HER301 THRU HER308
HIGH EFFICIENCY RECTIFIERS
Forward Current - 3.0 Amperes
Reverse Voltage - 50 to 1000 Volts
FEATURES
DO-201AD
The plastic package carries Underwriters Laboratory
Flammability Classification 94V-0
High switching for high efficiency
Low reverse leakage
High forward surge current capability
High temperature soldering guaranteed:
250 C/10 seconds,0.375”(9.5mm) lead length,
5 lbs. (2.3kg) tension
1.0 (25.4)
MIN.
0.220(5.6)
0.197(5.0)
DIA.
0.375(9.5)
0.285(7.2)
MECHANICAL DATA
1.0 (25.4)
MIN.
Case: JEDEC DO-201AD molded plastic body
Terminals: Plated axial leads, solderable per MIL-STD-750,
Method 2026
Polarity: Color band denotes cathode end
Mounting Position: Any
Weight:0.04 ounce, 1.10 grams
0.052(1.3)
0.048(1.2)
DIA.
Dimensions in inches and (millimeters)
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Ratings at 25 C ambient temperature unless otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
MDD Catalog Number
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward rectified current
0.375”(9.5mm) lead length at TA=50 C
Peak forward surge current
8.3ms single half sine-wave superimposed on
rated load (JEDEC Method)
Maximum instantaneous forward voltage at 3.0A
Maximum DC reverse current
TA=25 C
at rated DC blocking voltage
TA=100 C
Maximum reverse recovery time
(NOTE 1)
Typical junction capacitance (NOTE 2)
Typical thermal resistance (NOTE 3)
Operating junction and storage temperature range
SYMBOLS HER
VRRM
VRMS
VDC
301
HER
302
50
35
50
100
70
100
HER
303
HER HER
304 305
200 300
140 210
200 300
I(AV)
HER
307
HER
308
UNITS
600
420
600
800
560
800
1000
700
1000
VOLTS
VOLTS
VOLTS
3.0
200.0
IFSM
VF
400
280
400
HER
306
1.3
1.0
Amps
150.0
Amps
1.70
Volts
5.0
150.0
IR
µA
trr
50
70
ns
CJ
70.0
50
pF
C/W
C
RθJA
TJ,TSTG
20.0
-65 to +150
Note:1.Reverse recovery condition IF=0.5A,IR=1.0A,Irr=0.25A
2.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
3.Thermal resistance from junction to ambient at 0.375”(9.5mm)lead length,P.C.B. mounted
FIG. 1- FORWARD CURRENT DERATING CURVE
3.0
2.4
1.8
Single Phase
Half Wave 60Hz
Resistive or
inductive Load
1.2
0.6
50
75
100
125
150
PEAK FORWARD SURGE CURRENT,
AMPERES
AVERAGE FORWARD RECTIFIED CURRENT,
AMPERES
RATINGS AND CHARACTERISTIC CURVES HER301 THRU HER308
FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD
SURGE CURRENT
200
8.3ms SINGLE HALF SINE-WAVE
(JEDEC Method)
160
120
HER301-HER305
80
HER306-HER308
40
175
10
AMBIENT TEMPERATURE, C
TJ=25 C
PULSE WIDTH=300 µs
1%DUTY CYCLE
10
1
0.1
HER301-HER303
HER304-HER305
HER306-HER308
0.01
0.2
0.6
1.0
1.4
1.8
2.0
FIG. 4-TYPICAL REVERSE CHARACTERISTICS
INSTANTANEOUS REVERSE CURRENT,
MICROAMPERES
INSTANTANEOUS FORWARD
CURRENT,AMPERES
FIG. 3-TYPICAL INSTANTANEOUS FORWARD
CHARACTERISTICS
100
TJ=100 C
10
1
TJ=25 C
0.1
0.01
INSTANTANEOUS FORWARD VOLTAGE,
VOLTS
60
80
200
TJ=25 C
HER301-HER305
HER306-HER308
TRANSIENT THERMAL IMPEDANCE,
C/W
400
FIG. 6-TYPICAL TRANSIENT THERMAL IMPEDANCE
100
10
1
0.1
0.01
0.1
1
10
2
0.1
1.0
10
REVERSE VOLTAGE,VOLTS
100
PERCENT OF PEAK REVERSE VOLTAGE,%
FIG. 5-TYPICAL JUNCTION CAPACITANCE
JUNCTION CAPACITANCE, pF
100
NUMBER OF CYCLES AT 60 Hz
100
t,PULSE DURATION,sec.
The cruve graph is for reference only, can't be the basis for judgment(曲线图仅供参考)!
100
很抱歉,暂时无法提供与“HER305”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.30000
- 100+0.28000
- 300+0.26000
- 500+0.24000
- 2000+0.23000
- 5000+0.22400
- 国内价格
- 10+0.31416
- 50+0.28968
- 200+0.26928
- 600+0.24888
- 1500+0.23256
- 3000+0.22236
