AC6D04C
40V /6A Power MOSFET
C
D04C
D
6D04C 6D04C-N 6D04C-P
General Description
Very low on-resistance RDS(on) @ VGS=4.5 V
Pb-free lead plating; RoHS compliant
V DS
40
-40
V
RDS(on),TYP@VGS=10V
RDS(on),TYP@VGS=4.5
ID
26.6
44.1
mΩ
41.8
69.3
mΩ
6
-5
A
Part ID
Package Type
Marking
AC6D04C
SOP8
6D04
Parameter
Tape and reel
infomation
100% UIS Tested
100% Rg Tested
3000
Maximum
Symbol
Units
Drain-Source Voltage
VDS
40
-40
V
Gate-Source Voltage
VGS
±V
6.0
-5.0
5.0
-4.0
Continuous Drain Current A
TA=25°C
ID
TA=70°C
Pulsed Drain Current B
IDM
9.6
-8.0
Avalanche Current G
IAR
1.9
-1.6
Repetitive avalanche energy L=0.1mH G
EAR
4.4
-3.7
2.0
2.0
1.3
1.3
TA=25°C
Power Dissipation A
PD
TA=70°C
Junction and Storage Temperature Range
A
mJ
W
-55 to 150
TJ, TSTG
°C
Thermal Characteristics
Parameter
Symbol
Maximum Junction-to-Ambient A
t ≤ 10s
Steady State
Maximum Junction-to-Lead C
Steady State
第 1 页,共 9 页
RJA
RJL
Typ
Max
Units
95
142
°C/W
190
228
°C/W
57
91
°C/W
AC6D04C
N-Channel Electrical Characteristics
STATIC PARAMETERS
Parameter
Conditions
BVDSS
Drain-Source Breakdown Voltage
ID = -250uA, VGS = 0V
IDSS
Zero Gate Voltage Drain Current
VDS=40V, VGS=0V
IGSS
Gate-Body leakage current
VDS = 0V, VGS = ±20V
VGS(th)
Gate Threshold Voltage
VDS = VGS ID = 250A
RDS(ON)
Static Drain-Source OnResistance
Symbol
Min
Typ
Max
40
V
1
5
uA
±100
nA
2.3
3
V
VGS=-10V, ID=6A
26.6
38.0
VGS=4.5V, ID=6A
41.8
54.3
1.5
gFS
Forward Transconductance
VDS=5V, ID=6A
87
VSD
Diode Forward Voltage
IS=1A,VGS=22V
0.72
IS
Units
mΩ
S
1
V
6
A
Typ
Max
Units
516
629
pF
82
100
pF
43
51
pF
0.7
Ω
Max
Units
Maximum Body-Diode Continuous Current
DYNAMIC PARAMETERS
Symbol
Parameter
Ciss
Input Capacitance
Coss
Output Capacitance
Crss
Reverse Transfer Capacitance
Rg
Gate resistance
Conditions
Min
VGS=0V, VDS=15V, f=1MHz
VGS=0V, VDS=0V, f=1MHz
SWITCHING PARAMETERS
Symbol
Parameter
Conditions
Qg (10V)
Total Gate Charge
Qg 4.5V)
Total Gate Charge
Qgs
Gate Source Charge
1.0
Qgd
Gate Drain Charge
1.4
tD(on)
Turn-On DelayTime
9.0
tr
Turn-On Rise Time
tD(off)
Turn-Off DelayTime
tf
Turn-Off Fall Time
trr
Body Diode Reverse Recovery
Time
IF=-8A, dI/dt=500A/s
18.0
ns
Qrr
Body Diode Reverse Recovery Charge
IF=18A, dI/dt=500A/s
10.0
nC
Min
Typ
4.3
2.2
VGS=10V, VDS=15V, ID=6A
VGS=10V, VDS=15V,RL=0.75Ω,
RGEN=3Ω
nC
7.2
25.2
ns
8.1
第 2 页,共 9 页
AC6D04C
第 3 页,共 9 页
AC6D04C
第 4 页,共 9 页
AC6D04C
第 5 页,共 9 页
AC6D04C
P-Channel Electrical Characteristics
STATIC PARAMETERS
Parameter
Conditions
BVDSS
IDSS
VDS=-40V, VGS=0V
IGSS
VGS(th)
VDS = VGS ID = 250A
RDS(ON)
gFS
VSD
Symbol
IS
Min
Typ
Max
Units
-40
V
-1
5
uA
±100
nA
-2.3
-3
V
VGS=-10V, ID=-5A
44.1
63.0
VGS=-4.5V, ID=-5A
69.3
90.1
VDS=-5V, ID=-5A
53
IS=-1A,VGS=0V
-0.72
-1.5
mΩ
S
-1
V
-5
A
Typ
Max
Units
940
1146
pF
97
119
pF
72
85
pF
1.6
Ω
Max
Units
DYNAMIC PARAMETERS
Symbol
Parameter
Ciss
Input Capacitance
Coss
Output Capacitance
Crss
Rg
Gate resistance
Conditions
Min
VGS=0V, VDS=-15V, f=1MHz
Symbol
Parameter
Conditions
Qg (10V)
Total Gate Charge
Qg 4.5V)
Total Gate Charge
Qgs
Gate Source Charge
2.2
Qgd
Gate Drain Charge
3.2
tD(on)
Turn-On DelayTime
10.5
tr
Turn-On Rise Time
tD(off)
Turn-Off DelayTime
tf
Turn-Off Fall Time
trr
Time
21.0
ns
Qrr
14.0
nC
Min
Typ
7.9
4.0
VGS=-10V, VDS=-15V, ID=-5A
VGS=-10V, VDS=-15V,RL=0.75Ω,
RGEN=3Ω
nC
8.4
29.4
ns
9.5
第 6 页,共 9 页
AC6D04C
第 7 页,共 9 页
AC6D04C
第 8 页,共 9 页
AC6D04C
第 9 页,共 9 页
很抱歉,暂时无法提供与“AC6D04C”相匹配的价格&库存,您可以联系我们找货
