FP6293
1MHz, 3.5A Step-Up Current Mode PWM Converter
General Description
The FP6293 is a current mode boost DC-DC converter. Its PWM circuitry with built-in 0.14Ω
power MOSFET make this regulator highly power efficient. The internal compensation network also
minimizes as much as 6 external component counts. The non-inverting input of error amplifier connects
to a 0.6V precision reference voltage and internal soft-start function can reduce the inrush current.
The FP6293 is available in the DFN-8L/SOP-8L(EP) package and provides space-saving PCB
for the application fields.
Features
Adjustable Output up to 13V
Internal Fixed PWM frequency: 1.0MHz
Precision Feedback Reference Voltage: 0.6V (±2%)
Internal 0.14Ω, 3.5A, 18V Power MOSFET
Shutdown Current: 0.1μA
Over Temperature Protection
Over Voltage Protection
Adjustable Over Current Protection: 0.5A ~ 3.5A
Package: DFN-8L, SOP-8L(EP)
Applications
Chargers
LCD Displays
Digital Cameras
Handheld Devices
Portable Products
Typical Application Circuit
VOUT
VIN
1
2
PGND
LX
OC
NC
8
7
FP6293
3
4
VCC
FB
EN
GND
6
5
This datasheet contains new product information. Feeling Technology reserves the rights to modify the product specification without notice.
No liability is assumed as a result of the use of this product. No rights under any patent accompany the sales of the product.
Rev. 0.71
Website: http://www.feeling-tech.com.tw
1/13
FP6293
Function Block Diagram
GND
VCC
EN
OC
UVLO
Shutdown
Circuitry
Adjustable
Current Limit
27kΩ~192kΩ
3.5 A ~ 0.5A
LX
OTP
OVP
Error Amp.
FB
Control
and
Driver
Logic
0.6V
PWM
Comp.
Soft
Start
PGND
Current Sense
Amp.
Slope
Compensation
Oscillator
1 MHz
Pin Descriptions
DFN-8L
Top View
Vcc
EN
FP6293
OC
XXxXXL
PGND
Name
No. I / O
Description
LX
PGND
1
P
IC Ground
NC
OC
2
I
Adjustable Current Limit (Floating Available)
Vcc
3
P
IC Power Supply
EN
4
I
Enable Control (Active High)
GND
5
P
IC Ground
I
Error Amplifier Inverting Input
FB
GND
Bottom View
FB
6
NC
7
LX
8
O
Power Switch Output
EP
9
P
Exposed PAD-Must connect to Ground
NA Not Connected
EP
Rev. 0.71
2/13
FP6293
SOP-8L(EP)
Top View
PGND
8
1
2
Vcc
3
EN
4
FP6293
XXx-XXL
OC
LX
7
NC
6
FB
5
GND
Bottom View
Name
No. I / O
Description
PGND
1
P
IC Ground
OC
2
I
Vcc
3
P
IC Power Supply
EN
4
I
GND
5
P
IC Ground
I
FB
6
NC
7
LX
8
O
Power Switch Output
EP
9
P
NA Not Connected
EP
Rev. 0.71
3/13
FP6293
Marking Information
DFN-8L
FP6293
XXxXXL
Halogen Free
Lot Number
Internal ID
Per-Half Month
Year
SOP-8L
FP6293
XXx - XXL
Halogen Free
Lot Number
Internal ID
Per - Half Month
Year
Halogen Free: Halogen free product indicator
Lot Number: Wafer lot number’s last two digits
For Example
Lot : 123456
XXx-56L
Internal ID: Internal Identification Code
Per-Half Month: Production period indicator in half month time unit
For Example : A → First Half Month of January
B → Second Half Month of January
C → First Half Month of February
D → Second Half Month of February
Year: Production year’s last digit
Rev. 0.71
4/13
FP6293
Ordering Information
Part Number
Operating Temperature
Package
MOQ
Description
FP6293dR-G1
-40°C ~ 85°C
DFN-8L
2500EA
Tape & Reel
FP6293XR-G1
-40°C ~ 85°C
SOP-8L(EP)
2500EA
Tape & Reel
Absolute Maximum Ratings
Parameter
Symbol
Conditions
Min.
Typ.
Max.
Unit
Supply Voltage
VCC
V
LX Voltage
VLX
V
V
DFN-8L(3x3mm)
+68
°C / W
SOP-8L(EP)
+83
°C / W
+150
°C
EN,FB Voltage
Thermal Resistance (Note1)
θJA
Junction Temperature
TJ
TOP
-40
+85
°C
Storage Temperature
TST
-65
+150
°C
+260
°C
Lead Temperature
(soldering, 10 sec)
Note1:
θJA is measured in the natural convection at T A=25°C on a low effective thermal conductivity test
board of JEDEC 51-3 thermal measurement standard.
