Plastic-Encapsulate Mosfets
SI2301
FEATURES
P-Channel MOSFET
High dense cell design for extremely low RDS(ON)
Rugged and reliable
Case Material: Molded Plastic.
Absolute Maximum Ratings (TA=25oC, unless otherwise noted)
Parameter
Symbol
Ratings
Units
Drain-Source Voltage
VDS
-20
V
Gate-Source Voltage
VGS
8
V
1.Gate
2.Source
ID
-2.3
A
3.Drain
IDM
-10
A
PD
1.25
W
Tj, Tstg
-55 to +150
°C
RθJA
100
°C/W
Drain Current (Continuous)
Drain Current (Pulsed) 1
SOT-23
D
o
Total Power Dissipation @TA=25 C
Operating Junction and Storage Temperature Range
Thermal Resistance Junction to Ambient (PCB mounted)
2
G
Electrical Characteristics (TA=25°C, unless otherwise noted)
Parameter
Symbol
S
Test Condition
Min
Typ
Max
Unit
Off Characteristics
Drain-Source Breakdown Voltage
Zero Gate Voltage Drain Current
BVDSS
VGS = 0V, ID = -250µA
IDSS
VDS = -20V, VGS = 0V
-1
µA
-20
V
Gate Body Leakage Current, Forward
IGSSF
VGS = 8V, VDS = 0V
100
nA
Gate Body Leakage Current, Reverse
IGSSR
VGS = -8V, VDS = 0V
-100
nA
-1
V
On Characteristics
c
VGS(th)
Gate Threshold Voltage
Static Drain-Source
RDS(on)
On-Resistance
Forward Transconductance
Dynamic Characteristics
gFS
Ciss
Output Capacitance
Coss
Reverse Transfer Capacitance
Switching Characteristics
Turn-Off Delay Time
Turn-Off Fall Time
VGS = -4.5V, ID = -2.8A
80
120
mΩ
VGS = -2.5V, ID = -2.0A
110
150
mΩ
VDS = -5V, ID = -2.8A
8
S
VDS = -6V, VGS = 0V, f = 1.0
MHz
880
pF
270
pF
Crss
175
pF
d
td(on)
tr
Turn-On Rise Time
-0.45
d
Input Capacitance
Turn-On Delay Time
VGS = VDS, ID = -250µA
VDD = -6V, ID = -1A, VGS =
-4.5V, RGEN = 6Ω
11
ns
5
10
ns
td(off)
32
65
ns
tf
23
45
ns
GUANGDONG HOTTECH
INDUSTRIAL CO., LTD
Page:P3 -P1
Qg
Total Gate Charge
Gate-Source Charge
Qgs
Gate-Drain Charge
Qgd
11
VDS = -6V, ID = -2.8A, VGS =
-4.5V
14.5
nC
1.5
nC
2.1
nC
Drain-Source Diode Characteristics and Maximun Ratings
Drain-Source Diode Forward Current 3
IS
Drain-Source Diode Forward Voltage 4
VSD
VGS = 0V, IS = -0.75A
-0.75
A
-1.2
V
1.Repetitive Rating : Pulse width limited by maximum junction temperatu. 2.Surface Mounted on FR4 Board,t
很抱歉,暂时无法提供与“SI2301”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.09486
- 200+0.08866
- 600+0.08246
- 3000+0.07626
