PRODUCT FAMILY DATA SHEET
CLM2C-RCA/ACA: PLCC4 Red & Amber SMD LEDs
PRODUCT DESCRIPTION
FEATURES
APPLICATIONS
SMD LEDs is packaged in the industry
• Size (mm): 3.2 x 2.8
• Channel Letter
standard package. These LEDs have high
reliability performance and are designed to
• Architectural Lighting
• Color and Typical Dominant
work under a wide range of environmental
Wavelength:
conditions. This high reliability feature
Red (619-624nm)
Amber (584-596nm)
makes them ideally suited to be used in
architectural lighting application conditions
Cree LED has been certified in accordance
with ISO/IATF16949.
• Moisture Sensitivity Level: 5a
• Lead - Free
• RoHS Compliant
Cree LED / 4400 Silicon Drive / Durham, NC 27703 USA / +1.919.313.5330 / www.cree-led.com
© 2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the
Cree LED logo is a trademark, of Cree, Inc.
CLD-CT1288
REV 6
1
CLM2C-RCA/ACA: PLCC4 RED & AMBER SMD LEDs
ABSOLUTE MAXIMUM RATINGS (TA = 25°C)
Items
Symbol
Absolute Maximum Rating
Red
Forward Current
Unit
Amber
IF
70
mA
IFP
200
mA
Reverse Voltage
VR
5
V
Power Dissipation
PD
182
mW
Operation Temperature
Topr
-40 ~ +100
°C
Storage Temperature
Tstg
-40 ~ +100
°C
Junction Temperature
TJ
110
°C
Junction/Ambient
RTHJA
250
°C/W
Junction/Solder Point
RTHJS
100
°C/W
Electrostatic Discharge
Classification(MIL-STD-883E)
ESD
Peak Forward Current
Note1
Class 2
Note:
1.
Pulse width ≤0.1 msec, duty ≤1/10.
TYPICAL ELECTRICAL & OPTICAL CHARACTERISTICS (TA = 25°C)
Characteristics
Color
Symbol
Condition
Unit
Forward Voltage
Red/Amber
VF
IF = 20 mA
V
Reverse Current
Red/Amber
IR
VR = 5 V
μA
Red
λD
IF = 20 mA
nm
Amber
λD
IF = 20 mA
nm
Red
IV
IF = 20 mA
mcd
Amber
IV
IF = 20 mA
mcd
1800
4000
Dominant Wavelength
Luminous Intensity
Minimum
Typical
Maximum
2.0
2.6
621
624
584
591
596
1400
3500
10
619
Continuous reverse voltage can cause LED damage.
CLD-CT1288
REV 6
2
INTENSITY BIN LIMIT
Red (20 mA)
Amber (20 mA)
Bin Code
Min.(mcd)
Max.(mcd)
Bin Code
Min.(mcd)
Max.(mcd)
Wb
1400
Xa
1800
1800
Xa
1800
2240
2240
Xb
2240
2800
Xb
2240
2800
Ya
2800
3550
Ya
2800
3550
Yb
3550
4500
Yb
3550
4500
Z0
4500
5600
Z0
4500
5600
A0
5600
7100
Tolerance of measurement of luminous intensity is ±10%
COLOR BIN LIMIT
Red (20 mA)
Amber (20 mA)
Bin Code
Min.(nm)
Max.(nm)
RB
619
624
Bin Code
Min.(nm)
Max.(nm)
A2
584
587
A3
587
590
A4
590
593
A5
593
596
Tolerance of measurement of dominant wavelength is ±1 nm.
CLD-CT1288
REV 6
3
ORDER CODE TABLE
Color
Red
Amber
Kit Number
Luminous Intensity (mcd)
Dominant Wavelength
Package
Min.
Max.
Color Bin
Min.(nm)
Color Bin
Max.(nm)
CLM2C-RCA-CWbZ0BB3
1400
5600
RB
619
RB
624
Reel
CLM2C-RCA-CXaZ0BB3
1800
5600
RB
619
RB
624
Reel
CLM2C-RCA-CXbZ0BB3
2240
5600
RB
619
RB
624
Reel
CLM2C-RCA-CYaZ0BB3
2800
5600
RB
619
RB
624
Reel
CLM2C-ACA-CXaA0253
1800
7100
A2
584
A5
596
Reel
CLM2C-ACA-CXbA0253
2240
7100
A2
584
A5
596
Reel
CLM2C-ACA-CXbA0343
2240
7100
A3
587
A4
593
Reel
CLM2C-ACA-CYaA0253
2800
7100
A2
584
A5
596
Reel
CLM2C-ACA-CYaA0343
2800
7100
A3
587
A4
593
Reel
CLM2C-ACA-CYbA0253
3550
7100
A2
584
A5
596
Reel
CLM2C-ACA-CYbA0343
3550
7100
A3
587
A4
593
Reel
Notes:
The above kit numbers represent order codes that include multiple intensity-bin and color-bin codes. Only one intensity-bin code and one color-bin
code will be shipped on each bulk. Single intensity-bin code and single color-bin codes will not be orderable.
Please refer to the HB LED Lamp Reliability Test Standards document for reliability test conditions.
Please refer to the HB LED Lamp Soldering & Handling document for information about how to use this LED product safely.
CLD-CT1288
REV 6
4
GRAPHS
The data below are collected from statistical figures that do not necessarily correspond to the actual parameters of each single LED.
Hence, these data will be changed without further notice.
