SPECIFICATION
Product Name
VARIABLE RESISTOR
Model No.
VG039NCHXT
Control No.
412
Date
January 9, 2007
HOKURIKU ELECTRIC INDUSTRY CO., LTD.
COMPONENTS DIVISION
ELECTRO-MECHANICAL COMPONENT FACTORY
SALES DEPARTMENT
Sales
Representative
Approved
Drawn
N.Kurata
Checked
M.Kanagawa
Checked
H.Takabayashi
Approved
T.Nakayama
The contents of this specification may change without prior notice. For inquiries, please refer
to product name, model No., and control No. written in the cover sheet of this specification.
Because this specification is for reference only, for your actual use of this part please
acknowledge and sign the formal specification for this part.
1. Scope
This specification applies to 3 mm Chip trimmer potentiometer with Metal - Glaze - Resistor, used in
electronic equipment.
2. Construction
②
(Dimensions and Materials) and
Rating
2.1. Dimension
See attached Drawing.
2.2. Materiales
See attached Material List
2.3. Operating Temperature Range
-40 ℃∼+100 ℃
2.4. Storage Temperature Range
-10 ℃∼+40 ℃
2.5. Nominal Total Resistance Range
100 Ω ∼ 1 MΩ
(1・2・3・5 series , see attached Application List)
2.6. Total Resistance Tolerance
±25 %
2.7. Power Rating
0.1 5 W (∼+70 ℃)
Power rating vs. ambient temperature shall be
denoted on the following chart.
100
80
Power Rating
ratio (%) 60
40
60
80
100
Ambient Temperature (℃)
2.8. Rated Voltage
Rated Voltage
E=√P・R
Where
P : Power Rating (W)
R : Nominal Total Resistance (Ω)
When the rated voltage exceeds the maximum
operating voltage, the maximum operating voltage
shall be the rated voltage.
2.9. Maximum Operating Voltage
③
②
①
50 V
Review Item 2.4, 3.3.2
2006.11.11 H.Takabayashi
Add Item 5.4 and review Item 5.
2006.8.2 H.Takabayashi
DRAWN
N.Kurata
Oct./11/’06
DATE
DATE
CHECKED
APPROVALS
H.Takabayashi
M.Urayama
Oct./11/’06
Oct./11/’06
DATE
DATE
Oct. ,11, 2006
⑥
⑤
④
TITLE
VARIABLE RESISTOR
HDK
TYPE
VG039NCH
HDK. DWG. NO.
HOKURIKU ELECTRIC
INDUSTRY CO.,LTD.
W-6522
REV.
B
1
7
3. Characteristics
Standard atmospheric conditions
Unless otherwise specified, the standard range of atmospheric conditions for
making measurements and tests is as follows :
Ambient temperature : 5 ℃ to 35 ℃
Relative humidity
: 45 % to 85 %
Air pressure
: 860 hPa to 1 060 hPa
If there is any doubt about the results, measurements shall be made within
the following limits :
Ambient temperature : 20 ℃±2 ℃
Relative humidity
: 60 % to 70 %
Air pressure
3.1. Mechanical characteristics
Item
Conditions
Specifications
1
Total Mechanical
Rotation
270 °±20 °
2
Rotational Torque
0.98 mN・m ∼
11.76 mN・m
3
End Stop
Strength
The following torsion moment of 14.7 mN・m shall
be applied to the spindle for 5 seconds in any
direction.
Without distinct
looseness or poor
contact.
4
Soldering
Strength
A static load shown in this figure shall be
applied to terminals for 30 s after soldering.
Without distinct
looseness or poor
contact.
Solder
9.8 N
9.8 N
4.9 N
5
Push Load
A push load of 9.8 N shall be applied to the
axial direction for 30 seconds from upper part of
the product.
③
②
①
Without distinct
looseness or poor
contact.
Without board
breaking.
⑥
⑤
④
DRAWN
N.Kurata
DATE Oct./11/’06
CHECKED
APPROVALS
H.Takabayashi
M.Urayama
DATE Oct./11/’06 DATE Oct./11/’06
TITLE
VARIABLE RESISTOR
DATE
Oct. ,11, 2006
HDK
TYPE
VG039NCH
HDK. DWG. NO.
