TP0610K-T1
www.VBsemi.tw
P-Channel 60 V (D-S) MOSFET
FEATURES
PRODUCT SUMMARY
VDS (V)
RDS(on) ()
VGS(th) (V)
ID (mA)
- 60
3 at VGS = - 10 V
- 1 to - 3
-500
• Halogen-free According to IEC 61249-2-21
Definition
• TrenchFET® Power MOSFET
• High-Side Switching
• Low On-Resistance: 3
• Low Threshold: - 2 V (typ.)
• Fast Swtiching Speed: 20 ns (typ.)
• Low Input Capacitance: 20 pF (typ.)
• Compliant to RoHS Directive 2002/95/EC
S
TO-236
(SOT-23)
G
G
1
3
S
D
2
D
P-Channel MOSFET
ABSOLUTE MAXIMUM RATINGS TA = 25 °C, unless otherwise noted
Parameter
Symbol
Limit
Drain-Source Voltage
VDS
- 60
Gate-Source Voltage
VGS
± 20
Continuous Drain Currenta
TA = 25 °C
TA = 100 °C
Pulsed Drain Currentb
Power Dissipationa
Maximum Junction-to-Ambienta
Operating Junction and Storage Temperature Range
Notes:
a. Surface mounted on FR4 board.
b. Pulse width limited by maximum junction temperature.
E-mail:China@VBsemi TEL:86-755-83251052
ID
IDM
TA = 25 °C
TA = 100 °C
PD
Unit
V
- 500
- 350
mA
-1500
460
240
mW
RthJA
350
°C/W
TJ, Tstg
- 55 to 150
°C
TP0610K-T1
www.VBsemi.tw
SPECIFICATIONS TA = 25 °C, unless otherwise noted
Limits
Parameter
Symbol
Test Conditions
Min.
VDS
VGS = 0 V, ID = - 10 µA
- 60
VGS(th)
VDS = VGS, ID = - 250 µA
-1
Typ.a
Max.
Unit
Static
Drain-Source Breakdown Voltage
Gate-Threshold Voltage
Gate-Body Leakage
Zero Gate Voltage Drain Current
On-State Drain Currenta
Drain-Source On-Resistancea
IGSS
IDSS
ID(on)
RDS(on)
-3
VDS = 0 V, VGS = ± 20 V
± 10
VDS = 0 V, VGS = ± 10 V
± 200
VDS = 0 V, VGS = ± 10 V, TJ = 85 °C
± 500
VDS = 0 V, VGS = ± 5 V
± 100
VDS = - 60 V, VGS = 0 V
- 25
VDS = - 60 V, VGS = 0 V, TJ = 85 °C
- 50
VGS = - 10 V, VDS = - 10 V
- 600
VGS = - 4.5 V, ID = - 25 mA
4
3
Diode Forward Voltage
VDS = - 10 V, ID = - 100 mA
VSD
IS = - 100 mA, VGS = 0 V
nA
mA
VGS = - 10 V, ID = - 100 mA
gfs
µA
- 250
VGS = - 10 V, VDS = - 4.5 V
VGS = - 10 V, ID = - 100 mA, TJ =125 °C
Forward Transconductancea
V
9
80
mS
- 1.4
V
Dynamic
Total Gate Charge
Qg
Gate-Source Charge
Qgs
Gate-Drain Charge
Qgd
Input Capacitance
Ciss
Output Capacitance
Coss
Reverse Transfer Capacitance
Crss
2.0
VDS = - 30 V, VGS = - 15 V
ID - 100 mA
1.2
VDS = - 25 V, VGS = 0 V
f = 1 MHz
10
nC
0.8
23
pF
5
Switchingb
Turn-On Time
td(on)
Turn-Off Time
td(off)
VDD = - 25 V, RL = 150
ID - 200 mA, VGEN = - 10 V, Rg = 10
ns
Notes:
a. Pulse test: PW 300 µs duty cycle 2 %.
b. Switching time is essentially independent of operating temperature.
Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation
of the device at these or any other conditions beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum
rating conditions for extended periods may affect device reliability.
