Plastic-Encapsulate Diodes
1N4001L THRU 1N4007L
Surface Mount General Purpose Silicon Rectifiers
Reverse Voltage - 50 to 1000 V
PINNING
Forward Current - 1 A
PIN
FEATURES
▪For surface mounted applications
▪Low profile package
▪Glass Passivated Chip Junction
▪Ideal for automated placement
▪Lead free in comply with EU RoHS 2011/65/EU directives
DESCRIPTION
1
Cathode
2
Anode
1
2
Top View
Marking Code: A1-A7
Simplified outline SOD-123FL and symbol
MECHANICAL DATA
▪Case: SOD-123FL
▪Terminals: Solderable per MIL-STD-750, Method 2026
▪Approx. Weight: 15mg / 0.00053oz
Maximum Ratings and Electrical characteristics
Ratings at 25 °C ambient temperature unless otherwise specified.
Single phase half-wave 60 Hz, resistive or inductive load, for capacitive load current derate by 20 %.
Symbols 1N4001L 1N4002L 1N4003L 1N4004L 1N4005L 1N4006L 1N4007L Units
Parameter
Maximum Repetitive Peak Reverse Voltage
V RRM
50
100
200
400
600
800
1000
V
Maximum RMS voltage
V RMS
35
70
140
280
420
560
700
V
Maximum DC Blocking Voltage
V DC
50
100
200
400
600
800
1000
V
Maximum Average Forward Rectified Current
at Ta = 65 °C
I F(AV)
1
A
Peak Forward Surge Current 8.3 ms Single Half
Sine Wave Superimposed on Rated Load
(JEDEC Method)
I FSM
30
A
Maximum Instantaneous Forward Voltage at 1 A
VF
1.1
V
IR
5
50
μA
Cj
9
pF
RθJA
120
°C/W
T j , T stg
-55 ~ +150
°C
Maximum DC Reverse Current
at Rated DC Blocking Voltage
Typical Junction Capacitance
Typical Thermal Resistance
Ta = 25 °C
Ta =125 °C
1)
2)
Operating and Storage Temperature Range
1)Measured with I F = 0.5 A, I R = 1 A, I rr = 0.25 A.
2)P.C.B. mounted with 0.2 X 0.2" (5 X 5 mm) copper pad areas.
GUANGDONG HOTTECH
INDUSTRIAL CO., LTD
Page:P2-P1
Fig.2 Typical Instaneous Reverse
Characteristics
Average Forward Current (A)
1.2
1.0
0.8
0.6
0.4
0.2
0.0
25
50
75
100
125
150
175
Instaneous Reverse Current ( μ A)
Fig.1 Forward Current Derating Curve
100
T J =150°C
T J =125°C
10
T J =100°C
1.0
T J =75°C
T J =50°C
0.1
T J =25°C
0.01
Junction Capacitance ( pF)
1.0
2 5°
C
°C
00
TJ
TJ =
=1
=1
50
°C
0.5
TJ
Instaneous Forward Current (A)
600
800
Fig.4 Typical Junction Capacitance
Fig.3 Typical Forward Characteristic
0.2
0.1
0.6
400
200
Instaneous Reverse Voltage (V)
Ambient Temperature (°C)
100
T J =25°C
10
1
0.7
0.8
0.9
1.0
1.1
0.1
1.0
10
100
Reverse Voltage (V)
Instaneous Forward Voltage (V)
Peak Forward Surage Current (A)
Fig.5 Maximum Non-Repetitive Peak
35
30
25
10
05
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
1
10
100
Number of Cycles
GUANGDONG HOTTECH
INDUSTRIAL CO., LTD
Page:P2-P2
很抱歉,暂时无法提供与“1N4007L”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.02544
- 200+0.02385
- 500+0.02226
- 1000+0.02067
- 3000+0.01987
- 6000+0.01876
