TS2177A/TS2178A
TS2277A/TS2278A
TS2478A
Trusignal
Microelectronics
Datasheet May 2018
10MHz, Rail-to-Rail I/O CMOS Operational Amplifier
Features
Product Description
Low Offset Voltage: 1mV (typ)
High Gain: 105dB (typ)
High Gain Bandwidth Product: 10MHz
Rail-to-rail Input/Output
Low IB: 5pA (typ)
Low supply voltage: +2.5 V to +5.5 V
Low Power Consumption: 1.2mA at 5 V
(per amplifier)
Extended Temperature: -40°C to +125°C
Applications
Signal Conditioning
Current Sensor Amplifier
Battery-Powered Applications
Portable Devices
Active Filtering
Weight Scale Sensor
Medical/Industrial Instrumentation
Power Converter/Inverter
The TS2177A/TS2178A families of products are low
noise, low voltage and low power operational
amplifiers with high gain-bandwidth product of 10MHz
and slew rate of 10V/μs. The maximum input offset
voltage is only 5mV and the input common mode
range extends beyond the supply rails.
TS2177A/TS2178A families of operational amplifiers
are specified at the full temperature range of −40C to
+125C under single or dual power supplies of 2.7V to
5.5V, however these products will operate under an
extended supply range from 2.5V to 5.5V at a
reduced temperatures range.
The TS2177A and TS2178A have a power-down
feature that reduces the supply current to 1uA.
TS2478A
TS2178A
TS2177A
5 V+
OUT 1
V- 2
6 V+
OUT 1
4 -IN
+IN 3
14 OUTD
-INA 2
5 Enable
V- 2
+IN 3
OUTA 1
+INA 3
12 +IND
4 -IN
SOT23-5
SOT23-6
TS2178A
TS2177A
V+
11
4
+INB 5
NC 1
-IN 2
+IN 3
V- 4
NC 1
7 V+
-IN 2
7 V+
6 OUT
+IN 3
6 OUT
5 NC
V- 4
TS2278A
V-
4
V+
7
OUTB
6
-INB
5
OUTB 7
9
-INC
8
OUTC
SO-14,TSSOP-14
5 NC
10 V+
OUTA
-INA 2
9 OUTB
-INA
+INA 3
8 -INB
V-
+INB
TS2277A
OUTA 1
+INA
V-
4
7 +INB
V+
Underside
die pad
must be
connected
to V-
6 EnableB
EnableA 5
MSOP-10
www.kunyuanic.com
OUTB
-INB
+INB
EnableB
EnableA
DFN-10
S0-8/MSOP-8/TSSOP8
REV KY.1.0.0A
8 Enable
TS2278A
8
+INA 3
SO-8
OUTA 1
-INA 2
V-
10 +INC
-INB 6
8 NC
SO-8
13 -IND
TS2177A/TS2178A
TS2277A/TS2278A
TS2478A
Trusignal
Microelectronics
Datasheet May 2018
ORDERING INFORMATION
Model
Part Number
Eco Plan
Package
AMP
Shutdown
Container, Pack Qty
TS2178A
TS2178ASOT235R
Rohs
SOT23-5
1
NO
Reel,3000
TS2178A
TS2178ASO8R
Rohs
SO-8
1
NO
Reel,2500
TS2177A
TS2177ASOT236R
Rohs
SOT23-6
1
YES
Reel,3000
TS2177A
TS2177ASO8R
Rohs
SO-8
1
YES
Reel,2500
TS2277A
TS2278AMSOP10R
Rohs
MSOP-10
2
YES
Reel,4000
TS2278A
TS2278ASO8R
Rohs
SO-8
2
NO
Reel,2500
TS2278A
TS2278AMSO8R
Rohs
MSOP-8
2
NO
Reel,4000
TS2278A
TS2278ATSSO8R
Rohs
TSSOP-8
2
NO
Reel,4000
TS2478A
TS2478ASO14R
Rohs
SO-14
4
NO
Reel,2500
TS2478A
TS2478ATSSOP14R
Rohs
TSSOP-14
4
NO
Reel,2500
TS2277A
TS2277ADFN10R
Rohs
DFN-10
2
YES
Reel,2500
ABSOLUTE MAXIMUM RATINGS
Parameter
Supply Voltage
Signal Input Terminal
voltage
Operating Temperature
Junction Temperature
Storage Temperature
Range
Lead Temperature
(Soldering, 10s)
Min
Max
7
Unit
V
(V-)-0.5
(V+)+0.5
V
-50
150
150
C
C
-65
150
C
260
C
ESD HBM
±3000
V
ESD MM
±400
V
ESC CDM
±1000
V
ESD CAUTION
ESD (electrostatic discharge) sensitive device
Charged devices and circuit boards can
discharge without detection. Although this
product features patented or proprietary
protection circuitry, damage may occur on
devices subjects to high energy ESD. Therefore,
proper ESD precautions should be taken to
avoid performance degradation or loss of
functionality.
REV KY.1.0.0A
2
www.kunyuanic.com
TS2177A/TS2178A
TS2277A/TS2278A
TS2478A
Trusignal
Microelectronics
Datasheet May 2018
ELECTRICAL CHARACTERISTICS: VS = +2.7V to +5.5V
Boldface limits apply over the specified temperature range, TA = −40C to +125C.
At TA = +25C, RL = 10kΩ connected to VS/2, and VOUT = VS/2, unless otherwise noted.
Symbol
VS
VIN +/IS
Parameter
Power Supply Voltage
Input Voltage Range
Supply Current(per amplifer)
PSRR
Power Supply Rejection Ratio
TA = −40C to +125C
Input Characteristics
VOS
Input Offset Voltage
dVOS/dT
Average Drift
IB
IOS
Min
2.7
(V-)-0.2
CMRR
TA = −40C to +125C
Open-Loop Gain
TA = −40C to +125C
Open-Loop Gain
TA = −40C to +125C
Output Characteristics
Output Voltage Swing from Rail
VOUT
TA = −40C to +125C
TA = −40C to +125C
IOUT
Output Current
Open-Loop Output Impedance
ROUT
Dynamic Performance
GBW
tS
Settling Time to 0.1%
Settling Time to 0.01%
Overload recovery time
SR
Slew Rate
THD
Total Harmonic Distortion+ Noise
REV KY.1.0.0A
Typ
Max
5.5
(V+) +0.2
1.65
Unit
V
V
mA
IO=0
1.1
VS =2.7 to VS =5.5V,
VCM
很抱歉,暂时无法提供与“TS2478A(TSSOP-14)”相匹配的价格&库存,您可以联系我们找货
