DSF1A THRU DSF1J
SURFACE MOUNT SUPER FAST RECTIFIER
Reverse Voltage - 50 to 600 Volts
SOD-123FL
FEATURES
Glass passivated device
Ideal for surface mouted applications
Low reverse leakage
Metallurgically bonded construction
High temperature soldering guaranteed:
250 C/10 seconds,0.375”(9.5mm) lead length,
5 lbs. (2.3kg) tension
1.8± 0.1
1.0±0.2
Cathode Band
Top View
0.10-0.30
2.8±0.1
1.3± 0.15
Forward Current - 1.0 Ampere
0.6±0.25
MECHANICAL DATA
Case: JEDEC SOD-123FL molded plastic body over passivated chip
Terminals: Plated axial leads, solderable per MIL-STD-750,
Method 2026
Polarity: Color band denotes cathode end
Mounting Position: Any
Weight:0.0007 ounce, 0.02 grams
3.7±0.2
Dimensions in millimeters
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Ratings at 25 C ambient temperature unless otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
SYMBOLS
MDD Catalog Number
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward rectified current
Peak forward surge current
8.3ms single half sine-wave superimposed on
rated load (JEDEC Method)
Maximum instantaneous forward voltage at1.0A
Maximum DC reverse current
TA=25 C
at rated DC blocking voltage
TA=100 C
Maximum reverse recovery time (NOTE 1)
Typical junction capacitance (NOTE 2)
Typical thermal resistance (NOTE 3)
Operating junction and storage temperature range
VRRM
VRMS
VDC
DSF1A DSF1B DSF1C DSF1D
E1B
E1C
E1D
E1A
50
35
50
100
70
100
150
105
150
DSF1E
E1E
DSF1G
E1G
300
210
300
200
140
200
400
280
400
DSF1J
E1J
UNITS
600
420
600
VOLTS
VOLTS
VOLTS
I(AV)
1.0
Amp
IFSM
25.0
Amps
VF
1.25
0.95
1.7
Volts
IR
5.0
100.0
µA
trr
35
ns
CJ
10
RθJA
TJ,TSTG
85
-55 to +150
pF
K/W
C
Note: 1.Measured with IF=0.5A, IR=1A, Irr=0.25A.
2.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
3.PCB mounted on 0.2*0.2" (5.0*5.0mm) coppeer pad area.
2014-03 01版
http://www.microdiode.com
RATINGS AND CHARACTERISTIC CURVES DSF1A THRU DSF1J
1.0
0.8
0.6
Single Phase
Half Wave 60Hz
Resistive or
inductive Load
0.4
0.2
50
FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD
SURGE CURRENT
PEAK FORWARD SURGE CURRENT,
AMPERES
AVERAGE FORWARD RECTIFIED CURRENT,
AMPERES
FIG. 1- FORWARD CURRENT DERATING CURVE
75
100
125
150
30
8.3ms SINGLE HALF SINE-WAVE
(JEDEC Method)
25
10
5.0
1
10
TJ=25 C
PULSE WIDTH=300 µs
1%DUTY CYCLE
1
0.1
DSF1A-DSF1D
DSF1E-DSF1G
DSF1J
0.01
0.8
1.2
1.6
1.8
FIG. 4-TYPICAL REVERSE CHARACTERISTICS
INSTANTANEOUS REVERSE CURRENT,
MICROAMPERES
INSTANTANEOUS FORWARD
CURRENT,AMPERES
FIG. 3-TYPICAL INSTANTANEOUS FORWARD
CHARACTERISTICS
10
1,000
100
10
TJ=100 C
1
0.1
TJ=25 C
0.01
INSTANTANEOUS FORWARD VOLTAGE,
VOLTS
2014-03 01版
40
60
80
100
FIG. 6-TYPICAL TRANSIENT THERMAL IMPEDANCE
100
10
1
0.1
0.01
REVERSE VOLTAGE,VOLTS
PERCENT OF PEAK REVERSE VOLTAGE,%
TRANSIENT THERMAL IMPEDANCE,
C/W
JUNCTION CAPACITANCE, pF
FIG. 5-TYPICAL JUNCTION CAPACITANCE
100
NUMBER OF CYCLES AT 60 Hz
AMBIENT TEMPERATURE, C
0.1
1
10
100
t,PULSE DURATION,sec.
很抱歉,暂时无法提供与“DSF1J”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.05100
- 100+0.04760
- 300+0.04420
- 500+0.04080
- 2000+0.03910
- 5000+0.03808
