SLV6D-FKB-CK1N1E1BB7D3D3 数据手册
Cree® PLCC6 3 in 1 SMD LED
SLV6D-FKB
PRODUCT DESCRIPTION
FEATURES
These SMD LEDs are packaged in an
• Size (mm):5.5 x 5.5
industry standard PLCC6 package.
• Dominant Wavelength:
Red (619 - 624nm)
Green (520 - 540nm)
Blue (460 - 480nm)
These high performance tricolor SMT
LEDs are designed to work in a wide
range of applications. A wide viewing
full color applications.
• Luminous Intensity (mcd)
Red (560 - 1120)
Green (900- 1800)
Blue (180 - 450)
The encapsulation resin contains UV
• Moisture Sensitivity Level: 5a
angle and high brightness make
these LEDs suitable for various
inhibitors to minimize the effects of
long-term exposure to direct sunlight,
resulting in stable light output over
the life of the LED.
APPLICATIONS
• Decorative lighting
• Amusement
• Lead-Free
• RoHS Compliant
• Matte Surface
part is tested under the condition of assembling it on a PCB with isolating the electrical path by silicone.
The leads area of the LED is not IPx8 rated and it’s required to insulate for moisture by customer in outdoor
application.
WWW.CREE.COM/HB
*:This
Copyright © 2019 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree and
Copyright © 2010 Cree, Inc. All rights reserved. The information in this document is subject to change without notice.
the Cree logo are registered trademarks of Cree, Inc.
Cree, the Cree logo and XLamp are registered trademarks of Cree, Inc.
Cree, Inc.
4600 Silicon Drive
Durham, NC 27703
USA Tel: +1.919.313.5300
www.cree.com/xlamp
CLD-CT1314.004
PRODUCT FAMILY DATA SHEET
Cree PLCC6 3 in 1 SMD LED
SLV6D-FKB
ABSOLUTE MAXIMUM RATINGS (TA = 25°C)
Items
Symbol
Absolute Maximum Rating
Unit
R
G
B
IF
50
35
35
mA
IFP
200
100
100
mA
Reverse Voltage
VR
5
5
5
V
Power Dissipation
PD
125
126
133
mW
Operation Temperature
Topr
-40 ~ +100
°C
Storage Temperature
Tstg
-40 ~ +100
°C
Junction Temperature
TJ
110
110
110
°C
Junction/ambient 1 chip on
RTHJA
450
400
450
°C/W
Junction/ambient 3 chips on
RTHJA
650
580
680
°C/W
Junction/solder point 1 chip on
RTHJS
230
230
200
°C/W
Junction/solder point 3 chips on
RTHJS
230
230
200
°C/W
Electrostatic Discharge
Classification(MIL-STD-883E)
ESD
Forward Current
Note 1
Peak Forward Current
Note 2
1000 V
Note: 1.Single-color light.
2.Pulse width ≤0.1 msec, duty ≤1/10.
TYPICAL ELECTRICAL & OPTICAL CHARACTERISTICS (T A = 25°C)
Characteristics
Condition
Symbol
Dominant Wavelength
IF = 15 mA(R)
IF = 10 mA(G)
IF = 10 mA(B)
Spectral bandwidth at 50% IREL max
IF = 15 mA(R)
IF = 10 mA(G)
IF = 10 mA(B)
Forward Voltage
IF = 15 mA(R)
IF = 10 mA(G)
IF = 10 mA(B)
Luminous Intensity
Reverse Current (max)
Values
Unit
R
G
B
λDOM
619~624
520~540
460~480
nm
Δλ
24
38
28
nm
VF(avg)
2.0
2.8
3.0
V
VF(max)
2.5
3.6
3.8
V
IF = 15 mA(R)
IF = 10 mA(G)
IF = 10 mA(B)
IV(min)
560
900
180
mcd
IV(avg)
780
1200
280
mcd
VR = 5 V
IR
10
10
10
μA
Note: Continuous reverse voltage can cause LED damage.