HOKURIKU ELECTRIC
INDUSTRY CO.,LTD.
W-6522
REV.
B
2
7
3. Characteristics
3.2. Electrical characteristics
Item
1
2
3
4
Resistance Law
(Taper)
Ineffective
Rotation
Residual
Resistance
Contact
Resistance
Conditions
Output voltage ratio at the middle of total
rotational angle.
40 %∼60 %
( Linear taper )
Ineffective rotation is the sum of all rotational
distances in which resistance does not change
and is calculated as a percentage of the
total mechanical rotation.
Total nominal
The resistances at each
resistance
end of the mechanical
1 kΩ or less
rotation between terminals
Total nominal
1 and 2, or 2 and 3
resistance
more than 1 kΩ
shall be measured.
10 % or less
of total mechanical
rotation, at each end.
The moving contact shall be rotated to a
point where the resistance between terminals 1
and 2 is half of the total resistance.
Contact resistance shall be calculated by the
following formula :
(R12+R23)−R13
Where
Temperature
Coefficient
(T. C. R.)
20 Ω
or less
2 % or less
of total nominal
resistance.
5 % or less
of nominal total
resistance.
×100(%)
2×R13
5
Specifications
R12 : Resistance between
R23 : Resistance between
R13 : Resistance between
terminals
terminals
terminals
1
2
1
and
and
and
2
3
3
The trimmer potentiometer shall be maintained
in a thermostatic chamber at a temperature,
according to the table as shown below.
Step
Temperature(℃)
Initial
+25±2
1
-40±3
2
+25±2
3
+100±3
Within ±250 ppm/
The mesurement shall be made, after the
thermostatic chamber achieved the mark
temperature and maintained for 30 min ∼ 45min.
③
②
①
⑥
⑤
④
DRAWN
N.Kurata
Oct./11/’06
DATE
DATE
CHECKED
APPROVALS
H.Takabayashi
M.Urayama
Oct./11/’06
Oct./11/’06
DATE
DATE
Oct. ,11, 2006
TITLE
VARIABLE RESISTOR
HDK
TYPE
VG039NCH
HDK. DWG. NO.
HOKURIKU ELECTRIC
INDUSTRY CO.,LTD.
W-6522
REV.
B
3
7
3.3. Endurance characteristics
When the items in ★mark, the moving contact shall be rotated to a point
where the resistance between 1 and 2 is half of the total resistance.
Item
②
Conditions
Specifications
1
Vibration
The entire frequency range, from 10 Hz to 55
Hz and return to 10 Hz, shall be transversed
in 1 min.
Amplitude (total excursion) : 1.5 mm
This motion shall be applied for a period of
2 h in each of 3 mutually perpendicular
directions.
(a total of 6 h)
Change in resistance
between 1 and 2 is
relative to the value
before test .
Within ±5 %
Without an instant
open during the test.
2
Resistance to
Soldering Heat
Re-flow soldering method
Peak temperature : Within 260 ℃ 10 s
Application time : more than 230 ℃, Within 40 s
Within ±2 % of initial
resistance.
Soldering iron method
Tip temperature : 400 ℃±10 ℃
Application time of soldering iron : 3 s +1 s /−0 s.
3
High
Temperature
Storage
The trimmer potentiometer shall be subjected in
a thermostatic chamber at a temperature of
70 ℃±2 ℃ without electrical load for 1 000 h±
12 h. Then the trimmer potentiometer shall be
taken out from the chamber and maintained at
standard atmospheric conditions for 1 h ∼ 2 h,
after which measurements shall be made.
Change in total
resistance is relative
to the value before
test.
Within ±5 %
4
Load Life
70 ℃±2 ℃ with a DC rated voltage for
1.5 h between terminals 1 and 3 followed by
a pause of 30 min for 1 000 h±12 h.
Then the trimmer potentiometer shall be taken
without electrical load, after which measurements
shall be made.
Change in total
to the value before
test.
Within ±5 %
5
Temperature
Cycle
a thermostatic chamber at 5 successive change
of temperature cycles, each as shown in table
below.
