REVISION AO
DO NOT
SCALE FROM
THIS PRINT
TFC-1XX-XX-XX-D-XX
NOTES:
1. C REPRESENTS A CRITICAL DIMENSION.
2. MINIMUM CONTACT RETENTION: 12 OZS.
3. MINIMUM LOCKING CLIP RETENTION: 8 OZS.
No OF POSITIONS
4. MAXIMUM HEIGHT VARIATION BETWEEN ANY TWO PINS: .005[0.13].
LEAD STYLE -01, -02: -02 THRU -50 (ALL
5. MAXIMUM TERMINAL BURR: .003[0.08].
POSITIONS AVAILABLE)
6. COPLANARITY: .004[0.10] = POS 02 THRU 26
LEAD STYLES -11, -12: (-05 THRU -50 MULTIPLES OF 5)
.006[0.15] = POS 27 THRU 50. C
POSITIONS -12, -16, -17 ALSO AVAILABLE
7. MEASURED FROM BEND.
LEAD STYLES -21, -22: (-05 THRU -50 MULTIPLES OF 5)
8. MEASURE FROM TIPS OF PIN.
POSITIONS -12 & -13 ALSO AVAILABLE
9. SIDES OF PLASTIC BODIES ON ALL LEAD STYLES EXCEPT THE -01 & -02
LEAD STYLES -31, -32: (-05 THRU -50 MULTIPLES OF 5)
WILL BE SOLID AND WITHOUT SIDE SLOTS.
-12 POSITION ALSO AVAILABLE
10. THIS FEATURE ONLY PRESENT ON -01 & -02 LEAD STYLES.
11. DUE TO THE HIGH AMOUNT OF INSERTION FORCE NEEDED,
THE –LC OPTION IS NOT COMPATIBLE WITH AUTO PLACEMENT. SAMTEC
RECOMMENDS MANUAL PLACEMENT FOR ALL ASSEMBLIES WITH THE
LEAD STYLE
–LC OPTION.
THROUGH HOLE
SURFACE MOUNT
12. NOTE DELETED.
-01 (SEE FIG 1)
-02 (SEE FIG 2, SHT 2)
13. NOT ALL PARTS FOLLOW EIA-481 ORIENTATION IN THE T&R POCKET.
-11
(SEE
FIG
1)
-12
(SEE FIG 2, SHT 2)
14. -TR OPTION ORDERS INVOLVING PARTIAL REEL QUANTITIES MAY BE PACKAGED ACCORDING
-21 (SEE FIG 1)
-22 (SEE FIG 2, SHT 2)
TO THE SAMTEC PACKAGING EFFICIENCY STANDARDS (SPES) FOUND ON WWW.SAMTEC.COM.
-31 (SEE FIG 1)
-32 (SEE FIG 2, SHT 2)
15. -FR OPTIONS WILL BE SHIPPED AT THE MAX QUANTITY PER REEL, BASED ON OPTIONS SELECTED.