IR Re-flow Soldering Curve
Rev. 0.71
5/13
FP6293
Recommended Operating Conditions
Parameter
Symbol
Supply Voltage
VIN
Operating Temperature Range
TA
Conditions
Ambient Temperature
Min.
Max.
Unit
2.6
Typ.
5.5
V
-40
+85
°C
DC Electrical Characteristics (VCC=3.3V, TA=25°C, unless otherwise specified)
Parameter
Symbol
Conditions
Min.
Typ.
Max.
Unit
5.5
V
System Supply Input
Input Supply Range
VCC
Under Voltage Lockout
2.6
VUVLO
2.2
UVLO Hysteresis
V
0.1
V
Quiescent Current
ICC
VFB=0.66V, No switching
0.19
mA
Average Supply Current
ICC
VFB=0.55V, Switching
2.84
mA
Shutdown Supply Current
ICC
VEN=GND
0.1
µA
FOSC
VFB=1.0V
Oscillator
Operation Frequency
Frequency Change with Voltage
0.8
△ f / △ V VCC=2.6V to 5.5V
Maximum Duty Cycle
TDUTY
1.0
1.2
MHZ
5
90
Reference Voltage
Reference Voltage
VREF
Line Regulation
0.588
0.6
0.612
0.2
VCC=2.6V~5.5V
V
%/V
Enable Control
Enable Voltage
VEN
Shutdown Voltage
VEN
0.96
V
0.6
V
MOSFET
On Resistance of Driver
RDS (ON) ILX=2A
0.14
Ω
3.5
A
Protection
OCP Current
IOCP
Adjustable OCP Current
IOCP
OTP Temperature
TOTP
With External Resistor:
27k~192k
3.5
0.5
+150
A
°C
Rev. 0.71
6/13
FP6293
Typical Operating Characteristics
(VCC=3.3V, VOUT=5V, TA= 25°C, unless otherwise noted)
Efficiency vs. Output Current
100
95
Efficiency (%)
90
85
80
75
70
0.1
0.3
0.5
0.7
0.9
1.1
1.3
1.5
Freqency (MHz)
Output Current (A)
Operation Frequency vs. Input Voltage
1.14
1.12
1.1
Operation Frequency
1.08
1.06
1.04
1.08
1.06
1.04
1.02
1.02
VIN =5V, VOUT =9V
1
2
3
4
5
6
-40
-20
Input Voltage (V)
40
60
80
100
Reference Voltage vs. Output Current
0.605
0.607
Feedback Voltage (V)
0.606
Reference Voltage (V)
T e m p e r a t u r e ( °C )
Reference Voltage vs. Input Voltage
0.605
0.604
0.603
0.602
0.601
0.604
0.603
0.602
0.601
0.6
2
3
4
5
0.6
6
0.4
Input Voltage (V)
0.6
0.8
1
1.2
1.4
1.6
Output Current (A)
Quiescent Current vs. Input Voltage
Average Supply Current vs. Input Voltage
270
4.5
Average Supply Current (mA)
Quiescent Current (uA)
vs. T emperature
1.1
Operation
Operation Frequency (MHz)
1.16
240
210
180
150
120
4
3.5
3
2.5
2
1.5
1
0.5
2
3
4
5
2
6
3
4
5
6
Input Voltage (V)
Input Voltage (V)
Rev. 0.71
7/13
FP6293
Function Description
Operation
The FP6293 is a current mode boost converter. The constant switching frequency is 1MHz and
operates with pulse width modulation (PWM). Build-in 18V / 3.5A MOSFET provides a high output
voltage. The control loop architecture is peak current mode control; therefore slope compensation
circuit is added to the current signal to allow stable operation for duty cycles larger than 50%.
Soft Start Function
Soft start circuitry is integrated into FP6293 to avoid inrush current during power on. After the IC
is enabled, the output of error amplifier is clamped by the internal soft-start function, which causes
PWM pulse width increasing slowly and thus reducing input surge current.
Current Limit Program
A resistor between OC and GND pin programs peak switch current. The resistor value should be
between 27k and 192k. The current limit will be set from 3.5A to 0.5A. Keep traces at this pin as short
as possible. Do not put capacitance at this pin. To set the over current trip point according to the
following equation:
IOCP =
96000
R3
Over Temperature Protection (OTP)
FP6293 will turn off the power MOSFET automatically when the internal junction temperature is
over 150°C. The power MOSFET wake up when the junction temperature drops 30 °C under the OTP
threshold temperature.
