SURFACE MOUNT ALUMINUM ELECTROLYTIC CAPACITORS
Bi-polarized, 105C
MVK-BP
@Bi-polarized chip type for the circuit, of which polarity is frequently reversed
@Solvent-proof type (see PRECAUTIONS AND GUIDELINES)
@Pb-free design
bi-polarized
MVK
?SPECIFICATIONS
Items
Characteristics
Category
Temperature Range
Rated Voltage Range
Capacitance Tolerance
Leakage Current
Dissipation Factor
(tane)
Low Temperature
Characteristics
(Max. Impedance Ratio)
Endurance
Shelf Life
-40 to +105C
6.3 to 50Vdc
P20% (M)
(at 20C, 120Hz)
I=0.05CV or 10MA, whichever is greater.
Where, I : Max. leakage current (MA), C : Nominal capacitance (MF), V : Rated voltage (V)
(at 20C after 2 minutes)
6.3V 10V 16V 25V 35V 50V
Rated voltage (Vdc)
0.35 0.26 0.24 0.20 0.18 0.18
tanE (Max.)
(at 20C, 120Hz)
Rated voltage (Vdc)
2
2
2
2
3
4
Z(-25C)/Z(+20C)
3
3
4
6
8
10
Z(-40C)/Z(+20C)
(at 120Hz)
The following specifications shall be satisfied when the capacitors are restored to 20C after the rated voltage is applied for 1000 hours
at 105C, however the polarization shall be reversed every 250 hours.
Capacitance change
[P30% of the initial value
D.F. (tanE)
[300% of the initial specified value
Leakage current
[The initial specified value
The following specifications shall be satisfied when the capacitors are restored to 20C after exposing them for 500 hours at 105C
without voltage applied.
Capacitance change
[P25% of the initial value
D.F. (tanE)
[200% of the initial specified value
Leakage current
?PART NUMBERING SYSTEM
?DIMENSIONS [mm]
1
3
4
5
6
7
8
9
10
BP0.2
W
AP0.2
LP0.3
L
5.7
5.7
5.7
A
4.3
5.3
6.6
12
13
14
15
16
?MARKING
17
18
B
4.3
5.3
6.6
C
5.1
5.9
7.2
W
0.5 to 0.8
0.5 to 0.8
0.5 to 0.8
EX) 35V4.7MF
Supplement code
Size code
Capacitance tolerance code
Capacitance code (ex. 4.7MF:4R7,10MF:100)
Taping code
Terminal code
Voltage code (ex. 6.3V:6R3,10V:100,50V:500)
Series code
Category
P
CP0.2
0.3max.
Size code D
4
D60
5
E60
6.3
F60
11
B MV K AAA A DA AAA M AAA G
@Terminal Code : A
FDP0.5
2
P
1.0
1.4
1.9
94K
4.7
35V
Please refer to "A guide to global code (surface mount type)"
?STANDARD RATINGS
WV
(Vdc)
6.3
10
16
25
35
Cap
(mF)
Size code
tane
Rated ripple
current
(mArms/
105c,120Hz)
10
22
47
6.8
15
33
4.7
10
22
3.3
6.8
15
2.2
4.7
10
D60
E60
F60
D60
E60
F60
D60
E60
F60
D60
E60
F60
D60
E60
F60
0.35
0.35
0.35
0.26
0.26
0.26
0.24
0.24
0.24
0.20
0.20
0.20
0.18
0.18
0.18
14
25
39
13
22
35
12
10
17
28
8.8
15
23
WV
(Vdc)
Part No.
BMVK6R3ADA100MD60G
BMVK6R3ADA220ME60G
BMVK6R3ADA470MF60G
BMVK100ADA6R8MD60G
BMVK100ADA150ME60G
BMVK100ADA330MF60G
BMVK160ADA4R7MD60G
BMVK160ADA100ME60G
BMVK160ADA220MF60G
BMVK250ADA3R3MD60G
BMVK250ADA6R8ME60G
BMVK250ADA150MF60G
BMVK350ADA2R2MD60G
BMVK350ADA4R7ME60G
BMVK350ADA100MF60G
50
(1/1)
Cap
(mF)
0.10
0.15
0.22
0.33
0.47
0.68
1.0
1.5
2.2
3.3
4.7
6.8
Size code
tane
Rated ripple
current
(mArms/
105c,120Hz)
D60
D60
D60
D60
D60
D60
D60
D60
E60
E60
F60
F60
0.18
0.18
0.18
0.18
0.18
0.18
0.18
0.18
0.18
0.18
0.18
0.18
1.3
1.9
2.3
2.8
3.4
4.1
5.5
7.5
10
13
16
Part No.
BMVK500ADAR10MD60G
BMVK500ADAR15MD60G
BMVK500ADAR22MD60G
BMVK500ADAR33MD60G
BMVK500ADAR47MD60G
BMVK500ADAR68MD60G
BMVK500ADA1R0MD60G
BMVK500ADA1R5MD60G
BMVK500ADA2R2ME60G
BMVK500ADA3R3ME60G
BMVK500ADA4R7MF60G
BMVK500ADA6R8MF60G
CAT. No. E1001E
很抱歉,暂时无法提供与“BMVK100ADA330MF60G”相匹配的价格&库存,您可以联系我们找货