Change in total
to the value before
test.
Within ±2 %
Without distinct
looseness or poor
contact.
Step
Temperature
1
2
−40 ℃±3 ℃
3
4
100 ℃±2 ℃
Duration
③
②
①
30 min
10 min to
15 min
30 min
10 min to
15 min
⑥
⑤
④
DRAWN
N.Kurata
Oct./11/’06
DATE
DATE
CHECKED
H.Takabayashi
Oct./11/’06
DATE
Oct. ,11, 2006
APPROVALS
M.Urayama
Oct./11/’06
DATE
TITLE
VARIABLE RESISTOR
HDK
TYPE
VG039NCH
HDK. DWG. NO.
HOKURIKU ELECTRIC
INDUSTRY CO.,LTD.
W-6522
REV.
B
4
7
Item
Conditions
Specifications
6
Humidity
The trimmer potentiometer shall be subjected in a
thermostatic chamber at a temperature of 40 ℃±
2 ℃ with relative humidity of 90% to 95% without
electrical load for 1 000 h±12 h.
Then the trimmer potentiometer shall be taken out
from the chamber and its surface moisture shall
be removed.
And then the trimmer potentiometer shall be
maintained at standard atmospheric conditions for
1 h ∼ 2 h, after which measurement shall be
made.
Change in total
to the value before
test.
Within ±5 %
7
Humidity
Load Life
2 ℃ and a relative humidity of 90 % to 95 %
with a DC rated voltage for 1.5 hours between
terminals 1 and 3 followed by a pause of 30
minutes for 1 000 h±12 h.
be removed.
1 h ∼ 2 h without electrical load, after wihch
measurement shall be made.
Change in total
to the value before
test.
Within ±5 %
8
Rotational
Life
The moving contact shall be rotated without
electrical load for 20 cycles±2 cycles at a rate of
10 min-1.
(A cycle of operation is defined as the travel of
the moving contact from one end of the
resistance element to the other and back through
90 % of the total mechanical rotation .)
Change in total
to the value before
test.
Within ±10 %
4.
Marking
Nominal total resistance ・・・・・ First number shows significant figures and the other
shows quantity of zero.
ex.
1 kΩ ・・・・ 13
10 kΩ ・・・・ 14
100 kΩ ・・・・ 15
Significant
figures
Quantity
of zero
13 (1 kΩ)
③
②
①
⑥
⑤
④
DRAWN
N.Kurata
Oct./11/’06
DATE
DATE
CHECKED
APPROVALS
H.Takabayashi
M.Urayama
Oct./11/’06
Oct./11/’06
DATE
DATE
Oct. ,11, 2006
TITLE
VARIABLE RESISTOR
HDK
TYPE
VG039NCH
HDK. DWG. NO.
HOKURIKU ELECTRIC
INDUSTRY CO.,LTD.
W-6522
REV.
B
5
7
①
5.
The
others
5.1. Preset Position
The moving contact set half position of total rotation angle (50 %±15 % of
total rotation angle) on delivery.
5.2. Application Notes
・ The soldering for this product should be reflow soldering. Please note that this product is not
applicable to flow soldering.
・ Be careful with flying flux in soldering.
・ If flux was stuck on the resistance, please wash it out thoroughly by alcoholic solvent.
・ Handle the trimmer potentiometer with care.
・ This product is not what meant the use to affect the human body life which needs advanced
safety and reliability, and the use of nuclear relation, and carried out design manufacture.
・ Please refer to EIAJ RCR-2191A "notes guideline(safe application guide of a potentiometer) of
the potentiometer for electric devices" about notes on other use.
・ In a case where there is a wiring pattern right under this product after mounting.
Please be sure to do some insuration measures on the pattern with a resist or some other
materials.
5.3. The wish matter of the consideration to the safety of a product
Although we are exerting our best effects to maintain the quality of this product, we cannot
guarantee that they will never cause short circuiting and open circuitry.
Therefore, when designing an equipment or device with which the priority is given to the safety, you
will please carefully study the influences to the whole equipment of a single function failure of
potentiometer in advance to make out a fail-safe design providing.