OPTION
-A: ALIGNMENT PIN (USE TFM-XX-D-XX-A,
SEE TABLE 1, SHT 3) (SEE FIG 5, SHT 3)
(NOT AVAILABLE WITH -RA)
-LC: LOCKING CLIP (USE LC-05-TM)
(SEE FIG 6, SHT 3, NOTE 3 & 11)
-P: PICK AND PLACE PAD (USE PPP-04)
(AVAILABLE IN ALL POSITIONS -05 THRU -50)
(SEE FIG 7, SHT 3)
-RA: RIGHT ANGLE
(AVAILABLE ONLY IN LEAD STYLE: -01)
(SEE FIG 8, SHT 2)
-TR: TAPE AND REEL (SEE FIG 4, SHT 4)
(FOR -X2 ONLY)
(SEE NOTE 13 & 14)
-K: POLYIMIDE FILM (SEE FIG 3, SHT 2)
(SEE TABLE 1, SHT 3)
(ALL LEAD STYLES EXCEPT -21 AVAILABLE)
(NOT AVAILABLE FOR -RA)
(USE K-DOT-.217-.313-.005)
-FR: FULL REEL QTY. TAPE & REEL
(FOR -X2 ONLY)
(SEE NOTE 13 & 15)
(No. OF POSITIONS x .050[1.27]) + .125[3.18] REF
(No. OF POSITIONS x .050[1.27]) + .025[.64] REF
PLATING SPECIFICATION
-F: 3µ" FLASH GOLD ON CONTACT AREA,
MATTE TIN TAIL
-L: 15µ" SELECTIVE GOLD ON CONTACT AREA,
MATTE TIN TAIL
-LM: 15µ" SELECTIVE GOLD ON CONTACT AREA,
MATTE TIN TAIL
-FM: 3µ" FLASH GOLD ON CONTACT AREA,
MATTE TIN TAIL
.110 2.79 REF
02
.155 3.94
REF
01
.050 1.27
REF
.135 3.43 REF
.075 1.91 REF
BODY SPECIFICATION
-D: DOUBLE ROW
.225 5.72
REF
SEE NOTE 10
C
(No. OF POSITIONS x .050[1.27]) - .050[1.27]
.050 1.27
.018 0.46 REF
2 MAX SWAY
(EITHER DIRECTION)
"A"
2 MAX SWAY
(EITHER DIRECTION)
"D" REF
(SEE TABLE 1,
SHT 3)
"A" REF
(SEE TABLE 1,
SHT 3)
SEE NOTE 9
C
"A"
.014 0.36 REF
2 MAX SWAY
(EITHER DIRECTION)
.096 2.44
.1635 4.153
REF
.010 0.25 REF
"F"±.003[0.08]
2 MAX SWAY
(EITHER DIRECTION)
.050 1.27
C
SECTION "A"-"A"
C
C
"C"±.003[0.08]
FIG 1
THROUGH HOLE
-01, -11, -21, -31
UNLESS OTHERWISE SPECIFIED,
DIMENSIONS ARE IN INCHES.
TOLERANCES ARE:
DECIMALS
ANGLES
.XX: .01 [.3]
2
.XXX: .005 [.13]
.XXXX: .0020 [.051]
MATERIAL:
IN-PROCESS
C
PROPRIETARY NOTE
THIS DOCUMENT CONTAINS CONFIDENTIAL AND
PROPRIETARY INFORMATION AND ALL DESIGN,
MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS
AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC,
INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE
OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR
REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY
OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS
WRITTEN CONSENT OF SAMTEC, INC.
DO NOT SCALE DRAWING
SHEET SCALE: 2.5:1
INSULATOR:
LCP, UL 94-V0
COLOR: BLACK
TERMINAL: PHOSPHOR BRONZE
F:\dwg\sw\exisprod\assembly\050\TFC-1XX-XX-XX-D-XX-ASM.SLDDRW
520 PARK EAST BLVD, NEW ALBANY, IN 47150
PHONE: 812-944-6733
FAX: 812-948-5047
e-Mail info@SAMTEC.com
code 55322
DESCRIPTION:
DWG. NO.
