Radial Lead Metal Oxide Varistor (MOV)
10D Series
Description
The 10D series radial leaded varistors provides an ideal circuit
protection solution for lower DC voltage applications by
offering higher surge ratings than ever before available in such
small discs.
The maximum peak surge current rating can reach up to
3.5KA (8/20 μs pulse) to protect against high peak surges,
including
indirect
lightning
strike
interference,
system
switching transients and abnormal fast transients from the
power source.
Features
Applications
u
Wide operating voltage (V1mA) range from 18V to 1100V
u
u
Fast responding to transient over-voltage
u
Large absorbing transient energy capability
u
Surge protection in consumer electronics
u
Low clamping ratio and no following-on current
u
Surge protection in industrial electronics
u
Meets MSL level 1, per J-STD-020
u
Surge protection in electronic home appliances, gas and
Transistor, diode, IC, thyristor or triac semiconductor
protection
petroleum appliances
u
Relay and electromagnetic valve surge absorption
General Characteristics
Material
No Radioactive Material
Operating Temperature
-40℃ ~ +85℃
Storage Temperature
-55℃ ~ +125℃
Body
Nickel Plated
Leads
Tin Plated
Devices with No lead
Nickel Plated
SOCAY Electronics Corp., Ltd.
Revision April 07, 2016
www.socay.com
1/4
@ SOCAY Electronics Corp., Ltd. 2016
Specifications are subject to change without notice.
Please refer to www.socay.com for current information.
10D Series
Specifications – General Characteristics (25±5℃)
Type Number
Standard
High
Surge
10D180K 10D180KJ
Maximum
Allowable
voltage
Varistor
Voltage
Maximum
Clamping
Voltage
Withstanding
Surge
Current
Maximum
Energy
(10/1000μs)
Typical
Rated
Capacitance
Power
(Reference)
VAC
(V)
VDC
(V)
V1mA
(V)
IP
(A)
VC
(V)
I(A)
I(A)
(J)
Standard
High Surge
(J)
High
Standard
1
2
1
2
Surge
Time Times Time Times
(W)
@1KHZ
(pf)
11
14
18(15~21.6)
5
36
500
0.05
5600
250
2000
1000
2.1
3.0
10D220K 10D220KJ
14
18
22(19.5~26)
5
43
500
250
2000
1000
2.5
5.0
0.05
4500
10D270K 10D270KJ
17
22
27(24~30)
5
53
500
250
2000
1000
3.0
6.0
0.05
3700
10D330K 10D330KJ
33(29.5~36.5)
5
66
500
250
2000
1000
4.0
7.0
0.05
3000
10D390K 10D390KJ
25
31
39(35~43)
5
77
500
250
2000
1000
4.6
9.0
0.05
2400
10D470K 10D470KJ
30
38
47(42~54)
5
93
500
250
2000
1000
5.5
11.0
0.05
2100
10D560K 10D560KJ
35
45
56(50~62)
5
100
500
250
2000
1000
7.0
13.0
0.05
1800
10D680K 10D680KJ
40
56
68(61~75)
5
135
500
250
2000
1000
8.2
15.0
0.05
1500
10D820K 10D820KJ
50
65
82(74~90)
25
135
2500
1250
3500
2500
12.0
17.0
0.4
1200
10D101K 10D101KJ
60
85
100(90~110)
25
165
2500
1250
3500
2500
15.0
18.0
0.4
1000
10D121K 10D121KJ
75
100
120(108~132)
25
200
2500
1250
3500
2500
18.0
21.0
0.4
830
10D151K 10D151KJ
95
125
150(135~165)
25
250
2500
1250
3500
2500
22.0
25.0
0.4
670
10D181K 10D181KJ
115
150
180(162~198)
25
300
2500
1250
3500
2500
27.0
30.0
0.4
560
10D201K 10D201KJ
130
170
200(180~220)
25
340
2500
1250
3500
2500
30.0
35.0
0.4
500
10D221K 10D221KJ
140
180
220(198~242)
25
360
2500
1250
3500
2500
32.0
39.0
0.4
450
10D241K 10D241KJ
150
200
240(216~264)
25
395
2500
1250
3500
2500
35.0
42.0
0.4
420
10D271K 10D271KJ
175
225
270(243~297)
25
455
2500
1250
3500
2500
40.0
49.0
0.4
370
10D301K 10D301KJ
190
250
300(270~330)
25
500
2500
1250
3500
2500
40.0
54.0
0.4
330
10D331K 10D331KJ
210
275
330(297~363)
25
550
2500
1250
3500
2500
40.0
58.0
0.4
300
10D361K 10D361KJ
230
300
360(324~396)
25
595
2500
1250
3500
2500
43.0
65.0
0.4
280
10D391K 10D391KJ
250
320
390(351~429)
25
650
2500
1250
3500
2500
47.0