5.4. Industrial Proprietorship
If the trouble on industrial proprietorship (related on delivered product s design
and production) happens, we solves it on own responsibility.
5.5. Nation of products
CHINA
③
②
①
⑥
⑤
④
DRAWN
N.Kurata
Oct./11/’06
DATE
DATE
CHECKED
H.Takabayashi
Oct./11/’06
DATE
Oct. ,11, 2006
APPROVALS
M.Urayama
Oct./11/’06
DATE
TITLE
VARIABLE RESISTOR
HDK
TYPE
VG039NCH
HDK. DWG. NO.
HOKURIKU ELECTRIC
INDUSTRY CO.,LTD.
W-6522
REV.
B
6
7
6. Taping Specification
6.1.
6.2.
6.3.
6.4.
6.5.
Dimension ................................................
Taping direction .......................................
Peeling strength of cover tape.................
Taping method.........................................
Taping quantity ........................................
Dwg. No.F-362.022
Dwg. No.F-362.022
0.1 N∼0.7 N
Fig.1
2 500 pcs./reel
and Fig.2
Leading position
150 mm min.
Vacant position
100 mm min.
Non sealing
20 mm min.
Chip component
Vacant position
100 mm min.
Fig.1
Feed direction
Fig2
③
②
①
⑥
⑤
④
DRAWN
N.Kurata
Oct./11/’06
DATE
DATE
CHECKED
H.Takabayashi
Oct./11/’06
DATE
Oct. ,11, 2006
APPROVALS
M.Urayama
Oct./11/’06
DATE
TITLE
VARIABLE RESISTOR
HDK
TYPE
VG039NCH
HDK. DWG. NO.
HOKURIKU ELECTRIC
INDUSTRY CO.,LTD.
W-6522
REV.
B
7
7
①
⑤
⑦
②
⑧
③
⑥
④
No.
PART NAME
部品名
BASE MATERIAL
材 質
1
BOARD
基 板
CERAMIC Al2O3
セラミック (アルミナ)
2
RESISTOR
抵抗体
METAL GLAZE COATING
メタルグレーズ皮膜
3
ELECTRODE
電 極
AgPd
銀パラジウム
4
1st, 3rd TERMINAL
1番, 3番 端 子
STEEL
鋼 板
⑥
⑤
④
③
②
①
UNDER PLATING Ni : 0.5∼2 μm
下地メッキ
下地メッキ
STEEL
鋼 板
6
TERMINAL JOINT
端子接合部
SOLDER (Sn-3Ag-0.5Cu)
鉛フリー半田
7
MOVING CONTACT
摺動子
STAINLESS STEEL
ステンレス
8
SEALING RESIN
封止樹脂
ACRYL
アクリル系
2007.1.9
2006.12.21
訂正日/Date
浦山
M. Urayama
作成日 / Original Date
2006/8/26
高林
高林
訂 正 理 由 / Reason of Correction
高林
H. Takabayashi
写図/Drawn
②
SURFACE PLATING Sn : 2 μm ∼ 4 μm
表面メッキ
下地メッキ厚変更 Correction Under Plating Thickness
No.8 部品名変更 Correction Part Name No.8
承認/Approved 検図/Checked 設計/Designed
②
表面メッキ
2nd TERMINAL
2番 端 子
5
①
PLATING
処 理
訂正者/Corrector
記 事 / Account
文書名 / Title
種別 / HDK TYPE
版/Rev.
使用材料表 / Material List
VG039NCH
B
仕様書番号 / DWG.NO.
SHEET
北陸電気工業 株式会社
FF No. 3026A
W-6502
1/1
適 用 品 一 覧 表 /Apprication
List
(適用外形寸法図/Drawing : F-362.021,F-362.022 )
残留抵抗値/Residual Resistance
Rev.