(RELATIVE LUMINOUS INTENSITY)
IF (mA)
5.0
100.0
4.0
80.0
Amber
Red
60.0
3.0
Red
40.0
Amber
2.0
20.0
1.0
VF(V)
0.0
1.8
2.0
2.2
2.4
2.6
0.0
2.8
FORWARD VOLTAGE.
-60
-50
-40
-20
-30
40
IF(mA)
100
80
FIG.2 RELATIVE LUMINOUS INTENSITY VS.
FORWARD CURRENT
FIG.1 FORWARD CURRENT VS.
Vr(V)
0.0
-10
100%
-10
80%
-20
60%
-30
40%
-40
20%
Amber
0%
300
-50
Ir(uA)
FIG.3 RED&AMBER REVERSE CURRENT
VS. REVERSE VOLTAGE.
400
Red
500
600
WL(nm)
800 900
700
FIG.4 RELATIVE LUMINOUS INTENSITY VS.
WAVELENGTH.
IF(mA)
10
1.0
30
Rth j-s=100 C/W
40
80
50
60
60
0.5
40
Rth j-a=250 C/W
70
T ( C)
60
80
100
FIG.5 RED&AMBER MAXIMUM FORWARD DC CURRENT VS AMBIENT
TEMPERATURE (Tjmax=110 C)
80
90
-1.0
-0.5
60
90
FIG.6 FAR FIELD PATTERN
CLD-CT1288
REV 6
5
MECHANICAL DIMENSIONS
All dimensions are in mm.
NOTES
RoHS Compliance
The levels of RoHS restricted materials in this product are below the maximum concentration values (also referred to as the threshold
limits) permitted for such substances, or are used in an exempted application, in accordance with EU Directive 2011/65/EC (RoHS2), as
implemented January 2, 2013. RoHS Declarations for this product can be obtained from your Cree LED representative or from the Product
Ecology section of the Cree LED website.
Vision Advisory
WARNING: Do not look at an exposed lamp in operation. Eye injury can result.
CLD-CT1288
REV 6
6
KIT NUMBER SYSTEM
Cree LED lamps are tested and sorted into performance bins. A bin is specified by ranges of color, forward voltage, and brightness. Sorted
LEDs are packaged for shipping in various convenient options.
Cree LEDs are sold by order codes in combinations of bins called kits. Order codes are configured in the following manner:
CLD-CT1288
REV 6
7
REFLOW SOLDERING
• The CLM2C-RCA/ACA is rated as a MSL 5a product.
Document No.: COTCO-05-0057
Rev. NO. : 13
• The recommended floor life out of bag is 24hrs.
• The temperature profile is as below.
Temperature
Melting-point
Pre-heat
Soak
Reflow
Cooling
Time
Use all SMD besides LP6-NPP1-01-N1
Use only
with CLM2C-RCA/ACA
Solder
= Sn63-Pb37
Solder = Lead-free
Average ramp-up rate =Solder
4ºC/s max.
Average ramp-up rate = 4ºC/s max
Preheat temperature
= 100ºC
Average ramp-up
rate =~150ºC
4ºC/s max
Preheat temperature = 150ºC ~200ºC
Preheat time
= 100s
max. = 150ºC ~200ºC
Preheat
temperature
Preheat time = 100s max.
time
= 120s max
Ramp-down ratePreheat
= 6ºC/s
max.
Ramp-down rate = 6ºC/s max.
Peak temperature = 230ºC max.
Peak temperature = 250ºC max.
Peak temperature = 235ºC max
Time within 5ºC of actual Peak Temperature = 10s max.
Document
No.: CREE-05-0
= 10s max.
Duration above 183ºC is 80s max.
Duration above 217ºC is 80s max.
Duration above 217ºC is 45s max
Rev. NO.
16
pick up SMD products during the process of SMT production . If handling is necessary, it should tak
[13]
use LP6-NPP1-01-N1
• The Only
packaging
sizes of these SMD products are very small and the resin is still soft after solidification. Users are required to handle
careful to pick up these products. The following two methods are necessary :
withSolder
care. Never
touch
the resin surface of SMD products.
= Low
Lead-free
• To avoid
damaging
therate
product’s
surface
Average
ramp-up
= 3ºC/s
max. and interior device, it is recommended to choose a special nozzle to pick up the SMD
products during the process of SMT production. If handling is necessary, take special care when picking up these products. The
Preheat temperature = 130ºC ~170ºC
following method is necessary:
Preheat time = 120s max.
1a: Fordocument
Small Top
side
0.8mm SMD
• Please refer to the HB LED Lamp Soldering Fig.
& Handling
for SMD
information about how toFig.
use 1b:
this For
LED Mini
product
safely.
Peak temperature = 213ºC max.
Time within 3ºC of actual Peak Temperature = 25s max.
Duration above 200ºC is 40s max.
Recommended solder pad design for heat dissipation (2-pin SMD LED):
7.0
For Small Top SMD series , it is recommended to use rubber material Nozzle to pick up SMD produc
figure size for reference :
2.6
CLD-CT1288
REV 6
a.) Circular Nozzle: inner diameter: Ø1.8mm+/-0.05mm, outer diameter: Ø2.3mm+/-0.05mm.
8
PACKAGING
• The LEDs are packed in cardboard boxes after packaging in normal or anti-electrostatic bags.
• Cardboard boxes will be used to protect the LEDs from mechanical shock during transportation.
• The boxes are not water resistant, and they must be kept away from water and moisture.
• The reel pack is applied in SMD LED.
• Max 2300 pcs per reel.
CLD-CT1288
REV 6
9
很抱歉,暂时无法提供与“CLM2C-RCA-CWBZ0BB3”相匹配的价格&库存,您可以联系我们找货
