1700
Me
1
0.4100
2700K
2500K
3000K
3500K
4000K
s
q
n
k
h
f
d
b
0.2900
0.3500
0.4100
0.4700
0.5300
x
CLD-CT1076
REV 8
6
ORDER CODE TABLE
Color
Cool White
Color
Warm White
Kit Number
Color Bin Code
Min.
Max.
CLM3C-WKW-CWbYa153
1400
3550
W1,W2,W3,W4,W5
CLM3C-WKW-CWbYa453
1400
3550
W4,W5
CLM3C-WKW-CXaYa453
1800
3550
W4,W5
Kit Number
Color Bin Code
Min.
Max.
CLM3C-MKW-CWaXb133
1120
2800
M1,M2,M3
CLM3C-MKW-CWaXb513
1120
2800
W5,M1
CLM3C-MKW-CWaXb233
1120
2800
M2,M3
CLM3C-MKW-CWbXb513
1400
2800
W5,M1
CLM3C-MKW-CWbXb233
1400
2800
M2,M3
Notes:
The above kit numbers represent order codes that include multiple intensity-bin and color-bin codes. Only one intensity-bin code and one color-bin
code will be shipped on each bulk. Single intensity-bin code and single color-bin codes will not be orderable.
Please refer to the HB LED Lamp Reliability Test Standards document for reliability test conditions.
Please refer to the HB LED Lamp Soldering & Handling document for information about how to use this LED product safely.
CLD-CT1076
REV 8
7
GRAPHS
The data below are collected from statistical figures that do not necessarily correspond to the actual parameters of each single LED.
Hence, these data will be changed without further notice.
50.0
(RELATIVE LUMINOUS INTENSITY)
IF (mA)
5.0
40.0
4.0
30.0
3.0
20.0
2.0
10.0
1.0
0.0
2.8
3.0
3.2
3.4
3.6
FIG.1 FORWARD CURRENT VS.
VF(V)
3.8
-50
-40
-30
-20
30
40
50
FIG.2 RELATIVE LUMINOUS INTENSITY VS.
FORWARD VOLTAGE.
Vr(V)
IF(mA)
0.0
FORWARD CURRENT
-10
100%
-10
80%
-20
60%
3700K - 5000K CCT
-30
40%
2600K - 3700K CCT
-40
20%
5000K - 10000K CCT
FIG.3 REVERSE CURRENT
VS. REVERSE VOLTAGE.
-50
Ir(uA)
0%
400 450
500
550 600
650 700
FIG.4 RELATIVE LUMINOUS INTENSITY VS.
WAVELENGTH.
WL(nm)
750
IF(mA)
1.0
50
40
30
Rth j-s=300 C/W
0.5
Rth j-a=350 C/W
Ta( C)
40
80
100
FIG.5 MAXIMUM FORWARD DC CURRENT VS AMBIENT
TEMPERATURE (Tjmax=110 C)
Angle
-60
-30
FIG.6 FAR FIELD PATTERN
60
90
CLD-CT1076
REV 8
8
MECHANICAL DIMENSIONS
All dimensions are in mm.
NOTES
RoHS Compliance
The levels of RoHS restricted materials in this product are below the maximum concentration values (also referred to as the threshold
limits) permitted for such substances, or are used in an exempted application, in accordance with EU Directive 2011/65/EC (RoHS2), as
implemented January 2, 2013. RoHS Declarations for this product can be obtained from your Cree LED representative or from the Product
Ecology section of the Cree LED website.
Vision Advisory
WARNING: Do not look at an exposed lamp in operation. Eye injury can result.
CLD-CT1076
REV 8
9
KIT NUMBER SYSTEM
Cree LED lamps are tested and sorted into performance bins. A bin is specified by ranges of color, forward voltage, and brightness. Sorted
LEDs are packaged for shipping in various convenient options.