公称全抵抗値
B100 Ω
B200 Ω
B220 Ω
B300 Ω
B330 Ω
B470 Ω
B500 Ω
B680 Ω
B1 kΩ
B2 kΩ
B2.2 kΩ
B3 kΩ
B3.3 kΩ
B4.7 kΩ
B5 kΩ
B6.8 kΩ
B10 kΩ
B20 kΩ
B22 kΩ
B30 kΩ
B33 kΩ
B47 kΩ
B50 kΩ
B68 kΩ
B100 kΩ
B200 kΩ
B220 kΩ
B300 kΩ
B330 kΩ
B470 kΩ
B500 kΩ
B680 kΩ
B1 MΩ
抵抗値
許容差
1-2 間
2-3 間
Between
Between
Tolerance
Terminal #1& #2 Terminal #2& #3
±25 %
品 番
Part Number
20 Ωmax 20 Ωmax
40 Ωmax
44 Ωmax
60 Ωmax
66 Ωmax
94 Ωmax
100 Ωmax
136 Ωmax
200 Ωmax
400 Ωmax
440 Ωmax
600 Ωmax
660 Ωmax
940 Ωmax
1 kΩmax
40 Ωmax
44 Ωmax
60 Ωmax
66 Ωmax
94 Ωmax
100 Ωmax
136 Ωmax
200 Ωmax
400 Ωmax
440 Ωmax
600 Ωmax
660 Ωmax
940 Ωmax
1 kΩmax
1.36 kΩmax 1.36 kΩmax
2
4
4.4
6
6.6
9.4
10
kΩmax
kΩmax
kΩmax
kΩmax
kΩmax
kΩmax
kΩmax
2 kΩmax
4 kΩmax
4.4 kΩmax
6 kΩmax
6.6 kΩmax
9.4 kΩmax
10 kΩmax
13.6 kΩmax 13.6 kΩmax
20 kΩmax 20 kΩmax
備 考
Remark
VG039NCHXT B101
B201
B221
B301
B331
B471
B501
B681
B102
B202
B222
B302
B332
B472
B502
B682
B103
B203
B223
B303
B333
B473
B503
B683
B104
B204
B224
B304
B334
B474
B504
B684
B105
⑥
⑤
④
③
②
①
写図/Drawn
文書名 / Title
訂正日/Date
浦山
M. Urayama
作成日 / Original Date
2006/8/28
高林
H. Takabayashi
製品規格 / Variable resistor
北陸電気工業 株式会社
FF No. 3026A
記 事 / Account
種別 / HDK TYPE
版/Rev.
VG039NCHXT
仕様書番号 / DWG.NO.
W-6500
SHEET
1/1
4
3
Φ3.6
D
1
2
摺動子回転範囲
Wiper Rotating Area
1.2
3
2.1
D
1.5
0.75
裏面樹脂封止
TERM.2
3.8
( 1 )
0.5
1.75
Resin
C
0.95
2
C
0.8
TERM.3
0.65
TERM.1
2.7
B
B
推奨ランドパターン寸法 (10/1)
回路図
PATTERN APPLICATION EXAMPLE (Scale 10/1)
CIRCUIT
C.W.
TERM.1
A
TERM.3
③
②
①
訂正箇所
TERM.2
訂
REVISION PLACE REVISION DATE
図法/ DRAWING 単位/ UNIT
第三角法
TRIGONOMETRY
1.2
1.2
訂正年月日
尺度/ SCALE
mm
REASON
訂正者
由
REVISION BY
処理/ DISPOSAL
材料/ MATERIAL
一般公差
0.8 1.2
3
A
種別・型名/ MODEL NAME
20/1
VG039NCH
H.Takabayashi
Aug.-28-'06
4
理
承認/APPROVED BY 検図/ CHECKED BY 設計/ DESIGNED BY 写図/ TRACED BY 図名/ DESCRIPTION
M.Urayama
1.2
正
記事/ REMARK
1.5
0.7
1.6
Aug.-28-'06
± 0.3 mm
GENERAL TOLERANCE
作成年月日
DRAWING DATE Aug./28/ '06
2
外観図 Drawing
北 陸 電 気 工 業 株 式 会 社
HOKURIKU ELECTRIC INDUSTRY CO.,LTD.
FF No.4006B
半固定可変抵抗器
Variable Resistor
図番/ DRAWING No.
版/ REV.
