TS2163A/TS2164A
TS2263A/TS2264A
TS2464A
Trusignal
Microelectronics
Datasheet July 2018
6.5MHz, Rail-to-Rail I/O CMOS Operational Amplifier
Features
Product Description
Low Offset Voltage: 1mV (typ)
High Gain: 105dB (typ)
High Gain Bandwidth Product: 6.5MHz
Rail-to-rail Input/Output
Low IB: 5pA (typ)
Low supply voltage: +2.7 V to +5.5 V
Low Power Consumption: 580μA at 5 V
(per amplifer)
Extended Temperature : -40°C to +125°C
Applications
Signal Conditioning
Current Sensor Amplifier
Battery-Powered Applications
Portable Devices
Active Filtering
Weight Scale Sensor
Medical/Industrial Instrumentation
Power Converter/Inverter
The TS2163A/TS2164A families of products are low
noise, low voltage and low power operational
amplifiers with high gain-bandwidth product of
6.5MHz and slew rate of 5V/μs. The maximum input
offset voltage is only 3.5mV and the input common
mode range extends beyond the supply rails.
TS2163A/TS2164A families of operational amplifiers
are specified at the full temperature range of −40C to
+125C under single or dual power supplies of 2.7V to
5.5V, however these products will operate under an
extended supply range from 2.7V to 5.5V at a
reduced temperatures range.
The TS2163A and TS2263A have a power-down
feature that reduces the supply current to 1uA.
TS2163A
TS2164A
5 V+
OUT 1
5 Enable
V- 2
V- 2
+IN 3
+IN 3
4 -IN
NC 1
V- 4
8 NC
NC 1
7 V+
-IN 2
14 OUTD
+INA 3
V+
13 -IND
12 +IND
V-
11
4
8 Enable
+INB 5
7 V+
6 OUT
+IN 3
6 OUT
5 NC
V- 4
5 NC
-INB 6
10 +INC
OUTB 7
SO-8
SO-8
OUTA 1
-INA 2
TS2163A
TS2164A
+IN 3
4 -IN
SOT23-6
SOT23-5
-IN 2
TS2464A
6 V+
OUT 1
9
-INC
8
OUTC
SO-14,TSSOP-14
TS2263A
TS2264A
OUTA 1
-INA 2
8
+INA 3
V-
4
7
OUTB
6
-INB
10 V+
-INA 2
9 OUTB
+INA 3
8 -INB
V-
5
S0-8
V+
+INB
TS2263A
OUTA 1
4
7 +INB
OUTA
-INA
+INA
V-
6 EnableB
EnableA 5
V+
Underside
die pad
must be
connected
to V-
www.kunyuanic.com
-INB
+INB
EnableB
EnableA
MSOP-10
DFN-10
REV KY.1.0.2B1
OUTB
TS2163A/TS2164A
TS2263A/TS2264A
TS2464A
Trusignal
Microelectronics
Datasheet July 2018
ORDERING INFORMATION
Model
Part Number
Eco Plan
Package
AMP
Shutdown
Container, Pack Qty
TS2164A
TS2164ASOT235R
Rohs
SOT23-5
1
NO
Reel,3000
TS2164A
TS2164ASO8R
Rohs
SO-8
1
NO
Reel,2500
TS2163A
TS2163ASOT236R
Rohs
SOT23-6
1
YES
Reel,3000
TS2163A
TS2163ASO8R
Rohs
SO-8
1
YES
Reel,2500
TS2263A
TS2263AMSOP10R
Rohs
MSOP-10
2
YES
Reel,4000
TS2264A
TS2264ASO8R
Rohs
SO-8
2
NO
Reel,2500
TS2264A
TS2264AMSO8R
Rohs
MSOP-8
2
NO
Reel,4000
TS2264A
TS2264ATSSO8R
Rohs
TSSOP-8
2
NO
Reel,4000
TS2464A
TS2464ASO14R
Rohs
SO-14
4
NO
Reel,2500
TS2464A
TS2464ATSSOP14R
Rohs
TSSOP-14
4
NO
Reel,3000
TS2263A
TS2263ADFN10R
Rohs
DFN-10
2
YES
Reel,2500
ABSOLUTE MAXIMUM RATINGS
Parameter
Supply Voltage
Signal Input Terminal
voltage
Operating Temperature
Junction Temperature
Storage Temperature
Range
Lead Temperature
(Soldering, 10s)
Min
Max
7
Unit
V
(V-)-0.5
(V+)+0.5
V
-50
150
150
C
C
-65
150
C
260
C
ESD HBM
±3000
V
ESD MM
±400
V
ESC CDM
±1000
V
ESD CAUTION
ESD (electrostatic discharge) sensitive device
Charged devices and circuit boards can
discharge without detection. Although this
product features patented or proprietary
protection circuitry, damage may occur on
devices subjects to high energy ESD. Therefore,
proper ESD precautions should be taken to
avoid performance degradation or loss of
functionality.
REV KY.1.0.2B1
2
www.kunyuanic.com
TS2163A/TS2164A
TS2263A/TS2264A
TS2464A
Trusignal
Microelectronics
Datasheet July 2018
ELECTRICAL CHARACTERISTICS: VS = +2.7V to +5.5V
Boldface limits apply over the specified temperature range, TA = −40C to +125C.
At TA = +25C, RL = 10kΩ connected to VS/2, and VOUT = VS/2, unless otherwise noted.
Symbol
Parameter
VS
VIN +/IS
Power Supply Voltage
Input Voltage Range
Supply Current(per amplifer)
Power Supply Rejection Ratio
PSRR
TA = −40C to +125C
Operating Conditions
Min
Typ
2.7
(V-)-0.2
IO=0
580
VS =2.7 to VS =5.5V,
VCM
很抱歉,暂时无法提供与“TS2464A(TSSOP-14)”相匹配的价格&库存,您可以联系我们找货