Copyright © 2010 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree, the Cree logo and XLamp are registered trademarks
Copyright
© 2019 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree and the Cree logo are registered trademarks of Cree, Inc.
of Cree, Inc.
2
SLV6D-FKB
INTENSITY BIN LIMIT (RED IF = 15 mA, GREEN IF = 10 mA, BLUE IF = 10 mA)
Red
Green
Blue
Bin Code
Min.(mcd)
Max.(mcd)
Bin Code
Min.(mcd)
Max.(mcd)
Bin Code
Min.(mcd)
Max.(mcd)
K
560
710
N
900
1120
E
180
224
np
635
805
st
1010
1260
bc
202
252
M
710
900
P
1120
1400
F
224
280
qr
805
1010
vw
1260
1600
de
252
318
N
900
1120
Q
1400
1800
G
280
355
fg
318
403
H
355
450
Tolerance of measurement of luminous intensity is ±10%.
COLOR BIN LIMIT (RED I F = 15 mA, GREEN IF = 10 mA, BLUE IF = 10 mA)
Red
Green
Blue
Bin Code
Min.(nm)
Max.(nm)
Bin Code
Min.(nm)
Max.(nm)
Bin Code
Min.(nm)
Max.(nm)
RB
619
624
G7
520
525
B3
460
465
G23
522.5
527.5
B23
462.5
467.5
G8
525
530
B4
465
470
G45
527.5
532.5
B45
467.5
472.5
G9
530
535
B5
470
475
G67
532.5
537.5
B67
472.5
477.5
Ga
535
540
B6
475
480
Tolerance of measurement of dominant wavelength is ±1 nm.
Copyright
of Cree, Inc.
3
SLV6D-FKB
ORDER CODE TABLE*
Kit Number
SLV6D-FKB-CKNNQEHBB7a363
Color
SLV6D-FKB-CM1P1F1BB7D3D3
Package
Min.
Max.
Color
Bin
Min.
(nm)
Color Bin
Max.
(nm)
Red
560
1120
RB
619
RB
624
Reel
Green
900
1800
G7
520
Ga
540
Reel
180
450
B3
460
B6
480
Reel
RB
619
RB
624
Reel
Blue
Dominant Wavelength (nm)
Red
Any 1 Intensity bin from K(560) - N(1120)
Green
Any 1 Intensity bin from N(900) - Q(1800)
Any 1 hue bin from G7(520) - Ga(540)
Reel
Blue
Any 1 Intensity bin from E(180) - H(450)
Any 1 hue bin from B3(460) - B6(480)
Reel
Red
Any 1 Intensity bin from M(710) - N(1120)
Green
Blue
RB
619
RB
624
Reel
Any 1 Intensity bin from P(1120) - Q(1800)
Reel
Any 1 Intensity bin from F(224) - H(450)
Reel
Notes:
1. The above kit numbers represent the order codes which include multiple intensity-bin and color-bin codes. Only one
intensity-bin code and one color-bin code will be shipped on each reel. Single intensity-bin code and single color-
bin code will be orderable in certain quantities.
2. For example, any 1 intensity-bin from K - N means only 1 intensity-bin (K or np or M or qr or N) will be
shipped by Cree.
3. For example, any 1 color-bin from G7 - Ga means only 1 color-bin (G7 or G23 or G8 or G45 or G9 or G67 or Ga) will
be shipped by Cree.
4. Please refer to the “Cree LED Lamp Reliability Test Standards” document #1 for reliability test conditions.
5. Please refer to the “Cree LED Lamp Soldering & Handling” document #2 for information about how to use this LED
product safely.
#1: Refer to http://www.cree.com/led-components/media/documents/LED_Lamp_Reliability_Test_Standard.pdf
#2: Refer to http://www.cree.com/led-components/media/documents/sh-HB.pdf
Copyright
of Cree, Inc.
4
SLV6D-FKB
GRAPHS
The above data are collected from statistical figures that do not necessarily correspond to the actual
parameters of each single LED. Hence, these data will be changed without further notice.
