PRODUCT FAMILY DATA SHEET
CLM3C-RKW/AKW: PLCC2 1 IN 1 SMD LED
PRODUCT DESCRIPTION
FEATURES
APPLICATIONS
SMD LEDs is packaged in the industry
• Size (mm): 2.7 X 2.0
• Channel Letter
standard package. These LEDs have high
reliability performance and are
• Architectural Lighting
• Color and Typical Dominant
designed to work under a wide range of
Wavelength:
environmental conditions.
Red (624nm)
Amber (591nm)
This high reliability feature makes
them ideally suited to be used under
illumination application conditions.
• Luminous Intensity (mcd)
CLM3C-RKW:(560-1400)
CLM3C-AKW:(355-900)
Its wide viewing angle makes these
LEDs ideally suited for channel letter, or • Lead - Free
general backlighting and illumina-tion • RoHS Compliant
applications. The flat top emitting surface
makes it easy for these LEDs
to mate with light pipes.
Cree LED / 4400 Silicon Drive / Durham, NC 27703 USA / +1.919.313.5330 / www.cree-led.com
© 2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the
Cree LED logo is a trademark, of Cree, Inc.
CLD-CT1156
REV 9
1
ABSOLUTE MAXIMUM RATINGS (TA = 25°C)
Items
Symbol
Absolute Maximum Rating
Unit
Red/Amber
Forward Current
IF
50
mA
IFP
200
mA
Reverse Voltage
VR
5
V
Power Dissipation
PD
130
mW
Operation Temperature
Topr
-40 ~ +100
°C
Storage Temperature
Tstg
-40 ~ +100
°C
Junction Temperature
TJ
110
°C
Junction/Ambient
RTHJA
450
°C/W
Junction/Solder Point
RTHJS
300
°C/W
Electrostatic Discharge
Classification (MIL-STD-883E)
ESD
Peak Forward Current
Note1
Class 2
Note:
1.
Pulse width ≤0.1 msec, duty ≤1/10.
TYPICAL ELECTRICAL & OPTICAL CHARACTERISTICS (TA = 25°C)
Characteristics
Color
Symbol
Condition
Unit
Forward Voltage
RKW/AKW
VF
IF = 20 mA
V
Reverse Current
RKW/AKW
IR
VR = 5 V
μA
RKW
λD
IF = 20 mA
nm
618
624
630
AKW
λD
IF = 20 mA
nm
584
591
596
RKW
IV
IF = 20 mA
mcd
450
710
AKW
IV
IF = 20 mA
mcd
355
700
Dominant Wavelength
Luminous Intensity
Minimum
Typical
Maximum
2.1
2.6
10
Continuous reverse voltage can cause LED damage.
CLD-CT1156
REV 9
2
INTENSITY BIN LIMIT
Red(20 mA) - CLM3C-RKW
Amber (20 mA) - CLM3C-AKW
Bin Code
Min.(mcd)
Max.(mcd)
Bin Code
Min.(mcd)
Max.(mcd)
Ua
450
560
Tb
355
450
Ub
560
710
Ua
450
560
Va
710
900
Ub
560
710
Vb
900
1120
Va
710
900
Tolerance of measurement of luminous intensity is ±10%
COLOR BIN LIMIT
Red (20 mA) - CLM3C-RKW
Bin Code
Min.(nm)
Max.(nm)
Bin Code
Min.(nm)
Max.(nm)
RA
618
630
A2
584
587
A3
587
590
A4
590
593
A5
593
596
Tolerance of measurement of dominant wavelength is ±1 nm
CLD-CT1156
REV 9
3
ORDER CODE TABLE
Color
Kit Number
Red
Red
Color
Kit Number
Dominant Wavelength
Min.
Max.
Color Bin
Min. (nm)
Color Bin
Max. (nm)
CLM3C-RKW-CUaVbAA3
450
1120
RA
618
RA
630
CLM3C-RKW-CUbVaAA3
560
900
RA
618
RA
630
Dominant Wavelength
Min.
Max.
Color Bin
Min. (nm)
Color Bin
Max. (nm)
Amber
CLM3C-AKW-CTbVa253
355
900
A2
584
A5
596
Amber
CLM3C-AKW-CUbVa353
560
900
A3
587
A5
596
Notes:
The above kit numbers represent order codes that include multiple intensity-bin and color-bin codes. Only one intensity-bin code and one color-bin
code will be shipped on each bulk. Single intensity-bin code and single color-bin codes will not be orderable.
Please refer to the HB LED Lamp Reliability Test Standards document for reliability test conditions.
Please refer to the HB LED Lamp Soldering & Handling document for information about how to use this LED product safely.
CLD-CT1156
REV 9
4
GRAPHS
The data below are collected from statistical figures that do not necessarily correspond to the actual parameters of each single LED.
Hence, these data will be changed without further notice.
(RELATIVE LUMINOUS INTENSITY)
IF (mA)
100.0
5.0
80.0
4.0
Red
60.0
3.0
Red
Amber
40.0
2.0
Amber
20.0
1.0
0.0
1.8
VF(V)
2.0
2.2
2.6
2.4
2.8
-60
-50
-40
-30
-20
0.0
40
80
IF(mA)
100
FIG.2 RELATIVE LUMINOUS INTENSITY VS.
FORWARD CURRENT
FIG.1 FORWARD CURRENT VS.
FORWARD VOLTAGE.
Vr(V)
0.0
-10
100%
-10
80%
-20
60%
-30
40%
-40
20%
Amber
-50
Ir(uA)
FIG.3 RED&AMBER REVERSE CURRENT
VS. REVERSE VOLTAGE.