Over Voltage Protection (OVP)
In some condition, the resistive divider may be unconnected, which will cause PWM signal to
operate with maximum duty cycle and output voltage is boosted higher and higher. The power
MOSFET will be turned off immediately, when the output voltage exceeds the OVP threshold level. The
FP6293’s OVP threshold is 16V.
Rev. 0.71
8/13
FP6293
Application Information
Inductor Selection
Inductance value is decided based on different condition. 3.3uH to 4.7µH inductor value is
recommended for general application circuit. There are three important inductor specifications, DC
resistance, saturation current and core loss. Low DC resistance has better power efficiency.
Also, it
avoid inductor saturation which will cause circuit system unstable and lower core loss at 1 MHz.
Capacitor Selection
The output capacitor is required to maintain the DC voltage. Low ESR capacitors are preferred to
reduce the output voltage ripple. Ceramic capacitor of X5R and X7R are recommended, which have
low equivalent series resistance (ESR) and wider operation temperature range.
Diode Selection
Schottky diodes with fast recovery times and low forward voltages are recommended. Ensure the
diode average and peak current rating exceed the average output current and peak inductor current. In
addition, the diode’s reverse breakdown voltage must exceed the output voltage.
Output Voltage Programming
The output voltage is set by a resistive voltage divider from the output voltage to FB. The output
voltage is:
R1
VOUT 0.6V1
R2
Layout Considerations
1. The power traces, consisting of the GND trace, the LX trace and the VCC trace should be kept
short, direct and wide.
2. LX、L and D switching node, wide and short trace to reduce EMI.
3. Place CIN near VCC pin as closely as possible to maintain input voltage steady and filter out the
pulsing input current.
4. The resistive divider R1and R2 must be connected to FB pin directly as closely as possible.
5. FB is a sensitive node. Please keep it away from switching node, LX.
6. The GND of the IC, CIN and COUT should be connected close together directly to a ground
plane.
Rev. 0.71
9/13
FP6293
Vin
L1
VIA to
GND
1
8
2
7
Vout
R3
3
FP6293
4
C1
D1
6
R1
5
C2
C3
C4
C5
R2
GND
Suggested Layout
Rev. 0.71
10/13
FP6293
Typical Application
L1 3.3µH
D1 SR54
VIN
3.7V
VOUT
5V
C1
22µF
R1
73K
C2
22µF
1
2
LX
OC
NC
8
C3
22µF
C4
22µF
C5
100µF
R2
10K
7
FP6293
R3
27K
3
4
Note:
PGND
VCC
FB
EN
GND
6
5
Don’t pull the Vout back to the FP6293’s Vcc pin. When the system receives the
noise, it will lead to Vout ripple too high and over the absolute maximum rating of
the Vcc pin.
Rev. 0.71
11/13
FP6293
Package Outline
DFN-8L
Unit: mm
Symbols
Min. (mm)
Max. (mm)
A
0.700
0.800
A1
0.000
0.050
A3
b
0.20REF
0.25
0.35
D
3.000 BSC
E
3.000 BSC
e
0.650 BSC
K
0.200
Symbols
Min. (mm)
Max. (mm)
E2
1.600
1.800
D2
1.900
2.050
L
0.350
0.450
Exposed PAD Dimensions:
Note:
1. Package dimensions are in compliance with JEDEC outline: MO-229
2. Dimension b applied to metalized terminal and is measured between 0.15mm and 0.30mm from
the terminal tip. If the terminal has the optional radius on the other end of the terminal, the
dimension b should not be measured in that radius area.
Rev. 0.71
12/13
FP6293
SOP-8L(EP)
UNIT: mm
Symbols
Min. (mm)
Max. (mm)
A
1.346
1.752
A1
0.050
0.152
A2
1.498
D
4.800
4.978
E
3.810
3.987
H
5.791
6.197
L
0.406
1.270
θ°
0°
8°
Symbols
Min. (mm)
Max. (mm)
E1
2.184 REF
D1
2.971 REF
Note:
1. Package dimensions are in compliance with JEDEC outline: MS-012 AA.
2. Dimension ”D” does not include molding flash, protrusions or gate burrs.
3. Dimension “E” does not include inter-lead flash or protrusions.
Rev. 0.71
13/13
很抱歉,暂时无法提供与“FP6293XR-G1”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1.83600
- 10+1.70100
- 30+1.67400
- 100+1.59300
