PJM10H03NSC
N-Channel Enhancement Mode Power MOSFET
Features
SOT-23-3
VDS = 100V,ID = 3A
RDS(ON) < 160mΩ(Typ.) @ VGS = 10V
RDS(ON) < 170mΩ(Typ.) @ VGS = 4.5V
High density cell design for ultra low RDS(on)
Excellent package for good heat dissipation
2
3
1
1. Gate
2.Source
3.Drain
Marking: 0103C
Applications
Power switching application
Uninterruptible power supply
Schematic diagram
3Drain
1
Gate
2 Source
Absolute Maximum Ratings
Ratings at 25℃ ambient temperature unless otherwise specified.
Symbol
Limit
Unit
Drain-Source Voltage
VDS
100
V
Gate-Source Voltage
VGS
±20
V
Drain Current-Continuous
ID
3
A
Drain Current-Pulsed Note1
IDM
30
A
Maximum Power Dissipation
PD
1.5
W
TJ,TSTG
150,-55 to 150
RθJA
83
℃/W
Parameter
Operating Junction and Storage Temperature Range
Thermal Characteristics
Thermal Resistance,Junction-to-Ambient
www.pingjingsemi.com
Revision:1.0 Feb-2019
Note2
1/7
PJM10H03NSC
Electrical Characteristics
(TA=25℃ unless otherwise noted)
Symbol
Condition
Min
Typ
Max
Unit
Drain-Source Breakdown Voltage
V(BR)DSS
VGS=0V ID=250μA
100
V
Zero Gate Voltage Drain Current
IDSS
VDS=100V,VGS=0V
1
μA
Gate-Body Leakage Current
IGSS
VGS=±20V,VDS=0V
±100
nA
VGS(th)
VDS=VGS,ID=250μA
1
1.5
2.0
V
VGS=10V, ID=3A
136
160
VGS=4.5V, ID=3A
140
170
VDS=5V,ID=3A
5
S
650
pF
24
pF
pF
6
nS
4
nS
nS
4
nS
nC
2.1
nC
3.3
nC
1.2
V
3
A
Parameter
Static Characteristics
Gate Threshold
Voltage Note3
Drain-Source On-State Resistance Note3
Forward Transconductance Note3
RDS(ON)
gFS
mΩ
Dynamic Characteristics
Input Capacitance
Ciss
Output Capacitance
Coss
Reverse Transfer Capacitance
Crss
VDS=50V,VGS=0V,
f=1.0MHz
Switching Characteristics
Turn-on Delay Time
td(on)
Turn-on Rise Time
tr
Turn-Off Delay Time
td(off)
Turn-Off Fall Time
tf
Total Gate Charge
Qg
Gate-Source Charge
Qgs
Gate-Drain Charge
Qgd
VDD=50V,RL=19Ω,
VGS=10V RG=3Ω
VDS=50V,ID=3A,
VGS=10V
Drain-Source Diode Characteristics
Diode Forward Voltage Note3
VSD
Diode Forward Current Note2
IS
VGS=0V, IS=3A
Notes:
1.
2.
3.
Repetitive Rating: Pulse width limited by maximum junction temperature.
Surface Mounted on FR4 Board, t ≤ 10 sec.
Pulse Test: Pulse Width ≤ 300μs, Duty Cycle ≤ 2%.
2/7
PJM10H03NSC
ID- Drain Current (A)
Normalized On-Resistance
Typical Characteristics Curves
TJ-Junction Temperature(℃)
Vds Drain-Source Voltage (V)
Figure 4 Rdson-JunctionTemperature
Vgs Gate-Source Voltage (V)
Figure 1 Output Characteristics
Qg Gate Charge (nC)
Figure 2 Transfer Characteristics
Figure 5 Gate Charge
Is- Reverse Drain Current (A)
Rdson On-Resistance(Ω)
Figure 3 Rdson- Drain Current
Vsd Source-Drain Voltage (V)
Figure 6 Source- Drain Diode Forward
3/7
C Capacitance (nF)
PJM10H03NSC
Figure 7 Capacitance vs Vds
Figure 9 BVDSS vs Junction Temperature
Power Dissipation (w)
Figure 8 Safe Operation Area
Figure 10 Power De-rating
r(t),Normalized Effective
Transient Thermal Impedance
Square Wave Pluse Duration(sec)
Figure 11 Normalized Maximum Transient Thermal Impedance
4/7
PJM10H03NSC
Package Outline
SOT-23-3
Dimensions in mm
2.8
1.6
10
12
0.95
0.35
0.127± 0.03
± 0.01
A
±0.1
±0.05
2.92 ± 0.05
R0.15MAX
`4X
R0.15MAX
`4X
1.26MAX
0.06
12
± 0.05
± 0.03
0.65
1.1
± 0.05
10
Ordering Information
Device
Package
Shipping
PJM10H03NSC
SOT-23-3
3000PCS/Reel&Tape
5/7
PJM10H03NSC
Conditions of Soldering And Storage
Recommended condition of reflow soldering
Figure
Recommended peak temperature is over 245 ℃. If peak temperature is below 245 ℃, you may adjust
the following parameters:
Time length of peak temperature (longer)
Time length of soldering (longer)
Thickness of solder paste (thicker)
Conditions of hand soldering
Temperature: 370 ℃
Time: 3s max.
Times: one time
Storage conditions
Temperature
5 to 40 ℃
Humidity
30 to 80% RH
Recommended period
One year after manufacturing
6/7
PJM10H03NSC
Package Specifications
Cover Tape
3,000 pcs per reel
SOT-23-3
Carrier Tape
30,000 pcs per box
10 reels per box
240
217
43
5
120,000 pcs per carton
4 boxes per carton
455
220
2. Tape and reel data(7inch Units:mm)
D
A
3000
T2
T1
2900
2000
1900
1000
600
B
C
E
PS
F
1.10±0.10
Pin1
N
3.2±0.10(Bo)
8 MAX
0.75
1.40±0.10(Ko)
B-B
Tape (8mm)
0.46
0.2
8 MAX
B
4.00±0.10
0.25±0.02(T)
2.45
1.55±0.05
3.50±0.05
2.00±0.05
8 ± 0 .1 0
4.00±0.10
B
1.75±0.10
Reel (7'')
Symbol
A
B
C
E
F
D
T1
T2
N
G
Value (unit: mm)
Ø 177.8±1
2.7±0.2
Ø 13.5±0.2
Ø 54.5±0.2
12.3±0.3
9.6+2/-0.3
1.0±0.2
1.2±0.2
3.15±0.1
1.22±0.1
7/7
很抱歉,暂时无法提供与“PJM10H03NSC”相匹配的价格&库存,您可以联系我们找货