Copyright
of Cree, Inc.
5
SLV6D-FKB
GRAPHS
Copyright
of Cree, Inc.
6
SLV6D-FKB
MECHANICAL DIMENSIONS
All dimensions are in mm.
NOTES
RoHS Compliance
The levels of RoHS-restricted materials in this product are below the maximum concentration values (also referred to
as the threshold limits) permitted for such substances, or are used in an exempted application in accordance with EU
Directive 2011/65/EC (RoHS2), as implemented by EU member states on January 2, 2013 and amended on March 31,
2015 by EU Directive 2015/863/EU.
RoHS Declarations for this product can be obtained from your Cree representative or from the Product Ecology section
of the Cree website.
Vision Advisory Claim
Users should be cautioned not to stare at the light of this LED product. The bright light can damage the eye.
Copyright
of Cree, Inc.
7
SLV6D-FKB
KIT NUMBER SYSTEM
Cree LED lamps are tested and sorted into performance bins. A bin is specified by ranges of color, forward voltage, and
brightness. Sorted LEDs are packaged for shipping in various convenient options. Please refer to the “Cree LED Lamp
Packaging Standard” document for more information about shipping and packaging options.
Cree LEDs are sold by order codes in combinations of bins called kits. Order codes are configured in the following manner:
Copyright
of Cree, Inc.
8
SLV6D-FKB
RELIABILITY
Tests and Results
Test
Applicable Standards
Test Condition
Note
Number of
Damaged
Temperature Cycle
JEITA ED-4701
100 105
-40°C~25°C~100°C~25°C
30 mins, 5 mins, 30 mins, 5 mins
100 cycles
0/45
Thermal Shock
MIL-STD-202G
-40°C~100°C
30 mins, 30 mins
100 cycles
0/45
Moisture Resistance
JEITA ED-4701
200 203
10 cycles
0/45
High Temperature Storage
JEITA ED-4701
200 201
TA=100°C
500 hrs
0/45
Temperature Humidity Storage
JEITA ED-4701
100 103
TA=60°C
RH=90%
500 hrs
0/45
Low Temperature Storage
JEITA ED-4701
200 202
TA=-40°C
500 hrs
0/45
High Temperature Life Test
TA=85°C
IF=15 mA
1000 hrs
0/45
Life Test
TA=25°C
IF: R=30mA G=35mA B=20mA
1000 hrs
0/45
High Humidity Heat Life Test
60°C RH=90%
IF=15 mA
500 hrs
0/45
Low Temperature Life Test
Ta=-40°C
500 hrs
0/45
Resistance to Soldering Heat(Reflow
Soldering)
JEITA ED-4701
300 301
Tsol=250°C,10sec
(Pre treatment 30°C,70%,168hrs)
2 times
0/45
Vibration-variable Frequency
MIL-STE-883
Method 2007
20G min, 20 to 2000Hz, 4cycles, 4mins,
Each x,y,z
0/45
Electrostatic Discharge Test
AEC(Q101-001)
Human body model 1000 V
(Forward and reverse current conduct
electricity each 1time)
0/45
25°C~65°C~
90%RH 24hrs/1cycle
Failure Criteria
Criteria for Judgment
Item
Symbol
Test
Condition
Min.
Max.
Forward Voltage
VF
IF = 20 mA
Initial Data x 1.1
Reverse Current
IR
VR = 5 V
10 μA
Luminous Flux/Intensity
ФV
IF = 20 mA
Initial Data x 0.7
Heat
IF = 20 mA
No dead lamps and visual damage
Vibration-variable
Frequency
IF = 20 mA
Copyright
of Cree, Inc.
9
SLV6D-FKB
REFLOW SOLDERING
The SLV6D-FKB is rated as a MSL 5a product.
The recommended floor life out of bag is 24hrs.
