Radial Lead Metal Oxide Varistor (MOV)
07D Series
Description
The 07D series radial leaded varistors provides an ideal circuit
protection solution for lower DC voltage applications by
offering higher surge ratings than ever before available in such
small discs.
The maximum peak surge current rating can reach up to
1.75KA (8/20 μs pulse) to protect against high peak surges,
including
indirect
lightning
strike
interference,
system
switching transients and abnormal fast transients from the
power source.
Features
Applications
u
Wide operating voltage (V1mA) range from 18V to 820V
u
u
Fast responding to transient over-voltage
u
Large absorbing transient energy capability
u
Surge protection in consumer electronics
u
Low clamping ratio and no following-on current
u
Surge protection in industrial electronics
u
Meets MSL level 1, per J-STD-020
u
Surge protection in electronic home appliances, gas and
Transistor, diode, IC, thyristor or triac semiconductor
protection
petroleum appliances
u
Relay and electromagnetic valve surge absorption
General Characteristics
Material
No Radioactive Material
Operating Temperature
-40℃ ~ +85℃
Storage Temperature
-55℃ ~ +125℃
Body
Nickel Plated
Leads
Tin Plated
Devices with No lead
Nickel Plated
SOCAY Electronics Corp., Ltd.
Revision April 07, 2016
www.socay.com
1/4
@ SOCAY Electronics Corp., Ltd. 2016
Specifications are subject to change without notice.
Please refer to www.socay.com for current information.
07D Series
Specifications – General Characteristics (25±5℃)
Type Number
Maximum
Allowable
voltage
Varistor
Voltage
Maximum
Clamping
Voltage
Withstanding
Surge
Current
I(A)
Standard
Maximum
Energy
(10/1000μs)
I(A)
High Surge
Typical
Rated
Capacitance
Power
(Reference)
(J)
Standard
(J)
High
Surge
(W)
@1KHZ
(pf)
250
0.9
2.0
0.02
2800
500
250
1.1
2.4
0.02
2300
125
500
250
1.4
3.0
0.02
1800
250
125
500
250
1.7
3.5
0.02
1500
77
250
125
500
250
2.1
4.0
0.02
1300
2.5
93
250
125
500
250
2.5
5.0
0.02
1100
56(50~62)
2.5
110
250
125
500
250
3.1
6.0
0.02
900
56
68(61~75)
2.5
135
250
125
500
250
3.6
7.0
0.02
740
50
65
82(74~90)
10
135
1200
600
1750
1250
5.5
10.0
0.25
600
07D101K 07D101KJ
60
85
100(90~110)
10
165
1200
600
1750
1250
6.5
12.0
0.25
500
07D121K 07D121KJ
75
100
120(108~132)
10
200
1200
600
1750
1250
7.8
13.0
0.25
420
07D151K 07D151KJ
95
125
150(135~165)
10
250
1200
600
1750
1250
9.7
13.0
0.25
330
07D181K 07D181KJ
115
150
180(162~198)
10
300
1200
600
1750
1250
11.7
16.0
0.25
280
07D201K 07D201KJ
130
170
200(180~220)
10
340
1200
600
1750
1250
13.0
17.0
0.25
250
07D221K 07D221KJ
140
180
220(198~242)
10
360
1200
600
1750
1250
14.0
19.0
0.25
230
07D241K 07D241KJ
150
200
240(216~264)
10
395
1200
600
1750
1250
15.0
21.0
0.25
210
07D271K 07D271KJ
175
225
270(243~297)
10
455
1200
600
1750
1250
18.0
24.0
0.25
185
07D301K 07D301KJ
190
250
300(270~330)
10
500
1200
600
1750
1250
20.0
26.0
0.25
165
07D331K 07D331KJ
210
275
330(297~363)
10
550
1200
600
1750
1250
23.0
28.0
0.25
150
07D361K 07D361KJ
230
300
360(324~396)
10
595
1200
600
1750
1250
25.0
32.0
0.25
140
07D391K 07D391KJ
250
320
390(351~429)
10
650
1200
600
1750
1250
25.0
35.0
0.25
130
07D431K 07D431KJ
275
350
430(387~473
10
710
1200
600
1750
1250
28.0
40.0
0.25
115
07D471K 07D471KJ
300
385
470(423~517)
10
775
1200
600
1750
1250
30.0
42.0
0.25
105
07D511K
07D511KJ
320
415
510(459~561)
10
845
1200
600
1750
1250
30.0
45.0
0.25
100
07D561K 07D561KJ
350
460