Cree LEDs are sold by order codes in combinations of bins called kits. Order codes are configured in the following manner:
CLD-CT1076
REV 8
10
REFLOW SOLDERING
• The CLM3C-WKW/MKW is rated as a MSL 5a product.
Document No.: COTCO-05-0057
Rev. NO. : 13
• The recommended floor life out of bag is 24hrs.
• The temperature profile is as below.
Temperature
Melting-point
Pre-heat
Soak
Reflow
Cooling
Time
Use all SMD besides LP6-NPP1-01-N1
Use only
with=CLM3C-WKW/MKW
Solder
Sn63-Pb37
Solder = Lead-free
Average ramp-up rate = 4ºC/s max.
Preheat temperature = 100ºC ~150ºC
Preheat temperature = 150ºC ~200ºC
Preheat time Preheat
= 100stemperature
max.
= 150ºC ~200ºC
Preheat time = 100s max.
Ramp-down rate =Preheat
6ºC/stime
max.
= 120s max
Ramp-down rate = 6ºC/s max.
Ramp-down
= 6ºC/s max
Peak temperature
= 230ºCrate
max.
Peak temperature = 250ºC max.
Solder
Time within
temperature
= 250ºC
max
5ºCPeak
of actual
Peak
Temperature
= 10s max.
Time within 5ºC of actual Peak Temperature = 10s max
Duration above 183ºC is 80s max.
Duration above 217ºC
is 60s
pick
up max
SMD
[13]
Document No.: CREE-05-0
Rev. NO. :
16
Time within 5ºC of actual Peak Temperature = 10s max.
Duration above 217ºC is 80s max.
products during the process of SMT production . If handling is necessary, it should ta
Only
use LP6-NPP1-01-N1
careful
to pick
Theis following
two solidification.
methods areUsers
necessary
• The
packaging
sizes of these SMD
products
are up
verythese
smallproducts.
and the resin
still soft after
are required
to handle
Solder
= Lowtouch
Lead-free
with
care. Never
the resin surface of SMD products.
• To Average
avoid damaging
product’s
ramp-upthe
rate
= 3ºC/ssurface
max. and interior device, it is recommended to choose a special nozzle to pick up the SMD
products
the process
of SMT
production. If handling is necessary, take special care when picking up these products. The
Preheatduring
temperature
= 130ºC
~170ºC
following method is necessary:
Preheat time = 120s max.
Fig. 1a: For Small Top SMD
Fig. 1b: For Mini side 0.8mm SMD
• Please refer to the HB LED Lamp Soldering & Handling document for information about how to use this LED product safely.
Peak temperature = 213ºC max.
Time within 3ºC of actual Peak Temperature = 25s max.
Duration above 200ºC is 40s max.
Recommended solder pad design for heat dissipation (2-pin SMD LED):
7.0 series , it is recommended to use rubber material Nozzle to pick up SMD produ
For Small Top SMD
figure size for reference :
2.6
CLD-CT1076
REV 8
a.) Circular Nozzle: inner diameter: Ø1.8mm+/-0.05mm, outer diameter: Ø2.3mm+/-0.05mm.
11
PACKAGING
• The LEDs are packed in cardboard boxes after packaging in normal or anti-electrostatic bags.
• Cardboard boxes will be used to protect the LEDs from mechanical shock during transportation.
• The boxes are not water resistant, and they must be kept away from water and moisture.
• The reel pack is applied in SMD LED.
• Max 3000 pcs per reel.
CARRIER TAPE
PACKAGE MARKING
4.0
3.3
2.25
T APE FEED DIRECTION
8.0
1.75
4.0
3.5
1.5
COVER TAPE
REEL(178x8mm)
Label
HUMIDITY INDICATOR
HUMICHECK
H UMIDITY IN DICA TOR
DAN GE RO US
DO N O T EAT
DESICCANT
Av oid
etal
Contact
w ww .v itapac.com
V102
Label
POLYETHYLENE BAG
Label
A CARTON
(240x220x35mm)
CLD-CT1076
REV 8
12