0%
300
400
500
Red
600
700
WL(nm)
800
FIG.4 RELATIVE LUMINOUS INTENSITY VS.
WAVELENGTH.
IF(mA)
1.0
100
80
60
Rth j-s=300 C/W
0.5
40
Rth j-a=450 C/W
60
80
Ta( C)
100
FIG.5 RED&AMBER MAXIMUM FORWARD DC CURRENT VS AMBIENT
TEMPERATURE (Tjmax=110 C)
Angle
-60
-30
60
90
FIG.6 FAR FIELD PATTERN
CLD-CT1156
REV 9
5
MECHANICAL DIMENSIONS
All dimensions are in mm.
NOTES
RoHS Compliance
The levels of RoHS restricted materials in this product are below the maximum concentration values (also referred to as the threshold
limits) permitted for such substances, or are used in an exempted application, in accordance with EU Directive 2011/65/EC (RoHS2), as
implemented January 2, 2013. RoHS Declarations for this product can be obtained from your Cree LED representative or from the Product
Ecology section of the Cree LED website.
Vision Advisory
WARNING: Do not look at an exposed lamp in operation. Eye injury can result.
CLD-CT1156
REV 9
6
KIT NUMBER SYSTEM
Cree LED lamps are tested and sorted into performance bins. A bin is specified by ranges of color, forward voltage, and brightness. Sorted
LEDs are packaged for shipping in various convenient options.
Cree LEDs are sold by order codes in combinations of bins called kits. Order codes are configured in the following manner:
CLD-CT1156
REV 9
7
REFLOW SOLDERING
• The CLM3C-RKW/AKW is rated as a MSL 5a product.
Document No.: COTCO-05-0057
Rev. NO. : 13
• The recommended floor life out of bag is 24hrs.
• The temperature profile is as below.
Temperature
Melting-point
Pre-heat
Soak
Reflow
Cooling
Time
Use all SMD besides LP6-NPP1-01-N1
Use only
with=CLM3C-RKW/AKW
Solder
Sn63-Pb37
Solder = Lead-free
Average ramp-up rate = 4ºC/s max.
Preheat temperature = 100ºC ~150ºC
Preheat temperature = 150ºC ~200ºC
Preheat time Preheat
= 100stemperature
max.
= 150ºC ~200ºC
Preheat time = 100s max.
Ramp-down rate =Preheat
6ºC/stime
max.
= 120s max
Ramp-down rate = 6ºC/s max.
Ramp-down
= 6ºC/s max
Peak temperature
= 230ºCrate
max.
Peak temperature = 250ºC max.
Solder
Time within
temperature
= 235ºC
max
5ºCPeak
of actual
Peak
Temperature
= 10s max.
Time within 5ºC of actual Peak Temperature = 10s max
Duration above 183ºC is 80s max.
Duration above 217ºC
is 45s
pick
up max
SMD
[13]
Document No.: CREE-05-0
Rev. NO. :
16
Time within 5ºC of actual Peak Temperature = 10s max.
Duration above 217ºC is 80s max.
products during the process of SMT production . If handling is necessary, it should ta
Only
use LP6-NPP1-01-N1
careful
to pick
Theis following
two solidification.
methods areUsers
necessary
• The
packaging
sizes of these SMD
products
are up
verythese
smallproducts.
and the resin
still soft after
are required
to handle
Solder
= Lowtouch
Lead-free
with
care. Never
the resin surface of SMD products.
• To Average
avoid damaging
product’s
ramp-upthe
rate
= 3ºC/ssurface
max. and interior device, it is recommended to choose a special nozzle to pick up the SMD
products
the process
of SMT
production. If handling is necessary, take special care when picking up these products. The
Preheatduring
temperature
= 130ºC
~170ºC
following method is necessary:
Preheat time = 120s max.
Fig. 1a: For Small Top SMD
Fig. 1b: For Mini side 0.8mm SMD
• Please refer to the HB LED Lamp Soldering & Handling document for information about how to use this LED product safely.
Peak temperature = 213ºC max.
Time within 3ºC of actual Peak Temperature = 25s max.
Duration above 200ºC is 40s max.
Recommended solder pad design for heat dissipation (2-pin SMD LED):
7.0 series , it is recommended to use rubber material Nozzle to pick up SMD produ
For Small Top SMD
figure size for reference :
2.6
CLD-CT1156
REV 9
a.) Circular Nozzle: inner diameter: Ø1.8mm+/-0.05mm, outer diameter: Ø2.3mm+/-0.05mm.
8
PACKAGING
• The LEDs are packed in cardboard boxes after packaging in normal or anti-electrostatic bags.
• Cardboard boxes will be used to protect the LEDs from mechanical shock during transportation.
• The boxes are not water resistant, and they must be kept away from water and moisture.
• The reel pack is applied in SMD LED.
• Max 3000 pcs per reel.
CARRIER TAPE
PACKAGE MARKING
4.0
3.3
2.25
T APE FEED DIRECTION
8.0
1.75
4.0
3.5
1.5
COVER TAPE
REEL(178x8mm)
Label
HUMIDITY INDICATOR
HUMICHECK
H UMIDITY IN DICA TOR
DAN GE RO US
DO N O T EAT
DESICCANT
Av oid
etal
Contact
w ww .v itapac.com
V102
Label
POLYETHYLENE BAG
Label
A CARTON
(240x220x35mm)
CLD-CT1156
REV 9
9
很抱歉,暂时无法提供与“CLM3C-AKW-CUAVB253”相匹配的价格&库存,您可以联系我们找货
