Datasheet
AS1361/AS1362
150mA/300mA, Ultra-Low-Noise, High-PSRR
Low Dropout Regulators, with POK
1 General Description
2 Key Features
The AS1361/AS1362 are ultra-low-noise, low-dropout
linear regulators specifically designed to deliver up to
150/300mA continuous output current, and can achieve
a low 140mV dropout for 300mA load current. The LDOs
are designed and optimized to work with low-cost, smallcapacitance ceramic capacitors.
The devices are available as the standard products
listed in Table 1.
Table 1. Standard Products
Preset Output Voltages: 1.5 to 4.5V (in 50mV steps)
Output Noise: 9µVRMS @ 100Hz to 100kHz
Power-Supply Rejection Ratio: 92dB @ 1kHz
Low Dropout: 140mV @ 300mA Load
Power-OK Output
Stable with 1µF Ceramic Capacitor for any Load
Model
Load Current
Output Voltage
Guaranteed 150/300mA Output
AS1361
150mA
Preset – 1.5 to 4.5V
1.25V Internal Reference
AS1362
300mA
Extremely-Low Quiescent Current: 40µA
An integrated P-channel MOSFET pass transistor allows
the devices to maintain extremely low quiescent current
(40µA).
Excellent Load/Line Transient
Overcurrent and Thermal Protection
The AS1361/AS1362 uses an advanced architecture to
achieve ultra-low output voltage noise of 9µVRMS and a
power-supply rejection-ratio of better than 80dB (up to
10kHz).
TSOT23 6-pin Package
3 Applications
The devices are ideal for mobile phones, wireless
phones, PDAs, handheld computers, mobile phone
base stations, Bluetooth portable radios and accessories, wireless LANs, digital cameras, personal audio
devices, and any other portable, battery-powered application.
An active-Low, open-drain power-ok output indicates if
the output voltage is within regulation.
The AS1361/AS1362 requires only 1µF output capacitor
for stability at any load. When the LDO is disabled, current consumption drops below 500nA.
The devices are available in a TSOT23 6-pin package.
Figure 1. Typical Application Circuit
Input
2 to 5.5V
OUT
IN
CIN
1µF
On
Off
Output
1.5 to 4.5V
6
1
IN 1
6 OUT
100kΩ
3
SHDNN
AS1361/
AS1362
2
GND
www.austriamicrosystems.com
4
GND 2
POK
5
BYPASS
CBYPASS
10nF
SHDNN 3
AS1361/
AS1362
5 BYPASS
4 POK
COUT
1µF
Revision 1.03
1 - 15
AS1361/AS1362
Datasheet - P i n o u t
4 Pinout
Pin Assignments
Figure 2. Pin Assignments (Top View)
IN 1
GND 2
6 OUT
AS1361/
AS1362
SHDNN 3
5 BYPASS
4 POK
TSOT23 6-pin
Pin Descriptions
Table 2. Pin Descriptions
Pin Number
Pin Name
1
IN
2
GND
3
SHDNN
Description
Unregulated Input Supply.
Ground
Shutdown. Pull this pin low to disable the LDO.
Power-OK Output. Active-Low, open-drain output indicates if the output
0 = VOUT 94% VOUTNOM
4
POK
5
BYPASS
Noise Bypass for Low-Noise Operation. Connect a 10nF capacitor from
this pin to OUT.
Note: This pin is shorted to GND in shutdown mode.
6
OUT
Regulated Output Voltage. Bypass this pin with a capacitor to GND. See
Capacitor Selection and Regulator Stability on page 12 for more details.
Revision 1.03
2 - 15
AS1361/AS1362
Datasheet - A b s o l u t e M a x i m u m R a t i n g s
5 Absolute Maximum Ratings
Stresses beyond those listed in Table 3 may cause permanent damage to the device. These are stress ratings only,
and functional operation of the device at these or any other conditions beyond those indicated in Electrical Characteristics on page 4 is not implied. Exposure to absolute maximum rating conditions for extended periods may affect
device reliability.
Table 3. Absolute Maximum Ratings
Parameter
Min
Max
Units
IN to GND
-0.3
+7
V
OUT, SHDNN, POK to GND
-0.3
IN +
0.3
V
BYPASS to GND
-0.3
OUT +
0.3
V
Output Short-Circuit Duration
Infinite
Thermal Resistance ΘJA
201.7
ºC/W
+85
ºC
Operating Temperature Range
-40
Junction Temperature
Storage Temperature Range
Package Body Temperature
-65
+150
ºC
+150
ºC
+260
ºC
Revision 1.03
Comments
on PCB
The reflow peak soldering temperature (body
temperature) specified is in accordance with
IPC/JEDEC J-STD-020D “Moisture/Reflow
Sensitivity Classification for Non-Hermetic Solid
State Surface Mount Devices”.