.050 X .050 TERMINAL STRIP
TFC-1XX-XX-XX-D-XX
BY: BRATCHER 05/25/2001
SHEET 1 OF 4
REVISION AO
NOTE: "R" = OVERALL LENGTH (REF)
"S" = {("R" - .216[5.49] /2} ±.020[.51]
"J"±.006[0.15]
"B"
C
C
3
SEE NOTE 9
"B"
C
01 03
.005±.020 0.11±0.508
.216 5.49
2
"E"
(SEE TABLE 1,
SHT 3)
SEE NOTE 6
FLUSH TO .012 [0.30] MAX
(SEE NOTE 7)
7 (-12, -22 & -32 STYLES)
3 (-02 STYLE ONLY)
C
3 MAX SWAY
(EITHER DIRECTION)
.235 5.97 MAX
"S"
(SEE NOTE)
SEE NOTE 10
"R"
(SEE NOTE)
SECTION "B"-"B"
"E"
(SEE TABLE 1,
SHT 3)
02
SEE NOTE 10
(No. OF POSITIONS x .050) -.050[1.27]
(TOL ACCUM ±.005[0.13] OVER 50 POS)
FIG 2
SURFACE MOUNT
-02, -12, -22, -32
DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1
NOTCH TO BE
ORIENTED AS SHOWN
"C"
02
01
"A" REF
(SEE TABLE 1,
SHT 3)
FIG 3
-K: POLYIMIDE FILM PAD
TERMINAL 2
TERMINAL 1
.075 1.91 REF
.014 0.36
REF (TYP)
"C"
2 MAX SWAY
(EITHER DIRECTION)
C
C
.020 0.51
(SEE NOTE 8)
90°
C
.050 1.27
(SEE NOTE 8)
C
FIG 8
SECTION "C"-"C"
-RA OPTION
TERMINAL 2
(SEE TABLE 1,
SHT 3)
.422 10.72
"A" REF
(SEE TABLE 1,
SHT 3)
.422 10.72
TERMINAL 2
(SEE TABLE 1,
SHT 3)
TERMINAL 1
(SEE TABLE 1,
SHT 3)
.075 1.91 REF
CARRIER STRIP
TERMINAL 1
I.D. MARK
C
IN-PROCESS 1
(ORIENT I.D. MARK AS SHOWN)
(FOR -RA OPTION ONLY)
90°
.020 0.51
C
IN-PROCESS 2
PROPRIETARY NOTE
SHEET SCALE: 2:1
PHONE: 812-944-6733
FAX: 812-948-5047
code 55322
DESCRIPTION:
DWG. NO.
TFC-1XX-XX-XX-D-XX
SHEET 2 OF 4
REVISION AO
"M"
(SEE NOTE)
"P"
(SEE NOTE)
C
.045 1.14
REF
(No. OF POSITIONS x .050[1.27]) + .075[1.91]
.050 1.27
REF
R.025 [0.64] REF
.394 10.01
REF
.050 1.27
*PPP-04
FIG 5
-A OPTION
.225 5.72
REF
"E"
CL
.050 1.27
C
CL
"E"
SECTION "E"-"E"
LC-05-TM
2 MAX SWAY
(EITHER DIRECTION)
.010 0.25 REF
NOTE: "M" = (No. OF POS X .050[1.27]) + .125[3.18] (REF)
"P" = {(“M” - .394[10.01]) /2} ±.020[.51]
.056 1.42 REF
2 MAX SWAY
(EITHER DIRECTION)
((No. OF POSITIONS x .050[1.27]) + .075[1.91])±.002[0.05]
FIG 6
* NOTCH ON PAD TO BE ON SAME END
AS THE NOTCH IN THE TFM BODY
-LC OPTION
(NOT AVAILBLE ON -RA)
FIG 7
-P OPTION
(PAD TO BE POSITIONED ON CL AS SHOWN)
PROPRIETARY NOTE
SHEET SCALE: 2:1
PHONE: 812-944-6733
FAX: 812-948-5047
code 55322
DESCRIPTION:
DWG. NO.
TFC-1XX-XX-XX-D-XX
SHEET 3 OF 4
REVISION AO
ROUND HOLES
LOADING DIRECTION ARROW
PART NOTCH
POLARIZATION NOTCH
PT-1-24-18-09
(SEE TABLE 2)
OBLONG HOLES
FIG 9
USER DIRECTION OF UN-REELING
POCKET NOT DETAILED
PT-1-24-XX-09
FIG 4
-TR: TAPE AND REEL
(SEE NOTE 13)
POLARIZATION NOTCH
PT-1-24-05-17
(SEE TABLE 2)
FIG 10
PT-1-24-05-17
POLARIZATION NOTCH
NOTE:
PARTS TO BE PACKAGED WITH THE LOADING DIRECTION ARROW
POINTED IN SAME DIRECTION AS THE ARROW ON TUBE.
PT-FTSH002-DV-A-P-M
(SEE TABLE 2)
PROPRIETARY NOTE
FIG 11
PT-FTSH002-DV-A-P-M
SHEET SCALE: 2:1
PHONE: 812-944-6733
FAX: 812-948-5047
code 55322
DESCRIPTION:
DWG. NO.
TFC-1XX-XX-XX-D-XX
SHEET 4 OF 4
