MU240H800AQ_CP
General - Outdoor
DWG NO. : A6467
A0
LED DRIVER SPECIFICATIONS
Customer's Part Number:
MOONS' Part Number:
Model:
P/N:
CUSTOMER'S APPROVAL STAMP
Please sign back after your approval. The specifications will come into force when we
receive purchase order.
DWG
CHK
STANDARD
APPD.
Page 1 of 7
subject to change without notice
SHANGHAI MOONS' AUTOMATION CONTROL CO., LTD.
Add: No.168, Mingjia Road, Shanghai 201107, P.R.China
Tel: +86 (0)21 52634688 Website: www.moons.com.cn
MU240H800AQ_CP
General - Outdoor
DWG NO. : A6467
Rev.
A0
Date
Contents
New release
ECO NO.
DWG
CHK
Tiger Yang
Feng He
A0
APPR
Feng He
Page 2 of 7
MU240H800AQ_CP
General - Outdoor
DWG NO. : MSSD-6467
A0
■ Features·Input voltage: 90-305Vac
·Built-in active PFC function: 0.98 Typ.
·High efficiency: 93.5% Typ.
·Constant current/ 0-10V dimming/ clock dimming/ PWM dimming/Dim off
·Full power at 75%Iomax~100%Iomax (constant power)
·IP67 design for indoor or outdoor installations
·High surge immunity
·Compliance to worldwide safety regulations for lighting
·Suitable for dry/damp locations
·5 Years Warranty
■ Specification
Model
(MU240H800AQ_CP)
800
93.5%
Efficiency (230Vac)(Typ.)Note.1
Voltage Range (V)Note.2
90~305Vac, OR 127~ 430Vdc
Voltage Rated (V)Note.2
120~277Vac
47~63
Frequency Range (Hz)
PF>0.98/120VAC, PF>0.95/230VAC, PF>0.93/277VAC at full load
Power Factor
THD
THD< 20% when output loading≧80% at 120VAC/230VAC input and output loading≧80% at 277VAC input
2.5A MAX at 120Vac, 1.3A MAX at 230Vac
AC Current (Max.)
Inrush Current (Max.)
COLD START 65A(twidth=680μs measured at 50% Ipeak) at 230VAC
MAX. No. of PSUs on 16A
CIRCUIT BREAKER
TBD
0.75mA at 277Vac/60Hz
Leakage Current (Max.)
40-30
Rated Output Voltage (V)
40-18
Output Voltage Range (V)
Rated Current (mA)
6000-8000
Output Current Range (mA)
600-8000
240W
Rated Power (W)
Output1
7.5%-100% of Io_max
Output Current Setting Range
75%-100% of Po_max
Constant Power Setting Range
10% of Io_max. ((PK-AV) /AV) with LED default mode and full load)
Ripple Current (Typ.)
Current Tolerance
±5%
Line Regulation
±3%
±3%
Load Regulation
Turn on delay Time
很抱歉,暂时无法提供与“MU240H800AQ_CP”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+557.28270
- 5+535.01337
- 21+513.59452
- 53+493.02614
