1206 5A 63V
1206 5A 63V
    HQ(华秋商城)
    63VDC 5A
1206 5A 63V 数据手册
12061206 SLOW BLOW SMD FUSES R HAL OG EN 12.100 Series 250mA-10A 72Vdc/63Vdc/32Vdc/24Vdc RoHS Pb H F COMPLIANT Description 12.100 Series are the fuses set the industry standard for performance, reliability and quality. The solder-free design provides excellent on-off and temperature cycling characteristics during use and. also makes our SMD fuses more heat and shock tolerant than typical subminiature fuses. Applicatons Features Secondary circuit protection Laptop, notebook, netbook Flat panel displays High definition television(HDTV) LCD/LED backlighting Computers and peripherals Gaming console systems Handheld/portable equipment Mobile device charges Automotive Central body control module Heating ventilation and air conditioning Doors,window lift and seat control Digital instrument cluster In-vehicle infotainment and navigation Electric pumps,motor control and Powertrain control module(PCU)/Engine Transimission Control Unit(TCU) Rapid interruption of excessive current Compatible with reflow and wave solder Ceramic and glass construction One time positive disconnect Lead free and Halogen free material Electrical Characteristcs Rated Current 250mA~10A 1A~3A 1A~5A 1A~5A 250mA~750mA 6A~10A 250mA~10A % of Amp Rating 100% 200% 250% 300% 350% 350% 1000% Opening Time 4hours, min 1.0s - 60 s 5.0s max 0.1s - 3.0 s 5.0s max 5.0s max 0.2ms - 20.0 ms Agency information File Number:E365879, Guide JDYX2/JDYX8 Specification Typical Pre-Arcing I²t (A²Sec)³ Marking (mOhms)² Typical Voltage Drop (mV) 250mA 3700 1350 0.00038 I 375mA 1850 720 0.00077 E 500mA 1050 690 0.0019 B 775 680 0.15 C 1A 485 550 0.18 H 1.5A 218 355 0.4 K 2A 133 310 1.1 N 2.5A 79 230 1.7 O 3A 49 185 2.2 P 3.5A 37 175 2.7 R 12.100.5 4A 33 160 3.2 S 12.100.6 4.5A 28 150 4.2 X 22 135 6 T 15.5 140 12 F 11.5 120 18 J 8.0 100 18 V 90 30 U Rated Current Rated Voltage Part No. 12.100.0.25 12.100.0.375 12.100.0.5 12.100.0.75 12.100.1 12.100.1.5 7 2 V d c 63Vdc 12.100.2 12.100.2.5 12.100.3 12.100.3.5 12.100.4 12.100.4.5 12.100.7 750mA 5A - 100A @72 Vdc 100A@63Vdc - 6A 12.100.8 12.100.10 32Vd c/24 Vdc - 7A 8A Typical Cold Resistance Breaking Capacity - 300A@ 24Vdc 100A@ 32Vdc 10A 7.0 PDF created with pdfFactory Pro trial version www.pdffactory.com Pb-Free FREE 1206 SLOW BLOW SMD FUSES R HAL OG EN 12.100 Series 250mA-10A 72Vdc/63Vdc/32Vdc/24Vdc RoHS Pb H F COMPLIANT Dimensions (Unit: mm/inch) Pad layout 3.20±0.20 1.52 (0.06) 0.51±0.25 (0.020±0.010) (0.126±0.008) 0.65+0.20,-0.15 1.60±0.20 (0.063±0.008) 2.03 (0.0256+0.008,-0.06) (0.08) 3.20±0.20 (0.126±0.008) 0.51±0.25 (0.020±0.010) Installation Recommendations 1 Wave Soldering Paameters Reflow Conditon - Temperature Min (Ts(min)) Pre Heat - Temperature Max (Ts(max)) - Time (Min to Max) (ts) Pb-free assembly 150℃ 200℃ 60 – 120 seconds Average Ramp-up Rate (Liquidus Temp 3℃/second max. (TL) to peak) TS(max) to TL - Ramp-up Rate Reflow - Temperature (TL) (Liquidus) - Temperature (tL) Peak Temperature (TP) Time within 5°C of actual peak 5℃/second max. 217℃ 60 – 150 seconds 260+0/-5℃ 30 seconds Temperature (tp) Ramp-down Rate Time 25°C to peak Temperature (TP) Do not exceed 6°C/second max 8 minutes max. 260°C tp TP Critical Zone TL to TP Ramp-up T TL e T S(m ax) m p e r TS(min) a t u r e tL Ramp-down Preheat tS 25 time to peak temperature (t 25℃ to peak) Time Solder Pot Temperature: 260°C max Solder Dwell Time: 10 Seconds max 2 Hand-Solder Parameters Solder Iron Temperature: 280±5°C Heating Time: 5 Seconds min Generally,hand-soldering is not recommended Part Numbering System 12.100.2 Package Category Time-Lag SMD Series Rated current Pb-Free Product Characteristics Materials Operatng Temperature Body: Ceramic Terminatons:Silver over-plated with tin Element: Alloy(Ag,Cu,Zn) Cover Coat:Glass -55°C to 125°C Consult temperature rerating curve chart. Thermal Shock 300 cycles -55°C to 125°C Humidity MIL-STD-202F, Method 103B,Condition D Vibraton Insulaton Resistance (Afer Opening) Per MIL-STD-202F, Method 201A Resistance to Soldering Heat PDF created with pdfFactory Pro trial version www.pdffactory.com Greater than 10,000 ohms MIL-STD-202G,Method 210F, Condition D FREE 1206 SLOW BLOW SMD FUSES R HAL OG EN 12.100 Series 250mA-10A 72Vdc/63Vdc/32Vdc/24Vdc RoHS Pb H F COMPLIANT Time Current Curve 100 3.5A 6A 8A 0.00001 PDF created with pdfFactory Pro trial version www.pdffactory.com Pb-Free FREE 1206 SLOW BLOW SMD FUSES R HAL OG EN 12.100 Series 250mA-10A 72Vdc/63Vdc/32Vdc/24Vdc RoHS Pb H F COMPLIANT Packaging 3,000 pieces of fuses in plastic or paper taper Do Po T P2 6°(max) Ao E 6°(max) F W Bo D1 P1 Ko Symbol Ao Bo Ko Spec 1.80±0.10 3.50±0.10 1.27±0.10 Symbol E F Do 3.50±0.10 1.50±0.10 Spec 1.75±0.10 (Unit: mm) Po P1 P2 4.00±0.10 4.00±0.10 D1 2.00±0.10 W T 1.00(Max) 8.00±0.10 0.23±0.02 Ф178 Ф60 11.3 Ф56 9.3 1.0 Ф4 1.3 5.0 Ф15.8 4.5 Ф13±0.2 5.5 10.8 56 2±0.1 3.5 (Unit: mm) PDF created with pdfFactory Pro trial version www.pdffactory.com 60 Pb-Free FREE
1206 5A 63V 价格&库存
很抱歉,暂时无法提供与“1206 5A 63V”相匹配的价格&库存,您可以联系我们找货