70.0
0.4
260
10D431K 10D431KJ
275
350
430(387~473
25
710
2500
1250
3500
2500
60.0
80.0
0.4
230
10D471K 10D471KJ
300
385
470(423~517)
25
775
2500
1250
3500
2500
65.0
85.0
0.4
210
10D511K 10D511KJ
320
415
510(459~561)
25
845
2500
1250
3500
2500
70.0
90.0
0.4
200
10D561K 10D561KJ
350
460
560(504~616)
25
925
2500
1250
3500
2500
70.0
92.0
0.4
180
10D621K 10D621KJ
385
505
620(558~682)
25
1025
2500
1250
3500
2500
70.0
95.0
0.4
160
10D681K 10D681KJ
420
560
680(612~748)
25
1120
2500
1250
3500
2500
70.0
98.0
0.4
150
10D751K 10D751KJ
460
615
750(675~825)
25
1240
2500
1250
3500
2500
70.0
100.0
0.4
130
10D781K 10D781KJ
485
640
780(702~858)
25
1290
2500
1250
3500
2500
80.0
105.0
0.4
130
10D821K 10D821KJ
510
670
820(738~902)
25
1355
2500
1250
3500
2500
85.0
110.0
0.4
120
10D911K 10D911KJ
550
745
910(819~1001)
25
1500
2500
1250
3500
2500
93.0
130.0
0.4
110
10D102K 10D102KJ
625
825
1000(900~1100)
25
1650
2500
1250
3500
2500
102.0
140.0
0.4
100
10D112K 10D112KJ
680
895
1100(990~1210)
25
1814
2500
1250
3500
2500
115.0
155.0
0.4
90
www.socay.com
2/4
10D Series
Electrical Rating
Item
Test Condition / Description
Maximum
Allowable Voltage
The recommended maximum sine wave voltage (RMS) or the maximum DC
voltage can be applied continuously.
Varistor Voltage
Requirement
The voltage between two terminals with the specified measuring current
1mA.DC applied is call Vb.
The maximum voltage between two terminals with the specification
standard impulse current.
Applied waveform: 8/20μs
I
1.0
0.9
Maximum
Clamping Voltage
To meet the
specified value
0.5
0.1
0.0
8μsec
20μsec
30% Max
T
Rated Wattage
The maximum average power that can be applied within the specified
ambient temperature.
Energy
The maximum energy within the varistor voltage change of ±10% when one
impulse of 10/1000μs. or 2 msec. is applied.
Withstanding
Surge Current
The maximum current within the varistor voltage change of ±10% with the
standard impulse current (8/20ȝsec.) applied one time
Vb at 20℃-Vb at 70℃
Varistor Voltage
Temp. Coefficient
Vb at 20℃
1
50
× 100(% /
0.05% / ℃ max
The change of Vb shall be measured after the impulse listed below is
applied 10,000 times continuously with the interval of ten seconds at room
temperature.
5D Series
7D Series
Surge Life
10D Series
14D Series
20D Series
180K to 680K
100A (8/20μs)
820K to 751K
400A (8/20μs)
180K to 680K
250A (8/20μs)
820K to 821K
1200A (8/20μs)
180K to 680K
500A (8/20μs)
820K to 112K
2500A (8/20μs)
180K to 680K
1000A (8/20μs)
820K to 182K
4500A (8/20μs)
180K to 680K
2000A (8/20μs)
820K to 182K
6500A (8/20μs)
△Vb / Vb ≤ ±10%
www.socay.com
3/4
10D Series
Part Marking
Part Numbering
10 D XXX K J
J: High Surge, without: Standard
Logo
Tolerance:
K: ±10%,
L:
±15%,
M:
Product Type
±20%
VDE Accreditation Logo
UL Accreditation Logo
Varistor Voltage
Type:
D: Disk, S: Square
Element Diameter
Packaging Information
Part Number
Quantity
Packaging Option
Packaging Specification
10DXXXXX
500
Plastic bag
Bulk Pack
Package Dimensions
Unit: mm
TABLE1
TABLE2
Symbol
Dimensions
Model
T(max.)
Model
T(max.)
H(max.)
H1(max.)
L(min.)
L1(min.)
D(max.)
P(±0.8)
T(max.)
d(±0.05)
d1(±0.05)
16.0
16.0
15.0
15.0
13.0
7.5
TABLE2
0.8
0.8
180K
220K
270K
330K
390K
470K
560K
680K
820K
101K
121K
151K
181K
201K
221K
241K
271K
4.6
4.7
4.8
5.0
5.3
5.4
5.5
5.6
4.7
4.9
5.1
5.4
4.8
5.0
5.1
5.2
5.4
301K
331K
361K
391K
431K
471K
511K
561K
621K
681K
751K
781K
821K
911K
102K
112K
5.5
5.8
6.0
6.2
6.5
6.7
6.8
7.0
7.3
7.6
8.0
8.1
8.3
8.8
9.3
9.9
www.socay.com
4/4
很抱歉,暂时无法提供与“10D391K”相匹配的价格&库存,您可以联系我们找货
