Plastic-Encapsulate Mosfets
AO3402
FEATURES
N-Channel MOSFET
Lead free product is acquired
Surface mount package
D
1.Gate
2.Source
SOT-23
3.Drain
G
S
Absolute Maximum Ratings (TA=25oC, unless otherwise noted)
Parameter
Symbol
Value
Unit
Drain-Source Voltage
VDS
30
V
Gate-Source Voltage
VGS
±12
V
Continuous Drain Current
ID
4
A
Pulsed Drain Current (note 1)
IDM
15
A
Power Dissipation
PD
1.4
W
RθJA
357
℃/W
Junction Temperature
TJ
150
Storage Temperature
TSTG
-55~+150
Thermal Resistance from Junction to Ambient (note 2)
GUANGDONG HOTTECH
INDUSTRIAL CO., LTD
Page:P4-P1
AO3402
Electrical Characteristics (TA=25°C, unless otherwise noted)
Parameter
Symbol
Test Condition
Min
Typ
Max
Unit
STATIC CHARACTERISTICS
Drain-source breakdown voltage
V (BR)DSS
VGS = 0V, ID =250µA
Zero gate voltage drain current
IDSS
VDS =24V,VGS = 0V
Gate-body leakage current
IGSS
VGS =±12V, VDS = 0V
VGS(th)
VDS =VGS, ID =250µA
Gate threshold voltage (note 3)
Drain-source on-resistance (note 3)
RDS(on)
30
V
1
µA
±100
nA
1.4
V
VGS =10V, ID =4A
55
mΩ
VGS =4.5V, ID =3A
70
mΩ
VGS =2.5V, ID =2A
110
mΩ
Forward transconductance (note 3)
gFS
VDS =15V, ID =4A
Diode forward voltage (note 3)
VSD
IS=1A, VGS = 0V
0.6
8
S
1
V
DYNAMIC CHARACTERISTICS (note 4)
Input capacitance
Ciss
Output capacitance
Coss
Reverse transfer capacitance
Crss
Gate resistance
Rg
VDS =15V,VGS =0V,f =1MHz
VDS =0V,VGS =0V,f =1MHz
390
pF
54.5
pF
41
Pf
3
Ω
3.3
ns
SWITCHING CHARACTERISTICS (note 4)
Turn-on delay time
Turn-on rise time
Turn-off delay time
td(on)
tr
VGS=10V,VDS=15V,
1
ns
td(off)
RL=3.75Ω,RGEN=6Ω
21.7
ns
Turn-off fall time
tf
2.1
ns
Total gate charge
Qg
4.34
nC
Gate-source Charge
Qgs
0.6
nC
Gate-drain Charge
Qgd
1.38
nC
1.2
ns
6.3
nC
Body diode reverse recovery time
Body diode reverse recovery charge
t.
Qrr
VDS =15V,VGS =4.5V,ID =4A
IF=4A,dI/dt=100A/µs
Notes :
1. Repetitive rating : Pulse width limited by junction temperature.
2. Surface mounted on FR4 board , t≤10s.
3. Pulse Test : Pulse Width≤80µs, Duty Cycle≤0.5%.
4. Guaranteed by design, not subject to producting.
GUANGDONG HOTTECH
INDUSTRIAL CO., LTD
Page:P4-P2
AO3402
Typical
Characteristics
10
15
10V
3V
12
8
VDS=5V
4.5V
6
ID(A)
ID (A)
9
2.5V
6
4
3
125°C
2
VGS=2V
25°C
2
3
4
5
VDS (Volts)
Fig 1: On-Region Characteristics
1
1.5
2
2.5
3
3.5
VGS(Volts)
Figure 2: Transfer Characteristics
150
Normalized On-Resistance
1.8
125
VGS=2.5V
RDS(ON) (mΩ
Ω)
0.5
100
75
VGS=4.5V
50
25
VGS=10V
VGS=4.5V
VGS=10V
1.4
1.2
VGS=2.5V
1
0.8
4
6
8
10
ID (A)
Figure 3: On-Resistance vs. Drain Current and
Gate Voltage
25
50
75
100
125
150
175
Temperature (°C)
Figure 4: On-Resistance vs. Junction Temperature
200
1.0E+01
1.0E+00
ID=2A
1.0E-01
IS (A)
RDS(ON) (mΩ
Ω)
150
100
125°C
50
125°C
1.0E-02
1.0E-03
25°C
1.0E-04
25°C
1.0E-05
4
6
8
1.0E-06
10
VGS (Volts)
Figure 5: On-Resistance vs. Gate-Source Voltage
GUANGDONG HOTTECH
0.0
0.2
0.4
0.6
0.8
1.0
1.2
VSD (Volts)
Figure 6: Body-Diode Characteristics
INDUSTRIAL CO., LTD
Page:P4-P3
AO3402
Typical
Characteristics
600
5
VDS=15V
ID=4A
500
Capacitance (pF)
VGS (Volts)
4
3
2
1
Ciss
400
300
200
Coss
100
2
3
4
5
Qg (nC)
Figure 7: Gate-Charge Characteristics
15
Power (W)
10µs
100µs
1.0
1ms
1s
DC
0.1s
0.1
1
10
100
VDS (Volts)
Figure 9: Maximum Forward Biased Safe
Operating Area (Note E)
Zθ JA Normalized Transient
Thermal Resistance
10
5
10ms
10s
10
30
TJ(Max)=150°C
TA=25°C
RDS(ON)
limited
0.1
TJ(Max)=150°C
TA=25°C
10.0
10
VDS (Volts)
Figure 8: Capacitance Characteristics
100.0
ID (Amps)
Crss
D=Ton/T
TJ,PK=TA+PDM.ZθJA.RθJA
RθJA=90°C/W
0.01
0.1
1
10
100
1000
Pulse Width (s)
Figure 10: Single Pulse Power Rating Junction-toAmbient (Note E)
In descending order
D=0.5, 0.3, 0.1, 0.05, 0.02, 0.01, single pulse
1
PD
0.1
Ton
T
Single Pulse
0.01
0.00001
0.0001
0.001
0.01
0.1
1
10
Pulse Width (s)
Figure 11: Normalized Maximum Transient Thermal Impedance
GUANGDONG HOTTECH
INDUSTRIAL CO., LTD
100
1000
Page:P4-P4
很抱歉,暂时无法提供与“AO3402”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.17568
- 20+0.15980
- 100+0.14393
- 500+0.12805
- 1000+0.12065
- 2000+0.11535