The lead finish for Pb-free leaded packages is
matte tin (100% Sn).
3 - 15
AS1361/AS1362
Datasheet - E l e c t r i c a l C h a r a c t e r i s t i c s
6 Electrical Characteristics
VIN = VOUT +0.5V, CIN = 1µF, COUT = 1µF, CBYPASS = 10nF, TAMB = -40 to +85ºC (unless otherwise specified). Typ values are at TAMB = +25ºC. Limits 100% tested at +25ºC. Limits over operating temperature range guaranteed by design.
Table 4. Electrical Characteristics
Symbol
Parameter
VIN
Input Voltage Range
Condition
Output Voltage Accuracy
IOUT
Maximum Output Current
ILIMIT
Current Limit
Dropout Voltage
1
Min
Max
Unit
2
Typ
5.5
V
IOUT = 1mA, TAMB = +25ºC
-0.5
+0.5
IOUT = 100µA to 150mA, TAMB = +25ºC
(AS1361)
-0.75
+0.75
IOUT = 100µA to 300mA, TAMB = +25ºC
(AS1362)
-1.0
+1.0
IOUT = 100µA to 150mA, (AS1361)
-1.5
+1.5
IOUT = 100µA to 300mA, (AS1362)
-2.0
+2.0
AS1361
150
AS1362
300
mA
AS1361, OUT = 90% of nom., TAMB = +25ºC
270
AS1362, OUT = 90% of nom., TAMB = +25ºC
510
VOUT ≥ 3V, IOUT = 150mA
70
95
VOUT ≥ 3V, IOUT = 300mA, AS1362
140
200
2.5V ≤ VOUT < 3V, IOUT = 150mA
90
120
2.5V ≤ VOUT < 3V, IOUT = 300mA, AS1362
170
230
2.0V ≤ VOUT < 2.5V, IOUT = 150mA
140
190
2.0V ≤ VOUT < 2.5V, IOUT = 300mA, AS1362
270
350
mA
mV
IOUT = 0.05mA
40
90
VIN = VOUTNOM - 0.1V, IOUT = 0mA
150
250
Line Regulation
VIN = (VOUT +0.5V) to 5.5V, IOUT = 0.1mA
0.02
%/V
VLDR
Load Regulation
IOUT = 1 to 150/300mA
0.0005
%/mA
ISHDNN
Shutdown Supply Current
IQ
Quiescent Current
VLNR
PSRR
Ripple Rejection
Output Noise Voltage (RMS)
SHDNN = 0V
9
f = 1kHz, IOUT = 10mA
92
f = 10kHz, IOUT = 10mA
80
f = 100kHz, IOUT = 10mA
62
f = 100Hz to 100kHz,
ILOAD = 0 to 150/300mA
9
500
µA
nA
dB
µV
Shutdown
2
RLOAD = 50Ω
300
µs
SHDNN Logic Low Level
VIN = 2 to 5.5V
0.4
V
SHDNN Logic High Level
VIN = 2 to 5.5V
1.5
IOUT = 0, VOUTRISING
90
Shutdown Exit Delay
V
Power-OK Output
VPOK
VOL
Power-OK Voltage Threshold
Hysteresis, IOUT = 0
94
98
1.5
VOUT
POK Output Voltage Low
ISINK = 1mA
0.3
V
POK Output Leakage Current
VOUT in regulation
1
µA
Revision 1.03
4 - 15
AS1361/AS1362
Table 4. Electrical Characteristics (Continued)
Symbol
Parameter
Condition
Min
Typ
Max
Unit
Thermal Protection
TSHDNM
ΔTSHDN
M
Thermal Shutdown
Temperature
160
ºC
Thermal Shutdown
Hysteresis
15
ºC
1. Dropout is defined as VIN - VOUT when VOUT is 100mV below the value of VOUT for VIN = VOUT + 0.5V.
2. Time needed for VOUT to reach 90% of final value.
Note: All limits are guaranteed. The parameters with min and max values are guaranteed with production tests or
SQC (Statistical Quality Control) methods.
Revision 1.03
5 - 15
AS1361/AS1362
Datasheet - Ty p i c a l O p e r a t i n g C h a r a c t e r i s t i c s
7 Typical Operating Characteristics
VIN = VOUT + 0.5V, CIN = COUT = 1µF, CBYPASS = 10nF, TAMB = 25°C (unless otherwise specified).
Figure 3. Output Voltage vs. Input Voltage
Figure 4. Output Voltage Accuracy vs. Load Current
3.5
0.5
0.4
Output Voltage Deviation (%)
Output Voltage (V) .
