FP6188
2A, 23V, 340KHz Synchronous Step-Down Converter
General Description
The FP6188 is a synchronous buck regulator with integrated two 0.13Ω power MOSFETs. It
achieves 2A continuous output current over a wide input supply range with excellent load and line
regulation. Current mode operation provides fast transient response and eases loop stabilization. The
device includes cycle-by-cycle current limiting and thermal shutdown protection. The FP6188 requires
a minimum number of readily available external components to complete a 2A buck regulator solution.
Features
2A Output Current
0.13Ω Internal Power MOSFET Switches
Stable with Low ESR Output Ceramic Capacitors Up to 93% Efficiency
Programmable Soft-Start
Fixed 340KHz Frequency
Thermal Shutdown
Cycle-by-Cycle Over Current Protection
Wide 4.5V to 23V Operating Input Range
Output Adjustable From 0.923V to 16V
Available SOP-8L (EP) Package
Input Under Voltage Lockout
Applications
Distributed Power Systems
Battery Charger Network Cards
Pre-Regulator for Linear Regulators
DSL Modems
Typical Application Circuit
VOUT
1
VIN
2
SS
BS
EN
IN
8
7
VIN
FP6188
3
4
SW
GND
COMP
FB
6
5
This datasheet contains new product information. Feeling Technology reserves the rights to modify the product specification without notice.
No liability is assumed as a result of the use of this product. No rights under any patent accompany the sales of the product.
Website: http://www.feeling-tech.com.tw
Rev. 0.70
1/11
FP6188
Function Block Diagram
Pin Descriptions
SOP-8L (EP)
Top View
Name No. I / O
1
8
SS
IN
2
7
EN
SW
3
6
COMP
4
FP6188
GND
XXx-XXL
BS
5
FB
Bottom View
Description
BS
1
O
Bootstrap
IN
2
P
Supply Voltage
SW
3
O
Switch
GND
4
P
Ground
FB
5
I
Feedback
COMP
6
O
Compensation
EN
7
I
Enable / UVLO
SS
8
O
Soft-Start
EP
9
P
Exposed PAD - Must connect to Ground
EP
Rev. 0.70
2/11
FP6188
Marking Information
SOP-8L (EP)
FP6188
XXx - XXL
Halogen Free
Lot Number
Internal ID
Per - Half Month
Year
Halogen Free: Halogen free product indicator
Lot Number: Wafer lot number’s last two digits
For Example
Lot : 123456
XXx-56L
Internal ID: Internal Identification Code
Per-Half Month: Production period indicator in half month time unit
For Example : A → First Half Month of January
B → Second Half Month of January
C → First Half Month of February
D → Second Half Month of February
Year: Production year’s last digit
Rev. 0.70
3/11
FP6188
Ordering Information
Part Number
Operating Temperature
Package
MOQ
Description
-40°C ~ +85°C
SOP-8L (EP)
2500EA
Tape & Reel
FP6188XR-G1
Absolute Maximum Ratings
Parameter
Symbol
Conditions
Min.
Typ.
Max.
Unit
Supply Voltage
VIN
-0.3
24
V
Supply Voltage
Vsw
-1
VIN +0.3
V
Bootstrap Voltage
VBS
Vsw -0.3
Vsw +6
V
-0.3
6
V
+150
°C
All Other Pins
Junction Temperature
TJ
Storage Temperature
TS
Allowable Power Dissipation
θJA
Thermal Resistance
θJC
+150
SOP-8L
800
mW
SOP-8L (EP)
1500
mW
-65
SOP-8L
+156
℃/W
SOP-8L (EP)
+83
℃/W
SOP-8L
+55
℃/W
SOP-8L (EP)
+10
℃/W
+260
Lead Temperature (soldering, 10
sec)
IR Re-flow Soldering Curve
Rev. 0.70
4/11
FP6188
Recommended Operating Conditions
Parameter
Symbol
Supply Voltage
Conditions
VIN
Ambient Temperature
Min.
Typ.
Max.
Unit
4.5
23
V
-40
+85
DC Electrical Characteristics (Ta= 25℃, VIN=12V, unless otherwise noted)
Parameter
Symbol Test Conditions
Standby Current
ISB
VEN≧3V,VFB≧1.0V
Shutdown Supply Current
IST
VEN=0
Feedback Voltage
VFB
VIN=12V,VCOMP
很抱歉,暂时无法提供与“FP6188XR-G1”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1.75500
- 10+1.62000
- 30+1.59300
- 100+1.51200
