7022X7
7022X7
    VCC
    LED YELLOW CLEAR 1206 SMD
7022X7 数据手册
engineered to light up your design www.vcclite.com 1.800.522.5546 7022X Series SMT LEDs 1206 Package Size Description and Features Surface Mount Technology • Tape and reel packaged for high-speed autoinsertion. • Convection and vapor-phase reflow compatible. • Compact form enables high density placement. • Packaged 2000 per reel. 3.20 C AT HODE MAR K LE D C HIP 1.60 Leading Edge LED Optoelectronic Performance • Consistent high brightness. 0.60 R 0.80 1.60 1.55 P LAS T IC 0.30 0.75 S UB S T R AT E Exceptional Reliability • Stringent process controls assure quality. • Extensive qualification testing to meet strictest requirements. • Designed to permit easy post-reflow solder joint inspection. • Refer to “Solder Pad Geometry 1.pdf” 0.50 0.50 ANODE P OLAR IT Y MAR K C AT HODE All dimensions in mm. Electro-Optical Characteristics and Ratings P AR T NUMB E R Output C olor Diffused/Non-Diffused P ackage C olor P ower Dissipation (mW) P eak F orward C urrent Max. (mA) R everse V oltage (V ) Operating temperature (°C ) S torage T emperature (°C ) F orward Voltage Typ. (IF =20mA) F orward Voltage Max. (IF =20mA) Lead S older Time @ 260°C (seconds) Luminous Intensity Min. (IF=20mA) Luminous Intensity Typ. (IF=20mA) P eak Wavelength (IF =20mA) R ated C urrent (mA) 7022X1 R ed Non-Diffused C lear 57.5 60 4 -40 to +85 -40 to +100 1.7 2.3 5 25.0 52.0 660 20 7022X3 Orange Non-Diffused C lear 70 60 4 -40 to +85 -40 to +100 2.2 2.8 5 10.0 25.0 605 20 7022X5 G reen Non-Diffused C lear 70 60 4 -40 to +85 -40 to +100 2.1 2.8 5 15.0 38.0 560 20 7022X7 Y ellow Non-Diffused C lear 70 60 4 -40 to +85 -40 to +100 2.2 2.8 5 10.0 30.0 580 20 CML and Chicago Miniature Lamp are registered trademarks of Visual Communications Company, LLC. 7022X11 R ed Non-Diffused C lear 70 60 4 -40 to +85 -40 to +100 2.0 2.8 5 10.0 22.0 630 20 7022X15 G reen Non-Diffused C lear 70 60 4 -40 to +85 -40 to +100 2.1 2.8 5 6.0 13.0 555 20
7022X7 价格&库存
很抱歉,暂时无法提供与“7022X7”相匹配的价格&库存,您可以联系我们找货