F-362.021
1
3
4±0.1
D
4±0.1
φ1.55±0.05
1
数量:2500 個/リール
1.7
D
QUANTITY:2500 pcs/REEL
0.25
4±0.1
C
4±0.1
4±0.1
3.5±0.05
(2.75)
5.5
8
2±0.1
2
1.75±0.1
4
0.07
11.4±1
C
φ60 -0/+1
φ13
0.2
5.
0±
0±
φ180 -3/+0
4.
0.2
9±1
B
2
B
3.0±0.2
尺度 SCALE 1/2
A
③
②
①
A
訂 正
検図 CHECKED
承認 APPROVED
浦山 M.Urayama
DATE Aug.-28-'06 DATE
一般公差
GENERAL TOLERANCE
0.3
R E V I S I O N S
設計 DESIGNED 単位:UNIT 尺度 SCALE
高林 H.Takabayashi
mm 5
1
DATE Aug.-28-'06
タイトル TITLE
テーピングリール
TAPING REEL
北陸電気工業株式会社
種別/HDK TYPE
VG039NCHXT
HDK 図面番号 DWG No.
F-362.022
版 REV.
4
3
nner
i
e
h
to t
n
i
el
e re
h
t
Put
D
①
PART No.
HDK TYPE VG039NCHXT
②
VALUE
ohms
QUANTITY ③ 2500pcs ④RoHS
⑤
DATE
⑥
Lot.No.
HOLKURIKU ELECTRIC
INDUSTRY CO.,LTD.
PART No.
HDK TYPE VG039NCHXT
VALUE
ohms
QUANTITY 2500pcs RoHS
DATE
Lot.No.
HOLKURIKU ELECTRIC
INDUSTRY CO.,LTD.
Label
(The pasting place of the label
shall be per the above drawing)
Inner box A
(A max.of 2 reels)
1
box.
(2 500 pcs)
C
2
Inner box B
(A max.of 6 reels)
Type name, Resistance value and
quantity are filled in.
Note 4.
Outer
Outer
Outer
Outer
Outer
B
①PART No. : Per customer's directions
②VALUE : Indication of the resistance value
(Ex. 100)
③QUANTITY : Label for the reel
④LEADLESS SOLDER : "RoHS"
⑤Date : Indication of taping date(Ex. 02.4.18)
⑥Lot.No. : Indication of HDK manufacturing
lot No.(Ex. Q-16-5-1)
Packaging Specification
box
box
box
box
box
a
b
c
d
e
D
C
Number of the reels put in
A max of 2 reels
A max of 6 reels
Inner box A
Inner box B
Inner box
Label description
Number of the reels
put in
A max of 6 reels
A max of 12 reels
A max of 24 reels
A max of 48 reels
A max of 30 reels
Total Quantity of the products
5 000 pcs. max.
15 000 pcs. max.
Total Quantity
of the products
15 000 pcs.max.
30 000 pcs.max.
60 000 pcs.max.
120 000 pcs.max.
75 000 pcs.max.
Size (W*L*H)
(Unit : mm)
290*210*90
505*210*90
400*220*180
400*220*330
390*210*225
B
Note 1- Glue the label on the reel (The gluing position is per the drawing.)
Note 2- Cushion material is to be put in to fill the empty space when the number of the
reels in an inner box does not reach 2 or 6 respectively.
Put the inner box
into the outer box.
Note 3- Cushion material is to be put in to fill the empty space when the total quantity
in the outer box does not reach 15 000 , 30 000 , 60 000, 75 000, or 120 000 pcs. respectively.
Note 4- Type name, resistance value and quantity shall be written on a inner box.
Example : VG039NCHXT
B 1 k ohm
15 000
③
②
①
A
H
W
A
DRAWN
CHECKED
N.Kurata
DATE Oct.11,2006 DATE
L
4
Outer box
TOLERANCE UNLESS
OTHERWISE SPECIFIED
3
REVISIONS
TITLE
UNIT
SCALE
H.Takabayashi
mm
5 1 VARIABLE RESISTOR
Oct.11,2006
APPROVED
DATE
2
HDK
VG039NCHXT
HDK DWG No.
R-2832
1
TYPE
REV.