3
IOUT = 150mA
2.5
IOUT = 300mA
2
1.5
1
0.5
0.2
0.1
Temp = -45°C
Temp = 25°C
-0.2
Temp = 85°C
-0.3
-0.4
-0.5
2
3
4
5
6
Input Voltage (V)
100
150
200
250
300
Load Current (mA)
Figure 5. Output Voltage Accuracy vs. Temperature
Figure 6. Dropout Voltage vs. Load Current
1
140
Dropout Voltage (mV) .
0.8
0.6
0.4
0.2
-0.4
-0.6
100
Temp = 85°C
Temp = 25°C
80
60
Temp = -45°C
40
-1
-40
120
10
35
60
85
Temperature (°C)
50
100
150
200
250
300
Load Current (mA)
Figure 7. Dropout Voltage vs. Output Voltage
80
70
60
50
40
30
2.2
2.4
2.6
2.8
3
3.2
Output Voltage (V)
Revision 1.03
6 - 15
AS1361/AS1362
Figure 8. Ground Pin Current vs. Input Voltage
Figure 9. Ground Pin Current vs. Load Current
80
100
IOUT= 300mA
75
IOUT = 150mA
50
IOUT = 0mA
25
125
75
Ground Pin Current (µA)
150
70
65
60
55
50
45
40
35
2
3
4
5
50
100
150
200
250
300
Load Current (mA)
Input Voltage (V)
Figure 10. Ground Pin Current vs. Temperature
Figure 11. PSRR vs. Frequency; IOUT = 10mA
100
45
80
PSRR (dB)
50
40
35
30
25
-40
60
40
10
35
60
85
Temperature (°C)
Figure 12. Output Noise Spectral Density vs. Freq.
100
10000
Figure 13. Output Noise vs. Bypass Capacitance
10000
15
14
13
12
1000
Noise (µVrms)
Output Noise Density (nV/ Hz)
1
Frequency (kHz)
100
11
10
9
8
7
6
10
0.01
5
0.1
1
10
100
1
Frequency (kHz)
10
100
Capacitance (nF)
Revision 1.03
7 - 15
AS1361/AS1362
200µs/Div
2V/Div
SHDNN
2V/DIV
VOUT
POK
20mV/DIV
VIN
VOUT
2V/Div
Figure 17. Enter & Exit Shutdown Delay
500mV/Div
Figure 16. Line Transient Response
200µs/Div
20mA/Div
IOUT
VOUT
200µs/Div
20mV/DIV
20mA/Div
Figure 15. Load Transient Response near Dropout,
VIN = 3.4V, VOUT = 3.3V
20mV/DIV
VOUT
IOUT
Figure 14. Load Transient Response,
VIN = 3.8V, VOUT = 3.3V
200µs/Div
Revision 1.03
8 - 15
AS1361/AS1362
Datasheet - D e t a i l e d D e s c r i p t i o n
8 Detailed Description
The AS1361/AS1362 are ultra-low-noise, low-dropout, low-quiescent current linear-regulators specifically designed for
space-limited applications. The devices are available with preset output voltages from 1.5 to 4.5V in 50mV increments.
These devices can supply loads up to 150/300mA. As shown in Figure 18, the AS1361/AS1362 consist of an integrated bandgap core and noise bypass circuitry, error amplifier, P-channel MOSFET pass transistor, and internal feedback voltage-divider.
The output voltage is fed back through an internal resistor voltage-divider connected to pin OUT. An external bypass
capacitor connected to pin BYPASS reduces noise at the output. Additional blocks include a current limiter, thermal
sensor, and shutdown logic.
Internal Voltage Reference
The 1.25V bandgap reference is connected to the error amplifier’s inverting input. The error amplifier compares this
reference with the feedback voltage and amplifies the difference. If the feedback voltage is lower than the reference
voltage, the pass-transistor gate is pulled low. This allows more current to pass to the output and increases the output
voltage. If the feedback voltage is too high, the pass transistor gate is pulled high, allowing less current to pass to the
output.
Internal P-Channel Pass Transistor
The AS1361/AS1362 feature a 0.5Ω (typ) P-channel MOSFET pass transistor, which provides several advantages
over similar designs using a PNP pass transistor, including prolonged battery life. The P-channel MOSFET does not
require a base driver, thus quiescent current is dramatically reduced. The AS1361/AS1362 LDOs do not exhibit problems associated with typical PNP-based LDOs, and consume only 40µA of quiescent current in light load and 220µA in
dropout (see Typical Operating Characteristics on page 6).
Output Voltage
The AS1361/AS1362 deliver preset output voltages from 1.5 to 4.5V, in 50mV increments (see Ordering Information on
page 14).
Shutdown
The AS1361/AS1362 feature a low-power shutdown mode that reduces quiescent current to