560(504~616)
10
925
1200
600
1750
1250
30.0
49.0
0.25
90
07D621K 07D621KJ
385
505
620(558~682)
10
1025
1200
600
1750
1250
33.0
55.0
0.25
80
07D681K 07D681KJ
420
560
680(612~748)
10
1120
1200
600
1750
1250
33.0
60.0
0.25
75
07D751K 07D751KJ
460
615
750(675~825)
10
1240
1200
600
1750
1250
67.2
65.0
0.25
70
07D781K
07D781KJ
485
640
780(702~858)
10
1290
1200
600
1750
1250
67.2
65.0
0.25
70
07D821K
07D821KJ
510
670
820(738~902)
10
1355
1200
600
1750
1250
67.2
70.0
0.25
60
VAC
(V)
VDC
(V)
V1mA
(V)
IP
(A)
VC
(V)
07D180K 07D180KJ
11
14
18(15~21.6)
2.5
36
250
125
500
07D220K
07D220KJ
14
18
22(19.5~26)
2.5
43
250
125
07D270K 07D270KJ
17
22
27(24~30)
2.5
53
250
07D330K 07D330KJ
33(29.5~36.5)
2.5
66
07D390K 07D390KJ
25
31
39(35~43)
2.5
07D470K 07D470KJ
30
38
47(42~54)
07D560K 07D560KJ
35
45
07D680K 07D680KJ
40
07D820K 07D820KJ
Standard
High
Surge
1 Time 2 Times 1 Time 2 Times
Remark: Voltage>33V, K is ±10%
www.socay.com
2/4
07D Series
Electrical Rating
Item
Test Condition / Description
Maximum Allowable
Voltage
The recommended maximum sine wave voltage (RMS) or the maximum DC
voltage can be applied continuously.
Varistor Voltage
Requirement
The voltage between two terminals with the specified measuring current
1mA.DC applied is call Vb.
The maximum voltage between two terminals with the specification
standard impulse current.
Applied waveform: 8/20μs
I
1.0
0.9
Maximum Clamping
Voltage
To meet the
specified value
0.5
0.1
0.0
8μsec
20μsec
30% Max
T
Rated Wattage
The maximum average power that can be applied within the specified
ambient temperature.
Energy
The maximum energy within the varistor voltage change of ±10% when one
impulse of 10/1000μs. or 2 msec. is applied.
Withstanding Surge
Current
The maximum current within the varistor voltage change of ±10% with the
standard impulse current (8/20ȝsec.) applied one time
Vb at 20℃-Vb at 70℃
Varistor Voltage
Temp. Coefficient
Vb at 20℃
1
50
× 100(% /
0.05% / ℃ max
The change of Vb shall be measured after the impulse listed below is
applied 10,000 times continuously with the interval of ten seconds at room
temperature.
5D Series
7D Series
Surge Life
10D Series
14D Series
20D Series
180K to 680K
100A (8/20μs)
820K to 751K
400A (8/20μs)
180K to 680K
250A (8/20μs)
820K to 821K
1200A (8/20μs)
180K to 680K
500A (8/20μs)
820K to 112K
2500A (8/20μs)
180K to 680K
1000A (8/20μs)
820K to 182K
4500A (8/20μs)
180K to 680K
2000A (8/20μs)
820K to 182K
6500A (8/20μs)
△Vb / Vb ≤ ±10%
www.socay.com
3/4
07D Series
Part Numbering
Part Marking
07 D XXX K J
J: High Surge, without: Standard
Logo
Tolerance:
K: ±10%,
L:
±15%,
M:
Product Type
±20%
UL Accreditation Logo
VDE Accreditation Logo
Varistor Voltage
Type:
D: Disk, S: Square
Element Diameter
Packaging Information
Part Number
Quantity
Packaging Option
Packaging Specification
07DXXXXX
1000
Plastic bag
Bulk Pack
Package Dimensions
Unit: mm
TABLE1
TABLE2
Symbol
Dimensions
Model
T(max.)
Model
T(max.)
H(max.)
12.0
180K
4.50
241K
4.60
H1(max.)
12.0
220K
4.60
271K
4.90
L(min.)
15.0
270K
4.70
301K
5.00
L1(min.)
15.0
330K
4.90
331K
5.10
D(max.)
9.0
390K
4.80
361K
5.20
P(±0.8)
5.0
470K
4.90
391K
5.40
T(max.)
TABLE2
560K
5.00
431K
5.70
d(±0.05)
0.6
680K
5.20
471K
6.00
d1(±0.05)
0.6
820K
4.10
511K
6.20
101K
4.30
561K
6.50
121K
4.50
621K
7.10
151K
4.80
681K
7.30
181K
4.30
751K
7.06
201K
4.40
781K
7.24
221K
4.50
821K
7.28
www.socay.com
4/4
很抱歉,暂时无法提供与“07D431K”相匹配的价格&库存,您可以联系我们找货