The temperature profile is as below:
Document No.: COTCO-05-0057
Rev. NO. : 13
Temperature
Melting-point
Pre-heat
Soak
Reflow
Cooling
Time
Use all SMD besides LP6-NPP1-01-N1
Use only
with
SLV6D-FKB
Solder
= Sn63-Pb37
Soldering
pad:
Solder
= Lead-free
Solder
Average ramp-up rate = 4ºC/s max.
Preheat temperature = 100ºC ~150ºC
2.7
Preheat temperature = 150ºC ~200ºC
Preheat time = 100s max.
Preheat time = 120s max
Peak temperature
230ºC
Peak temperature
= 250ºC=max
Ramp-down rate = 6ºC/s max.
max.
Time Time
within within
5ºC of actual
Temperature
= 10s max
5ºC ofPeak
actual
Peak Temperature
Duration
above 217ºC
60s max
Duration
aboveis183ºC
is 80s
Only use LP6-NPP1-01-N1
Peak temperature = 250ºC max.
= 10s max.
max.
Time within 5ºC of actual Peak Temperature = 10s max.
Duration above 217ºC is 80s max.
0.475
5.65
max.
1.7 1.3 1.7
Ramp-down
rate =max
6ºC/s
Ramp-down
rate = 6ºC/s
[13]
Solder = Low Lead-free
8.2
Average ramp-up rate = 3ºC/s max.
Preheat temperature = 130ºC ~170ºC
Preheat time = 120s max.
Peak temperature = 213ºC max.
Time within 3ºC of actual Peak Temperature = 25s max.
Duration above 200ºC is 40s max.
Recommended solder pad design for heat dissipation (2-pin SMD LED):
Refer to "http://www.cree.com/led-components/media/documents/sh-HB.pdf" for soldering & handling details.
7.0
Copyright
of Cree, Inc.
2.6
10
SLV6D-FKB
Document No.: CREE-05-005
Rev. NO. :
16
NOTES
pick up SMD products during the process of SMT production . If handling is necessary, it should take
careful
to pick
up these
The packaging sizes of these
SMD
products
areproducts. The following two methods are necessary
very small and the resin is still soft after solidification.
Users are
required to handle with care. Never touch the resin surface of SMD products.
To avoid damaging the product’s surface and interior device, it is recommended to choose a special nozzle to pick
up the SMD products during the process of SMT production. If handling is necessary, take special care when picking
up these products. The following method
necessary:
Fig. 1a:isFor
Small Top SMD
Fig. 1b: For Mini side 0.8mm SMD
For Small Top SMD series , it is recommended to use rubber material Nozzle to pick up SMD products
figure size for reference :
a.) Circular Nozzle: inner diameter: Ø1.8mm+/-0.05mm, outer diameter: Ø2.3mm+/-0.05mm.
b.) Rectangle Nozzle: inner size: 1.3mm x 2.3mm, outer size > SMD size.
6. Electrostatic Discharge and Surge current
Electrostatic discharge (ESD) or surge current (EOS) may damage SMD LED.
Precautions such as ESD wrist strap, ESD shoe strap or antistatic gloves must be worn whenever handling of S
All devices, equipment and machinery must be properly grounded.
It is recommended to perform electrical test to screen out ESD failures at final inspection.
It is important to eliminate the possibility of surge current during circuitry design
7. Heat Management
Heat management of SMD LED must be taken into consideration during the design stage of SMD LED applicatio
current should be de-rated appropriately by referring to the de-rating curve attached on each product specification.
Data is subject to change without prior notice.
Copyright
of Cree, Inc.
11
SLV6D-FKB
PACKAGING
The boxes are not water resistant and they must be kept away from water and moisture.
The LEDs are packed in cardboard boxes after packaging in normal or anti-electrostatic bags.
Cardboard boxes will be used to protect the LEDs from mechanical shocks during transportation.
The reel pack is applied in SMD LED.
Max 3000 pcs per reel.
Copyright
of Cree, Inc.
12
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Cree, Inc.:
SLV6D-FKB-CK1N1E1BB7D3D3 SLV6D-FKB-CKNNQEHBB7a363 SLV6D-FKB-CM1P1F1BB7D3D3