TP0610K-T1
www.VBsemi.tw
TYPICAL CHARACTERISTICS 25 °C, unless otherwise noted
1.0
1200
VGS = 10 V
TJ = - 55 °C
5V
6V
I D - Drain Current (mA)
ID - Drain Current (A)
0.8
0.6
4V
0.4
3V
900
25 °C
125 °C
600
300
0.2
2V
0.0
2
3
4
5
VDS - Drain-to-Source Voltage (V)
4
6
8
10
VGS - Gate-to-Source Voltage (V)
Output Characteristics
Transfer Characteristics
40
15
VGS = 0 V
VGS = 4.5 V
32
C - Capacitance (pF)
RDS(on) - On-Resistance (Ω)
12
9
VGS = 5 V
6
VGS = 10 V
3
Ciss
24
16
Coss
8
Crss
400
600
800
5
ID - Drain Current (mA)
10
Capacitance
15
1.8
ID = 500 mA
1.5
12
VDS = 30 V
(Normalized)
25
V DS - Drain-to-Source Voltage (V)
On-Resistance vs. Drain Current
VDS = 48 V
9
6
3
15
VGS = 10 V at 500 mA
1.2
VGS = 4.5 V at 25 mA
0.9
0.6
0.3
0.3
0.6
0.9
1.2
Qg - Total Gate Charge (nC)
Gate Charge
1.5
1.8
0.0
- 50
- 25
50
75
100
125
TJ - Junction Temperature (°C)
On-Resistance vs. Junction Temperature
150
TP0610K-T1
www.VBsemi.tw
10
1000
I S - Source Current (A)
VGS = 0 V
100
TJ = 125 °C
10
TJ = 25 °C
8
ID = 500 mA
6
4
ID = 200 mA
2
TJ = - 55 °C
0.00
0.3
0.6
0.9
1.2
V SD - Source-to-Drain Voltage (V)
4
6
8
10
Source-Drain Diode Forward Voltage
On-Resistance vs. Gate-Source Voltage
0.5
3
0.4
2.5
ID = 250 µA
0.3
2
0.2
Power (W)
VGS(th) Variance (V)
2
0.1
1.5
- 0.0
1
TA = 25 °C
- 0.1
0.5
- 0.2
- 0.3
- 50
50
75
100
125
150
0.01
0.1
100
10
1
Time (s)
Threshold Voltage Variance Over Temperature
Single Pulse Power, Junction-to-Ambient
600
Normalized Effective Transient
Thermal Impedance
2
1
Duty Cycle = 0.5
0.2
Notes:
0.1
PDM
0.1
0.05
t1
t2
1. Duty Cycle, D =
t1
t2
2. Per Unit Base = RthJA = 350 °C/W
0.02
3. TJM - TA = PDMZthJA(t)
Single Pulse
4. Surface Mounted
0.01
10-4
10-3
10-2
10-1
1
Square Wave Pulse Duration (s)
10
Normalized Thermal Transient Impedance, Junction-to-Ambient
100
600
TP0610K-T1
www.VBsemi.tw
SOT-23 (TO-236): 3-LEAD
b
3
E1
1
E
2
e
S
e1
D
0.10 mm
C
0.004"
A2
A
C
q
Gauge Plane
Seating Plane
Seating Plane
C
A1
Dim
0.25 mm
L
L1
MILLIMETERS
INCHES
Min
Max
Min
Max
A
0.89
1.12
0.035
0.044
A1
0.01
0.10
0.0004
0.004
A2
0.88
1.02
0.0346
0.040
b
0.35
0.50
0.014
0.020
c
0.085
0.18
0.003
0.007
D
2.80
3.04
0.110
0.120
E
2.10
2.64
0.083
0.104
E1
1.20
1.40
0.047
e
0.95 BSC
e1
L
1.90 BSC
0.40
L1
q
ECN: S-03946-Rev. K, 09-Jul-01
DWG: 5479
0.0748 Ref
0.60
0.016
0.64 Ref
S
0.024
0.025 Ref
0.50 Ref
3°
0.055
0.0374 Ref
0.020 Ref
8°
3°
8°
TP0610K-T1
www.VBsemi.tw
0.053
(1.341)
0.097
(2.459)
Recommended Minimum Pads
Dimensions in Inches/(mm)
0.049
(0.559)
(1.245)
(0.950)
0.029
0.022
(0.724)
0.037
(2.692)
0.106
RECOMMENDED MINIMUM PADS FOR SOT-23
TP0610K-T1
www.VBsemi.tw
Disclaimer
All products due to improve reliability, function or design or for other reasons, product specifications and
data are subject to change without notice.
Taiwan VBsemi Electronics Co., Ltd., branches, agents, employees, and all persons acting on its or their
representatives ( collectively, the "Taiwan VBsemi"), assumes no responsibility for any errors, inaccuracies or
incomplete data contained in the table or any other any disclosure of any information related to
the product.(www.VBsemi.tw)
Taiwan VBsemi makes no guarantee, representation or warranty on the product for any particular purpose of
any goods or continuous production. To the maximum extent permitted by applicable law on Taiwan VBsemi
relinquished: ( 1) any application and all liability arising out of or use of any products; ( 2) any and all liability,
including but not limited to special, consequential damages or incidental ; ( 3) any and all implied warranties,
including a particular purpose, non-infringement and merchantability guarantee.
Statement on certain types of applications are based on knowledge of the product is often used in a typical
application of the general product VBsemi Taiwan demand that the Taiwan VBsemi of. Statement on whether the
product is suitable for a particular application is non-binding. It is the customer's responsibility to verify specific
product features in the products described in the specification is appropriate for use in a particular application.
Parameter data sheets and technical specifications can be provided may vary depending on the application and
performance over time. All operating parameters, including typical parameters must be made by customer's
technical experts validated for each customer application. Product specifications do not expand or modify Taiwan
VBsemi purchasing terms and conditions, including but not limited to warranty herein.
Unless expressly stated in writing, Taiwan VBsemi products are not intended for use in medical, life saving,
or life sustaining applications or any other application. Wherein VBsemi product failure could lead to personal
injury or death, use or sale of products used in Taiwan VBsemi such applications using client did not express their
own risk. Contact your authorized Taiwan VBsemi people who are related to product design applications and
other terms and conditions in writing.
The information provided in this document and the company's products without a license, express or implied,
by estoppel or otherwise, to any intellectual property rights granted to the VBsemi act or document. Product
names and trademarks referred to herein are trademarks of their respective representatives will be all.
Material Category Policy
Taiwan VBsemi Electronics Co., Ltd., hereby certify that all of the products are determined to be
R oHS compliant and meets the definition of restrictions under Directive of the European Parliament
2011/65 / EU, 2011 Nian. 6. 8 R i Yue restrict the use of certain hazardous substances in electrical and
electronic equipment (EEE) - modification, unless otherwise specified as inconsistent.(www.VBsemi.tw)
Please note that some documents may still refer to Taiwan VBsemi RoHS Directive 2002/95 / EC. We
confirm that all products identified as consistent with the Directive 2002/95 / EC European Directive
2011/65 /.
Taiwan VBsemi Electronics Co., Ltd. hereby certify that all of its products comply identified as
halogen-free halogen-free standards required by the JEDEC JS709A. Please note that some Taiwanese
VBsemi documents still refer to the definition of IEC 61249-2-21, and we are sure that all products
conform to confirm compliance with IEC 61249-2-21 standard level JS709A.
