BAT54/A/C/S
Surface Mount Schottky Barrier Diode
SOT-23
0.020(0.51)
0.015(0.37)
Features
Low turn-on voltage
Fast switching
PN junction guard ring for transient and ESD
protection
0.055(1.40)
0.047(1.19)
0.080(2.05)
0.070(1.78)
0.024(0.61)
0.018(0.45)
Mechanical Data
0.098(2.50)
0.083(2.10)
0.041(1.05)
0.047(0.89)
0.120(3.05)
0.104(2.65)
Case: SOT-23, Molded plastic
Terminals: Solderable per MIIL-STD-202,
Method 208
0.043(1.10)
0.035(0.89)
0.006(0.15)
0.001(0.013)
0.024(0.61)
0.018(0.45)
0.007(0.178)
0.003(0.076)
Dimensions in inches and (millimeters)
BAT54
Maximum Ratings
Type Number
BAT54A
BAT54C
BAT54S
T A =25℃ unless otherwise specified
Peak Repetitive Reverse Voltage
Working Peak Reverse Voltage
DC Blocking Voltage
Repetitive Peak Forward Current
@ t=1.0s
Power Dissipation (Note 1)
Thermal Resistance Junction to Ambient Air
Operating and Storage Temperature Range
Electrical Characteristics
Type Number
Reverse Breakdown Voltage (Note 1)
Reverse Leakage Current (Note 1) VR=25V
Forward Voltage (Note 1)
Value
Units
V RRM
V RWM
VR
30
V
200
300
600
200
500
-65 to + 125
mA
mA
mA
mW
O
C /W
O
C
IF
IFM
Forward Continuous Current
Forward Surge Current
Symbol
IF=0.1mA
IF=1.0mA
IF= 10mA
IF = 30mA
IF=100mA
IFSM
Pd
R θJA
T J, T STG
Symbol
V (BR)R
IR
Min
30
Typ
Max
VF
2.0
240
320
400
500
1000
10
5.0
Units
V
uA
mV
Cj
pF
trr
nS
Notes: 1. Short Duration Pulse Test used to Minimize Self-Heating Effect.
2. Reverse Recovery Test Conditions: IF=10mA through IR=10mA to IR=1.0mA,
R L=100Ω.
Junction Capacitance
VR=0, f=1.0MHz
Reverse Recovery Time (Note 2)
www.slkormicro.com
1
BAT54/A/C/S
RATINGS AND CHARACTERISTIC CURVES (BAT54 / A / C / S)
FIG.1- POWER DERATING CURVE
FIG.2- TYPICAL FORWARD CHARACTERISTICS
50
75
100
1000
IR, LEAKAGE CURRENT ( A)
VR =25V
100
10
1
50
100
150
Tj, JUNCTION TEMPERATURE ( C)
www.slkormicro.com
C
C
+2
5
TJ
10
TJ
C
5
200
300
400
500
600
Tj, INSTANTANEOUS FORWARD VOLTAGE (mV)
FIG.3- TYPICAL REVERSE CHARACTERISTICS
TJ = -25 C
1
0.1
125
TA, AMBIENT TEMPERATURE ( C)
0.1
10
12
100
100
200
TJ
INSTANTANEOUS FORWARD CURRENT (mA)
PD, POWER DISSIPATION (mW)
1000
2
很抱歉,暂时无法提供与“BAT54C”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.05180
- 200+0.04799
- 600+0.04418
- 3000+0.04037
